Home » Eclipse Projects » Eclipse Platform » Rich Client Platform (RCP) timeframe?
Rich Client Platform (RCP) timeframe? [message #125348] Tue, 09 September 2003 09:56 Go to next message
Originally posted by: joerg.von.frantzius.artnology.nospam.com
Hi all,
does anybody know about planning on a timeframe for RCP? Will it be
included with Eclipse 3.0 final?
Thanks for any hints,
Jörg.
Re: Rich Client Platform (RCP) timeframe? [message #125523 is a reply to message #125348] Tue, 09 September 2003 10:55 Go to previous messageGo to next message
Originally posted by: simon.ibm.oti.lab
The work is progressing. We would really like to have something ready for
M4. We still need to get approval from the PMC to release these changes into
the HEAD stream and eventually to be part of 3.0 (we are breaking APIs so
approval is required)
Simon :-)
"Joerg von Frantzius" <joerg.von.frantzius@artnology.nospam.com> wrote in
message news:bjkm3t$ge$1@eclipse.org...
> Hi all,
> J
Re: Rich Client Platform (RCP) timeframe? [message #125741 is a reply to message #125348] Tue, 09 September 2003 12:07 Go to previous messageGo to next message
Just out of curiosity...
What are you planning to do with the RCP?
Chris Laffra
> Hi all,
> J
Re: Rich Client Platform (RCP) timeframe? [message #125831 is a reply to message #125741] Tue, 09 September 2003 12:41 Go to previous messageGo to next message
--------------020704010404050408080705
I'm not too sure whether I'll need RCP or not, as the whole thing is in
a very early stage, to say the least. Just checking out whether it's
going to be an option or not...
>Chris Laffra
>>Hi all,
>>J
Re: Rich Client Platform (RCP) timeframe? [message #126257 is a reply to message #125523] Wed, 10 September 2003 01:36 Go to previous messageGo to next message
What is this RCP about? I thought Equinox project was a sub-project to make
Eclipse a headless UI/plugin application shell. I have seen almost nothing
in Equinox in the past few months, so is it still going on? Is it now RCP?
Or what?
"Simon Arsenault" <simon@ibm.oti.lab> wrote in message
news:bjkpi6$4gv$1@eclipse.org...
into
> Simon :-)
> > Hi all,
> > J
Re: Rich Client Platform (RCP) timeframe? [message #126504 is a reply to message #126257] Wed, 10 September 2003 10:36 Go to previous messageGo to next message
Look at the 3.0 plan and bug report 40682 for more information about the
RCP. You can also look at the proposal documents on the ui team web page
( http://dev.eclipse.org/viewcvs/index.cgi/%7Echeckout%7E/plat form-ui-home/do
cs.html).
In short, the RCP plan item it to split the org.eclipse.ui plugin into
several plugins (some of this was done for 2.1). There will be a "generic"
workbench plugin that can be used by clients wanting to build applications
that are not IDEs. There will be another plugin using this generic workbench
to build the IDE of eclipse.
This RCP work definitely complements the Equinox work, it does not replace
it. The equinox project is dealing more with dynamic plug-ins, alternate
runtimes, services, security, etc The RCP work is to remove the IDE
specific pieces from the workbench, so the workbench is more useful to other
applications.
Simon :-)
"Kevin" <supreme_java_guru_1@yahoo.com> wrote in message
news:bjmcvc$nao$1@eclipse.org...
make
> Or what?
for
> into
so
> > Simon :-)
in
> > > Hi all,
> > > J
Re: Rich Client Platform (RCP) timeframe? [message #128704 is a reply to message #125741] Sat, 13 September 2003 00:51 Go to previous messageGo to next message
Just to add to the discussion, we have been waiting eagerly for 3.0
and the RCP. We are currently developing rich GUI application plugin
in anticipation (of course, it still works without the RCP, but we have
to hack the eclipse code to get rid off things we don't need).
We are currently heavily testing 3.0 and reporting bugs. And change
our apps according to API change.
We are developing an enterprise information security platform, with
rich GUI front-end application. One area of application is HIPAA-compliant
system in hospitals. We provide role-based access control to the
information,
and security (including encryption and digital signature) is critical.
Data are in XML format, and rendered on the fly in the eclipse desktop.
So we use heavily SWT, GEF, EMF.
Things we found are missing, which could have helped a lot:
- easy way to remove IDE-related components
- browser component : eclipse should have provided a browser
api and package the moz gecko engine (as a plugin) long time ago
- not enough of useful SWT widget, and the programming model is weird.
Widgets in Swing are nicer (sure, some of Swing components are pure
horror), such JTable. The SWT counterpart does not play nice with model
(as in MVC)
- Some of the UI components are considered internal use only, wonder
why, such the form components in update.ui.forms, and the scrollable
section used in PDE manifest editor. Ok, the scrollable section form
is horribly slow, but it's kinda nice for some app, and you can't trust to
call them as they are "internal" and might change without any reason.
- GEF widgets are sometimes weird too, and not enough. We end up
having to write a lot of these stuffs ourselves (as for SWT too).
- And did I mention documentation? Please, more documentation,
especially on the API. A lot of those APIs are not documented, just
the methods and parameters name, and we are expected to guess what
they do and how they work. We end up reading the code of all the
components we use to understand how to use them. And there are
components that probably could have helped us a lot, and we probably
didn't even know, coz they are documented, and sometimes, we just skipped.
- ability to unload plugins that are not used anymore, which is the
work of equinox, but the development of equinox seems to be "really"
slow compared to other eclipse projects. We currently don't have the
resources to look at this area yet, but we would like to get some hack
going to reduce resource consumption by eclipse.
Sorry for the long rant. Eclipse is good stuff :)
Re: Rich Client Platform (RCP) timeframe? [message #129282 is a reply to message #128704] Mon, 15 September 2003 10:02 Go to previous message
Could you add your comments to bug report #36967
(https://bugs.eclipse.org/bugs/show_bug.cgi?id=36967) so we do not lose
track of them
Simon :-)
"kk" <kk@dev.null> wrote in message news:bju7lr$7lo$1@eclipse.org...
> information,
> (as in MVC)
Previous Topic:ColorerEditor
Next Topic:Compiling a project deletes everything on the directory specified.
Current Time: Sun Jul 27 06:34:50 EDT 2025
Powered by FUDForum. Page generated in 0.04536 seconds
