Home » Archived » OHF » Equinox Server-side incubator
Equinox Server-side incubator [message #11408] Tue, 15 November 2005 13:40 Go to next message
Originally posted by: eishays.us.ibm.com
Good news.
We have good interest coming from both Geronimo and Equinox projects on
having OSGi bundles enabled on the server side.
I participate we will have good collaboration from both communities as
we will be one of the first showcase of such technology.
Take a look at this link:
http://eclipse.org/equinox/incubator/server/proposal.php
Eishay
Re: Equinox Server-side incubator [message #11663 is a reply to message #11408] Fri, 02 December 2005 08:16 Go to previous messageGo to next message
Thanks a lot for the information.
How exactly does that relate to OHF?
Or was it posted here accidentially instead of Equinox ?;-)
Re: Equinox Server-side incubator [message #11697 is a reply to message #11663] Fri, 02 December 2005 14:14 Go to previous messageGo to next message
--------------050405060904090706070404
The info is related to the OHF based on OSGi/Server goal we have (see
the "OSGi/Server EOHF Project Proposal" thread started at the mid October).
The project proposal is relevant to all of the OHF bundles that can
and/or should be used in a server side environment.
You can find a description in the project proposal. Attached is a sketch
that was the base of the OHF/OSGi/Server talk we had in Washington. The
idea was brought to the Equinox and Geronimo communities using the
mailing lists and meetings. It received good responses from both, check
the communities mailing list/newsgroup to learn more.
Eishay
Content-Type: image/png;
name="ohf.server.png"
Content-Disposition: inline;
filename="ohf.server.png"
iVBORw0KGgoAAAANSUhEUgAABIcAAAJKCAYAAAC21yXLAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
/45JREFUeF7svQeYHNWV9s//22Dvt5/D2l6vs8Fhjde7a2wTRRJJOeeAIkJZ KKGIhCIZBTIC
hACTMyIJCRAmSIBBkgkGB8BeIwmw19gGaaZ7wv2/5946Vbdu36qunulJPQee 9+nq7upUfbrV
9zfvec//p5Q6QP6TIyBHQI6AHAE5AnIE5AjIEZAjIEdAjkBTH4H7779f7dq1 64BcLnfA888/
39QPJ/cvR0COgByBdnkEjjzyyAM+8YlPHHDIIYcc0KdPn/8v00EgOJSmqqoq dd9996n58+er
jh07iuQYSA1IDUgNSA1IDUgNtIsamDFjhrrtttvUhx9+iJ9K6b+X5Ho5PlID yTWwd+9eNXHi
RPWPn/xH1bFPRzV+yXg17bxp6pqt14jkGEgNSA1IDTRBDdB3LH3X0ncufffS dzB9F6f9W5UI
huiHEP0o4i/xqedNVeu2rhPJMZAakBqQGpAakBqQGmgXNTBrzSzVaUgn9anP fkqNHj266I8q
gQMCiKQGCmtgzZo16sCDD1QLrlygtu/frl6uf1kkx0BqQGpAaqAZa4C+e+k7 mL6L6Ts56d8q
Lxwip9BXDvyKoh9FL8n/cgTkCMgRkCMgR0COgByBdn4ElmxYon8bXXXVVeIi EhdVquteAJEB
RNR9MGTIEDVsxjD11J+fkoVgMy4EBcAJgJQakBrw1QB9F9N3Mn0303e0++9V wT9uS5Ys0daj
pz7El7j8L0dAjoAcATkCcgTkCMgRkCOgj8D2qu1qwMQB2potAEBcQlID6TWA jAu19PqlAoUE
CkkNSA1IDbSyGqDvZvqOToVDBIaIJAkUkiMgR0COgBwBOQJyBOQIyBHwH4HZ a2YLIBL3kLiH
UmqA1hSUdSHuBXEvSA1IDUgNtM4aoO9o+q62AVH4Dxu1kpFjKPwZ1MrolhRV 6ywqeV/kfZEa
kBqQGpAaaFc1EPxSoj+mpfXti6tEnEXttQZ27typvnfI9xLB0I76HUokx0Bq QGpAaqD5aiDp
dxp9V9N3Nv97FfYEUx/95r2bBQ4JFJO/8kgNSA1IDUgNSA1IDSTVQPBLiVrM 6LdTsckf7RUQ
yOtuv3AMY5PVrTtvTYdDdVgUieQYSA1IDUgNNG0NBDA+CQ7dsP0GhZH3cThE U8kofDpmnpYf
xvLDWGpAakBqQGpAakBqQGogXgPWr6WL77vY27MvYKT9gpH2/t5v3bpV/aTj T8ynJOG7Q7sF
GrggvO+N+9QtL96itfndzQ2+n4Y+vtyu4e+dHDs5dlIDLVADReAQfVfTdzZ9 d9O/X3qSwOe/
9Hm19cOtAoda8Q/gx3Y/pm7++c2hKt3Cf++b96pn/vZM4g8Lur49HY9yvN90 POm4leO+5D6k
jUhqQGqg3daA9WuJJrrSbyhxDwkMau9QiF///Pnz1dTzphbAIfrN9o3vfiNV J/Q5QRH88S0g
p6ycom97wAEHhKLzvtvwvkmPl/Y4snhtgcVrA0GhvFfyXkkNZKiBDHCIvrPp u1vDISb89AMn
zTk04swR+kv5kGMOadbFpf7i73tC+Jju+ab4cUr/qNj32xyPmfQ6aDFPr9/3 D6L7PJviWLTE
fdJrptfrAxm+Hwf0Q4H2byvHg18D/VBqzuNLgDHpuDbn85DHEqggNSA10KZr wIFDPUf3VBs2
bJDpZRJQLQHVqIGDDz5Y3f3G3V44RL/X6Dct/Q5yRcCGf8/trNupbJ3Y50R9 HZ2uvGmluvXF
W7VGzh4Zwqb737g/vM3UlVP1/nQ9bdvqM7ZP+Dhb3t0Sexz3ceV8/H2Q4yHH Q2qgddeAF5Zl
gEPUBkztwBoOMeEvBocYkNCX7TVPXtNsi1oXSNE/Kn1O69Nkj88gxv7h2tSP mfYjmf/qQXCO
nTIrblqhIR29F3R5m/6R7XFrJR1vfs10PR0D3/Foytoo13Ged9k8/f61hIuH jk9zA95yHTe5
HwEKUgNSA62iBhw4dO5t56ohQ4YIHBI4JHAINfCpz34q6kawfuPRbzb63UpQ KKmtjK6jfeZf
Nr8A9BDU8S1M196/NgRHfD3DIQJIvtvQ/dPjJN2nLIBb9wJY3h95f6QG/DXQ UDhEHWSf/exn
DRwaPXq0WrJhCXxDyc4hgkH0JUqL2uZ20TS3W4kWzvSYreEHKB1vOu4EQnzP pzU913IdL3qt
dPzJ5WLfJ0Ew/Q95ChgkaNTc8LJcr7u57ofdQ0k11VzPQx5HFvlSA1IDbbYG HDi0bus61bFj
R4FDAofaPRyiqIp//OQ/RmuKEuEQ5QjR7ziCOztrsfiB+I+kfN53So6iHx39 I7XlD3AC4TZT
VxjnkIZDwf24p3S/dJu0+5XrzHsgkmMgNdDKayBwWzYUDhEHou9MDYfoBw39 sEmDQ7abhhbn
vsU7/cgjJwS7IQhssGXUXehT9gm31NAilffzOZJcOES38zku6LZ8P/TYvh+d dDvbxuoukOm+
GbjYj9PQx7Rfp/38si7Muf3IPX782tIcKPbx9x1Xek2cQUOPQ/tzjo/v2Nmv ha+n52UfT9/z
9D1O2oKAjr/dRkj7MtAo5nih10n14nv/7TrzHX/79fGxc49b1mNKzzlr/dO+ SXViP779/JMc
R8VeIx93Or7FjmWbXbS14twwOaYCQ6QGKqQGHDi08Z2N6sADDxQ4JHCo3cOh d955R0/wC9cU
JcIhdvQwHLr2iWvD9rBSFqcCh1r5QlaAkwA3qYHy1kBzwyHbLcQuIl++Cy04 WQx1mPjbC3KG
HgyaGMj4nCEuHPI5idgx4j6mneni24cez14k27k+9msu5THTXicfC/dxkxYM 7BwqpVXKDvwr
dlz5+HOPNz+eDya57Xbs8HGPuS+vyX2cJNhF0IMdavYx4eeVBP2KLbi4Hc2t TRuy2DXJYYd8
3H2vlfvm7cemY8Gv1X6vaXv1/atDYMm2aa5P9/Ng35Ye23ef9nvEUJPfR65j er2+XCO6T9q3
Jdrair1Xcn2FLJ4F0rUK96l8npro8yRwqN1DEAmf9geQNxQOUQg1gSH+/aOz gCwH0MobV5a0
kCoGhzh3iPYrBTrJvgKdpAakBlplDTQnHPIBA/7y1j3DluxF+LN/e1ZfR6cM KTbvxshJXMaL
Y7qfW35+S3gftAimRSuFzfH9MnxIOj/yzJFhfzLvQ/dp347/EkGn9vP1PR4/ V3s/9znw7ez7
o9eW9jrvexPTF4Jj5Xtc91jyeT6m/Bzo2NnHzL0d78fHmq6n46mD+XCs7OPI MIPub839a/R1
fJl9v3RfdDnfngEhvQ7f8eT74vvzPY7v9XJd2MeK9mOwl/a6k44fQy16zkn1 4dYkPX96LHoe
/NrpfbCPadivbh0DhjL2cWY3E92eH59fJ78ePm8/Bn1ubMjDnyeubXpddo3Q vvZr9D0u78+v
Kez7dz7HScdSLo9/38nxkOMhNVB5NZAJqAkcEjgkLilvDWSBQ7yGsE/5j3L0 OyjMCfK0h+2q
3aWyiOEQtY254t9WdHmW+5J9sh1zOU5ynKQGmqcGvHCqOeGQL9eG819siEM/ kl04wj+cGSbw
opkXw+7tGSbYC+licMi93l6A0wKaFtX0OC7IoP1ooR0Lx7NeQxIc4oW1vTh3 Xyc/VtLr9D1u
2iLDHsnJ/4D6IA4DCxsS8P0yJHHhkPu47n50Pd8vQxvfPvb92scmCST6Xm/S /fqAnf0+uxMv
GNrR83WhGN/OfU1J7xWDvLRjytAoDZrSdcXgkO/zRM/fhWXsgKL7Y/DnAz2l fM5kkVt5i1x5
T+U9lRoovQYEDslIenEFNbwGssAhd1oZ/8bTv90w0jwMmi0DHPKBKIJCo2aP Utv+sk3gUEbY
Jov+5ln0y3GW45ylBloUDnGbjzsRi0eNu4DEXrS6P0ptiMOww/fD1QUBaXCI F/+lOCBoIU9w
hv4R4oW/fftizqFiYMd9nbS4dx0vxe4j6Qc9PXcGXbarxHWQuLCEzrvumySo xiDPBhXu+8r/
2PoexwUkSY+T5b23X5cPkjBMZGBm/+WJrmM4Qu+z+1zZccbvvevmcY+p7/m6 t0l6rW5NJTmH
3DpJgmL2+5H0vJPgpw3xbAgri8jSF5FyzOSYSQ1UXg0IHGo4GBCoIscuCxwK f3MDBHF4Krvk
6benDYeonUwHVAftX+HCqQaLyBSFbWUv3Jq6X9p9yHXpx1iOjxwfqYFmrAEL 5LYoHGJ4kmQB
pcvDVht8yYeLVusLn7/4w4UzrgvhkGe/cEEcXGffju7LPs9TDfQ/NJ77si+j /mL3dfA/Rvbt
3cdPekx6bN9j2scgXLg7+5byvNNeF/dM819b7BY033tGl/Hzdo+r/Th03Ql9 0LaEY0p94DxW
1H4v7Xwb32P53vdi71FS/YycbVoHtXvHeZ/p9dhy66zY8+T3Pum9Sqtpfh+L HVO3ptzHSnts
7ThyXrNbY7597OPv+3z46rzY+yPXRz9k5VjIsZAaqKAasFprBQ4J4BDI1fAa aCgcot+a/Fvy
/jfuN4AIziGaPkaX81SxJDg0atYo9Y3vfEOtvXethkECh5px0VoE1AlAkPdC aqAMNdBa4FCa
Q4Rby8J8lVYMhxii0Ckt5De/i+wjPF8fpMkKhxjIuAsEH5xwQVIWOETPUbeO 4TmnLULsxytl
wZ8GhwjGaPCH58DbLjzSrpMiQM4Fa8X2T3r+YcZRkWPhPl4SdPE9j1IBDd2H e5ukY9rUcEi7
qvDDygfOwrbJFMBU7H2R6ytoEZzhMyvvt7zf7a4GBA5JhpBkCJWlBhoKh+g7 h9v9f3QMxssH
cIgAEY2pp98yNLnMB4e2fbhNgyESL0IFDpVhMSrQR1xnUgOtpwZaAxziiUZp E6JiLUQBHPK5
GNh9QqDBXlT7nCBpTiEfbLBdLvYPWp56QCAmadEey2sJFk3F4FAatHGva6xz iI/vs39FuLdn
Uece1zSHDR0Pej58X2lwiF8HO7zYRcTPIQ1CcftWQ51DSS4Y23KctHCh12a/ Lnuynnsbuo6e
K0OVpPeKHWcMFO37ca9rCTjENazbAJ0aSbsu7f1vdwtDASaZQK/UhUCjiq0B gUNlAQPiuGm4
46ZSjl1j4BB9v/BvPfrNyq0T9//y/tBVdM6N5xhAFCxar3v8Ou0qIni04NIF 6hc1v9CatmKa
vuy2F24LL+Pr5NQcI5EcA6mB1lsDBW6r1gCHOBw4aew4Wa9jU7esL3XX7cIw gRfYvBCny23w
wQ4fe6FbDBb5bkP3abfehBDLWgTSc0lrK7Ofl/scCJaEU9WC++THtNufGguH +K8o9DxdkEbn
+bgy4GCo4x5XHyArBgf4vn3tXAwd3Pc5nOBlOXyKPY692ODj5XPBsOWYnTAu rKHnxO+nDbP4
ddjuLX6v2B3lcwHx82LA5B5TPgb2Y7UEHGJgSo9tv0Z+z32wjeuEYW3FLvgE +gj0kRqQGshS
AwKHBA6Jc6gsNdBYOGS3l1FLGQMimmBGv2c4KoCAEDmF9HmcklPIXuhOWx7A oecBh/JYAIrk
GEgNSA209hqwoG2rg0OP7XlMfwkTIErrv7cXzjbxZxjDC3M6bwMfhgD2fryw d4FDMThkPy4D
Ib5fXiyzo4au1+HMgDvcssWnvEBmwGE7knyLfn6+7mP6XmdD2sr4+XBbl5ud w+ddxwidd4+r
ezx8Dqwk10mSk4ehHB8b+3jY91UKHGInlM8FQ/dJ1/Pj8GviUz4ebr6ODUka 8l7R4zIIauhr
bcq2Mnp+aa/Rl43Fr8fn3BNQJO4QqQGpgXZXAwKHygIGKsX9Iq+j4Q6oNDj0 zN+e0b/Bw+mv
CeB27f1r1dSVU9Xa+9aGcIghETmH+o7tG46nJyj0+P88rp1ENhxav2W9IkC0 /c/bZUHc2hfE
8vykRqUGTA20Zjh0zVbTckNf4GlwiCdCcbuS7WQhqEHn6dR1gjAcovsnGEP7 EWxYc/+agr9y
0r52vo973oY6BH34MX3OEvt6Xhhzu5XbkkbPmx+3oY/JrUtuWxidD/+BzPBX TXottD/DDTql
5+ZrdaLXwVlBvL8vHynpNblOHt97Yrtq6H2jx6Fj64M6WR7Hfky+r7TFCR1X ri+unSSgZNcH
Hw+6rXvskt4r+7XyY5b6Wt0acx8r6bF9tUnPhy5331O3RpIysej2/DlodwvA DJ81OSYCRqQG
2mENCBwSOCTOobLUQBocstcTetJjwr/J9rQydypP2rSyWIuMLDYFOEgNSA20 tRpozXDoZYX/
0TZWTLExvimZQ+4/AKUEBcsP9fb1Q52dT0ngS+qh8fVADqg0eCTHuPHHWI6h HEOpgTZUAwKH
ygIGxHHTcMdNpRy71gqHXsm/okRyDKQGpAZaUw0UtLsKHDoglpEiP6Tb0A/p JnZgcPuf1ET5
a4IdaHJsy39s5ZjKMZUaaKM1IHBI4JA4h8pSAwKHZPHdmhbf8lykHltzDQgc soCCOIfa6A/o
JoZCdgsXuVuSprTJAqzh9UPHNa1VUI5tw4+tHDs5dlIDbbQGBA6VBQxUivtF XkfDHVBtAg7l
sGAWyTGQGpAaaIkasFyM7QIOUbaQLwCXfjCHPcR1O9Vzf31O0eQB+zLZ3inH A7XBdUBtT9c+
ea0cE+uYNPYzcv8b9+t2ssbej9xePqtSA1IDbakGikI7gUMCh8Q5VJYaEDgk 4EnAm9SA1EBK
DbQ3OJT2A6wt/ZCU5yoLH6kBqQGpAakBqYHKqAGBQw13goiLRo5dKTUgcEjA gIABqQGpAYFD
Km3qAP8okx/ZlfEjW95HeR+lBqQGpAakBtpSDQgcEsBRCuCQfRteL20RDr2a e1WJ5BhIDUgN
NEUNFIAycQ5F+QMFPyRr8eNaJMdAakBqQGpAakBqQGqgnDXgtOMKHGr4Yl9A iRy7UmpA4JAs
sJtigS33KXXVVmtA4FBKYLHAIYFhAgOlBqQGpAakBqQGmrwGBA6VJT+mFCgg +wpEohpo83Co
GotwkRwDqQGpgYbWgONEFDgkcEj++lvOv/7KfUk9SQ1IDUgNSA2UWgMChwQO ScB0i9SAwCGB
SwLXpAbadQ0IHELbGE/5KDLmXJxD8tfiJv9rcakLCNlfFp1SA1IDUgOVVwMC h1oEDIh7SNxD
AocEDLRrMNBQt4ncrnKcSgKHBA4J8BDoJTUgNSA1IDUgNdCKakDgkMAhcQ61 SA1UGhx6rfo1
JZJjIDUgNZBUAwUwVOCQwCFZELSiBYE4ACrPASDvqbynUgNSA6XWgMChFgED 4hwS55DAIVlE
C0iRGmhPNSBwqP5l9bKlsKWMWsukrUx+wJf6A172l5qRGpAakBqQGih3DQgc EjgkzqEWqYGK
h0NVWPiL5BhIDbTvGrAchQKHBA7Jj/hy/4iX+5OakhqQGpAakBooZw0IHGoR MCDOIXEOCRwS
eCTwTGqg4mtA4FDcLdRczqFdtbuUSI6B1IDUgNSA1IDUgNSAXQNF27kFDgkc EudQi9RAe4JD
r1e9rkRyDKQGKr8GCmCXwCGBQ7IwkYWJ1IDUgNSA1IDUQOuoAYFD4lARl1Lr rIFicGjzns1q
6fVL1Ql9TlCHHn+o+uKX/kUdcMABIjkGUgNSA1IDTVQDh3Y8VJHGLxmvbt1x aywiSJt+8P9L
+J++i+nf1gM6duyo1m1dpy80Vwf/Oy1ktmOIt5syc0h+hLeOH+HyPsj7IDUg NSA1IDXQmmpA
4FDrBAMCbOR9SYJDT/35KTVsxjANgwaPPkldf+9Z6u4nz1W79tyk9tQ/GNPe +oeUVl1peq/u
YRWqFtsZ9X7tIypUDbYz6oOaR5WoNR+DTXh/PMrjspaU7znpy1rzsWzfzy3r d4Lez/4+wXbW
7yG9n/UdVur3H39vut+ndJ6+a0mzlwxVPzjkW+q/jvwvdcO2GyJIJHBIfuS3 ph/58lykHqUG
pAakBqQGSqkBgUMCIQREtc4a8MGhVfeuUl8/8Itq2epxBSDIt5Bps3AojwW0 qIzHwIE4OZz3
6H1cVsnyvWZ9WQHgkvor2+fPAXVtHQ6537MPbrtY/eTI76kBEweo7fu3t2Hn UA1+PIvkGEgN
SA1IDUgNSA20rxpwMggFDrVOMCDARt4XFw5NO3ea6tLnSPXmn2/PBIZoESNw qD0s8i24YQGf
SoY8zfnaCoBSCJLaQ22V4TVWOBxiWHT+lZPVTzr+RD314VNttK1MFgPtazEg 77e831IDUgNS
A1IDVAMCh1okXFhgj8CeUmvAhkMLrlqgW8h87qC0ywQOlWFx26IOpgD8OC6f 5oQj8ljF3VQC
kFI+Z+0EDtH38C2PLFUdunRQ26q2tcHMIVkkyCJBakBqQGpAakBqoP3VgMAh gUMyfaxN1ADD
oQ3bN6gOHf9LvbP/HoFDLQpqmhI0xSFQiwKZasCQSlQLtszF4FF7cx61IzhE gGjZmnE6E67t
BVLLgqD9LQjkPZf3XGpAakBqQGpA4FCbAAOlukxk/8pzJhEc+vI3v6wDT7fs vKRkMCRtZU0J
cxpy34UuoGaBQI0GPY8BFj2m3msjoudqVAbI1QxAKQRHlQqN2hkc2qMe1EHV AodkwSELDqkB
qQGpAakBqYHWXwMChwQOiXOoTdQAwaHPfO4z6vQZvRQtOEptKRM41BCAU67b RIHPTQaASoYf
bQfwtBSIahBUaiKAVDHQqB3Coc071wocknBrCfiWGpAakBqQGpAaaAM1IHCo TYABcQJVnhOo
1PeU4NA//OM/KFpoCBwqF7RJv58tz1+q3vnzvalTwuL7NE072Obtl6m3//e+ VPfL5m2XqW2v
rg/2aWbwU4XHa2Jt3na5ImV6nDK5mujxnsMxZThF2/o5OPdfEkQqER5tew2P ifffBxXbJDBq
h3Bot9qovvSlT6udO3eqAzp27KjWbV2nU6pftv+vx7ki2lG/Q4Wqw3aKdtbt VDHV4nyKCsba
yl93W/9fd+U9kvdIakBqQGpAaqDcNSBwSOCQOIfaRA0888wz6nOf+2dFCw2B Q8lQ549oxymH
Hn/+Mv3X/rOWj064v8fU489fHu7zQe4xjIMvgwAePrC0BTCCnsfCZaPDy2+6 e5kaNroLQNDm
UN/6zlfVER3+M3aZfX3qdhXupxXriuvn6WNAuu+xi5r+uQbH1T2mdHzpsszH Nbgf+/1M3Ebt
bAcI6tb76FgdHXG0ecystfVH3I9WnlWez0Oxz1TmUfftFA4df/y/qyVLllQG HPpFzS+USI6B
1IDUgNSA1IDUQNusgVQHl8ChNgEGSnWZyP6V5zS66KKL1GGHf0vgUJEQ6mKL 2KzXF8KhYNFt
AaAt2wNwA4CUdfEe7udAoEJoYMDP5m1XBHBoTCoISoRDLQh93sNjl0Pdeh2t wRe9RoJifJ9N
DbTCYxocw/PWTAWkw/tA5y0w19DtD3Af9vvOr9G+7PxLpqiFDakvq07jwKhp YJHAoYRWX7QA
E9AfPvwI1aVLF4FDspBomwsJed/kfZMakBqQGqicGhA4VHmgQOBP+3tP586d q0486T8EDjUb
HCruCsoMh1JAUDGwUBQOBeDCBRkNBSfFYc4WwJkm0H7cJ8u6/1+8c4eGQpNn DFQEiWi7YY+f
Dqp8x6vRx7REgGQ7k1LdRo10qDUFLBI4lA6HpkzpqA4++GCBQ7K4qJzFhbyX 8l5KDUgNSA20
zRoQONT+QILAo8p7z8eOHat69/mxwKFS4RAyXv6YSXAGAeKQaGHua+dyF+ze fZC98+o7t6nh
cLjQYp9E23SZCyBeeed2DT14PzoNnSkB9Anh0NIx6u0PHlALcUrQgkTb921C m9X+zfo83X7b
L67XEIXv84r18/T17zm6HJfbj3v5+vkRnAkgDV1m3xdt37vpYvXePoCcQAuW jtWX0b50f7TP
W+9vjF3Pj+O7vX1fvu3J0wdq59Rzuzbox6Ht81ZPiz0Huh1dRqL97OesX5f1 fOm50XN+6wNz
ys9t2Oiu6hdv3xE7BnxM+dhp5xCOOR1PW3SZ/Rr5PbH3offBPZZ2ixy97+H7 im16LKoX2630
AWqLdeX1c2Pv35Ub5sZcSO/86X7dikindF34/NC2dt/mi2L7ct0baJTx8+K0 bwocSodD06ef
qA488ECBQ7KQaJsLCXnf5H2TGpAakBqonBoQOFR5oEDgT/t7TwcMGKAGDz1C 4FDZ4FAcBmUC
P2l5QMHCnYARL/IJ/JD4/E13LQsBEYEBez+CA7SAJ/ihs4MCALH5uaCtDACC wA/vw+BCQ4QA
DvH90T4EO+g83R9BkNCVA/DD90Gwgq6jU9pv2KiuIUjhy3gfuo7v78Y7l4f7 0WW8Lz8+w5iw
FQy3ZRBDj0PApxgU4utDQBMAHve8+1j8fJJe1+ZnrwyPsXYk4bmQ+LkTXCp4 7ACW8evhY0kw
iW9H7W4LAkhEr5GhHL039rEkkET78rHUNRHsw5eZ9w+ZUoBDoZvIag+064Th ItcNwyMGl3x7
hkP8GC4gsus/EywSOJRtYmTQViZwSHKKJKdJakBqQGpAakBqoFXUgMCh9gcS BB5V3nsucCjb
hLKCTKHQCRFkBhXN+ok7hxhG2C4be9uERQc5NMFinq5/+48PxJxCsUU+YACf JzeQ7TAhKED3
SSCILrfhEDtYIkdL1IrFi37bKUMuGRfYkLvG574h+OM6dDRUslw3BFYYvtgA hW7Hj8uuIYZJ
dBv7PuzHKQaIfE4hdhK5DiYGJjbgovvnx+P9GQ7R67CfW9Jro/t1ARSf5za3 8H48EOleOLsM
oIs7juh95WPJ739YI5YzyYVDVGv6/QucRexGo/NciwSIGA7RY5BrTUMj1D5B IdpPB19n/Cx4
YZHAIYFDsb8i5/EXVZEcA6kBqQGpAakBqYHWVQMeICdwqPJAgcCf9veeChxq CBxKdwelLY7t
xXUSGGIgwXCI3EAFC/dgoU9OEj1tK2gDIzjArhG3RYn2o+sJBm1+zjhdbPeP zz1TzFGTBDj4
8l+8dYdptwJQIhFMsdvDaL+9ED3O4QAmtB2ePwrnP8Z5S9/69ldVVziS3Mt3 /RZuG1w3CW4d
9zr3PN2e9qXb8HXk7KHj4d734XgOtG94H8Hz24XXRc+ZIBE9X4ZDPvcSAy06 FvR63WMaOocs
FxMBIhdy0bHj1rfwWKKNzXZv0XYE+UybWiocCuqIYV9SRhJdT9dxOyI5i+x2 NNrmx80Kh9z9
NCzS09CicGtpK2vvbWWyGGhdiwF5P+T9kBqQGpAakBqgGhA4JNPHZDR9RdaA wKGscMg4hLJP
BbNGx1uZLnaeUFK4cywsGgtydnWkuow8DhJyfXDbFTuA2I3CMMN28TQGDtm3 ZcATnjqAh6DM
PY9erOYvGavhCgEYAjN0uvfjx7UIyNjn6bLHnjFAi6+j622598H35Z7y7en+ bDEI2vXbO8Pn
wffvu6/oOW4Jnxvdnwuj6HXSc3sMbicGX0nOId/7kuaEIuBE0IjeRzqWdmsY Q6Oobc1kRPmA
kes2ssEiO5lsOORmWNF1IRyy6p2dRZmBUfAZ0zlFAEUChwQOyY9wWYhJDUgN SA1IDUgNtLYa
EDhUkWBAnELtzynkvucCh9Lg0CbAoE3qfahgpHyx1hl3gYzzxRbXDIvssGha pFOeDGe/JAEi
AkEEA6gNi0EQL9YJGnA+TWPhEAMfcvnYjhoblBg4YiCPq669jtG3YxF8mTR9 UAEMaggcovvS
Tp6Ex6bLzw3a3+h4JolgDt9HNjgUgSsDh+KvO4RDwXXusQrdSXAOEUAKHV1W 650PEDG0YdcP
1QbnHHnhkzW5zQVGdB++UGyqP863irUjWi2PXLdcb3zedRaF59M+O87ENPPZ g+AmMkr4vNbg
ckvv1zyiMqsW+1p6r/ZhlVl12DfQ3rqHVEmqx/7QnvoEAJR2ebvJHGptP4bl +cgCTWpAakBq
QGpAakCcQ+KaEThWoTUgcMhdbEZAiBamrKJwyAODPoCb4gOMT7e1ZZtZ/C9c NjZ+HRbuHwTa
ErR8LYQbhC6jU7oNXf4+zhs9Htc+nIcYFNy3aZU+z+L7IDhEl7FDhS7nfSL3 z+NoaTIikHEE
oMt7AB6RntCX0XXvffyEVrSfOW9r8zNXoZXsIbVgyWn6dUwGDHL3cW/vuz+6 Hw1OcD/u7fX5
j4qLn/fmp69SdH+uGFrx/dP+5vUXvi77OfJzu/fR1QX78uumfXzHyj6Wz+26 MXiNyGWyj3nw
fvD7x+8nHUv7feYa0OHjwfsftpVZ9RC1mpk6CsFOUF9ci3TK+9K2W5t6v6DG I+dQvObN9fRZ
iKaiJYIiDxyKfw4TIJHAoY5q3dZ16iX8/7L9fz3OFdGO+h0qVB22U7SzbqeK qRbnU7SrdpeK
qQbnE+SdWCM/wGURJjUgNSA1IDUgNdD6akCcQwJHKhSOtHf3lMAhgkN+IFQU DiW4g+x2sUQ4
FIAfexHug0MEgrb9wuTh0KSwEAoFC33KoKHFO8EgH/BhQNANjh2dOeTAId1W FkCIOAhKhz4u
HKL7p9sTBLJBCsESE1R9RhwoWSDn3kfMPhrCBJeH7hqc32sp6fLndt6oW8zm AxzZ+9vbtI8+
jiPhLnLul8/TdToI+9oFep+w1ew3d8bg0413rDCva9UZ+nKCTXzfLkgqBtKK Xc/3RyDIhHvf
YB3LCOTRe011wC6zTHDIAUhvv/9gDDq+jUyjEPokwaEAaqbBIbeFMhEUFYFD iaBI4JDAIQmu
lvBuqQGpAakBqQGpgWaqAYFDAocEDlVkDbRfOBS0q1juIHvh6W4XZA1ZYCgp O4guD+FQgivI
hUMEgzgsWrt6AocQwx2CQbzoJxAQBgljkb8N0EBPjAKocV1DYeYQWpsIBm0O 8ntsFw67Ztjp
k+YIcoEGQyC6/K33AIgATH4BoML7EWjp2tMAqhsAVhjGMNQJ84ICaJMEgQj+ uIBnFx6Hc4vu
AWiKwM+T2I7E4Ce+Txw+0XU6mBrPleEQPzd6HLrsMYAgPlb8WHQZt6mdC2Dk wiZ9nC3wZbuR
3GPJTiM9IS1wLNHxpcek95Yu43ogSMX7MDRiOMTuLw3u0DZ2053LdY1Qbbhu IrqOb/fKW3fq
feiUM4xuumu5rkW7Nt3atSFSeF3gKkr/jFiOIm45CyBR2mcyBooI8NaQTHtZ 5pYyaj+TtjJx
DsliopkWE/LX/9b31395T+Q9kRqQGmhIDQgcqkgw0N5dM/L61QHtDw6ZtpT3 SRnB0PvVuI2T
k5K22A2vQ16Lu4COteUgU+b9UFELWOgAQvbN+wA5LAYCDCbYbUOgh/fhEevs AuJTcrj4nC42
tGBnSti6BZgRuonY6fM3OIqgEPpge28gctvYeUK8TeCE9nlux436eoYt3/r2 13D+a2rSGYMA
d/5Lb+/9G2AORNt0GZ+3T2l/vq19qt0+we19p7xv2j782LTvrl/fFT4vfn58 H3T+saevDh+P
tqPXFWUq0WX0fPkY0WkIvoLjxu4kOq4sBlnue82AiaAaH0t+L+g8vYchbNLv 2ePqxjsM+And
Wagp3seuryuuQ16VlQfF23Q578dQMWpHNDX8gTWFzeeGCwOuAUxTQVE1PjPW Z40+e5k+p8Fn
mrOJ3i8FEAkcaptw6JX8K0okx0BqQGpAakBqQGqgaWog9Q8nAocEDolzqCJr oH3AITgJEGSr
gZCtNDhEi1JLtGB9HwvXUEmL3GAaFC+Gvc4gtHbp9h0rA8ZepNM2LcL1PhYc om1yfiwENCLd
9+iqKJcGEIBAAInAAUEfErU7MVCgbbrOPs8uH/uyG29fod7aC/cPYIW+DaCO DTcY9DD0sa/b
9es7dUvW/LNPM61ZHlhjX08Ahvah0xhs+dnV6rmXb1J7/wpY5NGuX92lzr34 DPM41+BxEvaz
L3+syH3yvvS4tO9v9zwcQSvc/z0Pr9aPR6fu62I4RNfTa6HnRnpuB16Dcwzo uNnHlLZ9x5Iu
p/tYgPu8F48ZwiOrJY+OJb3PdEpOLXZs2e87XUbvO7mMzPtPNXID3lvjIiNx nb2CSW0Eg6i+
