Home » Archived » Visual Editor (VE) » overriding property handling globally
overriding property handling globally [message #126264] Thu, 15 June 2006 15:06 Go to next message
Is it possible to override property editing for all widgets?
What I want is to supply special handling for the "model" property of
all widgets. If I don't have any special handling available for the
particular widget, I want to delegate to the default handling.
Re: overriding property handling globally [message #126278 is a reply to message #126264] Thu, 15 June 2006 16:38 Go to previous messageGo to next message
Originally posted by: jefmyers.us.ibm.com
Ernest,
If your widgets have a common base class with the model property, you
should be able to specify the property editor in an override on that
class, then override the override on subclasses when necessary.
Hope this helps,
- Jeff
Re: overriding property handling globally [message #126326 is a reply to message #126278] Fri, 16 June 2006 09:17 Go to previous message
Jeff,
What I really want to do is to allow my users to assign the model
property of arbitrary widgets (if I have a connection that can be made).
So if they've dropped a JList, I want to discover that and allow them
to select from any data sources that I know about that are adaptable to
a ListModel. However, if the argument to setModel is not relevant to
me, then I would just let the default property editing take place.
What I have kind of working at the moment is a context menu item that
gets added to widgets. When the user invokes the context menu for a
JList object, I decide what sort of hookup (if any) is available.
I'm just trying to see if it's possible to get that same behavior in the
property sheet.
-Ernest
Jeff Myers wrote:
> Ernest,
> Hope this helps,
> - Jeff
Re: overriding property handling globally [message #613353 is a reply to message #126264] Thu, 15 June 2006 16:38 Go to previous message
Ernest,
Hope this helps,
- Jeff
Re: overriding property handling globally [message #613357 is a reply to message #126278] Fri, 16 June 2006 09:17 Go to previous message
Jeff,
property sheet.
-Ernest
Jeff Myers wrote:
> Ernest,
> Hope this helps,
> - Jeff
Previous Topic:overriding property handling globally
Next Topic:In which state is creating of new tutorials for VE
Current Time: Sun Jul 27 06:04:57 EDT 2025
Powered by FUDForum. Page generated in 0.03787 seconds
