When will gmf2.0 be released [message #11504] |
Wed, 09 August 2006 01:28  |
Originally posted by: dzhpingbo.sohu.com
In my example, I would expect a model navigator tree view where I could add,
delete, move, etc the model elements,
or select one and edit its properties in the Properties view. Also would
expect to drag/drop a model element onto a diagram.
I see the
Re: When will gmf2.0 be released [message #11901 is a reply to message #11504] |
Wed, 09 August 2006 08:59   |
GMF 2.0 will be released with Europa at the end of next June. It is likely
this feature will be added sooner, though... Have you cast a vote for this
bug?
Best,
Rich
On 8/9/06 1:28 AM, in article ebbrpg$p4e$1@utils.eclipse.org, "dzh"
> I see the ¡°common model navigator" view will be implemented in gmf2.0 from
> https://bugs.eclipse.org/bugs/show_bug.cgi?id=112818)
> but what is the shedule of gmf2.0, when will it be published?
> If I have to wait for a long time, I have to develop it myself. Now I had
> developed a tree that can listen to all the changes in worspace and
> Editdomain, but far away to fulfill my demands....
Re: When will gmf2.0 be released [message #19982 is a reply to message #11504] |
Wed, 16 August 2006 02:57  |
I'm also developing such a model view. I reused parts of the EMF outline
view.
How do you listen for changes in the GMF model?
I already tried to register with the various command stacks but without
succeess ...
Martin.
FUDForum. Page generated in 0.25337 seconds
