Home » Archived » Visual Editor (VE) » Visual Editor makes my computer freeze
Visual Editor makes my computer freeze [message #124239] Wed, 03 May 2006 02:22 Go to next message
Originally posted by: melref.gmail.com
I am developing a user inteface application in eclipse, using visual
editor.
Sometimes when I run the application my computer freezes and I can't do
anything without restarting it.
I have windows xp prof with sp2 and jre 1.6.0.
How can I understand the cause of error?
Is it possible that there may be a conflict between Java and windows sp2?
Am I able to disable or enable something about java in Windows?
Re: Visual Editor makes my computer freeze [message #124406 is a reply to message #124239] Fri, 05 May 2006 11:52 Go to previous messageGo to next message
Originally posted by: richkulp.us.NO_SPAM.ibm.com
Is there anything in the .log file?
Try jre 1.5 instead. We haven't done any testing with 1.6.
SP2 should not be a problem.
ishanour wrote:
> editor.
> anything without restarting it. I have windows xp prof with sp2 and jre
> 1.6.0.
> sp2? Am I able to disable or enable something about java in Windows?
Rich Kulp
Re: Visual Editor makes my computer freeze [message #124783 is a reply to message #124406] Sun, 14 May 2006 08:57 Go to previous messageGo to next message
I installed JRE 1.5_06 and installed everything from the beginning:
-Eclipse build eclipse-SDK-3.2M6
-EMF build 2.2.0M6
-GEF Build 3.2M6
When I create my project and try to run it, sometimes it works but most of
the time it freezes the whole OS. I cant even see the cause of problem.
May this be related with heap size?
Also Here is my log:
!SESSION 2006-05-13 17:36:06.515
eclipse.buildId=I20060331-2000
java.version=1.5.0_06
Command-line arguments: -os win32 -ws win32 -arch x86 -clean
!ENTRY org.eclipse.ve.propertysheet 2 0 2006-05-13 17:40:20.050
!MESSAGE
!STACK 0
org.eclipse.ve.internal.java.core.BeanCellRenderer.calculate JavaBeanPropertyEditor(BeanCellRenderer.java:142)
org.eclipse.ve.internal.java.core.BeanCellRenderer.getText(B eanCellRenderer.java:82)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.getValueAsString(AbstractPropertySheetEntry.java:738)
org.eclipse.ui.views.properties.PropertySheetViewer.updateEn try(PropertySheetViewer.java:1298)
org.eclipse.ui.views.properties.PropertySheetViewer.createIt em(PropertySheetViewer.java:368)
org.eclipse.ui.views.properties.PropertySheetViewer.updateCh ildrenOf(PropertySheetViewer.java:1254)
org.eclipse.ui.views.properties.PropertySheetViewer.access$2 (PropertySheetViewer.java:1175)
org.eclipse.ui.views.properties.PropertySheetViewer$3.childE ntriesChanged(PropertySheetViewer.java:313)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.fireChildEntriesChanged(AbstractPropertySheetEntry.java :375)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:847 )
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1029)
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:943)
org.eclipse.ui.views.properties.PropertySheetPage.selectionC hanged(PropertySheetPage.java:473)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.superSelectionChanged(EToolsPropertySheetPage.java:250)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e.access$2(EToolsPropertySheetPage.java:243)
org.eclipse.ve.internal.propertysheet.EToolsPropertySheetPag e$1.run(EToolsPropertySheetPage.java:236)
at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:3 5)
org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchr onizer.java:123)
at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.jav a:3323)
at org.eclipse.swt.widgets.Display.msgFilterProc(Display.java:2 756)
at org.eclipse.swt.internal.win32.OS.CallWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.CallWindowProc(OS.java:180 3)
at org.eclipse.swt.widgets.Tree.callWindowProc(Tree.java:1226)
at org.eclipse.swt.widgets.Composite.WM_SYSCOMMAND(Composite.ja va:1448)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3320 )
at org.eclipse.swt.widgets.Tree.windowProc(Tree.java:4548)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4023 )
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3334 )
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:18 79)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2964)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1914)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1878)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:419)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:95)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:78)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:92)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:68)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:169)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
at org.eclipse.core.launcher.Main.run(Main.java:977)
at org.eclipse.core.launcher.Main.main(Main.java:952)
!ENTRY org.eclipse.ve.propertysheet 2 0 2006-05-13 17:40:20.090
!MESSAGE
!STACK 0
!ENTRY org.eclipse.ve.propertysheet 2 0 2006-05-13 17:40:20.100
!MESSAGE
!STACK 0
!ENTRY org.eclipse.ve.propertysheet 2 0 2006-05-13 17:40:20.110
!MESSAGE
!STACK 0
!ENTRY org.eclipse.ve.propertysheet 2 0 2006-05-13 17:40:20.150
!MESSAGE
!STACK 0
org.eclipse.ui.views.properties.PropertySheetViewer.updateCh ildrenOf(PropertySheetViewer.java:1273)
!MESSAGE
!STACK 0
!ENTRY org.eclipse.ve.propertysheet 2 0 2006-05-13 17:40:20.160
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!ENTRY org.eclipse.ve.propertysheet 2 0 2006-05-13 17:40:20.170
!MESSAGE
!STACK 0
org.eclipse.ui.views.properties.PropertySheetViewer.setInput (PropertySheetViewer.java:945)
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!ENTRY org.eclipse.ve.propertysheet 2 0 2006-05-13 17:40:20.180
!MESSAGE
!STACK 0
!ENTRY org.eclipse.ve.propertysheet 2 0 2006-05-13 17:40:35.903
!MESSAGE
!STACK 0
org.eclipse.ui.views.properties.PropertySheetViewer.access$4 (PropertySheetViewer.java:1292)
org.eclipse.ui.views.properties.PropertySheetViewer$3.valueC hanged(PropertySheetViewer.java:326)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.fireValueChanged(AbstractPropertySheetEntry.java:401)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.setValues(AbstractPropertySheetEntry.java:1032)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshValues(AbstractPropertySheetEntry.java:893)
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry.refreshChildEntries(AbstractPropertySheetEntry.java:824 )
org.eclipse.ve.internal.propertysheet.AbstractPropertySheetE ntry$3.run(AbstractPropertySheetEntry.java:880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2969)
!ENTRY org.eclipse.ve.propertysheet 2 0 2006-05-13 17:40:35.913
!MESSAGE
!STACK 0
Re: Visual Editor makes my computer freeze [message #124798 is a reply to message #124406] Sun, 14 May 2006 09:03 Go to previous messageGo to next message
Or should I step back to jre 1.4. and the older version of VE???