bChk12FBbQZ1TFBz264NOhOrsO7NlLSYfJ8h6zNmPnPxz2EiKHI+2+/pzzs5 iDK4iAQOCRyS
hUXTLCzkuMpxlRqQGpAaaLs1IHBIJleJk6b91UBlwyGzQKSFolksZoBDzmL0 PSxQSTEwRAtY
e2HrLnqt87RILgiRpsW0A32yng9Dii0YlCWIOXEfy63iAqDk88bdU5IywJss gMfeZw/us5zy
PX7oaCry/AkmkTOH4FDsfko9Tnr/yI2Vtm07jRpVA3YtObAoa12G+1Fth2Hp pvbNZ8ADh+zL
+PNkA1hsR58/BxK5jiIPHIo+90VAkcAhgUOyeGm7ixd57+S9kxqQGpAaaJoa EDjU/sCAwCB5
zysPDrFLKIJCReGQ604IgBAvTL1wqMhi9z1cT4pNFWOnUAlgqKwwqGQQlBEA NQD8lBPqNOV9
ERw6CC1mxR5jUxIcynJsMgOk4tAoBozo/c4wwa1wn8iF5jqLMsEirnNrol70 ecgAiSxAZH8G
E0EROQBT4BB//hPdRAKHBA7JwqJpFhZyXOW4Sg1IDUgNtN0aEDgkoEBgUfur gcqBQ3GXkL0g
9MIhWlAmuIT8C9LibiFeAL8HpwTLHTOuz6fAobLBoJJAUAYIlAVyBPsUAylN dv1ftqo9pSiD
84iCqbPCIdqPnENZXl9ml1QmcJQOjRrvMCoRFtntksH2e8gkij4XDE6LtJpZ zqGikIhbRANI
5Pv8J0IigUMVBIdy+BEukmMgNSA1IDUgNSA1UFoNeHL8BA61PzAgMEje87YP h4pDoRgcsnOG
NBwybWOJwlSy96CCEN3AOeQDQnohHCgLHCoEQg1wfGSGQUVAUEYIlAWAZNqn FJjT2vfNAJuy
HJNM4KgoNMoIjMrgLCqAnUlwiD8XFjwtcBQ5OUT02dMq8jl1s4iKwaFYy1kt vkMsQPRe7cMq
s+qwb6C9dQ+pklSP/aE99Q+WLvWg2q02qunTT1QHHnigOqBjx9Y9yv6Fj19Q a+5Zo3qP7K0O
O/4wddD3vhWmpHNaupya1HiRHINy1MDB/32wOuy4w9Wg0wepqx68qrRFYhtb VD/wygNq+srp
+vWSynH85D7kcyg14K+BT33m0/pzdmKvk9SiKxapJ/6A8cRBOPWuml0qUbW4 ztLO2p0qVXW4
3tKOOvwhK0310R+6Xq5/WRWVwj7B/y+pl9TGdzbqH1QCRwSOtPcaaLtwyITN Zl0EvpfD/hYY
eg+jsrNAIV6c2nDoPSxgzaLWckNYQCgLHNJAKCU36H2MYE8V4MD7gd7DabK2 4roE/RWXp2gv
rmuw/vKU2isqPAaNOKZp75W+Lul9Di9PrhOupWJ1V6wFTYOiYnDI/qy4oCgJ DjEkSgJF9HmG
+DNOn3ctK3MscVuHVhMgMpAoMxgiiCRwKP3HHf0QnLNqjvrCv31Bndyzk7pg 3Wp1y6Y71WM7
t6rf7vtDTG/te1cV6GNcJpJjIDVQcg08uO0xdeujd6kVa89Tx51yvP4MXvjT CysKEt354p16
kfqt731bTZw9Rb9eknxnyPem1EDT1cDO3b/Un7Orb79ODRt3Kr5b/lUNGj9I QyKBQwJW2jtY
qYTX3/bg0CMGCrGKLf54kRjAIQ2FWK4bwV6AOtsEhzQU0gqgUAIQSoJD72HR HIdCyQ6hgkV6
Y2FQU4CgJoA/e3CfbUVlh18NAEeNA0alw6L0DKMAeBL4dACR/ZlI3CZQRJ8t LdPGGTqHfJ9N
+/Nrf6719iYDh2wlfVdY3yfmu6UEQCRwKBkO3ffafdohNHrqaWrHntcLYJDA oab78S4LIzm2
bg08/9ZO1WNgL/XDw3+onvyfJ9s8JBoxbYT6/n//h8AgAacCA1uqBqw/6Cy/ 5FxA2m+pC26+
QJxDMt69Ise7VwL0yfoa2g4cwoINi7a9tHDLAoecheFevVi0wJDtHEqBQntx HSlatGYHQ2YR
HAChYArUex9naxnTcKgxzqByOoIaCYEaBHs+BCRqjWoAvCoLRCoBHKUCo1R3 kR8Wha4icqhl
aUOjGg/r3YCiTHDIziUKIFH0+Qvay5IgkfPZps+7+cxngET29wm2zXcMAaIM kEjgkB8OXfHw
FeqHRxzidQi5UIjPi3NIgIZAraavgbuf3KgO/u/vK3LdtMV8rufef067hRZd sESgQEtBAXlc
qT2qAcftu3PPL1X3gT3VpMWT/IBI2soEmgg4axM10PrhUASFaNGWCodcp0Cw QIwWig4cygCF
9sK9QIq1kJHDIcU1tBfXaX2M/fQimRbLlpIW2FZuUMltYuWCQQ0EQZkAUNlh z88AkMqpMgOp
DCCpUeAoIzBqGCzyg6K9do0m1bFb7/gM0GdBq5jbLtZmhv2Dz585LQKIyEkU QCL+zNuniU4i
DxyKvmuKQCKBQ4Vw6PaXb4c74UeZ3EI2KBI41PRgQOCLHGOqgZ+9vl0dcvgh atOvN7U5QHRM
p2PVhvtulsW5ABqpgZauAU8rOP2bPuHMyToDrKDFTOBQmwADWd0lsl/lthC2 XjhUCIVS4VAM
DBnXgKuCdjLPYtM4FQwQ0kK2ECkLHGIgZBbCtCD2gCHXOZQQJB2HQ1aejA2B END8nkd7cVkm
AdbsLUFFnTx/BlwpWYA7f64ENeC1F4Flpbw34b4Z3ntfzYSXcX0VOIwMLCI4 ZCuchGaDogI4
hNsEnwcbEnlBkQuHgs+fC4kKQJHTIur7/EeQ2Gk3S4FDRSGRwKE4HHr6T0+r g3/4ffXUL7cX
bSMbN32Czh8S55AAC4FWzV8D5CAiB87P//rzNgOIxs0Zp85cPr8oFJi9ZJ5a dd2lRfeTumv+
upNjXkHHPAEO0b/pRxx3pLru8evigEjgkMAhcQ61iRpolXAocAjxwsw9jbWV ZYBC4aIwJWMo
CQoVg0NxIBRBoaJwKIBC7mLbnKeFuCdgmBbuzQSDUkFQZgBUPuizGwCpQP+L y8opz2OUF1yV
AJASwFHJwKihsCgh4Jpq01+zcMYx6EyFQwaaGnncRElwiCERnYbwlls+C8Pl 92ISoZYHEhdA
Is4iCiBR0veOt91M4FAcDg0cP1BR9kBS65h9+YHfOUgNHDWkWeDQ2x/vViI5 BlID8RoYM3Wc
mnfxPPVq7tVWr7tevEtnDGV5Dw896nB14LcPyrRvlvuTfeS7o5JqoGyALgUO bX97h/rqN7+q
XvjohQgQCRxqE2BAHEGV6wjK+t62LjiU7BayF2waDvGCLoBDaYtAXii608k4 z8R1CTEQsk9d
55DPJRQteqMFsK+dLGlxbRbeRiEcctvFAjhUTmdQ40FQ6RAoBnrKCXha6r4C sNRwmJQBHJUD
GGWFRW7dBbDSrtEkUBTmElmQyPfZ8LqJssChAjcRIJHrHGI4VAQS6UwiO6g6 yBxKA0QxSCRw
KIJD1E72/R/+RyYwRJBI4JAsuCppwdUWX8sbf3obC7ivqa3/s7XVwyFuJ8ty nAUOyXdLljpp
r/s0Bxyif+NpGAVNKw3bywQOCRwS51CbqIHWAYeyQSG9YMtjX2sxlwUKuXCI FpJaTuuYDwrZ
zqG9WLhqBXlC6QveoK0saLfZi9NQsdacCAiFC++/Ag45i/NwpHza4j5ji1gi DCrqCMoOgUL4
01KwprU9boPgUcOAUWZ3UVotBXlGhXXoqdcQagYtZ1atMyjK8lnhTCL9+Qog UdpnMryOPsfV
pAgShc6hLJAoHwdE9B1TDA6FgKgO30cBINpb95AqSfXYH9pT/2DpUg+q3Wqj mj79RHXggQeq
Azp27KjWbV2nXsL/L9v/1+NcEe2o36FC1WE7RTvrAINs1UZwaPgZp6qzEBKb xTVE+yxdvVID
otlL56r7n32kcIw9/VWyTJkK7XURIK9bFsnFamAs3ENzL57bquHQY79+TEOs Yq+Fr9/4zKPa
OTRo1FBF21lvJ/vJ56U91EC5/l315QTa//5Tezm5hwQOiRMlq2NF9msdtdLi cEhPBMqwGKMF
WyCCQ3uxoNPytY24C8LgPDmHzAIyWEzarSop23v0dQEU0mHTdmtMwvZHuFzL gkK8bTmEbCC0
F1CIRYvyEAjZ2+6CPgMQahgMygaCNARqERDzNB63KdQCr6ckcFQEGHncRQ2C RZ76MzUZ1aje
9tWyp+b38OchbClL+NzQZ0vLfN7MZy+DQkBkINGehO8Ab6sZf5cEkIi/ZzJB ouD76z1AopLA
EIGkSoND9CMwS9YQ/3gkMHTAAQeEovOuOvXqUhZA1B5+8MtrlIVtQ2rg1kfv Vocje6g1t5YR
vCKIlfX1de7VVcMh/n6hbZ+y3p/sJ5+tSqqB5oJD9G89tYLe8dIdBhCJc6hN uEYE0LQOQNOS
70PLwaGHDRRipeUMWWBorw2GXDiUsiA0i8UACmV0DNHCdM8+I7NY5YVrChzC IpgWwqwIDmEh
jfH0WvaC2l1s4/wefVkKHGooEEp1BqXDoKZ1AnkgD3Jtd5egd7FvQ1TKY4T7 FkCpJgBK5QJG
DYVFCfVHtWnq0yOua65zfWrgaPwzEYBTHyiyP2PY5s9fUUhkh8jjc74nAESZ IJEFhwg479Hf
MRGMToVEwfeX/i6Dg6gkQFRJcOjh3z6s/7Kf1TVE+5FjKK55OB8XuYvK8UO2 kn7Yy2uRhWo5
a4Bayz7xyU+0ajjUdVA3dckNV2aGQ8tWn6PORCh1MZXzOMp9yeeyrdRAOf5N 1feRkjnEvwWG
joOj+IqzBA5JO5WAsTZUAy0Ch2qxiNIqAoecBRot2szCLXANMRwqAoXMQjFw DHkmkbnOBBsK
7SH3gguGXOdQ4IqwF8ARHLKgEC+aE4AQL7y9cIhHzCeAIXYH7cVo91AADHsT 9TSuS9YeXLcH
EKQ8egb3E+hPOE3Qblze1pT0WsLXq193mY4jvScp71n0fia870Ft2E6yRFcR 1xudWqDIrtFE
SBSDQ6b+/Z8NDyQqgEPm81cUEsVG3gMOYeogf+5TARF9d3jgkPmecSCRD2Bb 32F7+HstKySq
JDh003M36fH1pcAhd9+mHGWf+KP9IyxoRHIM2nkN/Ou//ava+nvkDlUjmLoV ipxNtz5yt9Rp
O69T+a4u8d+rhEEMzQmHzlg4U01cPFHgUBsCAy3pWJHHbh2upeaFQwYK0SLK LKRS4JAFhhgK
eeFQAhiiBaFRsEh0R9RbY+oZDsWhEDmGeGHquIYYDqVAoT3aLUGuCY9jKIBD 7kK7AA7ZC3QP
HPK1i7UcDLIAEAERBwC1NehTrufrhUcMyhoLjjLBokJQtIcdZI6rKAaKfLUH SJRes4GbyHbG
BfXPn4eikCgRDhWBRD44FANEKa1m1JpqAaLC75sUF5EDh0oCRJUEh1bfs1qd 3LNTg+DQll0/
CxxEmJr0/q+0bt10l/mrZFNnDsliSxbcUgPa9ffYrx5rlWCIYBW1rD79+vMl 1+rzv9mplq0y
LiKGS6uvvbTk+xEoUSKUkM9U66ixVgCHLli3WvUe2VvgkMAhcQ61oRpoPjgU B0OJcCjBLWQv
2GJZQx445EIh7SJIgUMaClktZDYU8jqHqB3GaR+LFr0GCoVwyJPJkrbA3oNM IdJe3+Icl3nz
g6x2sTgcaipnULITqFxQpej9/BEuo6ZQM7qXYuCoHMAoIywK4ZDdZuiCoqT6 C+ozFRL5at76
TCSBIp3RRZ8tCxD5PoteJ1ESHAo++7aLqMBJZOeWBW1lhYAowUXkgUMR/C7S ZlZJcGjZ+mWq
34iBJcMhGmVv5w49gGBqEl1GYbICh2RRJgvzpq+BSoRDBIHs3CECRFRLdBlN MyNwJLXV9LUl
x7gFj7HAofSBHNbwDhrmsfGdjXrCh7hXWod7Rd6HlnsfmgUOWW4hXjh54ZCT LeQu0ELnkL2Y
s+BQDAqRY4gXhilwqBgUisGhICNlD04LHRBxKLQHE8lIdr7QHiyatYLcltgp L7oT4NAeAkM2
HErID0pqFWtcm5i/JawowCkFtJQEep4FGGpKlQCeSnmNGfYtKzBKaEHbg1ZD I0+4NUMirjcH
EjG8DE99tRzUebz2zefBBqdeSGTnEOnMoci9V7gdZIIR2C0GhzyQKJxo5oTa 78mZ9lWfCsKq
U+BQURdRe4dDlDdEEIinlVEYNYEhcgydPn2iuQ4LunIAImkra8EFirgIWj2E qDQ4RC4hDZhH
YlrZ049qGMRwiJxEBIg69+za6t8XASvyvdWoGhA4JHCoDblVBAa1HAxyj33T wqFCt5AXDgUj
6nnhlbQw04s2KDahLGwfi7eQuWDIdQ7RYjLMMUldgGJx+jHayggI2QqdQ34o ZMOhEAq5cMgB
QvbCm5xDIRCywZAXCkVh0jYcKgBCCG3ek0lBWxiAzZ5AjXbpfADgkirAng/i ehfnW5Pc5xed
T3ltJUGvQijFx1+fxlr1MryXdtaRBYoiOGSHkDugiCCRU4OmJo2zzSsGRVzn sdMADgXQNBES
WZ8x85lLg0NWq5kDiHyf//AybjUNvjvciYf8PVMqILK/2+Lfc+Qg8riI2jsc 4jH29vQyhkME
iMg5RIs6gUOyQGrUAkngVFEIUmlwiMCPDX9sOES1xIBI6kq+Wyq6BgQOCRwS OCTtbA2ogaaD
Q+lgKHQOcchr4BoqBoZcOJTUQpYEhzQUIuk2sgwLTyxOd9MCtQAOpUMhgkO7 9UI4cAvZp2kL
bFy3W19vLc7tlp8QDiVNF0sJP04EQ2WEQYkAqHWDn3JBqEKAlACOGgiN/LAo ARQlBGHT5Dk/
ILLcRO6Us6AeTW0Wkafm6bNgPg9FIJHzOTOfvUBpn9f9Zuy9lv6MFzoHCy5j SORzDgUgOhkQ
BW1m/P0FB1ESHEp0ELVnOLTtrZf12Pr74RRKgkM0uYz+wi9wSBZwFb2AawXw qtLgEH1vsFOI
aseFQ+QmImcRnUptyfdLxdaAwCGBQw0AA+LgaT0OnpZ6L5oGDhUHQ3rBZE// SWjj0IszXqg5
zqE9WNTZgdPFF4TB4lEvIouAoWBBSovTOBzC4vZjCwx5Fry8EC6AQzrQN3lh TQtvljdbCNOm
fIt6PWb+f41SJ2PF4FAcCDXIGZQBBDUKurwP51BrUiOcTJmgUQOAUSosSoJD Qa3omkkCRVRr
LiDCebtGE0ER17kFiezPRCokos+WlnHq8ecvhERJgEjDoQgQ7c4ChziwOgeQ RN8lASRyv29S
28ys77A0OOTNIWrPcIiAEMGhWzbdKXCoFcCBil0cybHNBD8YDr1W/ZpqjSo1 kJpgELWmcl0n
waEndj6T6fjI50MAUpusAYFDAocEDolzqAE1UH44lA0M7amJ4NCemoSMDwcK RYs2s5DbQ4s6
T7aQC4looagXiwyFeCHpW2g6UCiCQ7xoteCQA4bcBXAIh3ix7IFD7mJ794cA RFB8YU4L9UDW
Yt6GQtngUNQmRlChZCDkhUGRI6hkENSawE+5nksJACkOjDwOoxLfowJQlDAN jWsldupCIq43
BxJxfaZCIrfeAYn8nw2PkyiEQ+ZzZsOhVBdRCIcMJNq9H595UhZIRN8hGhAx JCoE0omACN9d
DLnpO00rIWMtDojw/dfe4dChHQ5TJJ9ziNrLCB516tVFnEMCOGQB38Q1UGlw iLKGyD3EziAX
DtF5ur5NLvibuBbkmFQQCBM4JHCoAWCgpdwq8ritx7FUVjhUZFEULpqCRRQt qjQY8sGhBDC0
W18eLOSygqFgoWicBZZcOBS4hNwF6W7tYrDgEE1essCQb+GrL9MZLIFbyD61 HELhIjuAQnE4
ZEEhCw55F/eJziErTLpE2ODPCDIwKDMIKhd0se7nD+8/p5pSTeJWynjMUoFR Ce9fLKPIgURp
9RO6iWJwiOsQziGnTr2QyFPz9FlI+pzEWs3os2V91uizV/h59LSaFcChzdkB UdheZr5XzHdM
RkAUfH+Z77IADmUFRPUGEO2pf7B0qQfVbrVRTZ9+oh6ucUDHjh3Vuq3rMG/j JWv+xsvpP4zq
zfU76ndEqsN2inbW7VQx1eI81JBpZevuvF63dhAgGjd9goZB9Nd+Em2THt/1 tMAhWQzKIr6J
a6DS4BBNIiP4Q9LfJ0EANbWaERii7x0ZaV9BEKSJPx9tFpgJHBI4JHBInEMN qIGywSEErhb7
i3ls8aQXUgEYcuFQChjabTuGisAh7RhiB4HrGrLbyhLcQmZhahRrJQvgUCIU CsCQDw7txsI5
tqB2F9v6PI2sj4Oh3Tjvcwq5C33TVhafLhZOFSsCF/ZgAtgeQIy4nsP55wCE MgjQZncj9O77
29BGllHvYb+mUNbHD/ZrzOvNckzp2Bs574ue1lbE/RVMRwuDrIO6KAqHgnYz qrnCOiRAVAQS
JcEhAkTFIJE98l47h6LPYKqLyAuHCBBlgERhQDXDoU0aECVCIrsF1v4OKxUQ UUg1AFG7hUPk
GCJARHDIHmdvgNHhZnLZx++WRTKtTBaCbXaB1wwL30qDQ/ReU8sYhVLb4+zp u4XOCxiS74N2
8X0gcEjgUAPAgDh4Wo+Dp6Xei7LAIQJDxeCQ/Vd1bO+2XUM2HCoChjQcshdz nrYRFwqZBWKQ
M+Q6hzKAIQ2H7EUrttPcQnoBHMh2DmkwxHAoAQqZhXcEh0IoRLlCVraQf4FP wcTRVKuCUfNJ
MCFoF4sAREYg1AAQlAp/mgL2NOV9poCkBkGjIgAuAkUGFoXOrqT3NYBDdh1Q fexG9tRuQESj
KK/KbTPT9UayIBHXpxcQUU2TK47r3IJE9mciFRC5n7MYHEpxEaXCoSKAyP4+ wTZ9xxilACIe
d2/BIfOdVoKDSE8wIzjUAPdQJTiHuJ2MTrfs+pmGQSTtFsK0Mi2BQ+KaaQY4 0i4WiinHsRLh
EL+n5CKi9jJWe3+v5fW3IzAmcEjgkMAhcQ41oAYaDYfqsLApBoc8YMgLhzxg iBdo4YJNj58O
soY8zqEkMOSFQ942MtupgG2MrCcxHNpNYMgHhywg5MIhe7GsF88FYIjdGPZp sDDnBXoiHAoW
+bTg16LFf4JsiFCQH0TOlCLuoBJhUCIIakpg0xruOwEalQyMUt4P815x3pOV V2S/xwl18G5Y
KymQyK27ABLF4VCKi8gBRAVwKMlFFHy+os9b8BksAonCyYMBJGIgHD9NyCFy 4RC+Y3aTLEiU
2GbmwKGSABF/b9J3aKmAqNLgEAGiEAgxGBI4JGBIwFCz1EAlwyGBIe0Ihsj3 Rfz7QuCQwKEG
gIGWcqvI47Yex1Kj4BAWNbuLwaEEMFQAhzKCIVq0JcGhNDAUg0NB1pAvWyjW xhKAIYZDIRhy
4VACGHpXX245KThrKIRDhVDoXbiG3sW4+tC1kQiH4lCIFvxm0V8EDsWgUDw/ yNvmVAIQ8sKg
FoA1f8BjFlOTtKSlvVYPMCoJFnlAEec+eSERvc8pcCiqlwAquk4iHxzCZVSb VKOpkMjO1Arq
33wWEhSMudduPIavgYOI4aw+TQNEdn6YDqTmljL31AOIkuBQFkBELWYBIKLv NFYmB1EAh8x3
aImAqFLgEE0rm710bqB5OI1r6eqVZXEPSVuZLBAFEiTXgIZDbz6mXqvCtLJW qFKnldF7TY4h
yhhKk9SEfC9UdA0IHBI4JHBInEMNqIGGwyGzoEmFQylgKAaHPOPqfY4h/df8 BDhUDAyFcIjB
EE7jcMjvGIoWp/GFKwdOJy14aTEcwiE3gDrIFXIX2HrhHSgZDvmhUCocYjeJ BkPJgdIhHHKB
0HtwqXjkBSx7kQVUJv0B9/OHPT5tx+VNLedxy/SaYsfGgUm+Y+wFSAEo8oWC x0ARv+8OJOJa
sU+N68xyEqXBIa7TJEjk1jsAUfR5KAKJLDhEoOhdC9CGn0VfDhF9ngORiygZ Dlk5RNySmgaH
igEizh8CILLhUCYHkQWHIkCUMZy6EuAQQSHOGuIAavdUppXJ4q2iF2+txOlQ aXDo1kfuDrOG
OJjadyq1Jd8vFV0DAocEDjUADIiDp/U4eFrqvWgYHIrAUCIcKgKGQjjEiyvL OZQGhnxwKAsY
0nDIWkDqhWTYVmaBIWcxSotTs0B14FCKW4gXwhoOFUwmS3YLpcMhLNz/zK1j xiXkX+RbjpFY
Fk2RKWOYBpboZLHAUAEQaiQ0KQRATQ19ynX/Fjxq5DHQwMjjOtKwKMW5paeq JUxB05DIDa0O
IFFS7cTazajWtOLtjXaNhiDThUR/QY07df/uXwwsLQqJPHCoOCDC59P9bO9L cg7Zlwej7ovB
oTRAZIVTu3CoKCBy4FBJgKgS4BCBIAqjprwhaSuTRVpFL9JaCQRKOsaVBoc4 iPqaOzY0S1ue
1K58f7XKGhA4JHBI4JA4hxpQA6XDoTgYygKHfIsmvXCyp/4EcKgYGHLhUFYw tJsWiwVwKN0t
xGCoAA79ze9+sBe/ejEMRYtkWjAHChbT3ELmXXDHFuWRoyNtYR+2lblQCJDg XZIPJFgj4pNA
RLmAUBwElQvStLb7iaBRoxxUDItSpqJpOMTyvbfB++5ComI1pOuI28wcSOSr 1YJWM65zCxLx
56EoIKLPlgWI4p/BKAOsoM1sXxwQvas/7xkBURY4lASIbDiUj9rK4i1m1oh7 e8x9IhzKEFDd
1uEQASFyDa1af4kGQwKHZHHVKhdXrRzqlOuYVRocIpfQoJFDBQy1k/ot1+eg 4u5H4JDAoQaA
gZZyq8jjth7HUmlwqBAMeeGQ5RpKAkO7sZBy4VAWMGTDod00WcgaVZ/YSoJF olksRq0nu2kx
abenJDiGCpxDtHj1wCEfGIrgkAWGaMFMuUJBtlDSYts4NiwohMX6u6QEx5C+ /I/YPwRDxjmi
oZAPDtlgIdi24VAsP4hARQPcMU0Kg3YDCjWFyt6u1khY5GQVxd8jCw75QJHz /jMkojrRSqul
oN7ikCjIHLLaH9361a2SMThkXEQhHHIcRAVZRPz5CiCRDYdSHUQaDkWAiD7v mQER2svou4Sz
zLh91XvqhlRngEPGQWQBolpskzxwKHP+UFuHQwSDyDlEmUMChwQMVdyirI0t yisNDh161OHq
9OkTBQ61sTqU74Ey/1sgcEjgkMAhcQ41oAaKwaF39t+jrrp1jho8+iTV4fj/ Uj8+8uAwJoLj
IuT0ADkmMAFIHcgx8NXA33/279VRxxyiNWXmULVxy+UGFvnazGw4hG0XDiUC ohAOGUDEcCgT
IKoCOLYAUVY4RDDbBtwEvLWsYOpEB1EKHMoEiCoBDlGe0MBRQ9o8HHrnoz1K JMegLdfA1xBI
vfnNzer1qtdbpSiQ+pnXX8j8OTtzyXydOdSW3xN57u37O6UsoEzgkMChBoAB cfC0HgdPS70X
SXDozT/frmYvGar+/rN/p7405PPqBxu+pQ598mB1+Lb/UKfUH+7oCJzPqDrs l6gjcV2JqsX+
Jeko7G+pBtvlUB73U6AOuKyhOhq3jasTznfKHaPV2VGX3LGK1DXUcdg26saq xnag7jg1Ot5S
R2x3VD1KVVVH1bPqBK0e2G6IuuN2hTpedasqVFfsG+l4bB+vuljqXHWcstUJ 542OVadk0jHY
rxlVjcdqkFAf1SnK4bqGyqm9qBZLr+cTPjhcHbrlB1rfXfkN9ZkjPqW+/o0v qetuWV4IiFw4
hAlmmQBRDA4hJyxwDmVyEGk4FAGiVDjktpe5zqFSAFGCc4jgUNH8oUqAQ+Qa IvcQQSIzsaxt
TiuTRVz7XsRVwvtfaXDoyZ3PKnIPkQgUJakS3jt5DZX5/SNwaKfaWRfXjrod KlX1uD7Qy/Uv
p4Mhut76/yX1ktr4zkZ14IEHYj0ucECOQfuuAR8cenDbxeqfD/6k+taSr6qT qg5VpygXBjUF
HCoRCjFEapVgqPQFdCdAJII/nUMdo7rkAXygrqHisKc7oE/3HOBOoB44ZfXM Adi4AvTpFdMJ
OH+C6h3qRGwnqw+uC1WF7aqTMoj2i9Qb21nUC/dtdGKontj2qYeGUicALtnq CLAUKQkmFUKk
YgCpiaFRSZCobcChQkB6lDrmNz9WX+z1Oe0m+uX/bIyCqn1wKAsgohZRCxC9 67iHUh1ENhyC
g+jdYCpiJgdREhzKkj8UuIcYBrmnqePtKwEOERgqZjekxd1bH7/baDXlKHtZ nFXm4qw9va+V
Bofoe6PYd4s4i+Rz25o/4wKHBA4JoGnfgKYl338XDi1bPU79S8dPq+P3/shA oaJgiEBRC7mG
CBC1NBzK6BbSrh8L/nTJE/w5BuCHdazqBghE6q4F6AP1CNQzD9hDCoBPL5wa Ae446oPzfXIn
qr6uAHf6BupXfZJy1b/6ZBXXKTjvqArnLQ3Atk/2PsnbeLwqUnSf/bDtqi/2 8akPLjc6CcAp
LgZLLkxikGTDJIZINkBiJ1I2eNREwKgoKGqrcIjgqXHakZvoUz/8Z/XYs9cY QJQEh4oBIs4P
CwCRgUPx9rJEQBTCIeMeerdqU3ZAlN+EVjLTXha2lWV1DxWBQ6ntZZUAh+5/ 9hFl6wGcd/X4
rqcbDYYILgkckoVga14ItvRzqzQ4RM6hjU9vKqqWPu7y+PK9lFQDAocEDrUk HJDHbt9gyoZD
azbM0C1koVuonHCo3O1krcE55IAh1/0TB0Au/IHrJ38c4I9RT0AgVi9s98oD +gTqg9M+ebhv
PMCnXw6QB+ofCrAld7Ia4Gggzg8E6HE1CJdF6oTtTmpwdee4qnC+rOqC+4tr EO7f1kCcL1Qn
XNYJMCpSP2wbGajU11IEjwxE6q3FjiRz2lMr7kgqdCK5DiTTxuaCo6hlrYyw KBUQNSEconY0
b2tZ6a645NZKA4jIRUSAaPurt2o4ZAOidwkK2UJwvDek2g6XByCK4JAnf8id YhaDQwiyJjiU
BRBROHUAhwgQFcChYvlDQTB1knOo4uEQB1G39UBqWeDJAq+t10ClwaG2/n7I 85fvFIFDAocE
0LRvQNOS7z/Doc0716rPHPn/GgCGMjqHypkzZOcStYBzqBMyiggEdQ7UBYvo yAVku38iABQH
P8cD/HQM1QfbBID6WuqXB/SB+msVAp+BOYCeQINwyhqcA9yxNATbRp3VEECf oQkahsuHVXeB
uhZoeFVX1Xh1w30YDUtUVzUUj+VqCC4jDdaKoNIgbNtimDQAYClSJziTIvlA EkMkA49ODtrZ
/PDIBUdx11GUfcTgyGQdNQIWtSQc8gKicsKhyEF05M//W/34sP9Qb30AMGMB ogI4lOQgsuEQ
tpPgUOgesgFRARwqwT2k4ZBxD3nhUFp7WQY4lAiI2qJziDKGKFvolfff1CHU JmfIlmQOyaJQ
FoUtUQNtHQ69/t5vdK7QbY/crUOol606JzVriDOIWuJYy2PKZzxLDQgcEjjU knBAHrt9gymG
Qz845FvqyJ3/GbWSZXYNZYBDTeUaaoa2MgJBnWsAgqAuNYBAUFeoG9rBSN21 Ch1Axv1jAyBy
/0QAqB+cQKT+WgYCDQg0EDBoYB7AJ1AS7BkK4GNrGM4PywHwQMMtnZrrqrQA flgjsB2pG7a7
qZHV3f2qwuUejcJl6eqB25WmU7H/qbhfW8Nx3lYIl/YDNEFDQwEi7Y9r8H7A JGiQpYH74UqC
BoQCPNpvAFJxeGSgkXEgmTwkdh7Fc4+M28i0qrHT6Fi4jY7VwdiZgVFLw6EC QFRuOBQBom8t
/pqaNX9UCIcMJHKcQ3zedRClwqEi7WVJcKgk9xCgFreTuadJ08sYDtWaAOri DqIH1Z76QG0R
DhEIohwQaiXjUfbFckEkc0gWUlkWUrJP4+qkrcMhaiGj7xKCPlQLkjnUuHqQ z1PLHz+BQwKH
BNC0b0DTku8/waHDj/iW+sroLzQQDDUGDjUwhLqJnEOJIKgGIAjqXoMsIKgH 1FO3gh0HAHSc
4wJKBkAR/DkJ8OdkwB+jwYBArCHYHpLvpIbmAX5IxYAPoM8ILcAdR6NwflQO AAcaDfDj05jq
HipST2z3VGNdVeGyRPXCda56ey7z7ddLjcFtR3s0Co8Xaj+2LY3ENmnE/h4x nYrzp+4HWIKG
WyKAxDIgKR0geeGRBY64dc12HNm5R27eUQSNbGB0HFrTaKpaEWDUGDhEk8wa Oq3MdzvdZtYU
cMgAopP+doT6p29+Qu389d0WIGogHPqYM4fsU7SMBVPMdpNziN1DXjiU0T0U tpalwKEk91DJ
cOihtg2HyDHEYIjgULvIHPobFhkiOQatvAY0HHoDo+z3Y5R9K5QeZf8aRtmn HEcCRK/v/Y3e
58kdGTOHWvn7It8dFf79CZApmUOAQLUJkmllB7QkIJDHbr9wiuDQ57/w/9Th 2zGint1CJbmG
isChpnQNNdI51MnnCPKBoBqAIKgX1LsGLWFQHziD+sIZRK1grgso7gDyA6Ch GgAZDQMEIg0P
dGq+izo1z9Cnawz6MPAZTcDH0pgcIE+gsTiN1FOdBtjDGoftSL2wbXQadHp1 7wKNr+6jxlf5
dTouJ5nr+2bW6dh3HG7j02n7+6hIvbEdaSy2WWOwPWY/4FKg0Tgl2RCJtn0g iSESA6Q0eDQY
IMl2HoXgSLeuFbarGXBkArTtsOxkYHR86CzqCljkAqO0Efcnp42xt68rFyBq YjhEgMh1D/0h
yTnktpdRK5nlHnqX4FABIIrgUCycOg0OFXMPERwKANG7aC0ryT1U+4jaA0C0 m5xDRdxDBZPL
2qJzyM0YaheZQ7L4FDDUBmqgEuCQgJQKBylt4HNUcg0KHEoGQwSMBA4JHFLt F9C0JJzr2rWr
+ruv/J9GgKG2A4c61aI9DOpSi/YwqGsIgowrSDuCfCAIMKhvDUAQ1K8GMAjq DyiUBoEiBxAD
IAOB4gCoixoBEDQSIIg1Ctuj8t284CcGfHIAPtC4UIA8OQCeQONzvZUWgA9p Qkx91ERAH9YE
bJMmVvfVmqTVL1IVti1NdM5Pruqv0jQJ15MmetVPTdzfT01I0HhcbgT4BJ3u aBxgEsuFSj6Q
5INIBiBFLqQkeESuI7ttLYRGyD6K5x1FLWo0ic0EZScDI+Ms6qhlMowMMNKw qBruomq4i6BO
kA2LToarqPkBUVM5h4x76PBn/1NnD/HkMoJDiYDIbi0L4BADIj8cSmgvS4RD gXsIgChxrH1W
OORzD5UAhwqyh9oDHKJJZevuuL5tTyurxAWNvKaKA17tDQ698Oudas21l1Xc +1gynJDPcsvW
gMAhgUMCPwSAtcIaOOIItHJ0/semgUOprqEj1Cl2e1hDt1MCqTvVIi8I6qKB UAfVtRbtYVB3
LRcGBY4gcgW5IAgwaEDNiVoDa9ASBg1CPpDdCha5gDqFAIhAELmACACN8AEg gkDQmHx3rbGB
ToPzxwU/BdAH4GdCKICdXKRJ2J6UM5BnsqMpgD6F6o/L+qupoQZge4CaxqrC dqCpOHU1rWog
rk/WVFxXoP24DJqiNaBAk3GZq0n7AZksTcS2Dyz5YJIPIGWBR277mt2yZreq MTTi0GwOyiZo
ROHYPGXNhGPHgVE8v+gExbCoBwOjaoAirTgsOgWwqCGA6ORGOYmaEg7hvpHx 9YlP/qN6630T
TJ0Kh2z3UBIcaoB76F09zp5VZHIZwyGcGudQCe4hwKHdWoFzqBT3UCXAoS27 fqYO7XCYOvA7
B3lFGSJtPnNIFl8tu/iS45/p+FciHOrcs6s68Nv4bkmRwBRxG7VoDQgcEjjU CsFASzpW5LFb
h1Pqhz/8ofrnYZ+oCDjUCaCIYBADoa5wB3WDumsdo3oACPWsRYsY1KvWD4P6 kyvIBUGAQYNr
