Home » Newcomers » Newcomers » SSH and CVS
SSH and CVS [message #11494] Fri, 21 January 2005 14:23
Originally posted by: vorlonemail-eclipse.yahoo.com
I try to use the sshext method in combination with cvs. Eclipse 3.1M4
(Windows XP) doesn't seem to use my key. The 2048 bit RSA key is
encrypted and I am never asked for the password to the key. Instead I am
being asked for the password to the cvs server.
It was working immediately after I upgraded to Eclipse 3.1M4 (from 3.0).
Then I switched to the ext method using putty, which worked but was too
slow for me. Now I wanted to switch back to extssh and it doesn't work
anymore. Nothing is shown in the error log. Eclipse behaves the same on
two different computers. A direct SSH connection using putty and the
same key in putty format can be established, so it doesn't seem to be a
problem on the server side or with the key.
Does anybody know what I can do to get this working? Is there a way to
get extssh log output?
Thanks in advance,
-Michael
Previous Topic:Unable to create Java project
Next Topic:I can't run eclipse
Current Time: Fri May 09 18:07:22 EDT 2025
Powered by FUDForum. Page generated in 0.09768 seconds
