Re: Help with upgrade [message #934992 is a reply to message #934957] |
Sat, 06 October 2012 14:50 |
Ed Merks Messages: 33145 Registered: July 2009 |
Doug,
It doesn't make much sense. It's like
com.genasys.codecontrol.codemap_1.0.0.jar isn't there at all. If you
look in the Help's installation details, you can see the bundle there?
On 06/10/2012 3:59 PM, Doug Orr wrote:
> Ed,
> Thanks. I tried putting my plugins into the dropins folder but none of
> them installed when I started Eclipse. I moved them back into the
> plugins folder, erased the .log, added -clean -debug to my start-up
> command line.
> The .log is below. In ithe log I notice that two plugins
> (mmaogenerator and codmap.edit) are unresolved because they cannot
> find the codemap plugin. I also notice that mmaogenerator is looking
> for codemap vesion _1.0.0 but codemap.edit is looking for version
> _0.0.0. - The codemap plugin.xml defines verion 1.0.0. - The
> mmaogenerator plugin.xml has a dependency on codemap
> bundle-version="1.0.0"
> - The codemap.edit plugin.xml has a dependency on codemap but does not
> specify a version.
> I don't think any of this explains why the
> com.genasys.codecontrol.codemap_1.0.0.jar is ignored.
> Should I add this post to the plugin developer forum?
> !SESSION 2012-10-06 09:39:46.889
> eclipse.buildId=M20090917-0800
> java.version=1.7.0_07
> java.vendor=Oracle Corporation
> BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_CA
> Framework arguments: -product
> org.eclipse.epp.package.modeling.product -Xmx1024M -XX:MaxPermSize=512M
> Command-line arguments: -os win32 -ws win32 -arch x86 -product
> org.eclipse.epp.package.modeling.product -clean -debug -Xmx1024M
> !ENTRY org.eclipse.equinox.registry 2 0 2012-10-06 09:39:50.945
> !MESSAGE The extensions and extension-points from the bundle
> "org.eclipse.gmf.runtime.common.ui.printing.win32" are ignored. The
> host bundle "org.eclipse.gmf.runtime.common.ui.printing" is not marked
> as singleton.
> !ENTRY org.eclipse.osgi 2 0 2012-10-06 09:39:54.377
> !MESSAGE One or more bundles are not resolved because the following
> root constraints are not resolved:
> !SUBENTRY 1 org.eclipse.osgi 2 0 2012-10-06 09:39:54.377
> !MESSAGE Bundle
> reference:file:plugins/com.genasys.mmaogenerator_1.0.0.201209201724.jar was
> not resolved.
> !SUBENTRY 2 com.genasys.mmaogenerator 2 0 2012-10-06 09:39:54.377
> !MESSAGE Missing required bundle com.genasys.codecontrol.codemap_1.0.0.
> !MESSAGE Bundle
> reference:file:plugins/com.genasys.codecontrol.codemap.edit_1.0.0.jar
> was not resolved.
> !SUBENTRY 2 com.genasys.codecontrol.codemap.edit 2 0 2012-10-06
> 09:39:54.377
> !MESSAGE Missing required bundle com.genasys.codecontrol.codemap_0.0.0.
> !MESSAGE The following is a complete list of bundles which are not
> resolved, see the prior log entry for the root cause if it exists:
> !MESSAGE Bundle com.genasys.codecontrol.codemap.edit_1.0.0 [13] was
> not resolved.
> 09:39:54.377
> !MESSAGE Bundle com.genasys.codecontrol.codemap.editor_1.0.0 [14] was
> not resolved.
> !SUBENTRY 2 com.genasys.codecontrol.codemap.editor 2 0 2012-10-06
> 09:39:54.377
> com.genasys.codecontrol.codemap.edit_0.0.0.
> !MESSAGE Bundle com.genasys.mmaogenerator_1.0.0.201209201724 [24] was
> not resolved.
> Thanks for your help,
> Doug
Ed Merks
Re: Help with upgrade [message #935905 is a reply to message #935044] |
Sun, 07 October 2012 12:53 |
Doug,
Note that it also doesn't list com.genasys.codecontrol.codemap as being
in the file system near line 3384
Bundles in the system:
Id: com.genasys.codecontrol.attachments.editor, Version: 1.0.0,
reference:file:plugins/com.genasys.codecontrol.attachments.editor_1.0.0.jar
Id: com.genasys.codecontrol.codemap.edit, Version: 1.0.0, Location:
On 06/10/2012 6:07 PM, Doug Orr wrote:
> I have attached a copy of my configuration details. On line 297 you can see that codemap.edit is installed (but not started) in the plugin details. Codemap is not there. However, at line 1768 you can see that codemap is one of the Installable Units in the profile.
> I don't know why this single plugin would be ignored when I have a dozen similar plugins that all install reliably.
> Again, thanks for loking at this,
> Doug
Ed Merks
FUDForum. Page generated in 0.04700 seconds