kA0EDYGG1pwStINFIMi0gsWdQNoBZMkGQGPzAEDQOK2e6vRA4+H8MWL444If QB+An8mBpuQA
eyxNxbYWQM80S2dg+wzAHtb0cHsgLjOaUT2oUFW4DJoeiLZdzawarHyagctt Tcf56fsjzcC2
q+n7B6kzHE3DeSMAqAAqEViaisumaDFkGgigZDQJcIk1EdsEkiZYYkfS6XAl sQggGfdRYfua
7TgaHeYfIWwbjiMSQ6MQGGEiW/KUNYJFpi2N1C90FZ2EVrR42HUvuIp6Qj2q O2p1h7oFsMi4
ijANLXAUZXIRAQwRHGo4IALAyTUhIAIcotwhPdb+rxEcKtpeZsEhcg+FzqEi 2UO6vWw/ZLmH
4nCoSPZQM8Ih7R6qD3KHKgEOderVRYfIDhw1RIsg0eyl8xRdzsCI3ENvffxu o/X2x7uVVx/h
8kYqNbxV4EQmONGiCzR5j1SlwaEzz56vv1sIEJ1+xiS9TaeDRw4NYdG1t98g tSm137I1IHBI
4JDAIXEOtcIa+O53v6s+M/v/tlk4ZLuDump3EAMhgkHHAAQREDoWMAh5QQBC fbTQIgbp9rAU
GEQgaAiBIGgYNLwGMAg6tSYdBMVcQEkQKA8ABE3Q6q0mBiLXz2QtA4AY/ITQ JwfoE+gMnJ6R
A/CBplunMzToMZoZapCaBfjDmontmdWDcZ41RM2uNjqTVYVtaHYRzakapmzN rhqK2zjaj/OO
zsR51ixsRxqC7SFqZoGGAiYN0Zru6AyAJtY0bDNQIoBkIJIBSFng0XhAJIJH BhohHyloXbPB
kZ15xLCosD3NTFnj6WpDA2A0tAqB2GhFGxwochWdEriKuAXNwCIDjE5Uvasx Ha0asAgiUNSt
ABRR+9kxWp1S8ogYDjUMEAVwqKkAEXLA/uX4T6u7Hl5t4NBfTVtZo+BQMfdQ FjiUlD1UChxy
W8tKdA5FrWWYWFYJcMjAoLl6ctm2t17WQEjDoH3vqgcw0YzOS1uZ/GVfwFHT 1wDBoS1vbFG/
3P/LVqmv4vkVC6S264QchwSG+DJyDy27+JzwPF1PsEhqq+lrS45xyjEWOCRw qBWCAXHvtA73
Tku+DwceeKD67NJ/jsOhesoRKkVoEat3VLSlrOFtZZ3q4A6CutQRDOqg3UHG IRQBoV4AQr01
EDpOA6G+UL9awCAttIhBYYtY4AxKhkGd1YiazmokoBBpVE3kCCoGgggAMQQK ARBA0KQ8AFCg
KXlAIGgqYBBpGpw/BIAY/hD4Yc3IAfpAMwPNygH4QDOD09m5wQA8gwF44poD 4BPXUJxnDVNz
q4epebYAfOZD87SGp2p+1anY12ieT/txeUy4v/1Gcx3NwXkjAKdwezggUqTZ uI41C9tGQwGT
Is3AtguRkuCR7T6yXUfGcTQgdBxxuxrnHrlOIwZGdjC2BkZVyDOCToUIFhlh ghoUgaLOahDc
RCQfLDLuopNU32rAIkAiAkUGEhkZR1FH3XpmdCzyigws6qQnnmHSWCByGLVa 91AKHErNHnKc
Q3/gQGpvMHU8e0g7hyxA5HUOZYFDOW4ry9haFsIhK5Q6a2tZW4dD1FJmj7Xn 0far1l+q4RDp
9OkTtYtInEOygJMFZtPWQKXBIYJB5B7iuiEYRK4hPn/bw3drB5HUVdPWlRzf IsdX4JDAIYFD
4hxqhTXQeDjkAUMEisoMh2JAqA4wCIraxYxDyA+EOgIGdQQMQm4QAaFa5AVB g2tNi5jfGeTC
oK5qdI3RGIChsTXddUuY2xbmB0EeCEQgKA8ABJ0Rqj8AUH+AnwFe+EMAaLYW oI+lOTm4eyA6
Jc0F8JlnaT625wP6kBYEp2b71AItxGWkswB4SAu1RoQ6C9s+LaoaqUhn+bQf l1taiO1IuO/9
RgtiGonzRvNxOWsetiOdCrAUaQ62GSYxSCqESMnwyAVHPsdR1KYWZR1lBkZV mKRW1VPLhkWn
hqCoawiKjKuoEBYNQFYR5RX1rz5Z9YP6ABT1hnppUBTBou5oOyN1SwBFNhxq de4hDYc+43UO
pbqHGgGH3i0Kh1Jay2znUAPh0Lv2xLL2AocYBtmj7Q/tcLhuK2M4pN1DWMAJ HJIFnCwym7YG
Kg0OEQyy4RC5hOgyu47ou2Xj05sEEElrWcvVgMAhgUOtEAy0pGNFHrt1uJZa MxyKAyE4hAgI
acEhBEXtYuQOOk67g4xDiIAQwaATAINIJwIInWiAEDS0Fq1i0LCwTawYDOqm TiMgBI2rQT4Q
lAUETdUQCE6gGAgCBMoDAuUBgaCZWgPh/jGarRUBoBD6EPiB5uUAf6D5WoA+ lhZUDwfcMTor
1KlqEYAP6yy9PQIC0IEWWzob21qAPEajimoJ9llaNVotcXQ2zmvtT9fi/aNU pNHYNloU0ygA
pkgLsc2AiSGSDZJsiMQAKQ0euc4jn+OIW9XsnCMKzOaAbDsc2wZGobuoCjlG 0BitXmp0AItG
a1jUHc6i7nAWGUeRcRVFsMi0nzEs6mScRdUItdaCo8gBRab1rKNWDw8oIieR dhO1xuwhHxzK
0lpWDA6ltZZlhUM+91CpcMhuLQucQ6XAoTB3qK07hxgOUdYQj7QnlxABIoZD S1evFDgkC7eW
W7i1o2NfaXCIWspsGEQtZbZT6Mkdz2rnosChpoWOAnXFOXTButWq98jealfN LrWrNq6dNK4+
TTLKXlw1As9apAZaGxxygVBXdgkxEKqDQwjqXRcHQuQOioAQwyByCJ0UAKGT 1TAAoeG1yA2C
Tq0lIMRtYl0cZ5ANg3oABvVQ4wkIQRNqeqmJNSYjiFvDwrawDCBoFoEgaHZ+ kDrT0hwAobla
hQBoAQAQaWEO4CfQWTg9KweHT6BFOCXosxg629ISwJ5CAehUj45pGc4vJ1WN 0VpmiS9LPh2L
2yRoPy73aBku82kpLre1ZN9YtWTfmFBnY5u1eB9AUqBFOF20DwDJ0kJsL9wH B5Kl+fvgPgoF
59E+OI600LYWaPY+tK1Bs7TgNoLcNjVyGhlgFJ+65gKjCcgtIo2v6qtOh8ZV IfBay4ZFPQGL
yFWEcGvdgsawqBAUDQUoGgJQNLga7WfVBIkMKOpfAIqo9ewErV4OKAqnnuWO VZ1yBIkMKMqi
yGnURMHUReBQonuoPcEhCqauBDhEeUO0QCMoRICIWsro/KBRCCiDg4gyh6St TBZvssBs+hqo
NDhEbWM87ZDG1pMIDhE0IkcRgSNpK2v6upLPrsAhgUOtwwkijhx5H0qpgQI4 VFLWEOUSNTRv
KMoc6oQx9pQhFOYIpQAhDYXq4BCC4g6hOBAaqh1CDIROAQzqpEYACI2sBRCC RtXabWJBq5h2
BnV3YFBPwCACQr3UJEChyTV91JSaICMogEGmNazQEeQDQXPygxVpLjQvDxAE zc8bJ9ACLQJB
BgIRANLQJ9DiHMCPpSU5uHsgOtWqHqWWBVqOUw17oBWBzPbYmFbiPOuc6tPU OVWnqXMhOk0T
7RNpHLZPD0TblvaPU+cU1elq5X7SuJhW7BunWMv3naZYy7AdCTAJAInEEMkH kFx45IIjgkYR
OCqERhoYOflGETAyE9hoyhoFYdMkNROAPQAB2IG7qAqtaNCEKsAiKA6LegMW 9YKzqBdcRREo
MrCoEBQNh6toGEGiajiKAIkGeUHRSXAVUUbRiUFGEUEi4ygyYdZB21nuONUF kIjUGZDIwKJk
UFQAh8odTN1QOPTRE5hQRlPKjChzKHPuEDuHgtyhwsyhoK0si3MobC17BGPt MabepxpcToo5
h0rMHVIPqd1qo5o+/URF3+EHdOzYUa3buk69hP9ftv+vx7ki2lG/Q4Wqw3aK djp/yeO/+i1b
v0z1GzEwdAGxG6jYKQEiGmdP+5FjiCeY0cIuDKiWaWXinmlHLp6WWFBXGhyi Y0jTyAgCkUuI
zhMUIiCkv1twuubay+RzJZ+rlq0BaSsT55A4Y1rEGVMKKGmP+7YkHEpqG9Mt Y3AHkXoBBsWA
UB0cQlBhy5jrEGIg1AkwiKBQZwOEoDG1gEFQ1CoWuYMmwB0Uh0G9AYMICPVR U6FpNQBBpAIY
xI6gyBWUCIIAgxZAC/NwA0FnAQgt0iBouFqsQVAEgRj8LAX8WZoD/Am0PAfw Y2lF9RhAnzEA
PWPUOYHOBfhhnRNuA9xUj1PnOTq/+nR1AQAP6fxAfD46HY/rfZqAyxO0H5fH hNvvj3Q+rnN1
Hq7X2md0bqjT1Tn7Iq3E9koLIBFIKgRIfnjkuo7YceSDRsZpZPKNuD2Nco3s UGyerDYDkIhA
UQEsqgIsqgIsgiYBEpEmhqCoD1xFRuPgKLJBkQ2LXFfRsGpAImgoIFEhKDLZ REYGEhlQFIdE
3XOARFoIsQ5AEUEiA4oKIVE8o6gJ3EMhHFoTTSuz2sqSQ6mbGg4l5A65bWWl 5A4JHPpDDCZx
OxlNLKO8IX2+DGCI7kNG2YtLoCWgS1t5zK99A9PKfolpZfswrawVqtRpZUnH nRxE1EpGp23l
vZHnWcHfXQKHBA4JHBI41AproCXgkHEKHWmmjaW1jQEMaYdQAIT61yFHCBpY F7mEhqBtzDiE
Tka7GLWNnQKHkA2E0DIGp9AYQCENhGrhDtIqDoQMDEJmEERAaDo0owZZQZDO CdLtYXEYRI6g
ubYjyAVBgEGL8gBB0OL8qepsEoDQEgAhEkGgJSEAgvsHAGhFoJU5wB/oHC2A H4hO9TZcP6Tz
LV0AAES6MDi9gABQ9XicN7pIa0KoiwF4VkF0amtV1URcnqZJuD5B+3G5o4v3 T1SRJmF7krqo
QBPVhfsiXYBtI8Am6PxADJAiiOQCpEL3EbuOIseRcR2R48jXphYCIysk2+Qa MTCiSWrkLEI3
DGQmpw3RCmFRFZxFVXAWARJNDUBRBIv6BaCor3YUjY+BImo/I0dR5CoaDUcR uYpGVCOnqBqt
Z5CBRF01JIpAUSe4ik5B+9kpaD0zoIjcRDztjJxEvXKYdpaDm0gLQdYARAYU +d1ElQqH7FBq
v3NI4JB2FJXTOUSuoVfefzMERAyH+JRay6jFrByASOBQBS+wxP3QaNBRaXCI MoaotSwJrNB1
9qh7ATDy/dAiNSBwSOBQKwQD7dEpI6853nbXnHAogkJHAQpxwHQQLp3mEmIg BCg0uA4OISi5
bYwcQjYQ6gog1A0wiAQgBI2vRXYQZFrFeqFVjNrFjEOIgdAZMSDUX82s6a9m 1QAIQbNrTF4Q
t4clwaCzyBXkgiDAoCV5gCBoKbQsPxJuoJGAQASCRgUgqBACEQg6Lwf4Y+mC HOAPC+DnQugi
6GKt8VqrQgH8AAStqgbkgVaHmqTWVButBeAhrQlkzk8u0CW4LK4pOJ+g/bgc Wlsg3C8uW5Og
1bh89b7JapWji/cBJgW6CKckhkg2QIrDowmB+8h2HaGFzWlbM9CIW9Q8wAgh 2RyMTYHY9kQ1
AkXz4CaaC80BKCqARVUARdB0QCKSAUVoQQtBUX+4ishRFIGiCQmgaCxaz8hR NKoakAgaCUjk
B0WdAYoonyiCRAODSWem5QygKIdsIgAigkS9AIh6hpCI3URxSNRicKhYKHUj 28oEDnFrWTO2
lVHbmD2tzIVDFE5NbSECh2Th1iILt3YEnSoNDrnTytz6oellkjkk3yst/r0i cEjgkMAhcQ61
whpoDjhELiFSV+QKERTqrnV0kdYxyyVkQ6E6uITqjEPI5AgZl9AoKHIIsUuI gBAyhKDxgEIa
CNUCCEGTa/1AyLiDME0MmgmH0CxoNnQmoNCZgEJzauAMgkxWkMkL4haxNBhE IGgpgSBoeR4g
CFoBrcyPhhtoNNw/o7UTyCiCQAx/LgQEujAH+BPo4hzgjyUDfiYA+kwA6CFN VGsDXaJPAXqg
S6oBdixdWj1FkS6DLgfgIV1WNTWmy3E+XdPUFVVGl7vaj8s8ugyXXbb/jEC0 bXSppUv2TVW2
1uL82n0ASpZWY9uFSIXwaBLcRqTIdRRvWTPQyG1Toxa1GDDaj2Bs6GyIJ6pF sGgEYJHRfA2K
yFVEoCiARVVwFlXBVQTNBCQizQhB0UDtKJqGlrOp0BRAIhcUmYwibj/rjfYz ZBRVw01UjYwi
yEAi4yYiGTdRF5x2wWlnuIoIFHXSoMg4iUzbWb8cIBFEkCgCRT5IZLKJKJMo yiVqxrYygUOK
JpXpaWU6kLoNZg5te+tlnSPE4lwh+zL3egmklgVciy/g2gEkqgQ4xCHTdq4Q bfvEuUNSW/L9
0qI1IHBI4FArBAPiopHw6qaEQ8lQiDKFjtFZQiRqHSNRlhC1jg0MnELkEjJO IYRLMxQCGDq1
jsOlk11CERDqASBEUKgnoBCAEDSlFg4hyLSL9Q3axVwgRDBoIGDQIMAgEoAQ NL8GMAgK84JC
Z9Bw0yIWOINcGEQgiGHQOQBC5+bHaJ2XHws3kNEFgEIGBhVCoFUAQatzgD+B 1uB0bW6iWgPR
qQE/kwB6jC4DACJdrhXAHwJA1VPVFVqAOYGuxCnpKoCdq6vOwKlfdJ1f03F5 gvbjcktXYTuu
GTg/Q12Jy1lXYFtrH+kMdbmly7B92T6AJOjSQAyQDDyaGsIjFxzFoZFpWeNW NXIaJQGjMBR7
P2CRlpmoRqAogkWj1KL9mJYGRxFpoQOK5lXBVQTNASQ6MwBFBhYRKBoMUDQI jqJBcBQZUGQg
kR8UTQAkotazcdXIJ9LygSKCRN2grmg96xpAoi4aEhknUQCJcoBEOYJEDIrS IVEXK5fIZBIB
EOXLqBbKHBLnUDM5h1atv0QHUJP0NKFg25zCKWSJWsq2/3aHOIfaAZxo0QWa HF9VCXCIgqcJ
ENmQiM+7p9RSltZ2JvUo0KhZakDgkMAhgUPiHGqFNdAUcMhtH4ucQgyFaBT9 sUWhEAEh0nBy
CkEjAIVG1gEIQeQSIo0Ns4R8LiECQuQS6gUg1NsAoVoAIS3OEOKWMXIIJQGh IQBCQ9RCQKGz
apAZVBPPDOIWMdsZlAqDCAhBF+RPUxdCFwEIkS4GFGI3kAuBCABdogX4E+iy 3GRsAwKRNPiZ
AuAzBaBnqtZVga4m8BPo6moAHq3pap2jawF4rq2aoa4JRNuurquaqQo1C5cl aD8uD3Tt/pnK
1TW4LtJMtQ77hNo3U129b4bWVZauBDQiGXgUB0gMj3zgiB1HPmhkWtTSgBHc RXqi2ulqBaaq
kZbHYBGBotFwFY2Gq2iU1iIbFFXBVQTNr4KrCIqDoiEhJEoGRZGbaDJazybB STShGvlE1XAT
QQYU2ZCIWs66a43UkKhbCIlMgHUAiXKARABEA7SQS1QEEsXDqym4+mjVKQ9I VC5A1EJwaDdP
LKvarCRzqJmmlRVrK5NA6j3qd3/bK5Jj0OQ1QHDo8V8+rt7Y90arFAVSP/va i5mPA8GfOZhO
Jp8f+f5oyhpoNEASOCRwqBWCAXEOiXOonHCoUz3ax6AuQftYt6B9rIduITsG k8cYCpFb6LhE
p5ANhbRLyIZCdQiXrkPbGMRZQj6XEAGhCAr1BhTqY4AQNKMWQAiKt4xFLiHj ELKB0FAAIYJC
w9TiGriDoFhmUNAqlugMcmFQHjAIujh/uloFrc6TK2g8XEDjQzeQC4EIAF0O XZEDAIKu1AIE
CnRVzgCgdVpnqGssXQsIFGmGuq4agMfSemyvr56lNpAAea53RJcZzfbqhqoz la0NOB9qP7Zj
wn3sn62uj+lMnD9TrdearXUdaV+ka/fNUqRrtACQLPngEYMjdh3Z0CjuNDJt ajYwIoeRnWcU
uoswWY0nqZ0LSGRgkQFFKwCKlsNNZFxFBhTZsGhRFVxFVXAUQQSJSASJjKNo GBxFQ+EoQqA1
nESRm4jyiWxHkWk7m4q2M2o9m1SNfCKoEBIhxBqtZmPQZkYa7UCi4XrKGbmI AIlygEQARKRB
AEQGFCVDonhw9bEIrj5GdckDEgEQdSoHIGq1cGgToBFUvUnttpU4rUxG2Zc8 1t7NHBI4JHCo
KRd2ct8ROKg0OCTvrUCh5qgBgUOYKEpTRS39dl98CukF61ar3iN7q101u9Su 2rh21u4UOCRw
SJxDrbAGCuCQOlydUl+KjlCd6o8wUKgemUJQIRSiFrJjVR/dQnYcpo+ZFjKe PMbtY6lOIRsK
1cElBLlQaBJaxwqBEEGhvgBCDIWQI1QLl1Bt3CXkAqHIJURACC1j0BJAoaU1 CJGuodwgkx2U
BoRCZ5APBgEIrYHW5tEeBpEr6FJIu4AKQJCBQFdBVwMCkdZB1+TOwKnRNTkD gK6D1lfP0Lo+
0AbAH9L1+pQg0Gx1g6Mbq89UN5EAdn4K0Wlcc3B5kubiugTtx+WBbsKp0ZwC 3YjLSTfgOlsb
9s1RpOv3ASAFWo/T9RY4IojkA0dXB84jdh1FbiPTqpYEjCKHkQnEDmERJqpd iElrF0DnAxSR
CBYZUISA6wASFYIiwKIquIqgxYBEiwCIDChiN9FwCxK5oGhwrO1sOlrOdOtZ NVrOquEmguKQ
CNlE2knUS+s0QCIGRQyJjIsIU85ygEQ5QCItZBJ5IdFJQS4RtZvZwdXHY7rZ cap7HoBIiwFR
I11EIRxaXdoo+48fV+9a+sPHW3De0T6cDwWH0L5A7Bqi00TnUEY4lH9Uvav1 iNqdpBpcR4qN
skeGUG2gIFuIM4bcU5M59KDarTaq6dNPVPQdfkDHjh3Vuq3r1Ev4/2X7/3qc K6Id3FJGp80Y
SE0/Im/ZdKeiqWVG8wq0dPXKdt1W1hwLHHkMWUhXIhx68de7tHsoTVL7UvuN qQGBQwKHxGUj
LptKrIHGwqHQLaTBEIKmoR717BRKgkIdda7QoDBoOp4plOgUYihUh4DpOgqY NnlCSVBoegCF
ZgIMzYJTaDag0JmAQnNqkSFECnOECl1CcSDEUGiEWl4DIARRkDRnB52H7CBq E4taxdgZFHcH
xWBQHjAIuiyPfCDIuIImh44gHwgiGHQtINB1gdbnAIECXZ9j+DMT4GeWutHS TQBBcQHyVBvd
HGquuqV6rroVkId0iz6dl6rbcL3R/ETdun++StMt++cp1s3Y12ie1k8D3bRv nrppH6ASdGOg
GwCMSAYeJYMjFxolAaNUWEST06BV+wGLoIsBiS7SoAgB11rjAYrGAxSdHoIi A4tOixxFVXAU
VcUhEYEigkRnARIthItoATQfTqI0N1HYdlZNgAjZRBoSDXAgETKJAIjGo9Xs dA8kMq1myCTK
ARJBBImGAxAZUFQcEpnpZhRaDUCUJ0B0nOoWQKJGu4haEg4BDAkcakY4RECI cofSgqnbeyB1
YxYucltZ+GatgUqDQ7c/fI866Nvf0t8tdJqkrMdH9pPPkq8GBA4JHKpEMCCv SYBXQ+FQJ7iL
OsMxFLqFNBg62oChel8L2fFwCjEUOgFB0yeakfRu0DTyhChXaDScQiTdPuZC IYChiXWlQKH+
gEIDQig0rxZtY7X+tjFyCEUuoVPhEiIgNBJAaKRaCSh0DnRujQmT9gMhq1VM u4MCZxBOCQYx
ELo8DxgEXak1RV0FXa2dQVMDJxCBoAgGRRBohtoAEES6IQcIBJnT2Vo/BQj6 KRxANwe6Bae3
AADdGgrQpxrQB7ot0O3V8xXpjkB3AvbcWbVA3RGIttN0V9VCXJ+g/bjc0R04 H2mBun2/rYXq
Nlx/Gy4j3RroFkAj0s37WIBHgEYkGxwlQ6N4ixq1p3Frmt2Wxu4iDYv0NDUz Qe2S/Qi7htYA
EpFWAw6tgi6Gi+girQkBLCoERdpRVAVQBC0DJFoGSMSgiBxFiwGIjJuIIBG5 iVxIRCHW1HY2
xLSdVcNNBE2vRoC1FxL1hZuoL1rO+qDlrBASmVYzZBLlAIm0kEkEQHRqCIkw 3cxqNytsNTtB
u4h6AxD1yh+vekIGEh0bQKJGuIh8cOhvT6g/BHoXp14Vcw7FXEPkIPI4h4rB IbeljM67bWXF
nEPsGmqgc0i7huorxDlEmUMURL1l1890C5q0lRWGwMqiVBalzVEDlQaHKHOI gNC1t98guUOS
2dVkNSBwSOCQgBQBKZVYAw2BQ6aNjMAQxtPDMRS6hQgKQb3rfS1kBgwRFCIN BRgaFoRNx3OF
DBQyuULdAjBknEIkDYWgyXUcMs15Qn2QJ2TaxyKnEEOhgXAKDVQhFAIYWlhL 4dImS2gxVAiE
DBQiIGSgECaMQecBDJ1fY4VJ6+ygcVF2UAwI2TAI7qAQCAUwKA8YBK3Lo0UM uhatYgSEyBlE
MOh6yAVBBINuIggU6OYcQFAoA4FugwOIdLvWPECfSHcyAKoG8IHuql4Y6h5s h6o6S90L3WOJ
zvt0X9ViRbo31CJsB9qP00D34NQWXX631lmh7sI2yQAlOj0LIIm0EBDJyGwD HO0zugXAiGTA
EQMjA41sp5HtMqLWNM40Ct1FQRj21ZiexhPUzOQ0tKGFoGgqQNEUrbVwEa2B XFDkdRRVjVPn
QCsDSLQckIhEoGgJHERnQ2mQaB5yiSibaG41IFE1IBFEgGhGASRCHhFazaYg i2gyAFEEiXqH
TiLdapZDJlEOkEgLwdUARAyJiruITkSr2Ymqbx6AKN9RKwJE7CJqYBaRhkOf Vnc9bLWVNTEc
ssOoU51DAod2qJ11yAiwFWQGLFu/TPUbMTBzzhABIfqrPk0v44wCgUMCh5oD hMhjFAK3SoND
BIYGjxzWZFBAakigLdWAwCGBQ5UIBuQ1CfAqFQ5FUOhI1a0ADCFwmsBQPQdO +9xChWAonEBW
kCvUXZ3OLWQAQgYMIWgamlqH6WN1lCeUBQoNglNosFrAUAhgaFGtmyWU5BIi IDQaQGiMugBQ
6EKtwkBpbhm7JHAI6VYxLXYIRUBoHYAQwSANhPKAQdD6/HR1PbRBA6EZoSso DoMMCLoFujUH
EATdlgMICnR7DhAIIgBEuivQ3YBA94SKANC91YA91YA30H3Q/YEeqF6stAB7 CnU2LjtbbbT0
YNUSZWsjztt6AOcf2E/CbQPdb23TZfftB2AKdC9O40BpcQCRFgEcGaAUQSQD ktiJRNCIXUcu
MLKzj24Ms41MYDYFZHMQ9rV6gpqZmmZA0XStKwGIDCiaBkfRVDiKIlBEkMgL iqrQdgadX4W2
syq0nUEEiSJQxE4iBFjDRUSgiCARiZxE3HJGbWfzq9FyVk2ACLlEgEQEiGbF IBHyiNBiRpoG
QDQVgMgHiU7P9VbjcsgjAiAiSDQ2BETsIqJ2M241My4iziMaiLDqAbmTMNUM WUR5A4j6BJCI
XUTUZsZZRFGbWcYsoobAoY/ieUMmeyhj3hAcRBoOBa4hPxxKyBtKdA5lCKO2 nENh1lCGzKGK
cw5R5pDAoeSx0bIIlUVoc9RApcGhwzDSfvwZkwQOiWuoSWtA4JDAIQEpAlIq sQa8cMgTSh21
kZFbyAZDHXQbmYFCGE8PMNSvHoHTkNtGZtxCJ2Es/cnq1Nho+rhbSIdNh1CI 3UIGCk3RUAhu
IQJDdX1DtxBlCpFM+xg7hRgKDYZTaIg6i6FQLVrHIBMwnQaFyCUUQaGLak5T FwMMrYJowpid
IeRvGcsIhPIAQtAN+ZloDZsJZ9CswBnEMCgOgm4HDCIIpEFQDhAoFCBQzuhe uIBI92mdBfBj
9AAAkK2N1QA9gR7C6UPVS7QeZgHsPAw9pE+XevVI1TLl6mFc5tND+5cq1sPW 9kOARw9CGwMx
TCKIxCJ4RODovgAm0fY9WsnAyLiNuEXNtKZRxpHJNOKAbArDNkHYZmoaTUub pXUtAJEBRTMA
iiJIRKDoSkCiK6DLLVC0VredkZsI+URVaDurQssZdGEAiS4EJDofgIh0LiAR aQUcRCRyES3T
gCiCRGfrlrMRalE1Ws6qkUsEQMSQiADRmSEkolazQdBAuIkGouWMIFH/Akg0 MYc2M4gA0ekA
RBEkwmQzx0UUASI7i+gUTDU7WQ3MAxLlAYkSAFE8i6iENrOao+LOoSyuoWJw KK2lrJxwqFhL
GQVUe9rKYnAoSxh1/YOVEUhNeUIDRw0ROPS3BsKhvwKciOQYlKEGNBx6HaPs P8Yo+1aor+L5
PfsqRtlnfK0UQk3uoaz7y37yXeKtgSJwTeCQwKFKBAPymgR4ZYFDcTCEaWSB Y6gn8oV6QaFb
KARDmERWH7WRDYm1kcXBUNRCxtlChW6hQigEtxDA0Iw6u4WMwqYZDBEUMmDI QKEhcAoNVYvh
FtJQqBZQCPLnCXHrWAIUqjldrYH0hLFYhtCkWIYQtYvFWsZch5CGQTPUjQSE oJvyAELQzfnZ
cAaRIiCUBIPuZhCUAwiC7oPuzwECQQ/kDATaCD0IFxDpIa2zAX6MzDaBoKXq EehRrWVqk6XH
sP1Y1XKtTYH4PJ9urlqhkvQYrtvk037cn6VHsf3o/mVajwRiiPQgIBKJwdHG YNsApCUaHhUH
RtyOZucZBTlGYfg1QyLXTWRA0XWARNcCEl0DrQMoMrCIIBG7iSifCG6iKrSd QWuq4CaCCBKt
DkDRxYBEBIpsSHQOWs1ILiRaGkCis6vhJIIIEJ1lQaJ5AEXGRTREt5qdiRaz 2QBEsyACRKQC
F1EOWURayCMCIBofQiK71YzazAqziEIHUR6ACHDIBkTsIqIWs15F2sxOSRt5 XyocIjDkwKHd
rnMoBQ7tLgqHUlxDrnOoGByywVCScygFDoWuoUqBQ+QaotwhgkQyrcwPiFJd IxkXyrLwlYVv
sRqoNDi09eXnFLmHSKnTyuQzJAAtrQYEDqVPC3XG2FNruIyyF7AgcKnt10Ax OFQcDB1j2sgs
MDQQYGhQPYdO221kJ6sRcAyNrOukRkE+MKSnkLnZQq5bKABDs+poAlkWt1AE hjQUqkWeEBQP
mc4IhWrGq0tqKFx6gpkyBplg6UKX0LVoG4u1jNkOIRcIAQrdmj9T3ZZHqxgU tojBHcTOIBsG
EQi6zwZBgEEboQdzAEHQQzmAHxIA0CMAQKRHtZYC/ixVj2kB/IRarrZUrwj1 OLaNVqonquJ6
HOdtPVl1jrL1BM67ehyXsbZge0twH1v2r1SszfsBmaDHQkUAiaHRwwBHrIew TQDJgCMDjxgW
GWBknEauu8jkGEXZRSb42oCiyE00R90EJ9GNcBLdAG2Am8i0njEkIkcRQaLA UVSFbKIqtJ1V
oeVMy0CiS6G1AEQkAkQ+SHQe3EMkAkQmk4icRGOQSQQnUfVotbR6lFoCxSER uYio1WwYWs2G
6iyiuSEgGqwBUYGLKIdWsxyyiACHSAYQkZOIXUQ9g1azyEVkcojsNrNOami+ kxpcAIjsNrPi
OUR+QHSUOsWGQ397sngQdTE4VMw1RHDIaikrbCvLCIfy2C/rCHtrlP2e2oej EfbUVtae4BCB
IZ5WlnR6KBZ3b32Mv042Um9/vFt59REub6Te+QhgJ0kprqAsf3UWOCRgpxjY Kcf1lQaHCAoV
+24RZ5F8top+dgQOCRxSbX+hL7BG3sNSayARDqG1LBsYslvJ4BZiMFSPaWRQ FDxtgyGaRtY5
DJ0u3kZGLWSWWwiOIQ2G6grdQgu8bqFhcAsNN24hDYYwfQyioGkTMh3PFIq1 j7FTiKEQwNBl
NRMDKDQpAQo5OULcMuYBQrcACDEUuj2PdjHozrwBQgyD7nGcQdoVlACDHskB AAXalAMIgggA
bQ60pZog0HJAH9IK9YSlJ6sBeaCtlp6qPlc9VWX0M0t8WXT5+biedF6insJ1 W2M6F+eNniTt
B1Sy9LgFjggg2eBoEwDSo1rL4TRaHgNGttPI7yyKt6HFQdF8gKJ5QevZXMCi CBIRKCJIZEDR
LLW+CqCoCpCoCpAIuhqA6CroSkCiKwGICBRdDkhEgCgJEl2k281MqxlDonO1 k2gsQBEgUTUg
EeRCIm4zWwj30AIAoggSDQmcRHEX0fQc2sygaQEgmhJAokmAQ6bVLGObWb6z GgYRIBoCQESQ
KHIQNRYQ+eFQ4oQyBkOWc4hcQzHnUAwOWRPKCAqxisEhXxA1X8bTyorBIdc1 FDiHYnAoa0tZ
pTiH7n/2EWXrAZx39fiupxsNhggsCRyShWDRhWA7dpFUGhwi59CDP3usqKQm 5HshtQYEDgkc
Ejh0QKlgQfZv+zAqCQ51AhyyJ5IVtpKRY4jA0LFBxpAHDNXzRLJCMDQW4dOJ I+qt0GmTLWSD
IWQLAQydSWAIMlPIfNlC7BYaBig0HFDo1AgK1WL6GBRNH+MWMsoUMrlCq2NQ aLy6lKEQwNAV
NQSFJmP8/OSgdcwETMfDpa0coQIoZAOhOQEQmqvuIigE3Z2fr+7Jc6tY1Cbm cwa5MOgxgkE5
wCBoSw4gCHocYgj0JJxAWy09BRD0s1DnqaerjZ7ROl/rWUAfW89VXaBYz1rb 5rILC0T72HoG
5yOdr57G/ZMYLBFE0iBpP8AR9KSWAUePB9qCU9JmQKPHIIJFBhi5sChqSYu3 obGrKAJFxlG0
IMgomo9gawZFc5FRBFBUBVAE3VgFN1EVIBF0PQARQaJrAYmuBSAyoAgtZxoU GUh0uQWJyE1E
LiJqN1uNLKJVgEMEiC4CILoQgOgCnUdETqLTkEcEJ1E1IBHkA0SL0WK2CO6h swCICBLZLiLT
agZAlIOLKAcXUQ5tZpAfEMXbzBJziPJwEOW7qOFlAESd80erTlDkIAIYypcA h2wwlASHsriG
nDDquHOoiGuI28oAhnZrOJQxiDoARXtqH1FZ4VCspaxS4JBrP5dpZSVOK2vH MEMW9eVd1BMc
euL1J9SbH7/ZKlVq5pDUR3nro90eT4FDAocEDgkcaoc1kASHOiuMqldmVH06 GDoO4dMJYKj+
ZDUcilrJjGPIgKGuahzkTiPzhk5zvhCgEIOhOXUInYZcMGSyhYYiW4jdQgyG 0EZGbiGCQrVw
C0GJYdMaDI1XayGCQqTLGQrVAApBV6ONbB10DbKFGgaFLJdQCITmq3vzC9R9 0P155AbljUPI
bRVjIBQ6gywYRCDo8RwcQdCT0NYcYBD0VC6CQE/DDUQyAOg89Wyg56oBd6Bt gbZXX6i0AHxI
z2tdFNMLOO/T81UXYz9b5nbbLW3D9jYHJjFE0vBoP6AR9DMtACPIBkbsMrId RuwuojwjO7/I
hF9z6LWZmnZ/OCFtkQ61vgdw6G7oLrSc3QlIZECRBYmqAImgNEjETiKCRBEg Mu1mBIku0y6i
yWg5o1azSYBEE0NIdLEGROMtQITA6mq4iAJAZFxEo0MX0dmAQy4gMi4i02Y2 JwdABDjkAiLj
IqIWM4y8Dx1ERQBRHjlEgEMj810zACKMug+CqtMyiCJAFIAhDxzK5BoK4BC7 hkLnUBbXUCIc
ygCGPHBoN4VOu/K5hnAZgaEQDpXiGqo0OETZQ+OmT1CHdjhca/bSeUo7hijP oJHtZHx7cQ7J
YrHdLnAzQMRKhUMv/mqXzhzi/CGaYHb7w/dIzk6GmpDPS/FJiVlag1P3SWlJ bmy7s759Qjt1
uf5d9f1BRzKH2r5rRJw/8h764FAIhgCHonH1NJWMwqfJMXRM4BgiMHR8YSsZ OYYYDNVzxhC3
knUBHGIw1E2ZjCEzpj4NDJk2MuMYCsFQnS902g+GVgIMabeQBkOYQgaZ0fSn KW4ji7uFDBTS
LWRwCmm3EIOhGoZCU5EpNA1j6M8wY+gT28cSWscKoBACpeEYegBgaCPA0IN5 ZAflkRsERQ4h
cgbF3UHaGRQCIQsGERDKAQRBz+QiEPQc3ECkbdB2gCDS81oAPZZerL5YkX4O yGO0SuulkrUa