Re: Visual Editor makes my computer freeze [message #124810 is a reply to message #124783] Sun, 14 May 2006 09:23 Go to previous messageGo to next message
I want to give some more information.
When I press the run button, it shows the loading.. box in editor,and then
my pointer disappear and eclipse and also computer stops to respond.I cant
control computer without reseting it. When it freeze, in the status bar it
writes setting up java visual editor/ reverse parser.
Re: Visual Editor makes my computer freeze [message #124856 is a reply to message #124810] Mon, 15 May 2006 10:26 Go to previous messageGo to next message
What "run" button? The editor doesn't have a run button. Do you mean the
"Open Visual Editor" menu action?
Does this happen on every class, or just specific ones?
Have you tried just creating a brand new visual class using the New
Visual Class wizard?
I don't know why you are getting the null pointer exception. There isn't
anything at that line that would be null normally.
Does this happen on a brand new workspace after creating a class using
the New Visual Class wizard?
It sounds like you are stuck in an infinite loop somewhere.
> then my pointer disappear and eclipse and also computer stops to
> respond.I cant control computer without reseting it. When it freeze, in
> the status bar it writes setting up java visual editor/ reverse parser.
Rich Kulp
Re: Visual Editor makes my computer freeze [message #124892 is a reply to message #124856] Mon, 15 May 2006 16:11 Go to previous messageGo to next message
With Run button I dont mean anything special.It is the button at the top.
I only meant to run the application.
Yes this happens only when i am using visual editor.
I uninstalled and installed JRE and eclipse and visual editor again and
again, but its always the same. I tried only jre 1.6 and jre 1.5_06, and
now will try 1.4 .
I also tried parameters like -clean -vmargs -Xms30M -Xmx768M but it did
nothing more than making eclipse run faster. It still freeze.
Yes I created a new project and then new Visual Class.
There is nothing wrong in the code because I didn't even change the
auto-created code.(I couldn't manage to reach that step :))
And I am also curious that is this problem related to :
http://192.18.37.44/forums/index.php?topic=10269.0
I don't know what to do. My last try will be installing jre 1.4_03 and try
again.....
Thank you,
ishanour
Re: Visual Editor makes my computer freeze [message #124915 is a reply to message #124892] Mon, 15 May 2006 18:58 Go to previous messageGo to next message
I installed JRE 1.4.2_11 and it doesn't freeze now. It is working properly.
But I need the latest version as you see, some code related with 5.0
doesn't work.
I don't understand...:(
For the requirements it writes
"JRE must be version 1.4.2 or greater for BeanInfo of SWT to work
correctly. "
Re: Visual Editor makes my computer freeze [message #124927 is a reply to message #124915] Mon, 15 May 2006 19:24 Go to previous message
I don't know why you have a problem with 1.5. We use 1.5 all of the time
and we don't run into this problem. 1.6 is still not in release so we
have no committed support for that.
I am very confused about the run button statement. Running an
application has absolutely nothing to do with the visual editor. They
are entirely separate concepts.
Rich Kulp
Re: Visual Editor makes my computer freeze [message #612836 is a reply to message #124239] Fri, 05 May 2006 11:52 Go to previous message
ishanour wrote:
> editor.
> 1.6.0.
Rich Kulp
Re: Visual Editor makes my computer freeze [message #612897 is a reply to message #124406] Sun, 14 May 2006 08:57 Go to previous message
-EMF build 2.2.0M6
-GEF Build 3.2M6
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
!MESSAGE
!STACK 0
Re: Visual Editor makes my computer freeze [message #612899 is a reply to message #124406] Sun, 14 May 2006 09:03 Go to previous message
Re: Visual Editor makes my computer freeze [message #612900 is a reply to message #124783] Sun, 14 May 2006 09:23 Go to previous message
Re: Visual Editor makes my computer freeze [message #612907 is a reply to message #124810] Mon, 15 May 2006 10:26 Go to previous message
Rich Kulp
Re: Visual Editor makes my computer freeze [message #612912 is a reply to message #124856] Mon, 15 May 2006 16:11 Go to previous message
now will try 1.4 .
again.....
Thank you,
ishanour
Re: Visual Editor makes my computer freeze [message #612915 is a reply to message #124892] Mon, 15 May 2006 18:58 Go to previous message
doesn't work.
correctly. "
Re: Visual Editor makes my computer freeze [message #612917 is a reply to message #124915] Mon, 15 May 2006 19:24 Go to previous message
Rich Kulp
Previous Topic:Source for com.ibm.etools.emf.event
Next Topic:JEM ecore model - registered?
Current Time: Sun Jul 27 12:38:43 EDT 2025
Powered by FUDForum. Page generated in 0.27209 seconds
