Home » Language IDEs » ServerTools (WTP) » Web Modules not showing up in Server Overview>>modules tab
Web Modules not showing up in Server Overview>>modules tab [message #124589] Fri, 22 July 2005 04:54 Go to next message
Originally posted by: madhu4277.gmail.com
I am having a problem with the Server Overview >> modules tab.
I have installed Eclipse 3.1 and the following of web tools
- wtp-sdk-1.0M5.zip
- emf-sdo-xsd-SDK-I200506230200.zip
- GEF-SDK-3.1RC4.zip
- JEM-SDK-I20050623.zip
- xdoclet-bin-1.2.3.zip
I have added a Dynamic Web Project for Tomcat 5.0 server. The problem is
when i add the external web module the same is not shown in the grid view
after addition, although the module gets added and the application works.
Am i missing any other software in my installation. Pls help.
Madhu
Re: Web Modules not showing up in Server Overview>>modules tab [message #124702 is a reply to message #124589] Fri, 22 July 2005 08:47 Go to previous message
Hi Madhu,
If by "grid view" you are referring to the Servers view, it is normal
for it not to display externally added webapps in the Tomcat
configuration. The Servers view only knows about projects/modules added
to the servers. It doesn't currently have the ability to see inside a
specific type of server configuration, such as Tomcat, to see what other
webapps it might be serving.
If "grid view" is referring to something else, please explain in more
detail. Thanks.
Larry
Madhu wrote:
> - wtp-sdk-1.0M5.zip
> view after addition, although the module gets added and the application
> works.
> Regards
> Madhu
Previous Topic:servlet beginner question
Next Topic:starting server from servers view or run -> run...
Current Time: Mon Jul 21 22:13:03 EDT 2025
Powered by FUDForum. Page generated in 0.03984 seconds