t2OZ+3gx0Au4XxbBJIZHGhzthwsp0LP7CRbZwMjAIgZG5C5iZ5GdYUT5RTYo IkhEosloZjqa
DYoWIaMoBRJVwUlUhZYzDyQiFxGJW83ISRR3EU0LWs2mAhIZQEQygIiyiIyL iAKrYy6iagZE
xkUUbzMbiSyikcgiYgfRqdpBFLaZ5QCJygGI8sgggkYDEBEcGhEDREkZRGmA 6FjVNX+sMmPu
O8BB1MG4hhw4tBuZQ1445LqGcN4GQxoOFQuh5iDqInBod1pLGV0XuIZ2I2/I C4bcCWXsGioB
DhW4hioJDtG0MsoGofwhFmeFDBo1VOBQ2l+uZYEni/wy1UAlwiGeWEbfJ5Qv xKLzBIsEfggw
LloD4hwS51A7dI0IHBI45MKhTnAMERzqSmBIHaW6qw6qR70BQ730yPo4GBqg 4RDCpzljyAJD
pxIYqkf4dH0SGOoOMNRdg6FJKa1kiWCozjeNLMoXWo5WshXIGDJgaGQcDNUa MERtZHo0vSdb
iNxCBIauhLRbCFBoHYGhGriFaihs2oChDQBDN0AFU8eskOnbETId5gmFUAgj 57VTyIVCiyIo
lEeGELQp7wdCBe4gACEDgwwQehZ6LgcQBEUg6EJAIKMXAYN+Hgrgp3qVellr tdYOEsDOzqo1
BdqFy9Lku80O3Ib1MrZJL+H+SQYgGXCkgdF+OI+04DiCfLDI5yxKBkUm4DoK t05yEyVAoio4
iQCIboNuCSDRTwGKolYzZBJZrWbXwT10LdrLrtFtZmegzcwGRFMtF9EkDYkK ARFcRNVoMwMg
Og8OInIRxQHRKIRVpwCiHMKqSwZETgZRvpc6LY9JZiEgMu6hrICob/4E1Qcy DqLjVU+oe/44
1Q1wqCvgUBe0lhlAZFrKOJD67odXKy8c8oAhmlYWg0P7XDjkyRoiKMQqyBzK 6BrKAoeSXEM1
xjWknUOluoYqBQ6RW4gWanS67a2XjVMIItcQgSG6btV1l5YFEIlzSBaCRReC ZQItbfFxKg0O
XXvbDfr7o3PProryh/g9YScRXTd45DABRO245jN9TgUOCRwSOCRtZe2wBmw4 pHOGuJ1Mg6Gj
VA/AoWhkfZQz1B/TyQwYCiaTUfi0BkMn6VYyAkMjNBjCVDLAoTH15BjidjJy DDEY6pEKhmb6
WsnIMQQwtCCAQ9GY+jQwNCp0DF0IMHRRrckWisBQ1EZm3EJBtpDlFloHKERg 6DqAofU1cAtB
BgzRSPoZGEc/E+PoMYa+KBTi9jEfFFoMp9Bi9YiGQgiUJiiUR4YQtCVvt4zF HULsDmIYZIAQ
XEHQ89ALuTgMegmOIJIBQasAgVapndUAQNAurbXqF4Fewekr1ZeoV6ouUa82 QnT7V6pwv6Eu
AVxaq7UzEIEjA40CYLQfwGg/gBHEsIhAkQ2L2FXkB0WcVWSmovnazkzLmXET JTmJ7qpaqEh3
aEC0QAMi4yKaZ7WanYk8otnII5oFSERZRDMRWE2AiLKIpiOL6AwNiSiH6EoE VVNYdVKbmXYQ
VaPNDEoGRNRilgKIAIfmQ3MBiJJazBJDqvMIqc4jpBpwaBzgEAOi0Wgt4/ay EcgfogwiN6Da
jLk/SfWHuL2MARHBoR6AQ90Bh7oBDnUFHNKAqAbuoWJwKAkM2XAIYGh3DA4V AUMFzqHH1LtV
gEPFHEOxlrJH1Z4k55AHDu0hMJQRDnldQ5UCh8gpRM4htqG7FnUacS/TylJa G2RhJ4v7MtVA
pcEhgkJp7iB2FWUCBGU6xvJYbRBQCxwSONQOwYA4h8Q5FIdDQc6Q7RoiOKS4 nYwDqLmd7HiM
rO8YuIZO0nAoAkORa0iDIcjkDHVDzpCBQxPRUjYJmgzn0BQ9rj5lKhmFT1PG kA2G6oaotIyh
yDFEYAgZQ2glC8FQ7Tg184U+atYLfaF+6qxfDi4MnbbbyLRbyAZDaCOrARiq MWDopwBDN+dn
AQzN8k8fg1voHgRNR5lC3D52FtrHyCnEUOhsQKGzC6FQHjlC0JN2hpDVMhZz CGkgBBgEvZiD
M0grgkEGBMENBO2CfgEYRCIA9Gqg16ovVaTXtS7T+mWgN6ouU0aXZxBuh31Z r2P79Srct9Zl
gE2Xar2idQnAEQEjA40IGBXAIstZFG9Du1Bdv+0MtR6ivCIOuDYT0sw0tCeq EGhdBUgEba5a
oR6DNlXBSVS1TD0CPVwFSFSFdjPogSpkElUtVvdB91ah1awKeUQQAaI7Q0gU uYhuRlD1TxFU
fRNkABG1mc1CYPVMDYlcQGRcRAmAqBo5RNDF1cUA0eggg8gAooIMohxazDQg ovayQkBEAdVJ
U8wmAg5NAByyAdFYQKIxaC2zAVHxgGpfe9lxAETHAhARHIJ7qMbAoU4BIPqX 4z+tCpxDaWAo
EQ4lTCezXUM+OJQVDNGkMkAhAkNeOOQFQ8gasuFQXbpzaE/9Q2oPwSBX6kG1 W21U06efqOg7
/ICOHTuqdVvXqZfw/8v2//U4V0Q76neoUHXYTtHOup0qplqch5atX6b6jRgY gh43d8A9T04h
gkM0rSwJDlH20IHfPkicQ0kLFFm0ChwqUw1UGhyiFjICQElAhiaZkXuITgXa tEFoU6a6L/re
CxwSOCRwSJxD7bAGGA5xO5kOobZdQwBDvZTbTha5hgajpUyPrE9qJ2PXUD3A EMRgaAKgEMEh
A4Z6AQz1UmYyWV81A6PqZ9rj6sOcocgx1HHlf6vPffdTMX0e5yN9GtufVj/o 840ADI1WF2g4
dJrqOPu/1Be++xn928DWv37nM2rQpccU5Av1WXGk+uJ3Pqv+DTr7hSFwDBkw dCPA0E01M9XA
FUerL33nX7TOef5UdRvG01ML2ZdxPq7P4fzn1FcsrX3+tMApxFBoCZxCS7VT 6MrnJ6qvfufz
Wl/z6guqx5jDdNsYOYSMS8iGQgBCgEIv5+AMggph0FrAoLWAQJdoxQBQNcAP 9Cb0q+ortH4d
05XqN9VQlVGnXodgrfdFLb6Mz5/S64fq11W4j0BvAiqR3sB5Aky/hF7XuswB RgyLioOih945
W339O1/Qoolpx/X6TxyzLzgyx5GO5zG9/kNteGWGBkSPARBdum0i3pfPa41c dpIGRBsBiCJI
RIAIk80SANGtaC+7RQMimmhWHBAt3DZE1xSp57Ij1WXVyCGqRlA1tLYaOUSA Q6sAhyJAhElm
QYuZCammFrMxyCCKABHnD4Uh1YBDCyFyD3F7GTuIzASzQXqCGQdU85j7ybm+ alIeAdUWIBoX
tpd1DwGR215mxtt30uPtjXvoZDWgwD10PNrLjkN7WeAeqgEgAhxiQORtKysG hhgOBa4h4xzK
CIZicOgxtbsKzqHMcIhyhhLgUFo7GcMhgKE9KXAo0TVUSc4hCqMWOFQ4pYxD TH8nmUOyeG+G
hXClwSFyDVH4tMAhAT9FAVDa50vgkMChdggGxDkkziEbDhkwZGUNwTXUi1xD gEN9lOsaonYy
cg0RHHJdQ5101lDYTkauIQ2H4Biqt9vJKIS6ZwCGegMM9VbT0yaTBa6hhXAM ERxy4Y7v/IFH
fxGOIQZDY9VBR/9bHAgBEhEUsm/bYcz3rYyhqYrgEF9/9gtDY2Dop4BDgwCH +Ppznx8BMDRH
3QkRGCr2HC95fhxayOJgaAvA0ONoIbvq+UlFb0/3/8OjDzRtYxC7hF4OoNDO HBxC0K4cu4Mi
IPQ6gNAv4QwivQFXEIMghkAa/kC/1bpKvRXo7eqrlatDO3wnyJX9onq7CtdD BIfo+dF1b1Xh
9tBvtQxQ+jW2f43TX0FvAhSRCBgxLIo7i/ygiLOKll0/TD9Wr9GH61DrH3aA m8KBf+55gkR3
vDNPu4gu3xYd61GAQ+QiMoDIdhEhiyhwERU6iOahzSw7ICI4xM+nF+DQ5dVo MQsBETKIAIjI
PeQCIpM/xCHVY0JA5LaXLcaI+0U5BFSH7qH0/KGC9rIQDrntZT2QPxR3D1F7 Wbbx9h2RPURw
iLKH4B6qgXtIw6G4eyjmHMoChggOWWBotw6jjuDQbgqftgOovc4hA4Z2V5Pg CEoTOYa0IjBU
4BxKayfjlrIUOJQKhioFDh3a4TBQ5S5eOPTq+7/Sk8vo+nJMVpHMIVkkNmqR 2AyApiWfX6XB
IcoTIvfQ63t+6wVEfH1LHnN57DbwnSRwSOCQwCFxDrXDGiA49C9L/9mfNaRd QxEc6qeonczO
GuoIMHRCdtcQw6F6n2uI4FAfr2vI1052ggWHOsz+vhr/Ylc18cVuahI0+cXu WlNe7KFm/7Kf
hkMXwjV0+Nh/DxfkBx39JTX1iR7qklqMq6+doEbecGIMEvUGEOLw6b4rjgpv twRwSLeSQQSG
bq6Z5cChkRoM3RU4hwgAfP/or6mLnx+rVgdaA7fQWkChCAyRW2gJ3EJLkStE YGgZWsiWq6uf
nxw+7pBZx6rrnp+i1m+fqq7fPk2LoBADhpu2TzetYw4U+gVBIejVHKAQ9HqO HEI2ELoMrqDL
4Qq6HCDoCkAgkgFBDIDeqV6nfhfo9zj9ffU16n8cHRbAoYMAhPR1Vdco2taD QXDd76pwH4He
CeDR2zj/FrZ/C/1Gg6I4LIpAUeQoovYz03oWdxONmHGCfiyCRBRm/cMOB4XH ZvH1Q9R1aDe7
dts0dcljp6v/ssDRoBnH6jazKxw4xG1m2QHRPOQQGUBU2GJmZRBVI4MIuqZ6 uiJAtGDbYLXm
T8i3Ahy6HHCIAZFxD9mAyM4fOg2AaCwCqscWuId0e1kOI+4hgkNnBe6hqL1s iJU/NEiRg8jr
HgIc8ruHDBzi9rLi7iHOHjpB9UUodR+IAFHPGoZDyB4K3EPcWhbCoY+eUBQ2 7Wo3wSBbmE4W
waEt2I7gUFEwpJ1DERjaUwwO2WAoCQ4VaycrAoeKgqFKgUPr7rw+oMeHYXz9 XPUAWsxu3XSX
On36xHBymR5pX4Zx9gKH2sBCrMIBTGuGASEc+uhN9WYr1Fe/8TX17KsvZnaR UfA0Tyfj8fXU
QsZj7enHwvKLz818f635vZPn1oTfbQKHBA61QzAgziFxDtlwyHUN6awh7RrC hDI4hzQcUhRC
zVlD5BoycMiXNUTOIZ01FLiGTg/g0ETAoUl6dD23lLFriOBQX7SU9Vc0oaxg bD0FUMM1dBZk
w6GTVvxQLcNksuWYTMbTyc7F2PrzIHYNLfrDELSSfVqvRQgMrUHm0NoADF1W iwBqaN4LA9Dm
Y1xE1O7DU8lsOLT0hWFhO9lPAYZugQavOCYEEee9MFLdVTNX3Y2MIXYOff/o r4cj6gvzhfxg
6EnkC62znEPjl3dSz+Z58phpIbtqixn2Q/rp9hlh+9it25F7BG18baF6xYJC P//fi9Td2+dA
c9WvcgYIbX51ibp/2zy15dWlgEFXqVs3z1RnLuut5kB3bJ4VQqA/VF+Ldhuj Hb9bpeYt66t1
ztrhak/1derwDt81x/Y7/6bPk2ibLqPr3q26Vv0hEIGjOx6bjcfoo7VszVA4 jVxQZBxFNz02
Q81Y1gvqqaZD518/MsgoijuJDunwLfWN7/yrevSdpXramQ2HKIuIWs04i+je dxbqdjN6bv/V
4Zs6i+jKbRGIG73s5DCH6JJt49Ua6M4/Loi1mF32ymR14bax6tJXJgYZRPMR VG3g0KLHhqhB
y45VA6EFjw3WGURLtg1XZ0NX/gm5VSEcGqoB0VrAoSurp2n30Nxtg9ScbQPD 9rL+a49R3ZYd
rvridPHvhiOgehzay8ZhghlNLxur5v9usOq59kh18rIfq5OX/1idBM3+/cAA EDXCPZTvpybH
3EO9EE7dE+HUBIdotH169pDbWtYfE8v66cllgEM1cA8BDjEgMnAocg99jjKH HsG0Mg8cKoBC
BIZCOGTAEMOhTGBofxwMpcIhFwz54FBWMESTyhKcQwYOeXKG7MvaeuYQt5Kt Wn+JBkGurY9c
QwSPygGG6D4EDjXhAkqgTpuHDJUGhwiYEAyi9jL3u6VYHpHAFvmuCGtA4JDA IYFD4hxqhzWQ
DQ6hpSyAQwM0HLJbyk4smFCW2lKGtjINh+rdlrI+aCkzcGgW8oZmI2cogkPW dDINh4YmwqHC
EGrjGup7aeT+6XdpB4Ch00PXkIFDGFkPHY2WMv4tcdYLg/Rksn6Wc2gZ4BDl DLFr6Jaa2YBD
x4a3OZ/hUE0cDj2QP0ttRPA0wSEzjczXSmYcQwSGtkLXWM4hgkPP5aMJZNRC Nml5F/243wDo
eOz3S0yuEFrICJLQ5T8++lvqNXIK5eAUgmYs7xm0fv2r+k0ODiHo0KO/HbZ+ DR4dtcfxMRg6
+hi02FyrYc/e6vXq8g3j1LcC6MP7HAH4w5fR6fvVG6Drw8vo+r1V69UeretU 114/Lvy9BpfR
xm0LdTsat58d2sE8N1c/BgiiqWkmwJqmna3Rr5n0MsDQz6FDLOfQBsChbQip fg56pup8hFWf
p7OHIji0sgAObUJA9aWAQvzYI5adiBazxQBEFFK9SH2/w9f1dQfj9C5ML7sD 08tozP1hvSJ3
WnjbNSchr8q0GPZbdrSGQ4u2mTY4Uu9lR2k4NA9giC8buPa4gnbHLwBcznl1 UAiHBm04Xn3+
OwZ42qLL+m44usA9lDV7aGquv5oSwKFJCKWeqIOpGQ7R5LKGtJYhmLoG7qEa hkO2e6g4HPK6
hRgMaTgUgSGzXaSVTLeWAQyR4BYiKMTytpT5wJALh7LkDAXj6/UYew8cyuQa qhTnkB1STcHU
5BwiabdQMNZe4JBMK5PFetMv1isRDnHd0Ch7AkUsqaemr6eKOcYChwQOtUMw IM4hcQ4xHOIg
6m46jNpMKIvlDQEO9YdzSMMhFcGhoQijHobR9ewcIjAUG1/PQdR2Sxng0GTA oSn1HETNLWXk
GmI4ZJxD3gllGg79MFwQUwj1N4/5ovom8oVYlDV0IPKF5vyyv55QdjxCqHkB PevFPhYcGq9d
Q1doODRZDbn0uHA/cgy5cOjfj/6K+vejv6r1vUAURM33fQHg0N0AQ/dYcIgC qEcs7widoEYG
GrX8RHXfnxcE4dOmncyAoeUaDD2VXxmDQxS0TG1ktkL4MLNjCIaohcyGQwyG 3shdpmaGcOiL
AENXqregQ482WUHG9fNFNWFmJziC+oQtYQR7fvG71YA969Wrv1sTg0BTZnZV i5YNUEd2iIAI
7f+/1TeqP1XfEINDH1QBGFVdr4aNjkDaUGyT+8huSaPWM2o7I/cSPSfKLbro +tHqXribZsI5
xM+1/+ijQkC0/rGp+vI+o4/EdLPVGhDZcOgGwKHtcA4RHHoWcKjH6MPC++k2 +lBMMjtHXeU4
h1w4NFLDIQqoXowpZoVw6E4Aop4zjgjv99Be39XuoeNHR3XHcGh99Uy12IFD VwEOzbfgEOVg
/Xfvg1R3uIaOGH1weL+Hj/6edg+dnztNfSEAQ4eO+Xc1eXsvNWZLF/UN1D09 zudw3azfD0ho
LbMnl3lay/L91VQNh/qgtayPhkMTAIcIEJmx9r7WMjPWnrKHCoOp0VpWE8Gh PnAOkXsoqbXs
c8d/JuYcKgqGPo6DoT0Mh9xsodj5AAyhpcwGQ17nUBIYsuFQDcKps+QMpcCh zGCoEuEQgSIC
QpQ1FBtpX4aWMnEOyWKwYharTeTSqmQ4JO+9fP4bXAMChwQOCRwS51A7rAEf HOrhgUOmpSyC
Q4MVt5RFcGhEfTS+nsOoTUsZppTZLWU2HAIgMkHU3FJm4NCZaCub48Ahbilb 5MAhn7uELzvj
xV4aDtlB1LNe7Kvh0KVoK7sMeUOXQ1cAEBEcWvhi5N4gOLS+5oyYcyjtsei6 CA7NLxpIfdnz
4zUcsnOG2DX0M8Chay3nUNLjkmvomi2Tg9BpjKUHHPqm5RwixxCBoTehWRYc IjD0du4qdZgF
h+7cMlu9m7sGQbvXqnMuGR4CiS3bzlZ/hBPogrWnhpet2zBBfQgI9Jfqm9Sb v7tMffs7X9LX
0elfqn+qL+fLCB79qeoG9UeIHUYEiYyb6Dr16z9eEcKoFWgxI0BkB1xveWVp EFx9hbrw+lHq
7m1zg8lml2pANHrGifqxV14/PIBDq2NwiKeY8SkfS3IP/fSVWRh1f4662oJD Y9BWRhPMLtsW
te0RHHoQcIjcQzYcIgfR3Xq8/YLw/f5eh6/FsodsQETOIT8cmhqDQwSGLkHm 0FqEUq/B1DIO
TaeWyAtz49QZ2/uE70XPS45UK3OYXJYbrc78/SDVb8MxauprfcLWsrM8wdQ8 tWx2bnCUO5Qf
oM6ApgEMTUVLWWlwqKsfDtVgahkUh0PGPZQFDmUCQxYcIjC0Zz9gUVYwVAwO pYEhhkMAQ3s8
cCgcWc8ZQzYYcpxDJYGhtg6HqF2Mwqi37PpZGEbNcIgCqKnNbOnqlQYSCRxS iRPLGgkKfv/X
95RIjgHVAMGhJ19/Uv3qo1+1StHze+7VnxetV3IJde7ZTa24+LyCfekyaikb f8bkovcjn4vK
+Vw0GAzR96vAIYFD7RAMiHNInEMuHOoO55ALh6K8IQcOARDZziEXDkV5Q2lw CK6hehsO9XPg
0AA1z5pSRnlDLhz6fp+vq5NX/kjrFKjTih9rdYZW/OVUDYf+s883LeeQC4fI OURwaJIac+PJ
MeeQC4e6zvqJHl1PE8oGIWuI8oYO62Pydmw4dG9NBIfIOfQfyB0i/UDrG1rr X59aEELNriEX
Dh3f+wdq4vLOWpOgjr3/U7eT8eOuvec0DYZeceDQG4BDBIYoY8iGQwSG3rHg ELmGGAztyV2n
Nm8/O7zvx7ctgRNog+re+ycBAPo39VfAn78BAn0EfVx9izqqw/dCOPQRzv+t +uYYHPozQNKT
25aF93nF9ePVZkCnx6BN2xaHmUXkIvo9MomWAxLZQIwcRKf0+qGGQ29g7P0v Mfb+dYRTExz6
UZA39Pg7y9ROtJi9DPeQ7RzygbX/Rij1uXeNVE9VnVsyHCL3ELeVMRy69JUI JA1edpyZXFaN
0fbQ8m0jIsdTRjjUY9kRBg7lAIdyE3ROlnZ3BXDoAgAidg7R5dRK9k045Y6e +QM17bW+akmO
g6kz5A7lMdY+P1DN0HCofwiHpuhQ6rhziHKHXOfQqHxXNQJi59AwHmlfg5H2 ARwaEHMORblD
ZmJZPJSanUN7kDkUwiG7hUxvAwDZIigUgKF0OGQ5hggMpcGhYmCI4FAAhlw4 VBQMWXCoZDDU
luEQZQwZS+BBOlPIbi0jGDRo1NAwg4i2BQ41XVuZLIArZwHc2PeyEuDQQz/b rOEPfb/4ABDD
Ibr+sKOOEEDUTuCwwKHdBZl75fp3NebyDVrB7X/TafuCdatV75G91a6aXWpX bVw7a3eqVNXh
eks76naoVNXj+kAv17+sikphn+D/l9RLauM7GxUtigWOCBxp7zXwz//8z+pT 4/5JcVtZyXBI
nahbykhNB4cGqvlWGLULh05aeYhaXocwamhl3Uh1bh2FUY+OjbDvuuLQcIE+ /MYTHOeQgUNX
AQ6dMvuQcL/Tbuyk1tfGnUOUOWTnDd2KzKEhVuYQO4dsOERQ6MGaReoh6OGa KG/IN6EsCQ5N
QObQdmQOPZ+/QL0A/Tx/oXr6zytDQPSjow/KAId6ha1aBg5dHTqHssAhbh8j RxDDoY8BgfYB
BnUI4NB3cB3Boo88cIha0Io5rxgOkXuIMpAICrm3IWfUBQimJjj0GsR5Q5Q9 RHCIWstsODR8
xvFq4rIuioKpSesxtYyyh36G7KGywKHqheqCbWPC56nhUHXTw6GR95zizRyi 43Vw728UD6XO
D1azAYZmAQzNBBjywSFyD9ltZVEodTSxrAAO1XRSQ6HBDhzqH2QO9Qlzhwon lnWpOVoVwKEi
YGgPIJENhvxwyAOF0uBQFjCU98OhTGAogEN7KXeoPkMAtRtQ3RYDqbe99bIG P+Qaom33RyT/
0OQx9lTI6+4oTyi1BFIXtpY0FijI7SsHLlUCHCLgQ3DojofvTQU/NMY+CSBJ TVdOTfN7KXBI
4FAiJBI4JC1j4gwrqIENGzYogkM0yt7OHCrJOURwSJ2sTi0bHHLbysg5RHBo ECaVDdaTyjLB
IQAinlRGzqFJT3QNF+//1edALxwi59AXvxtMK/vuZ9XFfxibCQ7ZgdS+tjKC QxsBhggQ2XBo
E8bXZ20rc+HQi4BDP89fpA4BFKLfOeQi2pVHW1ne31ZGzqFTepucJgIu6c6h a9Vj2xc7bWVx
59BfgpYyA4lujjmH6Pxf4Siy28ooh+iBzfMj59CG07VzaBP0KJxDj2xbpPXU qyvU76qROwS9
XX212v6789XStYNVp96HoF0uAkUEiF6vvlTdse1MfZ8n9v5vtasacAh6uToO h27cNl1tr75Q
bYOeq0buUPX56pnq89TPoKeq4Ryq9rSVVXvayqrRVlaNUGroy3CD0eNq5xDg 0KWvRs6hHjMP
j8GhBZsHN4lziHKHzs2NVeO2dFXHzPxP7RyyA6q7XnI4Qqkd51B+mJqXR+YQ wNCZAEM2HJoO
11Ax51By5pDlHAIYGuLAoYa0lWnnUAPAUCEcSgFDPudQVjDkgUOZwRDgEIGh vfUEh4pMJvNd
3xbh0MBRQzQc8oEhbiuzARHtS21m5fgrp8AhgUOy8E9e+Ld1OLT2msv1P7J0 muV9ptYzAklZ
9pV92jYwEjgkcEjgkDiB2rsTKOvrf+ONN7R77utf/3oBHMoUSI1QagyUV0M1 HDpJnQpA5Msc
GpsSSD2VAqmhaWgrO8PJHJodZg5FcGgBANFZAETF4NA55BwiOFQ3Wl1QN0a3 lV3k5A4dOfZ7
elqZnTnUYWw0qexHfb6lrq3F2PFa/7Sym4Mx9uQc8sOhaFqZgUNnBe6hxXpa 2aOYVsZwaHOQ
O2RPKnMDqQkObYNziNxD5BwiOHTT82eEziEDh1ZpOOQGUnNr2U+CyWQEhzhz iAOpyTn0P7l1
6g/IHHoXmUObti8KgQZBnA+QOXS+lTl0y93T1Z8ROk1643eXxjKHqIWMxPlC 5Dj6I/azA60n
zeyMIOD1mBR1nXoX09Am4PyKtUPV1leXazi0bO0QNRuh1ONmnqJ+U32l+nX1 FepX0NiZJ4XP
66FXF6kzlvXQ5xesHaDB0A6AIRcO3RDCIUwsAxx6BnDoaQ2Hzg3hkB1IrTOH qmlamZM5BDhE
YOj2P82NwaG7qheoO6EvB8HkFFB+C5xDN+u2sjNjodRZM4fstrLVnrayM18b oDotP1RRGPX8
Re: Equinox Server-side incubator [message #11844 is a reply to message #11697] Tue, 06 December 2005 10:35 Go to previous messageGo to next message
Thanks Eishay for the info and getting to talk to them. I am also involved
with WTP and server-side technologies.
Unfortunately Geronimo was removed from the latest WTP releases (?)
Or it might now be developed by Apache directly and has to be added extra?
However, for the server and mid-tier part I am expert as I have designed
and developed systems in that domain for over 10 years (if you include
other systems than Java and J2EE) now. Besides client development based on
Swing and (more recently) SWT/RCP.
I hope, you don't mind me using that illustration in my OHF presentation
next week ?
And if you need any help about flexible and modular project structure
(what made Geronimo work as it does today ;-) I am expert in using Maven
and also integrating it with various other tools and environments.
P.s.:
What is Vista in your picture? Not Windows "Longhorn", I guess.
Werner
Re: Equinox Server-side incubator [message #11904 is a reply to message #11844] Tue, 06 December 2005 13:31 Go to previous messageGo to next message
Originally posted by: eishays.us.ibm.com
The project proposal has nothing to do with WTP, though it is our
intention to integrate with it once we'll cover our current scope.
You may use what ever is published here, let me know if you need to
cover something in specific, I may have something relevant handy.
VistA is the "Veterans Health Information Systems and Technology
Architecture", a very popular in the veterans health system. VistA was
developed using the M or Mumps language/database. Currently available
releases utilize both GT.M, available as open-source for Linux and Unix
computers, and Intersystems Cache, a proprietary Mumps compiler.
Eishay
> involved with WTP and server-side technologies.
> on Swing and (more recently) SWT/RCP.
> next week ?
> P.s.:
> Cheers,
> Werner
Re: Equinox Server-side incubator [message #12946 is a reply to message #11904] Wed, 07 December 2005 15:45 Go to previous messageGo to next message
Thanks for the offer (and explenation)
Since I already got more than the 10 slides allowed for the 15 min. (well
if you take away cover, etc. it comes to 11 or 12) I think your diagram is
more than enough.
As WTP can for the server side be just one possible support, I guess
Geronimo is also just an example (might be used for a reference
implementation?) but not the only one.
Same goes for Spring. I guess Servlet and OSGi are generic, so they are OK?
If you want to modify the pic for future use, maybe J2EE (or Java EE,
since v5 does not match the 2EE any more ;-) instead of Geronimo should do.
Not so sure about Spring alternative, but "IoC Container", "PageFlow
Container" or something like "MVC Container" might do...
Werner
Re: Equinox Server-side incubator [message #13173 is a reply to message #12946] Mon, 19 December 2005 14:03 Go to previous messageGo to next message
Since Equinox relies on OSGi on the server side, maybe plugins such as
this one (for Maven) might be useful for development, build and delivery:
http://docs.safehaus.org/display/OSGI/OSGi+Plugin+for+Maven+ 2.0
It is not (yet) listed under the official plugins for Maven on Apache.
As many other extensions for Maven might be hidden e.g. in Geronimo's
"tent" since it uses Maven everywhere...
Werner
Re: Equinox Server-side incubator [message #13226 is a reply to message #13173] Mon, 19 December 2005 16:31 Go to previous messageGo to next message
I noticed this activity, the problem with it is that its based on the
Apache Felix project which is another OSGi implementation, not related
to Equinox.
Unfortunately, we might have a problem here since Geronimo is under the
Apache organization, therefore its community might prefer to work with
Felix.
It is true that they both are implementation of the same standards, but
we all know how things like these go...
Re: Equinox Server-side incubator [message #13398 is a reply to message #11408] Mon, 23 January 2006 01:39 Go to previous message
The project is going public at "the server side":
http://www.theserverside.com/news/thread.tss?thread_id=38611
From the latest developments and community reactions, it looks like
we'll have good base infrastructure to expose the OHF plugins to the
server side.
Eishay Smith wrote:
> Good news.
> We have good interest coming from both Geronimo and Equinox projects on
> having OSGi bundles enabled on the server side.
> I participate we will have good collaboration from both communities as
> we will be one of the first showcase of such technology.
