Home » Language IDEs » Java Development Tools (JDT) » mixing v3 and v2
mixing v3 and v2 [message #124311] Wed, 03 December 2003 16:01 Go to next message
Originally posted by: moopa06.ca.om
Do Bad Things(tm) happen if I start using v3(m5) on my code and then I
loose my nerve and decide to go back to v2? I am thinking about .project,
classpath file formats for example
Re: mixing v3 and v2 [message #124387 is a reply to message #124311] Thu, 04 December 2003 03:31 Go to previous messageGo to next message
likely yes. Going to M5 shouldn't be a problem, however, going back can be.
Re: mixing v3 and v2 [message #125357 is a reply to message #124311] Mon, 08 December 2003 15:46 Go to previous messageGo to next message
You should be ok as long as you use separate metadata dirs for each
Eclipse instance. The actual .project and .classpath files should have
no problem being shared, in my experience.
Re: mixing v3 and v2 [message #920900] Sun, 23 September 2012 11:38 Go to previous messageGo to next message
No Message Body
Re: mixing v3 and v2 [message #920901] Sun, 23 September 2012 11:38 Go to previous message
No Message Body
Previous Topic:Dependent class compilation
Next Topic:ASTParser does not parse javadoc comments
Current Time: Mon Nov 17 04:47:48 EST 2025
Powered by FUDForum. Page generated in 0.16588 seconds
