Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Teneo] Switch to DB2 and not getting identity columns
[Teneo] Switch to DB2 and not getting identity columns [message #124960] |
Mon, 02 June 2008 12:18  |
I was successfully generating a schema on MySQL and getting the auto
increment on the id primary key column. I switched to DB2 dialect and if
I leave the primary key as e_id I do get IDENTITY columns but when I use
id in the model with the annotation I do not get them. Am I missing
something?
Here are my properties
props.setProperty(Environment.DRIVER, "com.ibm.db2.jcc.DB2Driver");
props.setProperty(Environment.USER, "Administrator");
props.setProperty(Environment.PASS, "e*****");
props.setProperty(Environment.URL, "jdbc:db2://192.168.0.3:50000/"
+ dbName);
props.setProperty(Environment.DIALECT,
org.hibernate.dialect.DB2Dialect.class.getName());
props.setProperty(PersistenceOptions.MAXIMUM_SQL_NAME_LENGTH ,
"30");
props.setProperty(PersistenceOptions.ID_FEATURE_AS_PRIMARY_K EY,
"true");
props.setProperty(PersistenceOptions.DEFAULT_ID_FEATURE_NAME ,
"id");
props.setProperty(PersistenceOptions.JOIN_COLUMN_NAMING_STRA TEGY, "simple");
props.setProperty(PersistenceOptions.ALSO_MAP_AS_CLASS, "false");
props.setProperty(PersistenceOptions.DEFAULT_TEMPORAL_VALUE,
"DATE");
props.setProperty(PersistenceOptions.DISABLE_ECONTAINER_MAPP ING, "true");
props.setProperty(PersistenceOptions.ALWAYS_VERSION, "false");
props.setProperty(PersistenceOptions.ALWAYS_MAP_LIST_AS_BAG,
"true");
props.setProperty(PersistenceOptions.INHERITANCE_MAPPING,
"JOINED");
Here is a sample of the XSD
<xsd:complexType name="Tranche">
<xsd:sequence minOccurs="0" maxOccurs="1">
<xsd:element ref="gensec:source" />
</xsd:sequence>
<xsd:attribute name="id" type="xsd:int">
<xsd:annotation>
<xsd:appinfo source="teneo.jpa">@Id</xsd:appinfo>
</xsd:annotation>
</xsd:attribute>
<xsd:attribute
default="http://www.mddl.org/mddl/scheme/trancheIDType.xml"
name="scheme" use="optional" />
<xsd:attribute name="nameRef" type="xsd:anyURI" />
<xsd:attribute default="valid" name="validity"
type="gensec:QualityEnumeration" use="optional" />
<xsd:attribute name="rank" type="xsd:int" />
</xsd:complexType>
<xsd:element name="tranche" type="gensec:Tranche" />
Thx,
David
Re: [Teneo] Switch to DB2 and not getting identity columns [message #124973 is a reply to message #124960] |
Mon, 02 June 2008 13:09   |
Opps, I checked the MySQL and it did not have the auto increment set
either. So when you replace e_id as the primary key which option is
required to get these columns as auto increment?
Thx.
David
david wrote:
> something?
> "jdbc:db2://192.168.0.3:50000/" + dbName);
> "30");
> "true");
> "id");
> "simple");
> "DATE");
> "true");
> "JOINED");
> </xsd:sequence>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> <xsd:attribute
> </xsd:complexType>
> Thx,
> David
Re: [Teneo] Switch to DB2 and not getting identity columns [message #124985 is a reply to message #124973] |
Mon, 02 June 2008 13:27   |
Hi David,
You should add the following annotations to the id-feature:
@Id
@GeneratedValue
(generated value has some more options, see the jpa spec for those).
What you can do is set this annotation in the EDataType and then use the EDataType for each of the
id efeatures.
gr. Martin
> Thx.
> David
> david wrote:
>> if I leave the primary key as e_id I do get IDENTITY columns but when
>> I use id in the model with the annotation I do not get them. Am I
>> missing something?
>> "30");
>> props.setProperty(PersistenceOptions.ID_FEATURE_AS_PRIMARY_K EY, "true");
>> "id");
>> "simple");
>> "DATE");
>> "true");
>> "JOINED");
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> <xsd:attribute
>> </xsd:complexType>
>> Thx,
>> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Switch to DB2 and not getting identity columns [message #125137 is a reply to message #124973] |
Wed, 04 June 2008 13:35  |
I'm using XSD for my model, but this may be helpful.
Note that the sequence definition must be on the schema tag, not on the
complexType definition.
<xsd:schema
xmlns:xsd='http://www.w3.org/2001/XMLSchema'
xmlns:ecore='http://www.eclipse.org/emf/2002/Ecore'
xmlns:com.vsp.consumer.model='http://model.consumer.vsp.com'
targetNamespace='http://model.consumer.vsp.com'
ecore:nsPrefix='com.vsp.consumer.model'
ecore:package='com.vsp.consumer.model'
elementFormDefault='qualified'
<xsd:annotation>
@SequenceGenerator(name="SEQ_XYZ3601T" sequenceName="SEQ_XYZ3601T")
</xsd:appinfo>
</xsd:annotation>
<xsd:complexType name="Consumer">
<xsd:annotation>
@Table(
name=XYZ3601T
uniqueConstraints = {
@UniqueConstraint(columnNames={"CONSUMER_SK"})
</xsd:appinfo>
</xsd:annotation>
<xsd:sequence>
<xsd:element default="0" name="consumerSK" type="xsd:int">
<xsd:annotation>
@Column(name=CONSUMER_SK,nullable="false",updatable=false)
@Id @GeneratedValue(strategy=SEQUENCE,generator="SEQ_XYZ3601T")
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
Re: [Teneo] Switch to DB2 and not getting identity columns [message #619150 is a reply to message #124960] |
Thx.
David
david wrote:
> something?
> "30");
> "true");
> "id");
> "simple");
> "DATE");
> "true");
> "JOINED");
> </xsd:sequence>
> <xsd:annotation>
> </xsd:annotation>
> </xsd:attribute>
> <xsd:attribute
> </xsd:complexType>
> Thx,
> David
Re: [Teneo] Switch to DB2 and not getting identity columns [message #619151 is a reply to message #124973] |
Hi David,
@Id
@GeneratedValue
id efeatures.
gr. Martin
> Thx.
> David
> david wrote:
>> missing something?
>> "30");
>> "id");
>> "simple");
>> "DATE");
>> "true");
>> "JOINED");
>> </xsd:sequence>
>> <xsd:annotation>
>> </xsd:annotation>
>> </xsd:attribute>
>> <xsd:attribute
>> </xsd:complexType>
>> Thx,
>> David
The Netherlands
Re: [Teneo] Switch to DB2 and not getting identity columns [message #619169 is a reply to message #124973] |
<xsd:schema
<xsd:annotation>
</xsd:appinfo>
</xsd:annotation>
<xsd:annotation>
@Table(
name=XYZ3601T
</xsd:appinfo>
</xsd:annotation>
<xsd:sequence>
<xsd:annotation>
</xsd:appinfo>
</xsd:annotation>
</xsd:element>
Current Time: Sun Jul 27 06:12:22 EDT 2025
Powered by FUDForum. Page generated in 0.05580 seconds