> Take a look at this link:
> http://eclipse.org/equinox/incubator/server/proposal.php
> Eishay
Re: Equinox Server-side incubator [message #565963 is a reply to message #11408] Fri, 02 December 2005 08:16 Go to previous message
Thanks a lot for the information.
How exactly does that relate to OHF?
Or was it posted here accidentially instead of Equinox ?;-)
Re: Equinox Server-side incubator [message #565999 is a reply to message #11663] Fri, 02 December 2005 14:14 Go to previous message
--------------050405060904090706070404
The info is related to the OHF based on OSGi/Server goal we have (see
the "OSGi/Server EOHF Project Proposal" thread started at the mid October).
The project proposal is relevant to all of the OHF bundles that can
and/or should be used in a server side environment.
You can find a description in the project proposal. Attached is a sketch
that was the base of the OHF/OSGi/Server talk we had in Washington. The
idea was brought to the Equinox and Geronimo communities using the
mailing lists and meetings. It received good responses from both, check
the communities mailing list/newsgroup to learn more.
Eishay
Content-Type: image/png;
name="ohf.server.png"
Content-Disposition: inline;
filename="ohf.server.png"
iVBORw0KGgoAAAANSUhEUgAABIcAAAJKCAYAAAC21yXLAAAAAXNSR0IArs4c 6QAAAARnQU1B
AACxjwv8YQUAAAAgY0hSTQAAeiYAAICEAAD6AAAAgOgAAHUwAADqYAAAOpgA ABdwnLpRPAAA
/45JREFUeF7svQeYHNWV9s//22Dvt5/D2l6vs8Fhjde7a2wTRRJJOeeAIkJZ KKGIhCIZBTIC
hACTMyIJCRAmSIBBkgkGB8BeIwmw19gGaaZ7wv2/5946Vbdu36qunulJPQee 9+nq7upUfbrV
9zfvec//p5Q6QP6TIyBHQI6AHAE5AnIE5AjIEZAjIEdAjkBTH4H7779f7dq1 64BcLnfA888/
39QPJ/cvR0COgByBdnkEjjzyyAM+8YlPHHDIIYcc0KdPn/8v00EgOJSmqqoq dd9996n58+er
jh07iuQYSA1IDUgNSA1IDUgNtIsamDFjhrrtttvUhx9+iJ9K6b+X5Ho5PlID yTWwd+9eNXHi
RPWPn/xH1bFPRzV+yXg17bxp6pqt14jkGEgNSA1IDTRBDdB3LH3X0ncufffS dzB9F6f9W5UI
huiHEP0o4i/xqedNVeu2rhPJMZAakBqQGpAakBqQGmgXNTBrzSzVaUgn9anP fkqNHj266I8q
gQMCiKQGCmtgzZo16sCDD1QLrlygtu/frl6uf1kkx0BqQGpAaqAZa4C+e+k7 mL6L6Ts56d8q
Lxwip9BXDvyKoh9FL8n/cgTkCMgRkCMgR0COgByBdn4ElmxYon8bXXXVVeIi EhdVquteAJEB
RNR9MGTIEDVsxjD11J+fkoVgMy4EBcAJgJQakBrw1QB9F9N3Mn0303e0++9V wT9uS5Ys0daj
pz7El7j8L0dAjoAcATkCcgTkCMgRkCOgj8D2qu1qwMQB2potAEBcQlID6TWA jAu19PqlAoUE
CkkNSA1IDbSyGqDvZvqOToVDBIaIJAkUkiMgR0COgBwBOQJyBOQIyBHwH4HZ a2YLIBL3kLiH
UmqA1hSUdSHuBXEvSA1IDUgNtM4aoO9o+q62AVH4Dxu1kpFjKPwZ1MrolhRV 6ywqeV/kfZEa
kBqQGpAaaFc1EPxSoj+mpfXti6tEnEXttQZ27typvnfI9xLB0I76HUokx0Bq QGpAaqD5aiDp
dxp9V9N3Nv97FfYEUx/95r2bBQ4JFJO/8kgNSA1IDUgNSA1IDSTVQPBLiVrM 6LdTsckf7RUQ
yOtuv3AMY5PVrTtvTYdDdVgUieQYSA1IDUgNNG0NBDA+CQ7dsP0GhZH3cThE U8kofDpmnpYf
xvLDWGpAakBqQGpAakBqQGogXgPWr6WL77vY27MvYKT9gpH2/t5v3bpV/aTj T8ynJOG7Q7sF
GrggvO+N+9QtL96itfndzQ2+n4Y+vtyu4e+dHDs5dlIDLVADReAQfVfTdzZ9 d9O/X3qSwOe/
9Hm19cOtAoda8Q/gx3Y/pm7++c2hKt3Cf++b96pn/vZM4g8Lur49HY9yvN90 POm4leO+5D6k
jUhqQGqg3daA9WuJJrrSbyhxDwkMau9QiF///Pnz1dTzphbAIfrN9o3vfiNV J/Q5QRH88S0g
p6ycom97wAEHhKLzvtvwvkmPl/Y4snhtgcVrA0GhvFfyXkkNZKiBDHCIvrPp u1vDISb89AMn
zTk04swR+kv5kGMOadbFpf7i73tC+Jju+ab4cUr/qNj32xyPmfQ6aDFPr9/3 D6L7PJviWLTE
fdJrptfrAxm+Hwf0Q4H2byvHg18D/VBqzuNLgDHpuDbn85DHEqggNSA10KZr wIFDPUf3VBs2
bJDpZRJQLQHVqIGDDz5Y3f3G3V44RL/X6Dct/Q5yRcCGf8/trNupbJ3Y50R9 HZ2uvGmluvXF
W7VGzh4Zwqb737g/vM3UlVP1/nQ9bdvqM7ZP+Dhb3t0Sexz3ceV8/H2Q4yHH Q2qgddeAF5Zl
gEPUBkztwBoOMeEvBocYkNCX7TVPXtNsi1oXSNE/Kn1O69Nkj88gxv7h2tSP mfYjmf/qQXCO
nTIrblqhIR29F3R5m/6R7XFrJR1vfs10PR0D3/Foytoo13Ged9k8/f61hIuH jk9zA95yHTe5
HwEKUgNSA62iBhw4dO5t56ohQ4YIHBI4JHAINfCpz34q6kawfuPRbzb63UpQ KKmtjK6jfeZf
Nr8A9BDU8S1M196/NgRHfD3DIQJIvtvQ/dPjJN2nLIBb9wJY3h95f6QG/DXQ UDhEHWSf/exn
DRwaPXq0WrJhCXxDyc4hgkH0JUqL2uZ20TS3W4kWzvSYreEHKB1vOu4EQnzP pzU913IdL3qt
dPzJ5WLfJ0Ew/Q95ChgkaNTc8LJcr7u57ofdQ0k11VzPQx5HFvlSA1IDbbYG HDi0bus61bFj
R4FDAofaPRyiqIp//OQ/RmuKEuEQ5QjR7ziCOztrsfiB+I+kfN53So6iHx39 I7XlD3AC4TZT
VxjnkIZDwf24p3S/dJu0+5XrzHsgkmMgNdDKayBwWzYUDhEHou9MDYfoBw39 sEmDQ7abhhbn
vsU7/cgjJwS7IQhssGXUXehT9gm31NAilffzOZJcOES38zku6LZ8P/TYvh+d dDvbxuoukOm+
GbjYj9PQx7Rfp/38si7Muf3IPX782tIcKPbx9x1Xek2cQUOPQ/tzjo/v2Nmv ha+n52UfT9/z
9D1O2oKAjr/dRkj7MtAo5nih10n14nv/7TrzHX/79fGxc49b1mNKzzlr/dO+ SXViP779/JMc
R8VeIx93Or7FjmWbXbS14twwOaYCQ6QGKqQGHDi08Z2N6sADDxQ4JHCo3cOh d955R0/wC9cU
JcIhdvQwHLr2iWvD9rBSFqcCh1r5QlaAkwA3qYHy1kBzwyHbLcQuIl++Cy04 WQx1mPjbC3KG
HgyaGMj4nCEuHPI5idgx4j6mneni24cez14k27k+9msu5THTXicfC/dxkxYM 7BwqpVXKDvwr
dlz5+HOPNz+eDya57Xbs8HGPuS+vyX2cJNhF0IMdavYx4eeVBP2KLbi4Hc2t TRuy2DXJYYd8
3H2vlfvm7cemY8Gv1X6vaXv1/atDYMm2aa5P9/Ng35Ye23ef9nvEUJPfR65j er2+XCO6T9q3
Jdrair1Xcn2FLJ4F0rUK96l8npro8yRwqN1DEAmf9geQNxQOUQg1gSH+/aOz gCwH0MobV5a0
kCoGhzh3iPYrBTrJvgKdpAakBlplDTQnHPIBA/7y1j3DluxF+LN/e1ZfR6cM KTbvxshJXMaL
Y7qfW35+S3gftAimRSuFzfH9MnxIOj/yzJFhfzLvQ/dp347/EkGn9vP1PR4/ V3s/9znw7ez7
o9eW9jrvexPTF4Jj5Xtc91jyeT6m/Bzo2NnHzL0d78fHmq6n46mD+XCs7OPI MIPub839a/R1
fJl9v3RfdDnfngEhvQ7f8eT74vvzPY7v9XJd2MeK9mOwl/a6k44fQy16zkn1 4dYkPX96LHoe
/NrpfbCPadivbh0DhjL2cWY3E92eH59fJ78ePm8/Bn1ubMjDnyeubXpddo3Q vvZr9D0u78+v
Kez7dz7HScdSLo9/38nxkOMhNVB5NZAJqAkcEjgkLilvDWSBQ7yGsE/5j3L0 OyjMCfK0h+2q
3aWyiOEQtY254t9WdHmW+5J9sh1zOU5ynKQGmqcGvHCqOeGQL9eG819siEM/ kl04wj+cGSbw
opkXw+7tGSbYC+licMi93l6A0wKaFtX0OC7IoP1ooR0Lx7NeQxIc4oW1vTh3 Xyc/VtLr9D1u
2iLDHsnJ/4D6IA4DCxsS8P0yJHHhkPu47n50Pd8vQxvfPvb92scmCST6Xm/S /fqAnf0+uxMv
GNrR83WhGN/OfU1J7xWDvLRjytAoDZrSdcXgkO/zRM/fhWXsgKL7Y/DnAz2l fM5kkVt5i1x5
T+U9lRoovQYEDslIenEFNbwGssAhd1oZ/8bTv90w0jwMmi0DHPKBKIJCo2aP Utv+sk3gUEbY
Jov+5ln0y3GW45ylBloUDnGbjzsRi0eNu4DEXrS6P0ptiMOww/fD1QUBaXCI F/+lOCBoIU9w
hv4R4oW/fftizqFiYMd9nbS4dx0vxe4j6Qc9PXcGXbarxHWQuLCEzrvumySo xiDPBhXu+8r/
2PoexwUkSY+T5b23X5cPkjBMZGBm/+WJrmM4Qu+z+1zZccbvvevmcY+p7/m6 t0l6rW5NJTmH
3DpJgmL2+5H0vJPgpw3xbAgri8jSF5FyzOSYSQ1UXg0IHGo4GBCoIscuCxwK f3MDBHF4Krvk
6benDYeonUwHVAftX+HCqQaLyBSFbWUv3Jq6X9p9yHXpx1iOjxwfqYFmrAEL 5LYoHGJ4kmQB
pcvDVht8yYeLVusLn7/4w4UzrgvhkGe/cEEcXGffju7LPs9TDfQ/NJ77si+j /mL3dfA/Rvbt
3cdPekx6bN9j2scgXLg7+5byvNNeF/dM819b7BY033tGl/Hzdo+r/Th03Ql9 0LaEY0p94DxW
1H4v7Xwb32P53vdi71FS/YycbVoHtXvHeZ/p9dhy66zY8+T3Pum9Sqtpfh+L HVO3ptzHSnts
7ThyXrNbY7597OPv+3z46rzY+yPXRz9k5VjIsZAaqKAasFprBQ4J4BDI1fAa aCgcot+a/Fvy
/jfuN4AIziGaPkaX81SxJDg0atYo9Y3vfEOtvXethkECh5px0VoE1AlAkPdC aqAMNdBa4FCa
Q4Rby8J8lVYMhxii0Ckt5De/i+wjPF8fpMkKhxjIuAsEH5xwQVIWOETPUbeO 4TmnLULsxytl
wZ8GhwjGaPCH58DbLjzSrpMiQM4Fa8X2T3r+YcZRkWPhPl4SdPE9j1IBDd2H e5ukY9rUcEi7
qvDDygfOwrbJFMBU7H2R6ytoEZzhMyvvt7zf7a4GBA5JhpBkCJWlBhoKh+g7 h9v9f3QMxssH
cIgAEY2pp98yNLnMB4e2fbhNgyESL0IFDpVhMSrQR1xnUgOtpwZaAxziiUZp E6JiLUQBHPK5
GNh9QqDBXlT7nCBpTiEfbLBdLvYPWp56QCAmadEey2sJFk3F4FAatHGva6xz iI/vs39FuLdn
Uece1zSHDR0Pej58X2lwiF8HO7zYRcTPIQ1CcftWQ51DSS4Y23KctHCh12a/ Lnuynnsbuo6e
K0OVpPeKHWcMFO37ca9rCTjENazbAJ0aSbsu7f1vdwtDASaZQK/UhUCjiq0B gUNlAQPiuGm4
46ZSjl1j4BB9v/BvPfrNyq0T9//y/tBVdM6N5xhAFCxar3v8Ou0qIni04NIF 6hc1v9CatmKa
vuy2F24LL+Pr5NQcI5EcA6mB1lsDBW6r1gCHOBw4aew4Wa9jU7esL3XX7cIw gRfYvBCny23w
wQ4fe6FbDBb5bkP3abfehBDLWgTSc0lrK7Ofl/scCJaEU9WC++THtNufGguH +K8o9DxdkEbn
+bgy4GCo4x5XHyArBgf4vn3tXAwd3Pc5nOBlOXyKPY692ODj5XPBsOWYnTAu rKHnxO+nDbP4
ddjuLX6v2B3lcwHx82LA5B5TPgb2Y7UEHGJgSo9tv0Z+z32wjeuEYW3FLvgE +gj0kRqQGshS
AwKHBA6Jc6gsNdBYOGS3l1FLGQMimmBGv2c4KoCAEDmF9HmcklPIXuhOWx7A oecBh/JYAIrk
GEgNSA209hqwoG2rg0OP7XlMfwkTIErrv7cXzjbxZxjDC3M6bwMfhgD2fryw d4FDMThkPy4D
Ib5fXiyzo4au1+HMgDvcssWnvEBmwGE7knyLfn6+7mP6XmdD2sr4+XBbl5ud w+ddxwidd4+r
ezx8Dqwk10mSk4ehHB8b+3jY91UKHGInlM8FQ/dJ1/Pj8GviUz4ebr6ODUka 8l7R4zIIauhr
bcq2Mnp+aa/Rl43Fr8fn3BNQJO4QqQGpgXZXAwKHygIGKsX9Iq+j4Q6oNDj0 zN+e0b/Bw+mv
CeB27f1r1dSVU9Xa+9aGcIghETmH+o7tG46nJyj0+P88rp1ENhxav2W9IkC0 /c/bZUHc2hfE
8vykRqUGTA20Zjh0zVbTckNf4GlwiCdCcbuS7WQhqEHn6dR1gjAcovsnGEP7 EWxYc/+agr9y
0r52vo973oY6BH34MX3OEvt6Xhhzu5XbkkbPmx+3oY/JrUtuWxidD/+BzPBX TXottD/DDTql
5+ZrdaLXwVlBvL8vHynpNblOHt97Yrtq6H2jx6Fj64M6WR7Hfky+r7TFCR1X ri+unSSgZNcH
Hw+6rXvskt4r+7XyY5b6Wt0acx8r6bF9tUnPhy5331O3RpIysej2/DlodwvA DJ81OSYCRqQG
2mENCBwSOCTOobLUQBocstcTetJjwr/J9rQydypP2rSyWIuMLDYFOEgNSA20 tRpozXDoZYX/
0TZWTLExvimZQ+4/AKUEBcsP9fb1Q52dT0ngS+qh8fVADqg0eCTHuPHHWI6h HEOpgTZUAwKH
ygIGxHHTcMdNpRy71gqHXsm/okRyDKQGpAZaUw0UtLsKHDoglpEiP6Tb0A/p JnZgcPuf1ET5
a4IdaHJsy39s5ZjKMZUaaKM1IHBI4JA4h8pSAwKHZPHdmhbf8lykHltzDQgc soCCOIfa6A/o
JoZCdgsXuVuSprTJAqzh9UPHNa1VUI5tw4+tHDs5dlIDbbQGBA6VBQxUivtF XkfDHVBtAg7l
sGAWyTGQGpAaaIkasFyM7QIOUbaQLwCXfjCHPcR1O9Vzf31O0eQB+zLZ3inH A7XBdUBtT9c+
ea0cE+uYNPYzcv8b9+t2ssbej9xePqtSA1IDbakGikI7gUMCh8Q5VJYaEDgk 4EnAm9SA1EBK
DbQ3OJT2A6wt/ZCU5yoLH6kBqQGpAakBqYHKqAGBQw13goiLRo5dKTUgcEjA gIABqQGpAYFD
Km3qAP8okx/ZlfEjW95HeR+lBqQGpAakBtpSDQgcEsBRCuCQfRteL20RDr2a e1WJ5BhIDUgN
NEUNFIAycQ5F+QMFPyRr8eNaJMdAakBqQGpAakBqQGqgnDXgtOMKHGr4Yl9A iRy7UmpA4JAs
sJtigS33KXXVVmtA4FBKYLHAIYFhAgOlBqQGpAakBqQGmrwGBA6VJT+mFCgg +wpEohpo83Co
GotwkRwDqQGpgYbWgONEFDgkcEj++lvOv/7KfUk9SQ1IDUgNSA2UWgMChwQO ScB0i9SAwCGB
SwLXpAbadQ0IHELbGE/5KDLmXJxD8tfiJv9rcakLCNlfFp1SA1IDUgOVVwMC h1oEDIh7SNxD
AocEDLRrMNBQt4ncrnKcSgKHBA4J8BDoJTUgNSA1IDUgNdCKakDgkMAhcQ61 SA1UGhx6rfo1
JZJjIDUgNZBUAwUwVOCQwCFZELSiBYE4ACrPASDvqbynUgNSA6XWgMChFgED 4hwS55DAIVlE
C0iRGmhPNSBwqP5l9bKlsKWMWsukrUx+wJf6A172l5qRGpAakBqQGih3DQgc EjgkzqEWqYGK
h0NVWPiL5BhIDbTvGrAchQKHBA7Jj/hy/4iX+5OakhqQGpAakBooZw0IHGoR MCDOIXEOCRwS
eCTwTGqg4mtA4FDcLdRczqFdtbuUSI6B1IDUgNSA1IDUgNSAXQNF27kFDgkc EudQi9RAe4JD
r1e9rkRyDKQGKr8GCmCXwCGBQ7IwkYWJ1IDUgNSA1IDUQOuoAYFD4lARl1Lr rIFicGjzns1q
6fVL1Ql9TlCHHn+o+uKX/kUdcMABIjkGUgNSA1IDTVQDh3Y8VJHGLxmvbt1x aywiSJt+8P9L
+J++i+nf1gM6duyo1m1dpy80Vwf/Oy1ktmOIt5syc0h+hLeOH+HyPsj7IDUg NSA1IDXQmmpA
4FDrBAMCbOR9SYJDT/35KTVsxjANgwaPPkldf+9Z6u4nz1W79tyk9tQ/GNPe +oeUVl1peq/u
YRWqFtsZ9X7tIypUDbYz6oOaR5WoNR+DTXh/PMrjspaU7znpy1rzsWzfzy3r d4Lez/4+wXbW
7yG9n/UdVur3H39vut+ndJ6+a0mzlwxVPzjkW+q/jvwvdcO2GyJIJHBIfuS3 ph/58lykHqUG
pAakBqQGSqkBgUMCIQREtc4a8MGhVfeuUl8/8Itq2epxBSDIt5Bps3AojwW0 qIzHwIE4OZz3
6H1cVsnyvWZ9WQHgkvor2+fPAXVtHQ6537MPbrtY/eTI76kBEweo7fu3t2Hn UA1+PIvkGEgN
SA1IDUgNSA20rxpwMggFDrVOMCDARt4XFw5NO3ea6tLnSPXmn2/PBIZoESNw qD0s8i24YQGf
SoY8zfnaCoBSCJLaQ22V4TVWOBxiWHT+lZPVTzr+RD314VNttK1MFgPtazEg 77e831IDUgNS
A1IDVAMCh1okXFhgj8CeUmvAhkMLrlqgW8h87qC0ywQOlWFx26IOpgD8OC6f 5oQj8ljF3VQC
kFI+Z+0EDtH38C2PLFUdunRQ26q2tcHMIVkkyCJBakBqQGpAakBqoP3VgMAh gUMyfaxN1ADD
oQ3bN6gOHf9LvbP/HoFDLQpqmhI0xSFQiwKZasCQSlQLtszF4FF7cx61IzhE gGjZmnE6E67t
BVLLgqD9LQjkPZf3XGpAakBqQGpA4FCbAAOlukxk/8pzJhEc+vI3v6wDT7fs vKRkMCRtZU0J
cxpy34UuoGaBQI0GPY8BFj2m3msjoudqVAbI1QxAKQRHlQqN2hkc2qMe1EHV AodkwSELDqkB
qQGpAakBqYHWXwMChwQOiXOoTdQAwaHPfO4z6vQZvRQtOEptKRM41BCAU67b RIHPTQaASoYf
bQfwtBSIahBUaiKAVDHQqB3Coc071wocknBrCfiWGpAakBqQGpAaaAM1IHCo TYABcQJVnhOo
1PeU4NA//OM/KFpoCBwqF7RJv58tz1+q3vnzvalTwuL7NE072Obtl6m3//e+ VPfL5m2XqW2v
rg/2aWbwU4XHa2Jt3na5ImV6nDK5mujxnsMxZThF2/o5OPdfEkQqER5tew2P ifffBxXbJDBq
h3Bot9qovvSlT6udO3eqAzp27KjWbV2nU6pftv+vx7ki2lG/Q4Wqw3aKdtbt VDHV4nyKCsba
yl93W/9fd+U9kvdIakBqQGpAaqDcNSBwSOCQOIfaRA0888wz6nOf+2dFCw2B Q8lQ549oxymH
Hn/+Mv3X/rOWj064v8fU489fHu7zQe4xjIMvgwAePrC0BTCCnsfCZaPDy2+6 e5kaNroLQNDm
UN/6zlfVER3+M3aZfX3qdhXupxXriuvn6WNAuu+xi5r+uQbH1T2mdHzpsszH Nbgf+/1M3Ebt
bAcI6tb76FgdHXG0ecystfVH3I9WnlWez0Oxz1TmUfftFA4df/y/qyVLllQG HPpFzS+USI6B
1IDUgNSA1IDUQNusgVQHl8ChNgEGSnWZyP6V5zS66KKL1GGHf0vgUJEQ6mKL 2KzXF8KhYNFt
AaAt2wNwA4CUdfEe7udAoEJoYMDP5m1XBHBoTCoISoRDLQh93sNjl0Pdeh2t wRe9RoJifJ9N
DbTCYxocw/PWTAWkw/tA5y0w19DtD3Af9vvOr9G+7PxLpqiFDakvq07jwKhp YJHAoYRWX7QA
E9AfPvwI1aVLF4FDspBomwsJed/kfZMakBqQGqicGhA4VHmgQOBP+3tP586d q0486T8EDjUb
HCruCsoMh1JAUDGwUBQOBeDCBRkNBSfFYc4WwJkm0H7cJ8u6/1+8c4eGQpNn DFQEiWi7YY+f
Dqp8x6vRx7REgGQ7k1LdRo10qDUFLBI4lA6HpkzpqA4++GCBQ7K4qJzFhbyX 8l5KDUgNSA20
zRoQONT+QILAo8p7z8eOHat69/mxwKFS4RAyXv6YSXAGAeKQaGHua+dyF+ze fZC98+o7t6nh
cLjQYp9E23SZCyBeeed2DT14PzoNnSkB9Anh0NIx6u0PHlALcUrQgkTb921C m9X+zfo83X7b
L67XEIXv84r18/T17zm6HJfbj3v5+vkRnAkgDV1m3xdt37vpYvXePoCcQAuW jtWX0b50f7TP
W+9vjF3Pj+O7vX1fvu3J0wdq59Rzuzbox6Ht81ZPiz0Huh1dRqL97OesX5f1 fOm50XN+6wNz
ys9t2Oiu6hdv3xE7BnxM+dhp5xCOOR1PW3SZ/Rr5PbH3offBPZZ2ixy97+H7 im16LKoX2630
AWqLdeX1c2Pv35Ub5sZcSO/86X7dikindF34/NC2dt/mi2L7ct0baJTx8+K0 bwocSodD06ef
qA488ECBQ7KQaJsLCXnf5H2TGpAakBqonBoQOFR5oEDgT/t7TwcMGKAGDz1C 4FDZ4FAcBmUC
P2l5QMHCnYARL/IJ/JD4/E13LQsBEYEBez+CA7SAJ/ihs4MCALH5uaCtDACC wA/vw+BCQ4QA
DvH90T4EO+g83R9BkNCVA/DD90Gwgq6jU9pv2KiuIUjhy3gfuo7v78Y7l4f7 0WW8Lz8+w5iw
FQy3ZRBDj0PApxgU4utDQBMAHve8+1j8fJJe1+ZnrwyPsXYk4bmQ+LkTXCp4 7ACW8evhY0kw
iW9H7W4LAkhEr5GhHL039rEkkET78rHUNRHsw5eZ9w+ZUoBDoZvIag+064Th ItcNwyMGl3x7
hkP8GC4gsus/EywSOJRtYmTQViZwSHKKJKdJakBqQGpAakBqoFXUgMCh9gcS BB5V3nsucCjb
hLKCTKHQCRFkBhXN+ok7hxhG2C4be9uERQc5NMFinq5/+48PxJxCsUU+YACf JzeQ7TAhKED3
SSCILrfhEDtYIkdL1IrFi37bKUMuGRfYkLvG574h+OM6dDRUslw3BFYYvtgA hW7Hj8uuIYZJ
dBv7PuzHKQaIfE4hdhK5DiYGJjbgovvnx+P9GQ7R67CfW9Jro/t1ARSf5za3 8H48EOleOLsM
oIs7juh95WPJ739YI5YzyYVDVGv6/QucRexGo/NciwSIGA7RY5BrTUMj1D5B IdpPB19n/Cx4
YZHAIYFDsb8i5/EXVZEcA6kBqQGpAakBqYHWVQMeICdwqPJAgcCf9veeChxq CBxKdwelLY7t
xXUSGGIgwXCI3EAFC/dgoU9OEj1tK2gDIzjArhG3RYn2o+sJBm1+zjhdbPeP zz1TzFGTBDj4
8l+8dYdptwJQIhFMsdvDaL+9ED3O4QAmtB2ePwrnP8Z5S9/69ldVVziS3Mt3 /RZuG1w3CW4d
9zr3PN2e9qXb8HXk7KHj4d734XgOtG94H8Hz24XXRc+ZIBE9X4ZDPvcSAy06 FvR63WMaOocs
FxMBIhdy0bHj1rfwWKKNzXZv0XYE+UybWiocCuqIYV9SRhJdT9dxOyI5i+x2 NNrmx80Kh9z9
NCzS09CicGtpK2vvbWWyGGhdiwF5P+T9kBqQGpAakBqgGhA4JNPHZDR9RdaA wKGscMg4hLJP
BbNGx1uZLnaeUFK4cywsGgtydnWkuow8DhJyfXDbFTuA2I3CMMN28TQGDtm3 ZcATnjqAh6DM
PY9erOYvGavhCgEYAjN0uvfjx7UIyNjn6bLHnjFAi6+j622598H35Z7y7en+ bDEI2vXbO8Pn
wffvu6/oOW4Jnxvdnwuj6HXSc3sMbicGX0nOId/7kuaEIuBE0IjeRzqWdmsY Q6Oobc1kRPmA
kes2ssEiO5lsOORmWNF1IRyy6p2dRZmBUfAZ0zlFAEUChwQOyY9wWYhJDUgN SA1IDUgNtLYa
EDhUkWBAnELtzynkvucCh9Lg0CbAoE3qfahgpHyx1hl3gYzzxRbXDIvssGha pFOeDGe/JAEi
AkEEA6gNi0EQL9YJGnA+TWPhEAMfcvnYjhoblBg4YiCPq669jtG3YxF8mTR9 UAEMaggcovvS
Tp6Ex6bLzw3a3+h4JolgDt9HNjgUgSsDh+KvO4RDwXXusQrdSXAOEUAKHV1W 650PEDG0YdcP
1QbnHHnhkzW5zQVGdB++UGyqP863irUjWi2PXLdcb3zedRaF59M+O87ENPPZ g+AmMkr4vNbg
ckvv1zyiMqsW+1p6r/ZhlVl12DfQ3rqHVEmqx/7QnvoEAJR2ebvJHGptP4bl +cgCTWpAakBq
QGpAakCcQ+KaEThWoTUgcMhdbEZAiBamrKJwyAODPoCb4gOMT7e1ZZtZ/C9c NjZ+HRbuHwTa
ErR8LYQbhC6jU7oNXf4+zhs9Htc+nIcYFNy3aZU+z+L7IDhEl7FDhS7nfSL3 z+NoaTIikHEE
oMt7AB6RntCX0XXvffyEVrSfOW9r8zNXoZXsIbVgyWn6dUwGDHL3cW/vuz+6 Hw1OcD/u7fX5
j4qLn/fmp69SdH+uGFrx/dP+5vUXvi77OfJzu/fR1QX78uumfXzHyj6Wz+26 MXiNyGWyj3nw
fvD7x+8nHUv7feYa0OHjwfsftpVZ9RC1mpk6CsFOUF9ci3TK+9K2W5t6v6DG I+dQvObN9fRZ
iKaiJYIiDxyKfw4TIJHAoY5q3dZ16iX8/7L9fz3OFdGO+h0qVB22U7SzbqeK qRbnU7SrdpeK
qQbnE+SdWCM/wGURJjUgNSA1IDUgNdD6akCcQwJHKhSOtHf3lMAhgkN+IFQU DiW4g+x2sUQ4
FIAfexHug0MEgrb9wuTh0KSwEAoFC33KoKHFO8EgH/BhQNANjh2dOeTAId1W FkCIOAhKhz4u
HKL7p9sTBLJBCsESE1R9RhwoWSDn3kfMPhrCBJeH7hqc32sp6fLndt6oW8zm AxzZ+9vbtI8+
jiPhLnLul8/TdToI+9oFep+w1ew3d8bg0413rDCva9UZ+nKCTXzfLkgqBtKK Xc/3RyDIhHvf
YB3LCOTRe011wC6zTHDIAUhvv/9gDDq+jUyjEPokwaEAaqbBIbeFMhEUFYFD iaBI4JDAIQmu
lvBuqQGpAakBqQGpgWaqAYFDAocEDlVkDbRfOBS0q1juIHvh6W4XZA1ZYCgp O4guD+FQgivI
hUMEgzgsWrt6AocQwx2CQbzoJxAQBgljkb8N0EBPjAKocV1DYeYQWpsIBm0O 8ntsFw67Ztjp
k+YIcoEGQyC6/K33AIgATH4BoML7EWjp2tMAqhsAVhjGMNQJ84ICaJMEgQj+ uIBnFx6Hc4vu
AWiKwM+T2I7E4Ce+Txw+0XU6mBrPleEQPzd6HLrsMYAgPlb8WHQZt6mdC2Dk wiZ9nC3wZbuR
3GPJTiM9IS1wLNHxpcek95Yu43ogSMX7MDRiOMTuLw3u0DZ2053LdY1Qbbhu IrqOb/fKW3fq
feiUM4xuumu5rkW7Nt3atSFSeF3gKkr/jFiOIm45CyBR2mcyBooI8NaQTHtZ 5pYyaj+TtjJx
DsliopkWE/LX/9b31395T+Q9kRqQGmhIDQgcqkgw0N5dM/L61QHtDw6ZtpT3 SRnB0PvVuI2T
k5K22A2vQ16Lu4COteUgU+b9UFELWOgAQvbN+wA5LAYCDCbYbUOgh/fhEevs AuJTcrj4nC42
tGBnSti6BZgRuonY6fM3OIqgEPpge28gctvYeUK8TeCE9nlux436eoYt3/r2 13D+a2rSGYMA
d/5Lb+/9G2AORNt0GZ+3T2l/vq19qt0+we19p7xv2j782LTvrl/fFT4vfn58 H3T+saevDh+P
tqPXFWUq0WX0fPkY0WkIvoLjxu4kOq4sBlnue82AiaAaH0t+L+g8vYchbNLv 2ePqxjsM+And
Wagp3seuryuuQ16VlQfF23Q578dQMWpHNDX8gTWFzeeGCwOuAUxTQVE1PjPW Z40+e5k+p8Fn
mrOJ3i8FEAkcaptw6JX8K0okx0BqQGpAakBqQGqgaWog9Q8nAocEDolzqCJr oH3AITgJEGSr
gZCtNDhEi1JLtGB9HwvXUEmL3GAaFC+Gvc4gtHbp9h0rA8ZepNM2LcL1PhYc om1yfiwENCLd
9+iqKJcGEIBAAInAAUEfErU7MVCgbbrOPs8uH/uyG29fod7aC/cPYIW+DaCO DTcY9DD0sa/b
9es7dUvW/LNPM61ZHlhjX08Ahvah0xhs+dnV6rmXb1J7/wpY5NGuX92lzr34 DPM41+BxEvaz
L3+syH3yvvS4tO9v9zwcQSvc/z0Pr9aPR6fu62I4RNfTa6HnRnpuB16Dcwzo uNnHlLZ9x5Iu
p/tYgPu8F48ZwiOrJY+OJb3PdEpOLXZs2e87XUbvO7mMzPtPNXID3lvjIiNx nb2CSW0Eg6i+
bChk12FBbQZ1TFBz264NOhOrsO7NlLSYfJ8h6zNmPnPxz2EiKHI+2+/pzzs5 iDK4iAQOCRyS
hUXTLCzkuMpxlRqQGpAaaLs1IHBIJleJk6b91UBlwyGzQKSFolksZoBDzmL0 PSxQSTEwRAtY
e2HrLnqt87RILgiRpsW0A32yng9Dii0YlCWIOXEfy63iAqDk88bdU5IywJss gMfeZw/us5zy
PX7oaCry/AkmkTOH4FDsfko9Tnr/yI2Vtm07jRpVA3YtObAoa12G+1Fth2Hp pvbNZ8ADh+zL
+PNkA1hsR58/BxK5jiIPHIo+90VAkcAhgUOyeGm7ixd57+S9kxqQGpAaaJoa EDjU/sCAwCB5
