Home » Language IDEs » ServerTools (WTP) » Using XML Editor in my plugin - is there some clean way ?
Using XML Editor in my plugin - is there some clean way ? [message #125344] Sun, 24 July 2005 19:49 Go to next message
hi !
Im trying to find a way to use web tools xml source editor in my
plugin... I searched this forum and docs but I didn't find what I need
or I overlooked it :)
It's quite simple: Im working on my plugin suite that is used for some
special tasks regarding editing of our format of deploy files... Our
plugin implements visual editing and generating source for lazy users
who dont want edit source directly... BUT: under this layer these
deploy files are simply xml files and there is need to have the
possibility to edit them directly in "source mode"...
Till now we used XMLEditor class from solareclipse suite but
solareclipse seems dead and there are bugs when used in eclipse 3.x so
Im trying to replace it by xml editor from webtools - webtools seems
like great and rapidly improving tools package being developed as part
of eclipse project. I dont wanna extend it by adding features, I only
want to use it as one page in our multi-page editor...
I succesfully used XMLMultiPageEditorPart, now Im able to edit our xml
files but I have some questions:
1. is there some clean way ? Now Im using directly mentioned class from
internal package, but my experience tells me that it's not best idea -
some time ago I was migrating our plugins to compile it under Eclipse
3.0 and 3.1 and this was real nightmare - developers who originally
implemented our plugin used classes from internal packages wildly and
you can imagine what refactoring of such code was - internal
implementation is not documented and the code was also completely
undocumented :))
2. is there way to enable syntax highlighting in my code for our files
? These files have not *.xml extension and I cant add these extensions
to XML Content Type in eclipse preferences because I need these
extensions associated with our plugin. I was not diging much in source
code but I found some methods in StructuredTextEditor connected with
StructuredTextViewerConfiguration class - is this the place for some
info ?
Thanks for any answer and sorry for long boring post :)
Re: Using XML Editor in my plugin - is there some clean way ? [message #125360 is a reply to message #125344] Sun, 24 July 2005 20:03 Go to previous messageGo to next message
one more problem connected with mentioned syntax highlighting error -
design page of xml editor multipage view is empty in case of files with
other than *.xml extension... So the problem probably is that I need tell
the editor that proper structured file type is loaded... or am I wrong ?
Re: Using XML Editor in my plugin - is there some clean way ? [message #125396 is a reply to message #125344] Mon, 25 July 2005 04:53 Go to previous messageGo to next message
Pavel Trka wrote:
> hi !
> undocumented :))
The not so really clean way I used was to use
org.eclipse.wst.xml.ui.internal.provisional.StructuredTextEd itorXML
in one of my tabs of my editor. If you want the XML outline to work,
then you need to implement getAdapter and feed that into the
StructuredTextEditorXML.
> info ?
You want to declare a content type that derives from XML one. That
worked like charm for me. See my snippet below for hooking up the
content type and the schema for my content type and namespace.
Axel
PS: plugin.xml snippet:
<extension
point="org.eclipse.core.runtime.contentTypes">
<content-type
file-extensions="xul"
priority="high"
name="Mozilla XUL Content Type"
id="xul"
base-type="org.eclipse.core.runtime.xml"
default-charset="UTF-8" />
</extension>
<extension
point="org.eclipse.wst.xml.core.catalogContributor">
<catalogContributor catalogId="solid">
<mappingInfo
key=" http://www.mozilla.org/keymaster/gatekeeper/there.is.only.xu l"
uri="src/schemas/SimpleXUL.xsd" />
</catalogContributor>
</extension>
Re: Using XML Editor in my plugin - is there some clean way ? [message #126235 is a reply to message #125396] Wed, 27 July 2005 03:50 Go to previous messageGo to next message
please can you provide me with some details about getAdapter
implementation in my class ? :)
Thanks, now it works ;) But with one small problem - syntax highlighting
is not active immediately after opening source page, it's active after I
start to edit the source... But this is maybee problem of our
implementation... When I use XMLMultiPageEditorPart, it's ok but in this
case there is another problem - this class has not getDocumentProvider()
method implemented and it's needed on some places in our plugin...
Can I ask what i the difference or relationship between
XMLMultiPageEditorPart and StructuredTextEditorXML ?
Re: Using XML Editor in my plugin - is there some clean way ? [message #126746 is a reply to message #126235] Thu, 28 July 2005 06:19 Go to previous messageGo to next message
It looks like this in my class:
* Get Adaptable from ourselves, or from the XML source editor page
public Object getAdapter(Class adapter) {
Object retObject = null;
if (editor != null) {
retObject = editor.getAdapter(adapter);
if (retObject != null)
return retObject;
return super.getAdapter(adapter);
You can ask, but I can't answer. I'm just forwarding the little things I
learnt recently, understanding the code is not yet part of my game.
Axel
Re: Using XML Editor in my plugin - is there some clean way ? [message #126879 is a reply to message #126746] Thu, 28 July 2005 09:22 Go to previous messageGo to next message
ok thanks for your answers ! It's obvious I have to learn some more things
about eclipse editor architecture ;)
> Axel
Re: Using XML Editor in my plugin - is there some clean way ? [message #127011 is a reply to message #126746] Thu, 28 July 2005 13:51 Go to previous messageGo to next message
Originally posted by: amywu.us.DELETETHISPART.ibm.com
When you need to call getDocumentProvider, what you can do is call
getAdapter(ITextEditor.class) and that should return an ITextEditor back to
you. There is a getDocumentProvider() method on that interface.
StructuredTextEditorXML is the XML Source Page editor. It is just 1 single
page editor. The XMLMultiPageEditor contains a design and source page. The
source page it contains is StructuredTextEditorXML.
Hope this helps.
"Axel Hecht" <axel@pike.org> wrote in message
news:dcabfb$eet$1@news.eclipse.org...
page
> return retObject;
> Axel
Re: Using XML Editor in my plugin - is there some clean way ? [message #127407 is a reply to message #127011] Fri, 29 July 2005 10:55 Go to previous message
hi,
thanks I'll try it when there will be some free time...
Im dumb :) This was of course the first thing that I was thinking about,
names of classes are pretty self-explanatory... Then I tried it (replacing
XMLMultiPageEditorPart by StructuredTextEditorXML), but (hell knows why) I
was surprised because I had still design page when I opened my deploy file
so I was confused and asking here... Now I tried it again and of course
there is source page only :) I dont know what I was doing before, maybee
I didnt compile or run it right, hell knows :) Thanks anyway
> Hope this helps.
sure, any answers are welcome...
Previous Topic:Validator JSP Error
Next Topic:RC5 Source Format issue
Current Time: Tue Jul 22 02:32:34 EDT 2025
Powered by FUDForum. Page generated in 0.52496 seconds
