Home » Language IDEs » Java Development Tools (JDT) » Refactoring: right way?
Refactoring: right way? [message #124434] Thu, 04 December 2003 08:12 Go to next message
Originally posted by: scheglov_ke.nlmk.ru
I write some new refactoring, it should create new CompilationUnit and
also change existing CompilationUnit. How to implement these functions in
right way? Give me please just short scenario and/or class names to use.
Currently I use CreateTextFileChange, generate unformated source code and
format it using following code:
return CodeFormatterUtil.format(CodeFormatter.K_CLASS_BODY_DECLARAT IONS,
src, 0, null, getLineSeperator(), null);
But I feel that this is not very good method.
Also for changing CU I am going to use CompilationUnitChange and then
create several TextEdit's. But I see that there are also class ASTRewrite
that is used in many refactorings, so not sure that I am going to use
best method.
SY, Konstantin.
Advanced Eclipse SWT Designer (http://www.swt-designer.com)
Re: Refactoring: right way? [message #124674 is a reply to message #124434] Thu, 04 December 2003 18:05 Go to previous messageGo to next message
Konstantin,
I recommend that you use the ASTRewrite to perform changes on the
compilation unit.
A rewirte creates edits which can then be attached to the
CompilationUnitChange. The
rewriter is aware of changing Java code. So it helps you dealing with
comments, formatting
and so on. If you use text edits directly you are on your own...
Dirk
"Konstantin Scheglov" <scheglov_ke@nlmk.ru> wrote in message
news:B33x5gmuDHA.3348@fairy.ao.nlmk...
and
> best method.
> SY, Konstantin.
Re: Refactoring: right way? [message #124759 is a reply to message #124674] Thu, 04 December 2003 23:30 Go to previous message
"Dirk BДumer" <dirk_baeumer@ch.ibm.com> wrote:
Thank you.
> compilation unit.
> Regards
> Dirk
> and
>> best method.
>> SY, Konstantin.
SY, Konstantin.
Previous Topic:Identation problems
Next Topic:cvs not working
Current Time: Sun Jul 27 07:06:53 EDT 2025
Powered by FUDForum. Page generated in 0.04693 seconds
