Home » Eclipse Projects » Buckminster dev » Re: [buckminster-dev] Has something changed on buckminster update site?
Re: [buckminster-dev] Has something changed on buckminster update site? [message #11557] Fri, 21 March 2008 06:21
Hi Adrian,
yes, something has changed. Eclipse 3.3.2 was released and Buckminster
headless-site.xml was updated to reflect this. Obviously I've made a
mistake somewhere. It should have redirected the requests for the file
in question to the Eclipse standard update site. I'll check...
Thanks for reporting this,
- thomas
Adrian Skehill wrote:
> Just getting the following error now when trying to install the core
> feature into a headless buckminster:
> Caused by: [0]org.eclipse.update.internal.core.FatalIOException: Ser
> ver returned HTTP response code: "404 Not Found" for URL: http://download.eclips
> e.org/tools/buckminster/updates/plugins/com.ibm.icu.base_3.8 .1.v20080103.jar.
> [java] at
> org.eclipse.update.internal.core.UpdateManagerUtils.checkCon nection
> I copied over the jar from an existing eclipse install and all is well for now.
> Adrian.
> _______________________________________________
> buckminster-dev mailing list
> buckminster-dev@eclipse.org
> https://dev.eclipse.org/mailman/listinfo/buckminster-dev
Previous Topic:[buckminster-dev] Has something changed on buckminster update site?
Next Topic:[buckminster-dev] CSPEC Resolution and other issues
Current Time: Tue Jul 22 13:54:49 EDT 2025
Powered by FUDForum. Page generated in 0.04401 seconds