zysPDrFLKIJCReGQ604IgBAvTL1wqMhi9z1cT4pNFWOnUAlgqKwwqGQQlBEA NQD8lBPqNOV9
ERw6CC1mxR5jUxIcynJsMgOk4tAoBozo/c4wwa1wn8iF5jqLMsEirnNrol70 ecgAiSxAZH8G
E0EROQBT4BB//hPdRAKHBA7JwqJpFhZyXOW4Sg1IDUgNtN0aEDgkoEBgUfur gcqBQ3GXkL0g
9MIhWlAmuIT8C9LibiFeAL8HpwTLHTOuz6fAobLBoJJAUAYIlAVyBPsUAylN dv1ftqo9pSiD
84iCqbPCIdqPnENZXl9ml1QmcJQOjRrvMCoRFtntksH2e8gkij4XDE6LtJpZ zqGikIhbRANI
5Pv8J0IigUMVBIdy+BEukmMgNSA1IDUgNSA1UFoNeHL8BA61PzAgMEje87YP h4pDoRgcsnOG
NBwybWOJwlSy96CCEN3AOeQDQnohHCgLHCoEQg1wfGSGQUVAUEYIlAWAZNqn FJjT2vfNAJuy
HJNM4KgoNMoIjMrgLCqAnUlwiD8XFjwtcBQ5OUT02dMq8jl1s4iKwaFYy1kt vkMsQPRe7cMq
s+qwb6C9dQ+pklSP/aE99Q+WLvWg2q02qunTT1QHHnigOqBjx9Y9yv6Fj19Q a+5Zo3qP7K0O
O/4wddD3vhWmpHNaupya1HiRHINy1MDB/32wOuy4w9Wg0wepqx68qrRFYhtb VD/wygNq+srp
+vWSynH85D7kcyg14K+BT33m0/pzdmKvk9SiKxapJ/6A8cRBOPWuml0qUbW4 ztLO2p0qVXW4
3tKOOvwhK0310R+6Xq5/WRWVwj7B/y+pl9TGdzbqH1QCRwSOtPcaaLtwyITN Zl0EvpfD/hYY
eg+jsrNAIV6c2nDoPSxgzaLWckNYQCgLHNJAKCU36H2MYE8V4MD7gd7DabK2 4roE/RWXp2gv
rmuw/vKU2isqPAaNOKZp75W+Lul9Di9PrhOupWJ1V6wFTYOiYnDI/qy4oCgJ DjEkSgJF9HmG
+DNOn3ctK3MscVuHVhMgMpAoMxgiiCRwKP3HHf0QnLNqjvrCv31Bndyzk7pg 3Wp1y6Y71WM7
t6rf7vtDTG/te1cV6GNcJpJjIDVQcg08uO0xdeujd6kVa89Tx51yvP4MXvjT CysKEt354p16
kfqt731bTZw9Rb9eknxnyPem1EDT1cDO3b/Un7Orb79ODRt3Kr5b/lUNGj9I QyKBQwJW2jtY
qYTX3/bg0CMGCrGKLf54kRjAIQ2FWK4bwV6AOtsEhzQU0gqgUAIQSoJD72HR HIdCyQ6hgkV6
Y2FQU4CgJoA/e3CfbUVlh18NAEeNA0alw6L0DKMAeBL4dACR/ZlI3CZQRJ8t LdPGGTqHfJ9N
+/Nrf6719iYDh2wlfVdY3yfmu6UEQCRwKBkO3ffafdohNHrqaWrHntcLYJDA oab78S4LIzm2
bg08/9ZO1WNgL/XDw3+onvyfJ9s8JBoxbYT6/n//h8AgAacCA1uqBqw/6Cy/ 5FxA2m+pC26+
QJxDMt69Ise7VwL0yfoa2g4cwoINi7a9tHDLAoecheFevVi0wJDtHEqBQntx HSlatGYHQ2YR
HAChYArUex9naxnTcKgxzqByOoIaCYEaBHs+BCRqjWoAvCoLRCoBHKUCo1R3 kR8Wha4icqhl
aUOjGg/r3YCiTHDIziUKIFH0+Qvay5IgkfPZps+7+cxngET29wm2zXcMAaIM kEjgkB8OXfHw
FeqHRxzidQi5UIjPi3NIgIZAraavgbuf3KgO/u/vK3LdtMV8rufef067hRZd sESgQEtBAXlc
qT2qAcftu3PPL1X3gT3VpMWT/IBI2soEmgg4axM10PrhUASFaNGWCodcp0Cw QIwWig4cygCF
9sK9QIq1kJHDIcU1tBfXaX2M/fQimRbLlpIW2FZuUMltYuWCQQ0EQZkAUNlh z88AkMqpMgOp
DCCpUeAoIzBqGCzyg6K9do0m1bFb7/gM0GdBq5jbLtZmhv2Dz585LQKIyEkU QCL+zNuniU4i
DxyKvmuKQCKBQ4Vw6PaXb4c74UeZ3EI2KBI41PRgQOCLHGOqgZ+9vl0dcvgh atOvN7U5QHRM
p2PVhvtulsW5ABqpgZauAU8rOP2bPuHMyToDrKDFTOBQmwADWd0lsl/lthC2 XjhUCIVS4VAM
DBnXgKuCdjLPYtM4FQwQ0kK2ECkLHGIgZBbCtCD2gCHXOZQQJB2HQ1aejA2B END8nkd7cVkm
AdbsLUFFnTx/BlwpWYA7f64ENeC1F4Flpbw34b4Z3ntfzYSXcX0VOIwMLCI4 ZCuchGaDogI4
hNsEnwcbEnlBkQuHgs+fC4kKQJHTIur7/EeQ2Gk3S4FDRSGRwKE4HHr6T0+r g3/4ffXUL7cX
bSMbN32Czh8S55AAC4FWzV8D5CAiB87P//rzNgOIxs0Zp85cPr8oFJi9ZJ5a dd2lRfeTumv+
upNjXkHHPAEO0b/pRxx3pLru8evigEjgkMAhcQ61iRpolXAocAjxwsw9jbWV ZYBC4aIwJWMo
CQoVg0NxIBRBoaJwKIBC7mLbnKeFuCdgmBbuzQSDUkFQZgBUPuizGwCpQP+L y8opz2OUF1yV
AJASwFHJwKihsCgh4Jpq01+zcMYx6EyFQwaaGnncRElwiCERnYbwlls+C8Pl 92ISoZYHEhdA
Is4iCiBR0veOt91M4FAcDg0cP1BR9kBS65h9+YHfOUgNHDWkWeDQ2x/vViI5 BlID8RoYM3Wc
mnfxPPVq7tVWr7tevEtnDGV5Dw896nB14LcPyrRvlvuTfeS7o5JqoGyALgUO bX97h/rqN7+q
XvjohQgQCRxqE2BAHEGV6wjK+t62LjiU7BayF2waDvGCLoBDaYtAXii608k4 z8R1CTEQsk9d
55DPJRQteqMFsK+dLGlxbRbeRiEcctvFAjhUTmdQ40FQ6RAoBnrKCXha6r4C sNRwmJQBHJUD
GGWFRW7dBbDSrtEkUBTmElmQyPfZ8LqJssChAjcRIJHrHGI4VAQS6UwiO6g6 yBxKA0QxSCRw
KIJD1E72/R/+RyYwRJBI4JAsuCppwdUWX8sbf3obC7ivqa3/s7XVwyFuJ8ty nAUOyXdLljpp
r/s0Bxyif+NpGAVNKw3bywQOCRwS51CbqIHWAYeyQSG9YMtjX2sxlwUKuXCI FpJaTuuYDwrZ
zqG9WLhqBXlC6QveoK0saLfZi9NQsdacCAiFC++/Ag45i/NwpHza4j5ji1gi DCrqCMoOgUL4
01KwprU9boPgUcOAUWZ3UVotBXlGhXXoqdcQagYtZ1atMyjK8lnhTCL9+Qog UdpnMryOPsfV
pAgShc6hLJAoHwdE9B1TDA6FgKgO30cBINpb95AqSfXYH9pT/2DpUg+q3Wqj mj79RHXggQeq
Azp27KjWbV2nXsL/L9v/1+NcEe2o36FC1WE7RTvrAINs1UZwaPgZp6qzEBKb xTVE+yxdvVID
otlL56r7n32kcIw9/VWyTJkK7XURIK9bFsnFamAs3ENzL57bquHQY79+TEOs Yq+Fr9/4zKPa
OTRo1FBF21lvJ/vJ56U91EC5/l315QTa//5Tezm5hwQOiRMlq2NF9msdtdLi cEhPBMqwGKMF
WyCCQ3uxoNPytY24C8LgPDmHzAIyWEzarSop23v0dQEU0mHTdmtMwvZHuFzL gkK8bTmEbCC0
F1CIRYvyEAjZ2+6CPgMQahgMygaCNARqERDzNB63KdQCr6ckcFQEGHncRQ2C RZ76MzUZ1aje
9tWyp+b38OchbClL+NzQZ0vLfN7MZy+DQkBkINGehO8Ab6sZf5cEkIi/ZzJB ouD76z1AopLA
EIGkSoND9CMwS9YQ/3gkMHTAAQeEovOuOvXqUhZA1B5+8MtrlIVtQ2rg1kfv Vocje6g1t5YR
vCKIlfX1de7VVcMh/n6hbZ+y3p/sJ5+tSqqB5oJD9G89tYLe8dIdBhCJc6hN uEYE0LQOQNOS
70PLwaGHDRRipeUMWWBorw2GXDiUsiA0i8UACmV0DNHCdM8+I7NY5YVrChzC IpgWwqwIDmEh
jfH0WvaC2l1s4/wefVkKHGooEEp1BqXDoKZ1AnkgD3Jtd5egd7FvQ1TKY4T7 FkCpJgBK5QJG
DYVFCfVHtWnq0yOua65zfWrgaPwzEYBTHyiyP2PY5s9fUUhkh8jjc74nAESZ IJEFhwg479Hf
MRGMToVEwfeX/i6Dg6gkQFRJcOjh3z6s/7Kf1TVE+5FjKK55OB8XuYvK8UO2 kn7Yy2uRhWo5
a4Bayz7xyU+0ajjUdVA3dckNV2aGQ8tWn6PORCh1MZXzOMp9yeeyrdRAOf5N 1feRkjnEvwWG
joOj+IqzBA5JO5WAsTZUAy0Ch2qxiNIqAoecBRot2szCLXANMRwqAoXMQjFw DHkmkbnOBBsK
7SH3gguGXOdQ4IqwF8ARHLKgEC+aE4AQL7y9cIhHzCeAIXYH7cVo91AADHsT 9TSuS9YeXLcH
EKQ8egb3E+hPOE3Qblze1pT0WsLXq193mY4jvScp71n0fia870Ft2E6yRFcR 1xudWqDIrtFE
SBSDQ6b+/Z8NDyQqgEPm81cUEsVG3gMOYeogf+5TARF9d3jgkPmecSCRD2Bb 32F7+HstKySq
JDh003M36fH1pcAhd9+mHGWf+KP9IyxoRHIM2nkN/Ou//ava+nvkDlUjmLoV ipxNtz5yt9Rp
O69T+a4u8d+rhEEMzQmHzlg4U01cPFHgUBsCAy3pWJHHbh2upeaFQwYK0SLK LKRS4JAFhhgK
eeFQAhiiBaFRsEh0R9RbY+oZDsWhEDmGeGHquIYYDqVAoT3aLUGuCY9jKIBD 7kK7AA7ZC3QP
HPK1i7UcDLIAEAERBwC1NehTrufrhUcMyhoLjjLBokJQtIcdZI6rKAaKfLUH SJRes4GbyHbG
BfXPn4eikCgRDhWBRD44FANEKa1m1JpqAaLC75sUF5EDh0oCRJUEh1bfs1qd 3LNTg+DQll0/
CxxEmJr0/q+0bt10l/mrZFNnDsliSxbcUgPa9ffYrx5rlWCIYBW1rD79+vMl 1+rzv9mplq0y
LiKGS6uvvbTk+xEoUSKUkM9U66ixVgCHLli3WvUe2VvgkMAhcQ61oRpoPjgU B0OJcCjBLWQv
2GJZQx445EIh7SJIgUMaClktZDYU8jqHqB3GaR+LFr0GCoVwyJPJkrbA3oNM IdJe3+Icl3nz
g6x2sTgcaipnULITqFxQpej9/BEuo6ZQM7qXYuCoHMAoIywK4ZDdZuiCoqT6 C+ozFRL5at76
TCSBIp3RRZ8tCxD5PoteJ1ESHAo++7aLqMBJZOeWBW1lhYAowUXkgUMR/C7S ZlZJcGjZ+mWq
34iBJcMhGmVv5w49gGBqEl1GYbICh2RRJgvzpq+BSoRDBIHs3CECRFRLdBlN MyNwJLXV9LUl
x7gFj7HAofSBHNbwDhrmsfGdjXrCh7hXWod7Rd6HlnsfmgUOWW4hXjh54ZCT LeQu0ELnkL2Y
s+BQDAqRY4gXhilwqBgUisGhICNlD04LHRBxKLQHE8lIdr7QHiyatYLcltgp L7oT4NAeAkM2
HErID0pqFWtcm5i/JawowCkFtJQEep4FGGpKlQCeSnmNGfYtKzBKaEHbg1ZD I0+4NUMirjcH
EjG8DE99tRzUebz2zefBBqdeSGTnEOnMoci9V7gdZIIR2C0GhzyQKJxo5oTa 78mZ9lWfCsKq
U+BQURdRe4dDlDdEEIinlVEYNYEhcgydPn2iuQ4LunIAImkra8EFirgIWj2E qDQ4RC4hDZhH
YlrZ049qGMRwiJxEBIg69+za6t8XASvyvdWoGhA4JHCoDblVBAa1HAxyj33T wqFCt5AXDgUj
6nnhlbQw04s2KDahLGwfi7eQuWDIdQ7RYjLMMUldgGJx+jHayggI2QqdQ34o ZMOhEAq5cMgB
QvbCm5xDIRCywZAXCkVh0jYcKgBCCG3ek0lBWxiAzZ5AjXbpfADgkirAng/i ehfnW5Pc5xed
T3ltJUGvQijFx1+fxlr1MryXdtaRBYoiOGSHkDugiCCRU4OmJo2zzSsGRVzn sdMADgXQNBES
WZ8x85lLg0NWq5kDiHyf//AybjUNvjvciYf8PVMqILK/2+Lfc+Qg8riI2jsc 4jH29vQyhkME
iMg5RIs6gUOyQGrUAkngVFEIUmlwiMCPDX9sOES1xIBI6kq+Wyq6BgQOCRwS OCTtbA2ogaaD
Q+lgKHQOcchr4BoqBoZcOJTUQpYEhzQUIuk2sgwLTyxOd9MCtQAOpUMhgkO7 9UI4cAvZp2kL
bFy3W19vLc7tlp8QDiVNF0sJP04EQ2WEQYkAqHWDn3JBqEKAlACOGgiN/LAo ARQlBGHT5Dk/
ILLcRO6Us6AeTW0Wkafm6bNgPg9FIJHzOTOfvUBpn9f9Zuy9lv6MFzoHCy5j SORzDgUgOhkQ
BW1m/P0FB1ESHEp0ELVnOLTtrZf12Pr74RRKgkM0uYz+wi9wSBZwFb2AawXw qtLgEH1vsFOI
aseFQ+QmImcRnUptyfdLxdaAwCGBQw0AA+LgaT0OnpZ6L5oGDhUHQ3rBZE// SWjj0IszXqg5
zqE9WNTZgdPFF4TB4lEvIouAoWBBSovTOBzC4vZjCwx5Fry8EC6AQzrQN3lh TQtvljdbCNOm
fIt6PWb+f41SJ2PF4FAcCDXIGZQBBDUKurwP51BrUiOcTJmgUQOAUSosSoJD Qa3omkkCRVRr
LiDCebtGE0ER17kFiezPRCokos+WlnHq8ecvhERJgEjDoQgQ7c4ChziwOgeQ RN8lASRyv29S
28ys77A0OOTNIWrPcIiAEMGhWzbdKXCoFcCBil0cybHNBD8YDr1W/ZpqjSo1 kJpgELWmcl0n
waEndj6T6fjI50MAUpusAYFDAocEDolzqAE1UH44lA0M7amJ4NCemoSMDwcK RYs2s5DbQ4s6
T7aQC4looagXiwyFeCHpW2g6UCiCQ7xoteCQA4bcBXAIh3ix7IFD7mJ794cA RFB8YU4L9UDW
Yt6GQtngUNQmRlChZCDkhUGRI6hkENSawE+5nksJACkOjDwOoxLfowJQlDAN jWsldupCIq43
BxJxfaZCIrfeAYn8nw2PkyiEQ+ZzZsOhVBdRCIcMJNq9H595UhZIRN8hGhAx JCoE0omACN9d
DLnpO00rIWMtDojw/dfe4dChHQ5TJJ9ziNrLCB516tVFnEMCOGQB38Q1UGlw iLKGyD3EziAX
DtF5ur5NLvibuBbkmFQQCBM4JHCoAWCgpdwq8ritx7FUVjhUZFEULpqCRRQt qjQY8sGhBDC0
W18eLOSygqFgoWicBZZcOBS4hNwF6W7tYrDgEE1essCQb+GrL9MZLIFbyD61 HELhIjuAQnE4
ZEEhCw55F/eJziErTLpE2ODPCDIwKDMIKhd0se7nD+8/p5pSTeJWynjMUoFR Ce9fLKPIgURp
9RO6iWJwiOsQziGnTr2QyFPz9FlI+pzEWs3os2V91uizV/h59LSaFcChzdkB UdheZr5XzHdM
RkAUfH+Z77IADmUFRPUGEO2pf7B0qQfVbrVRTZ9+oh6ucUDHjh3Vuq3rMG/j JWv+xsvpP4zq
zfU76ndEqsN2inbW7VQx1eI81JBpZevuvF63dhAgGjd9goZB9Nd+Em2THt/1 tMAhWQzKIr6J
a6DS4BBNIiP4Q9LfJ0EANbWaERii7x0ZaV9BEKSJPx9tFpgJHBI4JHBInEMN qIGywSEErhb7
i3ls8aQXUgEYcuFQChjabTuGisAh7RhiB4HrGrLbyhLcQmZhahRrJQvgUCIU CsCQDw7txsI5
tqB2F9v6PI2sj4Oh3Tjvcwq5C33TVhafLhZOFSsCF/ZgAtgeQIy4nsP55wCE MgjQZncj9O77
29BGllHvYb+mUNbHD/ZrzOvNckzp2Bs574ue1lbE/RVMRwuDrIO6KAqHgnYz qrnCOiRAVAQS
JcEhAkTFIJE98l47h6LPYKqLyAuHCBBlgERhQDXDoU0aECVCIrsF1v4OKxUQ UUg1AFG7hUPk
GCJARHDIHmdvgNHhZnLZx++WRTKtTBaCbXaB1wwL30qDQ/ReU8sYhVLb4+zp u4XOCxiS74N2
8X0gcEjgUAPAgDh4Wo+Dp6Xei7LAIQJDxeCQ/Vd1bO+2XUM2HCoChjQcshdz nrYRFwqZBWKQ
M+Q6hzKAIQ2H7EUrttPcQnoBHMh2DmkwxHAoAQqZhXcEh0IoRLlCVraQf4FP wcTRVKuCUfNJ
MCFoF4sAREYg1AAQlAp/mgL2NOV9poCkBkGjIgAuAkUGFoXOrqT3NYBDdh1Q fexG9tRuQESj
KK/KbTPT9UayIBHXpxcQUU2TK47r3IJE9mciFRC5n7MYHEpxEaXCoSKAyP4+ wTZ9xxilACIe
d2/BIfOdVoKDSE8wIzjUAPdQJTiHuJ2MTrfs+pmGQSTtFsK0Mi2BQ+KaaQY4 0i4WiinHsRLh
EL+n5CKi9jJWe3+v5fW3IzAmcEjgkMAhcQ41oAYaDYfqsLApBoc8YMgLhzxg iBdo4YJNj58O
soY8zqEkMOSFQ942MtupgG2MrCcxHNpNYMgHhywg5MIhe7GsF88FYIjdGPZp sDDnBXoiHAoW
+bTg16LFf4JsiFCQH0TOlCLuoBJhUCIIakpg0xruOwEalQyMUt4P815x3pOV V2S/xwl18G5Y
KymQyK27ABLF4VCKi8gBRAVwKMlFFHy+os9b8BksAonCyYMBJGIgHD9NyCFy 4RC+Y3aTLEiU
2GbmwKGSABF/b9J3aKmAqNLgEAGiEAgxGBI4JGBIwFCz1EAlwyGBIe0Ihsj3 Rfz7QuCQwKEG
gIGWcqvI47Yex1Kj4BAWNbuLwaEEMFQAhzKCIVq0JcGhNDAUg0NB1pAvWyjW xhKAIYZDIRhy
4VACGHpXX245KThrKIRDhVDoXbiG3sW4+tC1kQiH4lCIFvxm0V8EDsWgUDw/ yNvmVAIQ8sKg
FoA1f8BjFlOTtKSlvVYPMCoJFnlAEec+eSERvc8pcCiqlwAquk4iHxzCZVSb VKOpkMjO1Arq
33wWEhSMudduPIavgYOI4aw+TQNEdn6YDqTmljL31AOIkuBQFkBELWYBIKLv NFYmB1EAh8x3
aImAqFLgEE0rm710bqB5OI1r6eqVZXEPSVuZLBAFEiTXgIZDbz6mXqvCtLJW qFKnldF7TY4h
yhhKk9SEfC9UdA0IHBI4JHBInEMNqIGGwyGzoEmFQylgKAaHPOPqfY4h/df8 BDhUDAyFcIjB
EE7jcMjvGIoWp/GFKwdOJy14aTEcwiE3gDrIFXIX2HrhHSgZDvmhUCocYjeJ BkPJgdIhHHKB
0HtwqXjkBSx7kQVUJv0B9/OHPT5tx+VNLedxy/SaYsfGgUm+Y+wFSAEo8oWC x0ARv+8OJOJa
sU+N68xyEqXBIa7TJEjk1jsAUfR5KAKJLDhEoOhdC9CGn0VfDhF9ngORiygZ Dlk5RNySmgaH
igEizh8CILLhUCYHkQWHIkCUMZy6EuAQQSHOGuIAavdUppXJ4q2iF2+txOlQ aXDo1kfuDrOG
OJjadyq1Jd8vFV0DAocEDjUADIiDp/U4eFrqvWgYHIrAUCIcKgKGQjjEiyvL OZQGhnxwKAsY
0nDIWkDqhWTYVmaBIWcxSotTs0B14FCKW4gXwhoOFUwmS3YLpcMhLNz/zK1j xiXkX+RbjpFY
Fk2RKWOYBpboZLHAUAEQaiQ0KQRATQ19ynX/Fjxq5DHQwMjjOtKwKMW5paeq JUxB05DIDa0O
IFFS7cTazajWtOLtjXaNhiDThUR/QY07df/uXwwsLQqJPHCoOCDC59P9bO9L cg7Zlwej7ovB
oTRAZIVTu3CoKCBy4FBJgKgS4BCBIAqjprwhaSuTRVpFL9JaCQRKOsaVBoc4 iPqaOzY0S1ue
1K58f7XKGhA4JHBI4JA4hxpQA6XDoTgYygKHfIsmvXCyp/4EcKgYGHLhUFYw tJsWiwVwKN0t
xGCoAA79ze9+sBe/ejEMRYtkWjAHChbT3ELmXXDHFuWRoyNtYR+2lblQCJDg XZIPJFgj4pNA
RLmAUBwElQvStLb7iaBRoxxUDItSpqJpOMTyvbfB++5ComI1pOuI28wcSOSr 1YJWM65zCxLx
56EoIKLPlgWI4p/BKAOsoM1sXxwQvas/7xkBURY4lASIbDiUj9rK4i1m1oh7 e8x9IhzKEFDd
1uEQASFyDa1af4kGQwKHZHHVKhdXrRzqlOuYVRocIpfQoJFDBQy1k/ot1+eg 4u5H4JDAoQaA
gZZyq8jjth7HUmlwqBAMeeGQ5RpKAkO7sZBy4VAWMGTDod00WcgaVZ/YSoJF olksRq0nu2kx
abenJDiGCpxDtHj1wCEfGIrgkAWGaMFMuUJBtlDSYts4NiwohMX6u6QEx5C+ /I/YPwRDxjmi
oZAPDtlgIdi24VAsP4hARQPcMU0Kg3YDCjWFyt6u1khY5GQVxd8jCw75QJHz /jMkojrRSqul
oN7ikCjIHLLaH9361a2SMThkXEQhHHIcRAVZRPz5CiCRDYdSHUQaDkWAiD7v mQER2svou4Sz
zLh91XvqhlRngEPGQWQBolpskzxwKHP+UFuHQwSDyDlEmUMChwQMVdyirI0t yisNDh161OHq
9OkTBQ61sTqU74Ey/1sgcEjgkMAhcQ41oAaKwaF39t+jrrp1jho8+iTV4fj/ Uj8+8uAwJoLj
IuT0ADkmMAFIHcgx8NXA33/279VRxxyiNWXmULVxy+UGFvnazGw4hG0XDiUC ohAOGUDEcCgT
IKoCOLYAUVY4RDDbBtwEvLWsYOpEB1EKHMoEiCoBDlGe0MBRQ9o8HHrnoz1K JMegLdfA1xBI
vfnNzer1qtdbpSiQ+pnXX8j8OTtzyXydOdSW3xN57u37O6UsoEzgkMChBoAB cfC0HgdPS70X
SXDozT/frmYvGar+/rN/p7405PPqBxu+pQ598mB1+Lb/UKfUH+7oCJzPqDrs l6gjcV2JqsX+
Jeko7G+pBtvlUB73U6AOuKyhOhq3jasTznfKHaPV2VGX3LGK1DXUcdg26saq xnag7jg1Ot5S
R2x3VD1KVVVH1bPqBK0e2G6IuuN2hTpedasqVFfsG+l4bB+vuljqXHWcstUJ 542OVadk0jHY
rxlVjcdqkFAf1SnK4bqGyqm9qBZLr+cTPjhcHbrlB1rfXfkN9ZkjPqW+/o0v qetuWV4IiFw4
hAlmmQBRDA4hJyxwDmVyEGk4FAGiVDjktpe5zqFSAFGCc4jgUNH8oUqAQ+Qa IvcQQSIzsaxt
TiuTRVz7XsRVwvtfaXDoyZ3PKnIPkQgUJakS3jt5DZX5/SNwaKfaWRfXjrod KlX1uD7Qy/Uv
p4Mhut76/yX1ktr4zkZ14IEHYj0ucECOQfuuAR8cenDbxeqfD/6k+taSr6qT qg5VpygXBjUF
HCoRCjFEapVgqPQFdCdAJII/nUMdo7rkAXygrqHisKc7oE/3HOBOoB44ZfXM Adi4AvTpFdMJ
OH+C6h3qRGwnqw+uC1WF7aqTMoj2i9Qb21nUC/dtdGKontj2qYeGUicALtnq CLAUKQkmFUKk
YgCpiaFRSZCobcChQkB6lDrmNz9WX+z1Oe0m+uX/bIyCqn1wKAsgohZRCxC9 67iHUh1ENhyC
g+jdYCpiJgdREhzKkj8UuIcYBrmnqePtKwEOERgqZjekxd1bH7/baDXlKHtZ nFXm4qw9va+V
Bofoe6PYd4s4i+Rz25o/4wKHBA4JoGnfgKYl338XDi1bPU79S8dPq+P3/shA oaJgiEBRC7mG
CBC1NBzK6BbSrh8L/nTJE/w5BuCHdazqBghE6q4F6AP1CNQzD9hDCoBPL5wa Ae446oPzfXIn
qr6uAHf6BupXfZJy1b/6ZBXXKTjvqArnLQ3Atk/2PsnbeLwqUnSf/bDtqi/2 8akPLjc6CcAp
LgZLLkxikGTDJIZINkBiJ1I2eNREwKgoKGqrcIjgqXHakZvoUz/8Z/XYs9cY QJQEh4oBIs4P
CwCRgUPx9rJEQBTCIeMeerdqU3ZAlN+EVjLTXha2lWV1DxWBQ6ntZZUAh+5/ 9hFl6wGcd/X4
rqcbDYYILgkckoVga14ItvRzqzQ4RM6hjU9vKqqWPu7y+PK9lFQDAocEDrUk HJDHbt9gyoZD
azbM0C1koVuonHCo3O1krcE55IAh1/0TB0Au/IHrJ38c4I9RT0AgVi9s98oD +gTqg9M+ebhv
PMCnXw6QB+ofCrAld7Ia4Gggzg8E6HE1CJdF6oTtTmpwdee4qnC+rOqC+4tr EO7f1kCcL1Qn
XNYJMCpSP2wbGajU11IEjwxE6q3FjiRz2lMr7kgqdCK5DiTTxuaCo6hlrYyw KBUQNSEconY0
b2tZ6a645NZKA4jIRUSAaPurt2o4ZAOidwkK2UJwvDek2g6XByCK4JAnf8id YhaDQwiyJjiU
BRBROHUAhwgQFcChYvlDQTB1knOo4uEQB1G39UBqWeDJAq+t10ClwaG2/n7I 85fvFIFDAocE
0LRvQNOS7z/Doc0716rPHPn/GgCGMjqHypkzZOcStYBzqBMyiggEdQ7UBYvo yAVku38iABQH
P8cD/HQM1QfbBID6WuqXB/SB+msVAp+BOYCeQINwyhqcA9yxNATbRp3VEECf oQkahsuHVXeB
uhZoeFVX1Xh1w30YDUtUVzUUj+VqCC4jDdaKoNIgbNtimDQAYClSJziTIvlA EkMkA49ODtrZ
/PDIBUdx11GUfcTgyGQdNQIWtSQc8gKicsKhyEF05M//W/34sP9Qb30AMGMB ogI4lOQgsuEQ
tpPgUOgesgFRARwqwT2k4ZBxD3nhUFp7WQY4lAiI2qJziDKGKFvolfff1CHU JmfIlmQOyaJQ
FoUtUQNtHQ69/t5vdK7QbY/crUOol606JzVriDOIWuJYy2PKZzxLDQgcEjjU knBAHrt9gymG
Qz845FvqyJ3/GbWSZXYNZYBDTeUaaoa2MgJBnWsAgqAuNYBAUFeoG9rBSN21 Ch1Axv1jAyBy
/0QAqB+cQKT+WgYCDQg0EDBoYB7AJ1AS7BkK4GNrGM4PywHwQMMtnZrrqrQA flgjsB2pG7a7
qZHV3f2qwuUejcJl6eqB25WmU7H/qbhfW8Nx3lYIl/YDNEFDQwEi7Y9r8H7A JGiQpYH74UqC
BoQCPNpvAFJxeGSgkXEgmTwkdh7Fc4+M28i0qrHT6Fi4jY7VwdiZgVFLw6EC QFRuOBQBom8t
/pqaNX9UCIcMJHKcQ3zedRClwqEi7WVJcKgk9xCgFreTuadJ08sYDtWaAOri DqIH1Z76QG0R
DhEIohwQaiXjUfbFckEkc0gWUlkWUrJP4+qkrcMhaiGj7xKCPlQLkjnUuHqQ z1PLHz+BQwKH
BNC0b0DTku8/waHDj/iW+sroLzQQDDUGDjUwhLqJnEOJIKgGIAjqXoMsIKgH 1FO3gh0HAHSc
4wJKBkAR/DkJ8OdkwB+jwYBArCHYHpLvpIbmAX5IxYAPoM8ILcAdR6NwflQO AAcaDfDj05jq
HipST2z3VGNdVeGyRPXCda56ey7z7ddLjcFtR3s0Co8Xaj+2LY3ENmnE/h4x nYrzp+4HWIKG
WyKAxDIgKR0geeGRBY64dc12HNm5R27eUQSNbGB0HFrTaKpaEWDUGDhEk8wa Oq3MdzvdZtYU
cMgAopP+doT6p29+Qu389d0WIGogHPqYM4fsU7SMBVPMdpNziN1DXjiU0T0U tpalwKEk91DJ
cOihtg2HyDHEYIjgULvIHPobFhkiOQatvAY0HHoDo+z3Y5R9K5QeZf8aRtmn HEcCRK/v/Y3e
58kdGTOHWvn7It8dFf79CZApmUOAQLUJkmllB7QkIJDHbr9wiuDQ57/w/9Th 2zGint1CJbmG
isChpnQNNdI51MnnCPKBoBqAIKgX1LsGLWFQHziD+sIZRK1grgso7gDyA6Ch GgAZDQMEIg0P
dGq+izo1z9Cnawz6MPAZTcDH0pgcIE+gsTiN1FOdBtjDGoftSL2wbXQadHp1 7wKNr+6jxlf5
dTouJ5nr+2bW6dh3HG7j02n7+6hIvbEdaSy2WWOwPWY/4FKg0Tgl2RCJtn0g iSESA6Q0eDQY
IMl2HoXgSLeuFbarGXBkArTtsOxkYHR86CzqCljkAqO0Efcnp42xt68rFyBq YjhEgMh1D/0h
yTnktpdRK5nlHnqX4FABIIrgUCycOg0OFXMPERwKANG7aC0ryT1U+4jaA0C0 m5xDRdxDBZPL
2qJzyM0YaheZQ7L4FDDUBmqgEuCQgJQKBylt4HNUcg0KHEoGQwSMBA4JHFLt F9C0JJzr2rWr
+ruv/J9GgKG2A4c61aI9DOpSi/YwqGsIgowrSDuCfCAIMKhvDUAQ1K8GMAjq DyiUBoEiBxAD
IAOB4gCoixoBEDQSIIg1Ctuj8t284CcGfHIAPtC4UIA8OQCeQONzvZUWgA9p Qkx91ERAH9YE
bJMmVvfVmqTVL1IVti1NdM5Pruqv0jQJ15MmetVPTdzfT01I0HhcbgT4BJ3u aBxgEsuFSj6Q
5INIBiBFLqQkeESuI7ttLYRGyD6K5x1FLWo0ic0EZScDI+Ms6qhlMowMMNKw qBruomq4i6BO
kA2LToarqPkBUVM5h4x76PBn/1NnD/HkMoJDiYDIbi0L4BADIj8cSmgvS4RD gXsIgChxrH1W
OORzD5UAhwqyh9oDHKJJZevuuL5tTyurxAWNvKaKA17tDQ698Oudas21l1Xc +1gynJDPcsvW
gMAhgUMCPwSAtcIaOOIItHJ0/semgUOprqEj1Cl2e1hDt1MCqTvVIi8I6qKB UAfVtRbtYVB3
LRcGBY4gcgW5IAgwaEDNiVoDa9ASBg1CPpDdCha5gDqFAIhAELmACACN8AEg gkDQmHx3rbGB
ToPzxwU/BdAH4GdCKICdXKRJ2J6UM5BnsqMpgD6F6o/L+qupoQZge4CaxqrC dqCpOHU1rWog
rk/WVFxXoP24DJqiNaBAk3GZq0n7AZksTcS2Dyz5YJIPIGWBR277mt2yZreq MTTi0GwOyiZo
ROHYPGXNhGPHgVE8v+gExbCoBwOjaoAirTgsOgWwqCGA6ORGOYmaEg7hvpHx 9YlP/qN6630T
TJ0Kh2z3UBIcaoB76F09zp5VZHIZwyGcGudQCe4hwKHdWoFzqBT3UCXAoS27 fqYO7XCYOvA7
B3lFGSJtPnNIFl8tu/iS45/p+FciHOrcs6s68Nv4bkmRwBRxG7VoDQgcEjjU CsFASzpW5LFb
h1Pqhz/8ofrnYZ+oCDjUCaCIYBADoa5wB3WDumsdo3oACPWsRYsY1KvWD4P6 kyvIBUGAQYNr
kA0EDYGG1pwStINFIMi0gsWdQNoBZMkGQGPzAEDQOK2e6vRA4+H8MWL444If QB+An8mBpuQA
eyxNxbYWQM80S2dg+wzAHtb0cHsgLjOaUT2oUFW4DJoeiLZdzawarHyagctt Tcf56fsjzcC2
q+n7B6kzHE3DeSMAqAAqEViaisumaDFkGgigZDQJcIk1EdsEkiZYYkfS6XAl sQggGfdRYfua
7TgaHeYfIWwbjiMSQ6MQGGEiW/KUNYJFpi2N1C90FZ2EVrR42HUvuIp6Qj2q O2p1h7oFsMi4
ijANLXAUZXIRAQwRHGo4IALAyTUhIAIcotwhPdb+rxEcKtpeZsEhcg+FzqEi 2UO6vWw/ZLmH
