loss of focus on drag and drop from palette [message #124639] |
Fri, 26 March 2004 16:59  |
Originally posted by: felipeg.us.ibm.com
I have implemented a DirectEditManager within an EditPart to provide direct
editing on the canvas. The problem I am having is that when the user drags
and drops the object from the palette, the drop causes the control to loose
focus. This works well when the user clicks the palette and then clicks the
canvas to create the object. Any ideas? I saw some code related to OS
specific ctrl unfocus. Any ideas? Randy?
Felipe
Re: loss of focus on drag and drop from palette [message #124951 is a reply to message #124940] |
Tue, 30 March 2004 16:40   |
Originally posted by: gaslade.yahoo.com
Well, for what it's worth... this all works ok for me, both for a DND
from the palette and from a select from the palette and a click on the FFS.
In my CreateCommand, once the new part has been added to it parent
(parent.addChild()) the new child part fires off a "ForcedDirectEdit"
event ( my event ). The edit part for this new child is listening to it
model part and catches this event. This is how I handle this caught
event....
public void modelUpdate(ForcedDirectEditEvent event) {
request = new DirectEditRequest();
request.setDirectEditFeature
(IBaseProvidersConstants.DIRECTEDITGRAPHICALLABEL);
* need to async this off to allow current UI work to complete
* before this request is handled. If this is not done then you *
will get unpredictable results
Display display = Display.getDefault();
if (display != null) {
display.asyncExec(new Runnable() {
public void run() {
performDirectEdit(request);
I think I had to async it off because some weird things were happening
on Linux but it maybe the solution to your problem as well.
Guy
Felipe Gomez wrote:
> The edit text control inside the edit part is losing focus, and yes, I am
> activating the directeditmanager immed after creation That way, the user
> creates an object and the edit box appears allowing the user to name the
> object.
> Felipe
> "Randy Hudson" <none@us.ibm.com> wrote in message
> news:c49asr$e0a$1@eclipse.org...
>>Which control is losing focus? Are you activating the directeditmanager
>>immediately after creation?
>>"Felipe Gomez" <felipeg@us.ibm.com> wrote in message
>>news:c428kh$s4u$1@eclipse.org...
>>direct
> drags
>>loose
>>the
>>>Thanks,
>>>Felipe
Re: loss of focus on drag and drop from palette [message #125001 is a reply to message #124951] |
Tue, 30 March 2004 23:07  |
Any time you use async you need to be careful. It sounds like a fine way to
workaround the problem, which might be that SWT is setting focus back to the
originiating control for the drag source (the palette)? With async, it is
possible that the user invokes Undo between the time the editpart is
created, and the time the direct edit request is sent. THis would mean the
editpart no longer exists in the diagram. A paranoid person like myself
would put a check in like:
> public void run() {
if (!editpart.isActive())
return; //Editpart was deleted for some reason before editing
"Guy Slade" <gaslade@yahoo.com> wrote in message
news:c4cp7d$qrd$1@eclipse.org...
FFS.
> event....
> public void run() {
> Guy
am
> > object.
> > Thanks,
> > Felipe
> >>direct
> > drags
> >>loose
> >>the
> >>>Thanks,
> >>>Felipe
FUDForum. Page generated in 0.27687 seconds
