Home » Newcomers » Newcomers » cannot launch CDT 3.0 from eclipe 3.1 on lin Redhat 32
cannot launch CDT 3.0 from eclipe 3.1 on lin Redhat 32 [message #124676] Mon, 19 December 2005 09:23
Originally posted by: learnerplts.yahoo.ie
I've installed eclipse 3.1 successfully on Redhat on lin 32 but I cannot
run the CDT plugin.
I firstly installed eclipse and it works.
I then installed the CDT 3.0 plugin.
When I launch eclipse I only see the Java options and not the C++.
Can someone help.
All installation instructions I have found on the net are for windows and
instruct using the installation wizard. I can see alot of ini files in the
installation area but cannot see which one to edit, if indeed it is an ini
file I should edit.
Previous Topic:How to apply preference changes?
Next Topic:problem starting server
Current Time: Sat Jul 26 06:04:34 EDT 2025
Powered by FUDForum. Page generated in 0.08851 seconds