4nCoSPZQM8Ih7R6qD3KHKgEOderVRYfIDhw1RIsg0eyl8xRdzsCI3ENvffxu o/X2x7uVVx/h
8kYqNbxV4EQmONGiCzR5j1SlwaEzz56vv1sIEJ1+xiS9TaeDRw4NYdG1t98g tSm137I1IHBI
4JDAIXEOtcIa+O53v6s+M/v/tlk4ZLuDump3EAMhgkHHAAQREDoWMAh5QQBC fbTQIgbp9rAU
GEQgaAiBIGgYNLwGMAg6tSYdBMVcQEkQKA8ABE3Q6q0mBiLXz2QtA4AY/ITQ JwfoE+gMnJ6R
A/CBplunMzToMZoZapCaBfjDmontmdWDcZ41RM2uNjqTVYVtaHYRzakapmzN rhqK2zjaj/OO
zsR51ixsRxqC7SFqZoGGAiYN0Zru6AyAJtY0bDNQIoBkIJIBSFng0XhAJIJH BhohHyloXbPB
kZ15xLCosD3NTFnj6WpDA2A0tAqB2GhFGxwochWdEriKuAXNwCIDjE5Uvasx Ha0asAgiUNSt
ABRR+9kxWp1S8ogYDjUMEAVwqKkAEXLA/uX4T6u7Hl5t4NBfTVtZo+BQMfdQ FjiUlD1UChxy
W8tKdA5FrWWYWFYJcMjAoLl6ctm2t17WQEjDoH3vqgcw0YzOS1uZ/GVfwFHT 1wDBoS1vbFG/
3P/LVqmv4vkVC6S264QchwSG+DJyDy27+JzwPF1PsEhqq+lrS45xyjEWOCRw qBWCAXHvtA73
Tku+DwceeKD67NJ/jsOhesoRKkVoEat3VLSlrOFtZZ3q4A6CutQRDOqg3UHG IRQBoV4AQr01
EDpOA6G+UL9awCAttIhBYYtY4AxKhkGd1YiazmokoBBpVE3kCCoGgggAMQQK ARBA0KQ8AFCg
KXlAIGgqYBBpGpw/BIAY/hD4Yc3IAfpAMwPNygH4QDOD09m5wQA8gwF44poD 4BPXUJxnDVNz
q4epebYAfOZD87SGp2p+1anY12ieT/txeUy4v/1Gcx3NwXkjAKdwezggUqTZ uI41C9tGQwGT
Is3AtguRkuCR7T6yXUfGcTQgdBxxuxrnHrlOIwZGdjC2BkZVyDOCToUIFhlh ghoUgaLOahDc
RCQfLDLuopNU32rAIkAiAkUGEhkZR1FH3XpmdCzyigws6qQnnmHSWCByGLVa 91AKHErNHnKc
Q3/gQGpvMHU8e0g7hyxA5HUOZYFDOW4ry9haFsIhK5Q6a2tZW4dD1FJmj7Xn 0far1l+q4RDp
9OkTtYtInEOygJMFZtPWQKXBIYJB5B7iuiEYRK4hPn/bw3drB5HUVdPWlRzf IsdX4JDAIYFD
4hxqhTXQeDjkAUMEisoMh2JAqA4wCIraxYxDyA+EOgIGdQQMQm4QAaFa5AVB g2tNi5jfGeTC
oK5qdI3RGIChsTXddUuY2xbmB0EeCEQgKA8ABJ0Rqj8AUH+AnwFe+EMAaLYW oI+lOTm4eyA6
Jc0F8JlnaT625wP6kBYEp2b71AItxGWkswB4SAu1RoQ6C9s+LaoaqUhn+bQf l1taiO1IuO/9
RgtiGonzRvNxOWsetiOdCrAUaQ62GSYxSCqESMnwyAVHPsdR1KYWZR1lBkZV mKRW1VPLhkWn
hqCoawiKjKuoEBYNQFYR5RX1rz5Z9YP6ABT1hnppUBTBou5oOyN1SwBFNhxq de4hDYc+43UO
pbqHGgGH3i0Kh1Jay2znUAPh0Lv2xLL2AocYBtmj7Q/tcLhuK2M4pN1DWMAJ HJIFnCwym7YG
Kg0OEQyy4RC5hOgyu47ou2Xj05sEEElrWcvVgMAhgUOtEAy0pGNFHrt1uJZa MxyKAyE4hAgI
acEhBEXtYuQOOk67g4xDiIAQwaATAINIJwIInWiAEDS0Fq1i0LCwTawYDOqm TiMgBI2rQT4Q
lAUETdUQCE6gGAgCBMoDAuUBgaCZWgPh/jGarRUBoBD6EPiB5uUAf6D5WoA+ lhZUDwfcMTor
1KlqEYAP6yy9PQIC0IEWWzob21qAPEajimoJ9llaNVotcXQ2zmvtT9fi/aNU pNHYNloU0ygA
pkgLsc2AiSGSDZJsiMQAKQ0euc4jn+OIW9XsnCMKzOaAbDsc2wZGobuoCjlG 0BitXmp0AItG
a1jUHc6i7nAWGUeRcRVFsMi0nzEs6mScRdUItdaCo8gBRab1rKNWDw8oIieR dhO1xuwhHxzK
0lpWDA6ltZZlhUM+91CpcMhuLQucQ6XAoTB3qK07hxgOUdYQj7QnlxABIoZD S1evFDgkC7eW
W7i1o2NfaXCIWspsGEQtZbZT6Mkdz2rnosChpoWOAnXFOXTButWq98jealfN LrWrNq6dNK4+
TTLKXlw1As9apAZaGxxygVBXdgkxEKqDQwjqXRcHQuQOioAQwyByCJ0UAKGT 1TAAoeG1yA2C
Tq0lIMRtYl0cZ5ANg3oABvVQ4wkIQRNqeqmJNSYjiFvDwrawDCBoFoEgaHZ+ kDrT0hwAobla
hQBoAQAQaWEO4CfQWTg9KweHT6BFOCXosxg629ISwJ5CAehUj45pGc4vJ1WN 0VpmiS9LPh2L
2yRoPy73aBku82kpLre1ZN9YtWTfmFBnY5u1eB9AUqBFOF20DwDJ0kJsL9wH B5Kl+fvgPgoF
59E+OI600LYWaPY+tK1Bs7TgNoLcNjVyGhlgFJ+65gKjCcgtIo2v6qtOh8ZV IfBay4ZFPQGL
yFWEcGvdgsawqBAUDQUoGgJQNLga7WfVBIkMKOpfAIqo9ewErV4OKAqnnuWO VZ1yBIkMKMqi
yGnURMHUReBQonuoPcEhCqauBDhEeUO0QCMoRICIWsro/KBRCCiDg4gyh6St TBZvssBs+hqo
NDhEbWM87ZDG1pMIDhE0IkcRgSNpK2v6upLPrsAhgUOtwwkijhx5H0qpgQI4 VFLWEOUSNTRv
KMoc6oQx9pQhFOYIpQAhDYXq4BCC4g6hOBAaqh1CDIROAQzqpEYACI2sBRCC RtXabWJBq5h2
BnV3YFBPwCACQr3UJEChyTV91JSaICMogEGmNazQEeQDQXPygxVpLjQvDxAE zc8bJ9ACLQJB
BgIRANLQJ9DiHMCPpSU5uHsgOtWqHqWWBVqOUw17oBWBzPbYmFbiPOuc6tPU OVWnqXMhOk0T
7RNpHLZPD0TblvaPU+cU1elq5X7SuJhW7BunWMv3naZYy7AdCTAJAInEEMkH kFx45IIjgkYR
OCqERhoYOflGETAyE9hoyhoFYdMkNROAPQAB2IG7qAqtaNCEKsAiKA6LegMW 9YKzqBdcRREo
MrCoEBQNh6toGEGiajiKAIkGeUHRSXAVUUbRiUFGEUEi4ygyYdZB21nuONUF kIjUGZDIwKJk
UFQAh8odTN1QOPTRE5hQRlPKjChzKHPuEDuHgtyhwsyhoK0si3MobC17BGPt MabepxpcToo5
h0rMHVIPqd1qo5o+/URF3+EHdOzYUa3buk69hP9ftv+vx7ki2lG/Q4Wqw3aK djp/yeO/+i1b
v0z1GzEwdAGxG6jYKQEiGmdP+5FjiCeY0cIuDKiWaWXinmlHLp6WWFBXGhyi Y0jTyAgCkUuI
zhMUIiCkv1twuubay+RzJZ+rlq0BaSsT55A4Y1rEGVMKKGmP+7YkHEpqG9Mt Y3AHkXoBBsWA
UB0cQlBhy5jrEGIg1AkwiKBQZwOEoDG1gEFQ1CoWuYMmwB0Uh0G9AYMICPVR U6FpNQBBpAIY
xI6gyBWUCIIAgxZAC/NwA0FnAQgt0iBouFqsQVAEgRj8LAX8WZoD/Am0PAfw Y2lF9RhAnzEA
PWPUOYHOBfhhnRNuA9xUj1PnOTq/+nR1AQAP6fxAfD46HY/rfZqAyxO0H5fH hNvvj3Q+rnN1
Hq7X2md0bqjT1Tn7Iq3E9koLIBFIKgRIfnjkuo7YceSDRsZpZPKNuD2Nco3s UGyerDYDkIhA
UQEsqgIsqgIsgiYBEpEmhqCoD1xFRuPgKLJBkQ2LXFfRsGpAImgoIFEhKDLZ REYGEhlQFIdE
3XOARFoIsQ5AEUEiA4oKIVE8o6gJ3EMhHFoTTSuz2sqSQ6mbGg4l5A65bWWl 5A4JHPpDDCZx
OxlNLKO8IX2+DGCI7kNG2YtLoCWgS1t5zK99A9PKfolpZfswrawVqtRpZUnH nRxE1EpGp23l
vZHnWcHfXQKHBA4JHBI41AproCXgkHEKHWmmjaW1jQEMaYdQAIT61yFHCBpY F7mEhqBtzDiE
Tka7GLWNnQKHkA2E0DIGp9AYQCENhGrhDtIqDoQMDEJmEERAaDo0owZZQZDO CdLtYXEYRI6g
ubYjyAVBgEGL8gBB0OL8qepsEoDQEgAhEkGgJSEAgvsHAGhFoJU5wB/oHC2A H4hO9TZcP6Tz
LV0AAES6MDi9gABQ9XicN7pIa0KoiwF4VkF0amtV1URcnqZJuD5B+3G5o4v3 T1SRJmF7krqo
QBPVhfsiXYBtI8Am6PxADJAiiOQCpEL3EbuOIseRcR2R48jXphYCIysk2+Qa MTCiSWrkLEI3
DGQmpw3RCmFRFZxFVXAWARJNDUBRBIv6BaCor3YUjY+BImo/I0dR5CoaDUcR uYpGVCOnqBqt
Z5CBRF01JIpAUSe4ik5B+9kpaD0zoIjcRDztjJxEvXKYdpaDm0gLQdYARAYU +d1ElQqH7FBq
v3NI4JB2FJXTOUSuoVfefzMERAyH+JRay6jFrByASOBQBS+wxP3QaNBRaXCI MoaotSwJrNB1
9qh7ATDy/dAiNSBwSOBQKwQD7dEpI6853nbXnHAogkJHAQpxwHQQLp3mEmIg BCg0uA4OISi5
bYwcQjYQ6gog1A0wiAQgBI2vRXYQZFrFeqFVjNrFjEOIgdAZMSDUX82s6a9m 1QAIQbNrTF4Q
t4clwaCzyBXkgiDAoCV5gCBoKbQsPxJuoJGAQASCRgUgqBACEQg6Lwf4Y+mC HOAPC+DnQugi
6GKt8VqrQgH8AAStqgbkgVaHmqTWVButBeAhrQlkzk8u0CW4LK4pOJ+g/bgc Wlsg3C8uW5Og
1bh89b7JapWji/cBJgW6CKckhkg2QIrDowmB+8h2HaGFzWlbM9CIW9Q8wAgh 2RyMTYHY9kQ1
AkXz4CaaC80BKCqARVUARdB0QCKSAUVoQQtBUX+4ishRFIGiCQmgaCxaz8hR NKoakAgaCUjk
B0WdAYoonyiCRAODSWem5QygKIdsIgAigkS9AIh6hpCI3URxSNRicKhYKHUj 28oEDnFrWTO2
lVHbmD2tzIVDFE5NbSECh2Th1iILt3YEnSoNDrnTytz6oellkjkk3yst/r0i cEjgkMAhcQ61
whpoDjhELiFSV+QKERTqrnV0kdYxyyVkQ6E6uITqjEPI5AgZl9AoKHIIsUuI gBAyhKDxgEIa
CNUCCEGTa/1AyLiDME0MmgmH0CxoNnQmoNCZgEJzauAMgkxWkMkL4haxNBhE IGgpgSBoeR4g
CFoBrcyPhhtoNNw/o7UTyCiCQAx/LgQEujAH+BPo4hzgjyUDfiYA+kwA6CFN VGsDXaJPAXqg
S6oBdixdWj1FkS6DLgfgIV1WNTWmy3E+XdPUFVVGl7vaj8s8ugyXXbb/jEC0 bXSppUv2TVW2
1uL82n0ASpZWY9uFSIXwaBLcRqTIdRRvWTPQyG1Toxa1GDDaj2Bs6GyIJ6pF sGgEYJHRfA2K
yFVEoCiARVVwFlXBVQTNBCQizQhB0UDtKJqGlrOp0BRAIhcUmYwibj/rjfYz ZBRVw01UjYwi
yEAi4yYiGTdRF5x2wWlnuIoIFHXSoMg4iUzbWb8cIBFEkCgCRT5IZLKJKJMo yiVqxrYygUOK
JpXpaWU6kLoNZg5te+tlnSPE4lwh+zL3egmklgVciy/g2gEkqgQ4xCHTdq4Q bfvEuUNSW/L9
0qI1IHBI4FArBAPiopHw6qaEQ8lQiDKFjtFZQiRqHSNRlhC1jg0MnELkEjJO IYRLMxQCGDq1
jsOlk11CERDqASBEUKgnoBCAEDSlFg4hyLSL9Q3axVwgRDBoIGDQIMAgEoAQ NL8GMAgK84JC
Z9Bw0yIWOINcGEQgiGHQOQBC5+bHaJ2XHws3kNEFgEIGBhVCoFUAQatzgD+B 1uB0bW6iWgPR
qQE/kwB6jC4DACJdrhXAHwJA1VPVFVqAOYGuxCnpKoCdq6vOwKlfdJ1f03F5 gvbjcktXYTuu
GTg/Q12Jy1lXYFtrH+kMdbmly7B92T6AJOjSQAyQDDyaGsIjFxzFoZFpWeNW NXIaJQGjMBR7
P2CRlpmoRqAogkWj1KL9mJYGRxFpoQOK5lXBVQTNASQ6MwBFBhYRKBoMUDQI jqJBcBQZUGQg
kR8UTQAkotazcdXIJ9LygSKCRN2grmg96xpAoi4aEhknUQCJcoBEOYJEDIrS IVEXK5fIZBIB
EOXLqBbKHBLnUDM5h1atv0QHUJP0NKFg25zCKWSJWsq2/3aHOIfaAZxo0QWa HF9VCXCIgqcJ
ENmQiM+7p9RSltZ2JvUo0KhZakDgkMAhgUPiHGqFNdAUcMhtH4ucQgyFaBT9 sUWhEAEh0nBy
CkEjAIVG1gEIQeQSIo0Ns4R8LiECQuQS6gUg1NsAoVoAIS3OEOKWMXIIJQGh IQBCQ9RCQKGz
apAZVBPPDOIWMdsZlAqDCAhBF+RPUxdCFwEIkS4GFGI3kAuBCABdogX4E+iy 3GRsAwKRNPiZ
AuAzBaBnqtZVga4m8BPo6moAHq3pap2jawF4rq2aoa4JRNuurquaqQo1C5cl aD8uD3Tt/pnK
1TW4LtJMtQ77hNo3U129b4bWVZauBDQiGXgUB0gMj3zgiB1HPmhkWtTSgBHc RXqi2ulqBaaq
kZbHYBGBotFwFY2Gq2iU1iIbFFXBVQTNr4KrCIqDoiEhJEoGRZGbaDJazybB STShGvlE1XAT
QQYU2ZCIWs66a43UkKhbCIlMgHUAiXKARABEA7SQS1QEEsXDqym4+mjVKQ9I VC5A1EJwaDdP
LKvarCRzqJmmlRVrK5NA6j3qd3/bK5Jj0OQ1QHDo8V8+rt7Y90arFAVSP/va i5mPA8GfOZhO
Jp8f+f5oyhpoNEASOCRwqBWCAXEOiXOonHCoUz3ax6AuQftYt6B9rIduITsG k8cYCpFb6LhE
p5ANhbRLyIZCdQiXrkPbGMRZQj6XEAGhCAr1BhTqY4AQNKMWQAiKt4xFLiHj ELKB0FAAIYJC
w9TiGriDoFhmUNAqlugMcmFQHjAIujh/uloFrc6TK2g8XEDjQzeQC4EIAF0O XZEDAIKu1AIE
CnRVzgCgdVpnqGssXQsIFGmGuq4agMfSemyvr56lNpAAea53RJcZzfbqhqoz la0NOB9qP7Zj
wn3sn62uj+lMnD9TrdearXUdaV+ka/fNUqRrtACQLPngEYMjdh3Z0CjuNDJt ajYwIoeRnWcU
uoswWY0nqZ0LSGRgkQFFKwCKlsNNZFxFBhTZsGhRFVxFVXAUQQSJSASJjKNo GBxFQ+EoQqA1
nESRm4jyiWxHkWk7m4q2M2o9m1SNfCKoEBIhxBqtZmPQZkYa7UCi4XrKGbmI AIlygEQARKRB
AEQGFCVDonhw9bEIrj5GdckDEgEQdSoHIGq1cGgToBFUvUnttpU4rUxG2Zc8 1t7NHBI4JHCo
KRd2ct8ROKg0OCTvrUCh5qgBgUOYKEpTRS39dl98CukF61ar3iN7q101u9Su 2rh21u4UOCRw
SJxDrbAGCuCQOlydUl+KjlCd6o8wUKgemUJQIRSiFrJjVR/dQnYcpo+ZFjKe PMbtY6lOIRsK
1cElBLlQaBJaxwqBEEGhvgBCDIWQI1QLl1Bt3CXkAqHIJURACC1j0BJAoaU1 CJGuodwgkx2U
BoRCZ5APBgEIrYHW5tEeBpEr6FJIu4AKQJCBQFdBVwMCkdZB1+TOwKnRNTkD gK6D1lfP0Lo+
0AbAH9L1+pQg0Gx1g6Mbq89UN5EAdn4K0Wlcc3B5kubiugTtx+WBbsKp0ZwC 3YjLSTfgOlsb
9s1RpOv3ASAFWo/T9RY4IojkA0dXB84jdh1FbiPTqpYEjCKHkQnEDmERJqpd iElrF0DnAxSR
CBYZUISA6wASFYIiwKIquIqgxYBEiwCIDChiN9FwCxK5oGhwrO1sOlrOdOtZ NVrOquEmguKQ
CNlE2knUS+s0QCIGRQyJjIsIU85ygEQ5QCItZBJ5IdFJQS4RtZvZwdXHY7rZ cap7HoBIiwFR
I11EIRxaXdoo+48fV+9a+sPHW3De0T6cDwWH0L5A7Bqi00TnUEY4lH9Uvav1 iNqdpBpcR4qN
skeGUG2gIFuIM4bcU5M59KDarTaq6dNPVPQdfkDHjh3Vuq3r1Ev4/2X7/3qc K6Id3FJGp80Y
SE0/Im/ZdKeiqWVG8wq0dPXKdt1W1hwLHHkMWUhXIhx68de7tHsoTVL7UvuN qQGBQwKHxGUj
LptKrIHGwqHQLaTBEIKmoR717BRKgkIdda7QoDBoOp4plOgUYihUh4DpOgqY NnlCSVBoegCF
ZgIMzYJTaDag0JmAQnNqkSFECnOECl1CcSDEUGiEWl4DIARRkDRnB52H7CBq E4taxdgZFHcH
xWBQHjAIuiyPfCDIuIImh44gHwgiGHQtINB1gdbnAIECXZ9j+DMT4GeWutHS TQBBcQHyVBvd
HGquuqV6rroVkId0iz6dl6rbcL3R/ETdun++StMt++cp1s3Y12ie1k8D3bRv nrppH6ASdGOg
GwCMSAYeJYMjFxolAaNUWEST06BV+wGLoIsBiS7SoAgB11rjAYrGAxSdHoIi A4tOixxFVXAU
VcUhEYEigkRnARIthItoATQfTqI0N1HYdlZNgAjZRBoSDXAgETKJAIjGo9Xs dA8kMq1myCTK
ARJBBImGAxAZUFQcEpnpZhRaDUCUJ0B0nOoWQKJGu4haEg4BDAkcakY4RECI cofSgqnbeyB1
YxYucltZ+GatgUqDQ7c/fI866Nvf0t8tdJqkrMdH9pPPkq8GBA4JHKpEMCCv SYBXQ+FQJ7iL
OsMxFLqFNBg62oChel8L2fFwCjEUOgFB0yeakfRu0DTyhChXaDScQiTdPuZC IYChiXWlQKH+
gEIDQig0rxZtY7X+tjFyCEUuoVPhEiIgNBJAaKRaCSh0DnRujQmT9gMhq1VM u4MCZxBOCQYx
ELo8DxgEXak1RV0FXa2dQVMDJxCBoAgGRRBohtoAEES6IQcIBJnT2Vo/BQj6 KRxANwe6Bae3
AADdGgrQpxrQB7ot0O3V8xXpjkB3AvbcWbVA3RGIttN0V9VCXJ+g/bjc0R04 H2mBun2/rYXq
Nlx/Gy4j3RroFkAj0s37WIBHgEYkGxwlQ6N4ixq1p3Frmt2Wxu4iDYv0NDUz Qe2S/Qi7htYA
EpFWAw6tgi6Gi+girQkBLCoERdpRVAVQBC0DJFoGSMSgiBxFiwGIjJuIIBG5 iVxIRCHW1HY2
xLSdVcNNBE2vRoC1FxL1hZuoL1rO+qDlrBASmVYzZBLlAIm0kEkEQHRqCIkw 3cxqNytsNTtB
u4h6AxD1yh+vekIGEh0bQKJGuIh8cOhvT6g/BHoXp14Vcw7FXEPkIPI4h4rB IbeljM67bWXF
nEPsGmqgc0i7huorxDlEmUMURL1l1890C5q0lRWGwMqiVBalzVEDlQaHKHOI gNC1t98guUOS
2dVkNSBwSOCQgBQBKZVYAw2BQ6aNjMAQxtPDMRS6hQgKQb3rfS1kBgwRFCIN BRgaFoRNx3OF
DBQyuULdAjBknEIkDYWgyXUcMs15Qn2QJ2TaxyKnEEOhgXAKDVQhFAIYWlhL 4dImS2gxVAiE
DBQiIGSgECaMQecBDJ1fY4VJ6+ygcVF2UAwI2TAI7qAQCAUwKA8YBK3Lo0UM uhatYgSEyBlE
MOh6yAVBBINuIggU6OYcQFAoA4FugwOIdLvWPECfSHcyAKoG8IHuql4Y6h5s h6o6S90L3WOJ
zvt0X9ViRbo31CJsB9qP00D34NQWXX631lmh7sI2yQAlOj0LIIm0EBDJyGwD HO0zugXAiGTA
EQMjA41sp5HtMqLWNM40Ct1FQRj21ZiexhPUzOQ0tKGFoGgqQNEUrbVwEa2B XFDkdRRVjVPn
QCsDSLQckIhEoGgJHERnQ2mQaB5yiSibaG41IFE1IBFEgGhGASRCHhFazaYg i2gyAFEEiXqH
TiLdapZDJlEOkEgLwdUARAyJiruITkSr2Ymqbx6AKN9RKwJE7CJqYBaRhkOf Vnc9bLWVNTEc
ssOoU51DAod2qJ11yAiwFWQGLFu/TPUbMTBzzhABIfqrPk0v44wCgUMCh5oD hMhjFAK3SoND
BIYGjxzWZFBAakigLdWAwCGBQ5UIBuQ1CfAqFQ5FUOhI1a0ADCFwmsBQPQdO +9xChWAonEBW
kCvUXZ3OLWQAQgYMIWgamlqH6WN1lCeUBQoNglNosFrAUAhgaFGtmyWU5BIi IDQaQGiMugBQ
6EKtwkBpbhm7JHAI6VYxLXYIRUBoHYAQwSANhPKAQdD6/HR1PbRBA6EZoSso DoMMCLoFujUH
EATdlgMICnR7DhAIIgBEuivQ3YBA94SKANC91YA91YA30H3Q/YEeqF6stAB7 CnU2LjtbbbT0
YNUSZWsjztt6AOcf2E/CbQPdb23TZfftB2AKdC9O40BpcQCRFgEcGaAUQSQD ktiJRNCIXUcu
MLKzj24Ms41MYDYFZHMQ9rV6gpqZmmZA0XStKwGIDCiaBkfRVDiKIlBEkMgL iqrQdgadX4W2
syq0nUEEiSJQxE4iBFjDRUSgiCARiZxE3HJGbWfzq9FyVk2ACLlEgEQEiGbF IBHyiNBiRpoG
QDQVgMgHiU7P9VbjcsgjAiAiSDQ2BETsIqJ2M241My4iziMaiLDqAbmTMNUM WUR5A4j6BJCI
XUTUZsZZRFGbWcYsoobAoY/ieUMmeyhj3hAcRBoOBa4hPxxKyBtKdA5lCKO2 nENh1lCGzKGK
cw5R5pDAoeSx0bIIlUVoc9RApcGhwzDSfvwZkwQOiWuoSWtA4JDAIQEpAlIq sQa8cMgTSh21
kZFbyAZDHXQbmYFCGE8PMNSvHoHTkNtGZtxCJ2Es/cnq1Nho+rhbSIdNh1CI 3UIGCk3RUAhu
IQJDdX1DtxBlCpFM+xg7hRgKDYZTaIg6i6FQLVrHIBMwnQaFyCUUQaGLak5T FwMMrYJowpid
IeRvGcsIhPIAQtAN+ZloDZsJZ9CswBnEMCgOgm4HDCIIpEFQDhAoFCBQzuhe uIBI92mdBfBj
9AAAkK2N1QA9gR7C6UPVS7QeZgHsPAw9pE+XevVI1TLl6mFc5tND+5cq1sPW 9kOARw9CGwMx
TCKIxCJ4RODovgAm0fY9WsnAyLiNuEXNtKZRxpHJNOKAbArDNkHYZmoaTUub pXUtAJEBRTMA
iiJIRKDoSkCiK6DLLVC0VredkZsI+URVaDurQssZdGEAiS4EJDofgIh0LiAR aQUcRCRyES3T
gCiCRGfrlrMRalE1Ws6qkUsEQMSQiADRmSEkolazQdBAuIkGouWMIFH/Akg0 MYc2M4gA0ekA
RBEkwmQzx0UUASI7i+gUTDU7WQ3MAxLlAYkSAFE8i6iENrOao+LOoSyuoWJw KK2lrJxwqFhL
GQVUe9rKYnAoSxh1/YOVEUhNeUIDRw0ROPS3BsKhvwKciOQYlKEGNBx6HaPs P8Yo+1aor+L5
PfsqRtlnfK0UQk3uoaz7y37yXeKtgSJwTeCQwKFKBAPymgR4ZYFDcTCEaWSB Y6gn8oV6QaFb
KARDmERWH7WRDYm1kcXBUNRCxtlChW6hQigEtxDA0Iw6u4WMwqYZDBEUMmDI QKEhcAoNVYvh
FtJQqBZQCPLnCXHrWAIUqjldrYH0hLFYhtCkWIYQtYvFWsZch5CGQTPUjQSE oJvyAELQzfnZ
cAaRIiCUBIPuZhCUAwiC7oPuzwECQQ/kDATaCD0IFxDpIa2zAX6MzDaBoKXq EehRrWVqk6XH
sP1Y1XKtTYH4PJ9urlqhkvQYrtvk037cn6VHsf3o/mVajwRiiPQgIBKJwdHG YNsApCUaHhUH
RtyOZucZBTlGYfg1QyLXTWRA0XWARNcCEl0DrQMoMrCIIBG7iSifCG6iKrSd QWuq4CaCCBKt
DkDRxYBEBIpsSHQOWs1ILiRaGkCis6vhJIIIEJ1lQaJ5AEXGRTREt5qdiRaz 2QBEsyACRKQC
F1EOWURayCMCIBofQiK71YzazAqziEIHUR6ACHDIBkTsIqIWs15F2sxOSRt5 XyocIjDkwKHd
rnMoBQ7tLgqHUlxDrnOoGByywVCScygFDoWuoUqBQ+QaotwhgkQyrcwPiFJd IxkXyrLwlYVv
sRqoNDi09eXnFLmHSKnTyuQzJAAtrQYEDqVPC3XG2FNruIyyF7AgcKnt10Ax OFQcDB1j2sgs
MDQQYGhQPYdO221kJ6sRcAyNrOukRkE+MKSnkLnZQq5bKABDs+poAlkWt1AE hjQUqkWeEBQP
mc4IhWrGq0tqKFx6gpkyBplg6UKX0LVoG4u1jNkOIRcIAQrdmj9T3ZZHqxgU tojBHcTOIBsG
EQi6zwZBgEEboQdzAEHQQzmAHxIA0CMAQKRHtZYC/ixVj2kB/IRarrZUrwj1 OLaNVqonquJ6
HOdtPVl1jrL1BM67ehyXsbZge0twH1v2r1SszfsBmaDHQkUAiaHRwwBHrIew TQDJgCMDjxgW
GWBknEauu8jkGEXZRSb42oCiyE00R90EJ9GNcBLdAG2Am8i0njEkIkcRQaLA UVSFbKIqtJ1V
oeVMy0CiS6G1AEQkAkQ+SHQe3EMkAkQmk4icRGOQSQQnUfVotbR6lFoCxSER uYio1WwYWs2G
6iyiuSEgGqwBUYGLKIdWsxyyiACHSAYQkZOIXUQ9g1azyEVkcojsNrNOami+ kxpcAIjsNrPi
OUR+QHSUOsWGQ397sngQdTE4VMw1RHDIaikrbCvLCIfy2C/rCHtrlP2e2oej EfbUVtae4BCB
IZ5WlnR6KBZ3b32Mv042Um9/vFt59REub6Te+QhgJ0kprqAsf3UWOCRgpxjY Kcf1lQaHCAoV
+24RZ5F8top+dgQOCRxSbX+hL7BG3sNSayARDqG1LBsYslvJ4BZiMFSPaWRQ FDxtgyGaRtY5
DJ0u3kZGLWSWWwiOIQ2G6grdQgu8bqFhcAsNN24hDYYwfQyioGkTMh3PFIq1 j7FTiKEQwNBl
NRMDKDQpAQo5OULcMuYBQrcACDEUuj2PdjHozrwBQgyD7nGcQdoVlACDHskB AAXalAMIgggA
bQ60pZog0HJAH9IK9YSlJ6sBeaCtlp6qPlc9VWX0M0t8WXT5+biedF6insJ1 W2M6F+eNniTt
B1Sy9LgFjggg2eBoEwDSo1rL4TRaHgNGttPI7yyKt6HFQdF8gKJ5QevZXMCi CBIRKCJIZEDR
LLW+CqCoCpCoCpAIuhqA6CroSkCiKwGICBRdDkhEgCgJEl2k281MqxlDonO1 k2gsQBEgUTUg
EeRCIm4zWwj30AIAoggSDQmcRHEX0fQc2sygaQEgmhJAokmAQ6bVLGObWb6z GgYRIBoCQESQ
KHIQNRYQ+eFQ4oQyBkOWc4hcQzHnUAwOWRPKCAqxisEhXxA1X8bTyorBIdc1 FDiHYnAoa0tZ
pTiH7n/2EWXrAZx39fiupxsNhggsCRyShWDRhWA7dpFUGhwi59CDP3usqKQm 5HshtQYEDgkc
Ejh0QKlgQfZv+zAqCQ51AhyyJ5IVtpKRY4jA0LFBxpAHDNXzRLJCMDQW4dOJ I+qt0GmTLWSD
IWQLAQydSWAIMlPIfNlC7BYaBig0HFDo1AgK1WL6GBRNH+MWMsoUMrlCq2NQ aLy6lKEQwNAV
NQSFJmP8/OSgdcwETMfDpa0coQIoZAOhOQEQmqvuIigE3Z2fr+7Jc6tY1Cbm cwa5MOgxgkE5
wCBoSw4gCHocYgj0JJxAWy09BRD0s1DnqaerjZ7ROl/rWUAfW89VXaBYz1rb 5rILC0T72HoG
5yOdr57G/ZMYLBFE0iBpP8AR9KSWAUePB9qCU9JmQKPHIIJFBhi5sChqSYu3 obGrKAJFxlG0
IMgomo9gawZFc5FRBFBUBVAE3VgFN1EVIBF0PQARQaJrAYmuBSAyoAgtZxoU GUh0uQWJyE1E
LiJqN1uNLKJVgEMEiC4CILoQgOgCnUdETqLTkEcEJ1E1IBHkA0SL0WK2CO6h swCICBLZLiLT
agZAlIOLKAcXUQ5tZpAfEMXbzBJziPJwEOW7qOFlAESd80erTlDkIAIYypcA h2wwlASHsriG
nDDquHOoiGuI28oAhnZrOJQxiDoARXtqH1FZ4VCspaxS4JBrP5dpZSVOK2vH MEMW9eVd1BMc
euL1J9SbH7/ZKlVq5pDUR3nro90eT4FDAocEDgkcaoc1kASHOiuMqldmVH06 GDoO4dMJYKj+
ZDUcilrJjGPIgKGuahzkTiPzhk5zvhCgEIOhOXUInYZcMGSyhYYiW4jdQgyG 0EZGbiGCQrVw
C0GJYdMaDI1XayGCQqTLGQrVAApBV6ONbB10DbKFGgaFLJdQCITmq3vzC9R9 0P155AbljUPI
bRVjIBQ6gywYRCDo8RwcQdCT0NYcYBD0VC6CQE/DDUQyAOg89Wyg56oBd6Bt gbZXX6i0AHxI
z2tdFNMLOO/T81UXYz9b5nbbLW3D9jYHJjFE0vBoP6AR9DMtACPIBkbsMrId RuwuojwjO7/I
hF9z6LWZmnZ/OCFtkQ61vgdw6G7oLrSc3QlIZECRBYmqAImgNEjETiKCRBEg Mu1mBIku0y6i
yWg5o1azSYBEE0NIdLEGROMtQITA6mq4iAJAZFxEo0MX0dmAQy4gMi4i02Y2 JwdABDjkAiLj
IqIWM4y8Dx1ERQBRHjlEgEMj810zACKMug+CqtMyiCJAFIAhDxzK5BoK4BC7 hkLnUBbXUCIc
ygCGPHBoN4VOu/K5hnAZgaEQDpXiGqo0OETZQ+OmT1CHdjhca/bSeUo7hijP oJHtZHx7cQ7J
YrHdLnAzQMRKhUMv/mqXzhzi/CGaYHb7w/dIzk6GmpDPS/FJiVlag1P3SWlJ bmy7s759Qjt1
uf5d9f1BRzKH2r5rRJw/8h764FAIhgCHonH1NJWMwqfJMXRM4BgiMHR8YSsZ OYYYDNVzxhC3
knUBHGIw1E2ZjCEzpj4NDJk2MuMYCsFQnS902g+GVgIMabeQBkOYQgaZ0fSn KW4ji7uFDBTS
LWRwCmm3EIOhGoZCU5EpNA1j6M8wY+gT28cSWscKoBACpeEYegBgaCPA0IN5 ZAflkRsERQ4h
cgbF3UHaGRQCIQsGERDKAQRBz+QiEPQc3ECkbdB2gCDS81oAPZZerL5YkX4O yGO0SuulkrUa
t2OZ+3gx0Au4XxbBJIZHGhzthwsp0LP7CRbZwMjAIgZG5C5iZ5GdYUT5RTYo IkhEosloZjqa
DYoWIaMoBRJVwUlUhZYzDyQiFxGJW83ISRR3EU0LWs2mAhIZQEQygIiyiIyL iAKrYy6iagZE
xkUUbzMbiSyikcgiYgfRqdpBFLaZ5QCJygGI8sgggkYDEBEcGhEDREkZRGmA 6FjVNX+sMmPu
O8BB1MG4hhw4tBuZQ1445LqGcN4GQxoOFQuh5iDqInBod1pLGV0XuIZ2I2/I C4bcCWXsGioB
