Any simple way for simple schema? [message #11375] |
Wed, 12 February 2003 04:48  |
Originally posted by: dwjang.jkdsoft.co.kr
I am developing a solution for database replication and choose XML for
communication. I got a
XML schema like...
<?xml version="1.0" ?>
<xsd:schema xmlns:xsd="http://www.w3.org/2001/XMLSchema">
<xsd:annotation>
<xsd:documentation>
Database structure and content schema for XI DB Services
(DBSourceService, DBSinkService, TransformationService)
</xsd:documentation>
</xsd:annotation>
<xsd:element name = "XIDocument">
<xsd:complexType>
<xsd:sequence>
<xsd:element name = "PrimaryTable"/>
<xsd:element name = "PrimaryKeyValue"/>
<xsd:element ref = "Database" minOccurs = "0" maxOccurs = "unbounded"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name = "Database">
<xsd:complexType>
<xsd:sequence>
<xsd:element ref = "Table" minOccurs = "0" maxOccurs = "unbounded"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name = "Table">
<xsd:complexType>
<xsd:sequence>
<xsd:element ref = "Field" minOccurs = "0" maxOccurs = "unbounded"/>
</xsd:sequence>
</xsd:complexType>
</xsd:element>
<xsd:element name = "Field">
<xsd:complexType>
<xsd:attribute name = "Type" type = "xsd:string" use = "required"/>
<xsd:attribute name = "TypeName" type = "xsd:string" use = "required"/>
<xsd:attribute name = "Length" type = "xsd:string" use = "required"/>
<xsd:attribute name = "Precision" type = "xsd:string" use = "required"/>
<xsd:attribute name = "RowObjIndex" type = "xsd:string" use =
"required"/>
<xsd:attribute name = "Nullable" type = "xsd:string" use = "required"/>
<xsd:attribute name = "IsPrimary" type = "xsd:string" use = "required"/>
</xsd:complexType>
</xsd:element>
</xsd:schema>
I just want to make and parse only this schema.
I tried to find libraries on xml schema.
Finary I found XSD on eclips site. But, I am new to XML Schema and even I am
not good at XML.
So I feel it is so complex to learn how to deal with xml schema with XSD.
Is there any simple sample or articles for me?
Thank for reading.
FUDForum. Page generated in 0.04102 seconds
