console redirection [message #124612] |
Mon, 08 September 2003 19:02  |
Is there a way I can do console redirection when I run my Java class
files within Eclipse. For example, I want to use a file called
input.txt as my standard input, but typing "< input.txt" in the program
arguments section of my java application configuration doesn't seem to work.
-mike
Re: console redirection [message #125933 is a reply to message #125896] |
Tue, 09 September 2003 13:57  |
"CL [dnoyeB] Gilbert" <ThisisFake@Fakeness.xyz> wrote in message
news:pan.2003.09.09.17.48.21.878997@Fakeness.xyz...
> >> work.
> > That's because that is operating system/command shell functionality, not
> > Java functionality.
> > I would recommend re-writing the app to accept the name of an input file
> > as an (optional?) parameter. Or write a wrapper that reads the input
> > file and feeds the underlying app that expects System.in input.
> > HTH,
> > Eric
> i am sure its easier than that. In netbeans their was a launching
> context, and you could put your command line options there. Their is
> likely a command like option somewhere in Eclipse that launches the
> 'javaw' command. I dont know where though...
To use java instead of javaw:
See the JRE Tab for your launch configuration.
Specify to launch in an Alternate JRE and then you are able to specify the
Java executable that will be used.
Darins
FUDForum. Page generated in 0.08090 seconds