DhW4hioJDtG0MsoGofwhFmeFDBo1VOBQ2l+uZYEni/wy1UAlwiGeWEbfJ5Qv xKLzBIsEfggw
LloD4hwS51A7dI0IHBI45MKhTnAMERzqSmBIHaW6qw6qR70BQ730yPo4GBqg 4RDCpzljyAJD
pxIYqkf4dH0SGOoOMNRdg6FJKa1kiWCozjeNLMoXWo5WshXIGDJgaGQcDNUa MERtZHo0vSdb
iNxCBIauhLRbCFBoHYGhGriFaihs2oChDQBDN0AFU8eskOnbETId5gmFUAgj 57VTyIVCiyIo
lEeGELQp7wdCBe4gACEDgwwQehZ6LgcQBEUg6EJAIKMXAYN+Hgrgp3qVellr tdYOEsDOzqo1
BdqFy9Lku80O3Ib1MrZJL+H+SQYgGXCkgdF+OI+04DiCfLDI5yxKBkUm4DoK t05yEyVAoio4
iQCIboNuCSDRTwGKolYzZBJZrWbXwT10LdrLrtFtZmegzcwGRFMtF9EkDYkK ARFcRNVoMwMg
Og8OInIRxQHRKIRVpwCiHMKqSwZETgZRvpc6LY9JZiEgMu6hrICob/4E1Qcy DqLjVU+oe/44
1Q1wqCvgUBe0lhlAZFrKOJD67odXKy8c8oAhmlYWg0P7XDjkyRoiKMQqyBzK 6BrKAoeSXEM1
xjWknUOluoYqBQ6RW4gWanS67a2XjVMIItcQgSG6btV1l5YFEIlzSBaCRReC ZQItbfFxKg0O
XXvbDfr7o3PProryh/g9YScRXTd45DABRO245jN9TgUOCRwSOCRtZe2wBmw4 pHOGuJ1Mg6Gj
VA/AoWhkfZQz1B/TyQwYCiaTUfi0BkMn6VYyAkMjNBjCVDLAoTH15BjidjJy DDEY6pEKhmb6
WsnIMQQwtCCAQ9GY+jQwNCp0DF0IMHRRrckWisBQ1EZm3EJBtpDlFloHKERg 6DqAofU1cAtB
BgzRSPoZGEc/E+PoMYa+KBTi9jEfFFoMp9Bi9YiGQgiUJiiUR4YQtCVvt4zF HULsDmIYZIAQ
XEHQ89ALuTgMegmOIJIBQasAgVapndUAQNAurbXqF4Fewekr1ZeoV6ouUa82 QnT7V6pwv6Eu
AVxaq7UzEIEjA40CYLQfwGg/gBHEsIhAkQ2L2FXkB0WcVWSmovnazkzLmXET JTmJ7qpaqEh3
aEC0QAMi4yKaZ7WanYk8otnII5oFSERZRDMRWE2AiLKIpiOL6AwNiSiH6EoE VVNYdVKbmXYQ
VaPNDEoGRNRilgKIAIfmQ3MBiJJazBJDqvMIqc4jpBpwaBzgEAOi0Wgt4/ay EcgfogwiN6Da
jLk/SfWHuL2MARHBoR6AQ90Bh7oBDnUFHNKAqAbuoWJwKAkM2XAIYGh3DA4V AUMFzqHH1LtV
gEPFHEOxlrJH1Z4k55AHDu0hMJQRDnldQ5UCh8gpRM4htqG7FnUacS/TylJa G2RhJ4v7MtVA
pcEhgkJp7iB2FWUCBGU6xvJYbRBQCxwSONQOwYA4h8Q5FIdDQc6Q7RoiOKS4 nYwDqLmd7HiM
rO8YuIZO0nAoAkORa0iDIcjkDHVDzpCBQxPRUjYJmgzn0BQ9rj5lKhmFT1PG kA2G6oaotIyh
yDFEYAgZQ2glC8FQ7Tg184U+atYLfaF+6qxfDi4MnbbbyLRbyAZDaCOrARiq MWDopwBDN+dn
AQzN8k8fg1voHgRNR5lC3D52FtrHyCnEUOhsQKGzC6FQHjlC0JN2hpDVMhZz CGkgBBgEvZiD
M0grgkEGBMENBO2CfgEYRCIA9Gqg16ovVaTXtS7T+mWgN6ouU0aXZxBuh31Z r2P79Srct9Zl
gE2Xar2idQnAEQEjA40IGBXAIstZFG9Du1Bdv+0MtR6ivCIOuDYT0sw0tCeq EGhdBUgEba5a
oR6DNlXBSVS1TD0CPVwFSFSFdjPogSpkElUtVvdB91ah1awKeUQQAaI7Q0gU uYhuRlD1TxFU
fRNkABG1mc1CYPVMDYlcQGRcRAmAqBo5RNDF1cUA0eggg8gAooIMohxazDQg ovayQkBEAdVJ
U8wmAg5NAByyAdFYQKIxaC2zAVHxgGpfe9lxAETHAhARHIJ7qMbAoU4BIPqX 4z+tCpxDaWAo
EQ4lTCezXUM+OJQVDNGkMkAhAkNeOOQFQ8gasuFQXbpzaE/9Q2oPwSBX6kG1 W21U06efqOg7
/ICOHTuqdVvXqZfw/8v2//U4V0Q76neoUHXYTtHOup0qplqch5atX6b6jRgY gh43d8A9T04h
gkM0rSwJDlH20IHfPkicQ0kLFFm0ChwqUw1UGhyiFjICQElAhiaZkXuITgXa tEFoU6a6L/re
CxwSOCRwSJxD7bAGGA5xO5kOobZdQwBDvZTbTha5hgajpUyPrE9qJ2PXUD3A EMRgaAKgEMEh
A4Z6AQz1UmYyWV81A6PqZ9rj6sOcocgx1HHlf6vPffdTMX0e5yN9GtufVj/o 840ADI1WF2g4
dJrqOPu/1Be++xn928DWv37nM2rQpccU5Av1WXGk+uJ3Pqv+DTr7hSFwDBkw dCPA0E01M9XA
FUerL33nX7TOef5UdRvG01ML2ZdxPq7P4fzn1FcsrX3+tMApxFBoCZxCS7VT 6MrnJ6qvfufz
Wl/z6guqx5jDdNsYOYSMS8iGQgBCgEIv5+AMggph0FrAoLWAQJdoxQBQNcAP 9Cb0q+ortH4d
05XqN9VQlVGnXodgrfdFLb6Mz5/S64fq11W4j0BvAiqR3sB5Aky/hF7XuswB RgyLioOih945
W339O1/Qoolpx/X6TxyzLzgyx5GO5zG9/kNteGWGBkSPARBdum0i3pfPa41c dpIGRBsBiCJI
RIAIk80SANGtaC+7RQMimmhWHBAt3DZE1xSp57Ij1WXVyCGqRlA1tLYaOUSA Q6sAhyJAhElm
QYuZCammFrMxyCCKABHnD4Uh1YBDCyFyD3F7GTuIzASzQXqCGQdU85j7ybm+ alIeAdUWIBoX
tpd1DwGR215mxtt30uPtjXvoZDWgwD10PNrLjkN7WeAeqgEgAhxiQORtKysG hhgOBa4h4xzK
CIZicOgxtbsKzqHMcIhyhhLgUFo7GcMhgKE9KXAo0TVUSc4hCqMWOFQ4pYxD TH8nmUOyeG+G
hXClwSFyDVH4tMAhAT9FAVDa50vgkMChdggGxDkkziEbDhkwZGUNwTXUi1xD gEN9lOsaonYy
cg0RHHJdQ5101lDYTkauIQ2H4Biqt9vJKIS6ZwCGegMM9VbT0yaTBa6hhXAM ERxy4Y7v/IFH
fxGOIQZDY9VBR/9bHAgBEhEUsm/bYcz3rYyhqYrgEF9/9gtDY2Dop4BDgwCH +Ppznx8BMDRH
3QkRGCr2HC95fhxayOJgaAvA0ONoIbvq+UlFb0/3/8OjDzRtYxC7hF4OoNDO HBxC0K4cu4Mi
IPQ6gNAv4QwivQFXEIMghkAa/kC/1bpKvRXo7eqrlatDO3wnyJX9onq7CtdD BIfo+dF1b1Xh
9tBvtQxQ+jW2f43TX0FvAhSRCBgxLIo7i/ygiLOKll0/TD9Wr9GH61DrH3aA m8KBf+55gkR3
vDNPu4gu3xYd61GAQ+QiMoDIdhEhiyhwERU6iOahzSw7ICI4xM+nF+DQ5dVo MQsBETKIAIjI
PeQCIpM/xCHVY0JA5LaXLcaI+0U5BFSH7qH0/KGC9rIQDrntZT2QPxR3D1F7 Wbbx9h2RPURw
iLKH4B6qgXtIw6G4eyjmHMoChggOWWBotw6jjuDQbgqftgOovc4hA4Z2V5Pg CEoTOYa0IjBU
4BxKayfjlrIUOJQKhioFDh3a4TBQ5S5eOPTq+7/Sk8vo+nJMVpHMIVkkNmqR 2AyApiWfX6XB
IcoTIvfQ63t+6wVEfH1LHnN57DbwnSRwSOCQwCFxDrXDGiA49C9L/9mfNaRd QxEc6qeonczO
GuoIMHRCdtcQw6F6n2uI4FAfr2vI1052ggWHOsz+vhr/Ylc18cVuahI0+cXu WlNe7KFm/7Kf
hkMXwjV0+Nh/DxfkBx39JTX1iR7qklqMq6+doEbecGIMEvUGEOLw6b4rjgpv twRwSLeSQQSG
bq6Z5cChkRoM3RU4hwgAfP/or6mLnx+rVgdaA7fQWkChCAyRW2gJ3EJLkStE YGgZWsiWq6uf
nxw+7pBZx6rrnp+i1m+fqq7fPk2LoBADhpu2TzetYw4U+gVBIejVHKAQ9HqO HEI2ELoMrqDL
4Qq6HCDoCkAgkgFBDIDeqV6nfhfo9zj9ffU16n8cHRbAoYMAhPR1Vdco2taD QXDd76pwH4He
CeDR2zj/FrZ/C/1Gg6I4LIpAUeQoovYz03oWdxONmHGCfiyCRBRm/cMOB4XH ZvH1Q9R1aDe7
dts0dcljp6v/ssDRoBnH6jazKxw4xG1m2QHRPOQQGUBU2GJmZRBVI4MIuqZ6 uiJAtGDbYLXm
T8i3Ahy6HHCIAZFxD9mAyM4fOg2AaCwCqscWuId0e1kOI+4hgkNnBe6hqL1s iJU/NEiRg8jr
HgIc8ruHDBzi9rLi7iHOHjpB9UUodR+IAFHPGoZDyB4K3EPcWhbCoY+eUBQ2 7Wo3wSBbmE4W
waEt2I7gUFEwpJ1DERjaUwwO2WAoCQ4VaycrAoeKgqFKgUPr7rw+oMeHYXz9 XPUAWsxu3XSX
On36xHBymR5pX4Zx9gKH2sBCrMIBTGuGASEc+uhN9WYr1Fe/8TX17KsvZnaR UfA0Tyfj8fXU
QsZj7enHwvKLz818f635vZPn1oTfbQKHBA61QzAgziFxDtlwyHUN6awh7RrC hDI4hzQcUhRC
zVlD5BoycMiXNUTOIZ01FLiGTg/g0ETAoUl6dD23lLFriOBQX7SU9Vc0oaxg bD0FUMM1dBZk
w6GTVvxQLcNksuWYTMbTyc7F2PrzIHYNLfrDELSSfVqvRQgMrUHm0NoADF1W iwBqaN4LA9Dm
Y1xE1O7DU8lsOLT0hWFhO9lPAYZugQavOCYEEee9MFLdVTNX3Y2MIXYOff/o r4cj6gvzhfxg
6EnkC62znEPjl3dSz+Z58phpIbtqixn2Q/rp9hlh+9it25F7BG18baF6xYJC P//fi9Td2+dA
c9WvcgYIbX51ibp/2zy15dWlgEFXqVs3z1RnLuut5kB3bJ4VQqA/VF+Ldhuj Hb9bpeYt66t1
ztrhak/1derwDt81x/Y7/6bPk2ibLqPr3q26Vv0hEIGjOx6bjcfoo7VszVA4 jVxQZBxFNz02
Q81Y1gvqqaZD518/MsgoijuJDunwLfWN7/yrevSdpXramQ2HKIuIWs04i+je dxbqdjN6bv/V
4Zs6i+jKbRGIG73s5DCH6JJt49Ua6M4/Loi1mF32ymR14bax6tJXJgYZRPMR VG3g0KLHhqhB
y45VA6EFjw3WGURLtg1XZ0NX/gm5VSEcGqoB0VrAoSurp2n30Nxtg9ScbQPD 9rL+a49R3ZYd
rvridPHvhiOgehzay8ZhghlNLxur5v9usOq59kh18rIfq5OX/1idBM3+/cAA EDXCPZTvpybH
3EO9EE7dE+HUBIdotH169pDbWtYfE8v66cllgEM1cA8BDjEgMnAocg99jjKH HsG0Mg8cKoBC
BIZCOGTAEMOhTGBofxwMpcIhFwz54FBWMESTyhKcQwYOeXKG7MvaeuYQt5Kt Wn+JBkGurY9c
QwSPygGG6D4EDjXhAkqgTpuHDJUGhwiYEAyi9jL3u6VYHpHAFvmuCGtA4JDA IYFD4hxqhzWQ
DQ6hpSyAQwM0HLJbyk4smFCW2lKGtjINh+rdlrI+aCkzcGgW8oZmI2cogkPW dDINh4YmwqHC
EGrjGup7aeT+6XdpB4Ch00PXkIFDGFkPHY2WMv4tcdYLg/Rksn6Wc2gZ4BDl DLFr6Jaa2YBD
x4a3OZ/hUE0cDj2QP0ttRPA0wSEzjczXSmYcQwSGtkLXWM4hgkPP5aMJZNRC Nml5F/243wDo
eOz3S0yuEFrICJLQ5T8++lvqNXIK5eAUgmYs7xm0fv2r+k0ODiHo0KO/HbZ+ DR4dtcfxMRg6
+hi02FyrYc/e6vXq8g3j1LcC6MP7HAH4w5fR6fvVG6Drw8vo+r1V69UeretU 114/Lvy9BpfR
xm0LdTsat58d2sE8N1c/BgiiqWkmwJqmna3Rr5n0MsDQz6FDLOfQBsChbQip fg56pup8hFWf
p7OHIji0sgAObUJA9aWAQvzYI5adiBazxQBEFFK9SH2/w9f1dQfj9C5ML7sD 08tozP1hvSJ3
WnjbNSchr8q0GPZbdrSGQ4u2mTY4Uu9lR2k4NA9giC8buPa4gnbHLwBcznl1 UAiHBm04Xn3+
OwZ42qLL+m44usA9lDV7aGquv5oSwKFJCKWeqIOpGQ7R5LKGtJYhmLoG7qEa hkO2e6g4HPK6
hRgMaTgUgSGzXaSVTLeWAQyR4BYiKMTytpT5wJALh7LkDAXj6/UYew8cyuQa qhTnkB1STcHU
5BwiabdQMNZe4JBMK5PFetMv1isRDnHd0Ch7AkUsqaemr6eKOcYChwQOtUMw IM4hcQ4xHOIg
6m46jNpMKIvlDQEO9YdzSMMhFcGhoQijHobR9ewcIjAUG1/PQdR2Sxng0GTA oSn1HETNLWXk
GmI4ZJxD3gllGg79MFwQUwj1N4/5ovom8oVYlDV0IPKF5vyyv55QdjxCqHkB PevFPhYcGq9d
Q1doODRZDbn0uHA/cgy5cOjfj/6K+vejv6r1vUAURM33fQHg0N0AQ/dYcIgC qEcs7widoEYG
GrX8RHXfnxcE4dOmncyAoeUaDD2VXxmDQxS0TG1ktkL4MLNjCIaohcyGQwyG 3shdpmaGcOiL
AENXqregQ482WUHG9fNFNWFmJziC+oQtYQR7fvG71YA969Wrv1sTg0BTZnZV i5YNUEd2iIAI
7f+/1TeqP1XfEINDH1QBGFVdr4aNjkDaUGyT+8huSaPWM2o7I/cSPSfKLbro +tHqXribZsI5
xM+1/+ijQkC0/rGp+vI+o4/EdLPVGhDZcOgGwKHtcA4RHHoWcKjH6MPC++k2 +lBMMjtHXeU4
h1w4NFLDIQqoXowpZoVw6E4Aop4zjgjv99Be39XuoeNHR3XHcGh99Uy12IFD VwEOzbfgEOVg
/Xfvg1R3uIaOGH1weL+Hj/6edg+dnztNfSEAQ4eO+Xc1eXsvNWZLF/UN1D09 zudw3azfD0ho
LbMnl3lay/L91VQNh/qgtayPhkMTAIcIEJmx9r7WMjPWnrKHCoOp0VpWE8Gh PnAOkXsoqbXs
c8d/JuYcKgqGPo6DoT0Mh9xsodj5AAyhpcwGQ17nUBIYsuFQDcKps+QMpcCh zGCoEuEQgSIC
QpQ1FBtpX4aWMnEOyWKwYharTeTSqmQ4JO+9fP4bXAMChwQOCRwS51A7rAEf HOrhgUOmpSyC
Q4MVt5RFcGhEfTS+nsOoTUsZppTZLWU2HAIgMkHU3FJm4NCZaCub48Ahbilb 5MAhn7uELzvj
xV4aDtlB1LNe7Kvh0KVoK7sMeUOXQ1cAEBEcWvhi5N4gOLS+5oyYcyjtsei6 CA7NLxpIfdnz
4zUcsnOG2DX0M8Chay3nUNLjkmvomi2Tg9BpjKUHHPqm5RwixxCBoTehWRYc IjD0du4qdZgF
h+7cMlu9m7sGQbvXqnMuGR4CiS3bzlZ/hBPogrWnhpet2zBBfQgI9Jfqm9Sb v7tMffs7X9LX
0elfqn+qL+fLCB79qeoG9UeIHUYEiYyb6Dr16z9eEcKoFWgxI0BkB1xveWVp EFx9hbrw+lHq
7m1zg8lml2pANHrGifqxV14/PIBDq2NwiKeY8SkfS3IP/fSVWRh1f4662oJD Y9BWRhPMLtsW
te0RHHoQcIjcQzYcIgfR3Xq8/YLw/f5eh6/FsodsQETOIT8cmhqDQwSGLkHm 0FqEUq/B1DIO
TaeWyAtz49QZ2/uE70XPS45UK3OYXJYbrc78/SDVb8MxauprfcLWsrM8wdQ8 tWx2bnCUO5Qf
oM6ApgEMTUVLWWlwqKsfDtVgahkUh0PGPZQFDmUCQxYcIjC0Zz9gUVYwVAwO pYEhhkMAQ3s8
cCgcWc8ZQzYYcpxDJYGhtg6HqF2Mwqi37PpZGEbNcIgCqKnNbOnqlQYSCRxS iRPLGgkKfv/X
95RIjgHVAMGhJ19/Uv3qo1+1StHze+7VnxetV3IJde7ZTa24+LyCfekyaikb f8bkovcjn4vK
+Vw0GAzR96vAIYFD7RAMiHNInEMuHOoO55ALh6K8IQcOARDZziEXDkV5Q2lw CK6hehsO9XPg
0AA1z5pSRnlDLhz6fp+vq5NX/kjrFKjTih9rdYZW/OVUDYf+s883LeeQC4fI OURwaJIac+PJ
MeeQC4e6zvqJHl1PE8oGIWuI8oYO62Pydmw4dG9NBIfIOfQfyB0i/UDrG1rr X59aEELNriEX
Dh3f+wdq4vLOWpOgjr3/U7eT8eOuvec0DYZeceDQG4BDBIYoY8iGQwSG3rHg ELmGGAztyV2n
Nm8/O7zvx7ctgRNog+re+ycBAPo39VfAn78BAn0EfVx9izqqw/dCOPQRzv+t +uYYHPozQNKT
25aF93nF9ePVZkCnx6BN2xaHmUXkIvo9MomWAxLZQIwcRKf0+qGGQ29g7P0v Mfb+dYRTExz6
UZA39Pg7y9ROtJi9DPeQ7RzygbX/Rij1uXeNVE9VnVsyHCL3ELeVMRy69JUI JA1edpyZXFaN
0fbQ8m0jIsdTRjjUY9kRBg7lAIdyE3ROlnZ3BXDoAgAidg7R5dRK9k045Y6e +QM17bW+akmO
g6kz5A7lMdY+P1DN0HCofwiHpuhQ6rhziHKHXOfQqHxXNQJi59AwHmlfg5H2 ARwaEHMORblD
ZmJZPJSanUN7kDkUwiG7hUxvAwDZIigUgKF0OGQ5hggMpcGhYmCI4FAAhlw4 VBQMWXCoZDDU
luEQZQwZS+BBOlPIbi0jGDRo1NAwg4i2BQ41XVuZLIArZwHc2PeyEuDQQz/b rOEPfb/4ABDD
Ibr+sKOOEEDUTuCwwKHdBZl75fp3NebyDVrB7X/TafuCdatV75G91a6aXWpX bVw7a3eqVNXh
eks76naoVNXj+kAv17+sikphn+D/l9RLauM7GxUtigWOCBxp7zXwz//8z+pT 4/5JcVtZyXBI
nahbykhNB4cGqvlWGLULh05aeYhaXocwamhl3Uh1bh2FUY+OjbDvuuLQcIE+ /MYTHOeQgUNX
AQ6dMvuQcL/Tbuyk1tfGnUOUOWTnDd2KzKEhVuYQO4dsOERQ6MGaReoh6OGa KG/IN6EsCQ5N
QObQdmQOPZ+/QL0A/Tx/oXr6zytDQPSjow/KAId6ha1aBg5dHTqHssAhbh8j RxDDoY8BgfYB
BnUI4NB3cB3Boo88cIha0Io5rxgOkXuIMpAICrm3IWfUBQimJjj0GsR5Q5Q9 RHCIWstsODR8
xvFq4rIuioKpSesxtYyyh36G7KGywKHqheqCbWPC56nhUHXTw6GR95zizRyi 43Vw728UD6XO
D1azAYZmAQzNBBjywSFyD9ltZVEodTSxrAAO1XRSQ6HBDhzqH2QO9Qlzhwon lnWpOVoVwKEi
YGgPIJENhvxwyAOF0uBQFjCU98OhTGAogEN7KXeoPkMAtRtQ3RYDqbe99bIG P+Qaom33RyT/
0OQx9lTI6+4oTyi1BFIXtpY0FijI7SsHLlUCHCLgQ3DojofvTQU/NMY+CSBJ TVdOTfN7KXBI
4FAiJBI4JC1j4gwrqIENGzYogkM0yt7OHCrJOURwSJ2sTi0bHHLbysg5RHBo ECaVDdaTyjLB
IQAinlRGzqFJT3QNF+//1edALxwi59AXvxtMK/vuZ9XFfxibCQ7ZgdS+tjKC QxsBhggQ2XBo
E8bXZ20rc+HQi4BDP89fpA4BFKLfOeQi2pVHW1ne31ZGzqFTepucJgIu6c6h a9Vj2xc7bWVx
59BfgpYyA4lujjmH6Pxf4Siy28ooh+iBzfMj59CG07VzaBP0KJxDj2xbpPXU qyvU76qROwS9
XX212v6789XStYNVp96HoF0uAkUEiF6vvlTdse1MfZ8n9v5vtasacAh6uToO h27cNl1tr75Q
bYOeq0buUPX56pnq89TPoKeq4Ryq9rSVVXvayqrRVlaNUGroy3CD0eNq5xDg 0KWvRs6hHjMP
j8GhBZsHN4lziHKHzs2NVeO2dFXHzPxP7RyyA6q7XnI4Qqkd51B+mJqXR+YQ wNCZAEM2HJoO
11Ax51By5pDlHAIYGuLAoYa0lWnnUAPAUCEcSgFDPudQVjDkgUOZwRDgEIGh vfUEh4pMJvNd
3xbh0MBRQzQc8oEhbiuzARHtS21m5fgrp8AhgUOy8E9e+Ld1OLT2msv1P7J0 muV9ptYzAklZ
9pV92jYwEjgkcEjgkDiB2rsTKOvrf+ONN7R77utf/3oBHMoUSI1QagyUV0M1 HDpJnQpA5Msc
GpsSSD2VAqmhaWgrO8PJHJodZg5FcGgBANFZAETF4NA55BwiOFQ3Wl1QN0a3 lV3k5A4dOfZ7
elqZnTnUYWw0qexHfb6lrq3F2PFa/7Sym4Mx9uQc8sOhaFqZgUNnBe6hxXpa 2aOYVsZwaHOQ
O2RPKnMDqQkObYNziNxD5BwiOHTT82eEziEDh1ZpOOQGUnNr2U+CyWQEhzhz iAOpyTn0P7l1
6g/IHHoXmUObti8KgQZBnA+QOXS+lTl0y93T1Z8ROk1643eXxjKHqIWMxPlC 5Dj6I/azA60n
zeyMIOD1mBR1nXoX09Am4PyKtUPV1leXazi0bO0QNRuh1ONmnqJ+U32l+nX1 FepX0NiZJ4XP
66FXF6kzlvXQ5xesHaDB0A6AIRcO3RDCIUwsAxx6BnDoaQ2Hzg3hkB1IrTOH qmlamZM5BDhE
YOj2P82NwaG7qheoO6EvB8HkFFB+C5xDN+u2sjNjodRZM4fstrLVnrayM18b oDotP1RRGPX8
3w/WmUPLg8whBkTkHloEOKQzh/LD1QKAofkAQ3PzQyw4NFA7h8g15MKhBm
Re: Equinox Server-side incubator [message #566123 is a reply to message #11697] Tue, 06 December 2005 10:35 Go to previous message
Thanks Eishay for the info and getting to talk to them. I am also involved
with WTP and server-side technologies.
Unfortunately Geronimo was removed from the latest WTP releases (?)
Or it might now be developed by Apache directly and has to be added extra?
However, for the server and mid-tier part I am expert as I have designed
and developed systems in that domain for over 10 years (if you include
other systems than Java and J2EE) now. Besides client development based on
Swing and (more recently) SWT/RCP.
I hope, you don't mind me using that illustration in my OHF presentation
next week ?
And if you need any help about flexible and modular project structure
(what made Geronimo work as it does today ;-) I am expert in using Maven
and also integrating it with various other tools and environments.
P.s.:
What is Vista in your picture? Not Windows "Longhorn", I guess.
Werner
Re: Equinox Server-side incubator [message #566213 is a reply to message #11844] Tue, 06 December 2005 13:31 Go to previous message
The project proposal has nothing to do with WTP, though it is our
intention to integrate with it once we'll cover our current scope.
You may use what ever is published here, let me know if you need to
cover something in specific, I may have something relevant handy.
VistA is the "Veterans Health Information Systems and Technology
Architecture", a very popular in the veterans health system. VistA was
developed using the M or Mumps language/database. Currently available
releases utilize both GT.M, available as open-source for Linux and Unix
computers, and Intersystems Cache, a proprietary Mumps compiler.
Eishay
> involved with WTP and server-side technologies.
> on Swing and (more recently) SWT/RCP.
> next week ?
> P.s.:
> Cheers,
> Werner
Re: Equinox Server-side incubator [message #566260 is a reply to message #11904] Wed, 07 December 2005 15:45 Go to previous message
Thanks for the offer (and explenation)
Since I already got more than the 10 slides allowed for the 15 min. (well
if you take away cover, etc. it comes to 11 or 12) I think your diagram is
more than enough.
As WTP can for the server side be just one possible support, I guess
Geronimo is also just an example (might be used for a reference
implementation?) but not the only one.
Same goes for Spring. I guess Servlet and OSGi are generic, so they are OK?
If you want to modify the pic for future use, maybe J2EE (or Java EE,
since v5 does not match the 2EE any more ;-) instead of Geronimo should do.
Not so sure about Spring alternative, but "IoC Container", "PageFlow
Container" or something like "MVC Container" might do...
Werner
Re: Equinox Server-side incubator [message #566412 is a reply to message #12946] Mon, 19 December 2005 14:03 Go to previous message
Since Equinox relies on OSGi on the server side, maybe plugins such as
this one (for Maven) might be useful for development, build and delivery:
http://docs.safehaus.org/display/OSGI/OSGi+Plugin+for+Maven+ 2.0
It is not (yet) listed under the official plugins for Maven on Apache.
As many other extensions for Maven might be hidden e.g. in Geronimo's
"tent" since it uses Maven everywhere...
Werner
Re: Equinox Server-side incubator [message #566462 is a reply to message #13173] Mon, 19 December 2005 16:31 Go to previous message
I noticed this activity, the problem with it is that its based on the
Apache Felix project which is another OSGi implementation, not related
to Equinox.
Unfortunately, we might have a problem here since Geronimo is under the
Apache organization, therefore its community might prefer to work with
Felix.
It is true that they both are implementation of the same standards, but
we all know how things like these go...
Re: Equinox Server-side incubator [message #566695 is a reply to message #11408] Mon, 23 January 2006 01:39 Go to previous message
The project is going public at "the server side":
http://www.theserverside.com/news/thread.tss?thread_id=38611
From the latest developments and community reactions, it looks like
we'll have good base infrastructure to expose the OHF plugins to the
server side.
Eishay Smith wrote:
> Good news.
> We have good interest coming from both Geronimo and Equinox projects on
> having OSGi bundles enabled on the server side.
> I participate we will have good collaboration from both communities as
> we will be one of the first showcase of such technology.
> Take a look at this link:
> http://eclipse.org/equinox/incubator/server/proposal.php
> Eishay
Previous Topic:Facets-problems when creating a 1.5M4 project??
Next Topic:Facets-problems when creating a 1.5M4 project??
Current Time: Wed Jul 30 19:08:33 EDT 2025
Powered by FUDForum. Page generated in 0.06173 seconds
