Home » Archived » BIRT » EAR and BIRT report embedding
EAR and BIRT report embedding [message #124552] Mon, 06 February 2006 02:44
Originally posted by: vsanjeev.indiatimes.com
It is very difficult to understand for me that how you can embed BIRT
report design with your web application. I would like to achive following
1. I want to create a web application which will use the design prepared
by BIRT with test server query
2. Then in my webapp I would like to replace the connection and datasets
within the report design so that I can dynamically change the query
parameters (which will be selected by user using parameter forms).
So in summary it should work like
BIRT design + dynamic connection + parameter = report output.
Through BIRT documentation it is very difficult to implement above
solution. Also the dependency of BIRT engine is very high dependency. I
just want to use BIRT as a pure JAVA library.
Does anybody know how to achieve this?
Previous Topic:BIRT embedded in the EAR application
Next Topic:Pigheaded BIRT?
Current Time: Fri Jul 18 16:50:40 EDT 2025
Powered by FUDForum. Page generated in 0.05777 seconds
