Home » Modeling » BPEL Designer » BPEL-Designer - Jars for Ganymede created
BPEL-Designer - Jars for Ganymede created [message #11337] Mon, 22 December 2008 04:14 Go to next message
Originally posted by: michael.gebhart.googlemail.com
I've just created the jars for the bpel-designer from CVS. This version
works with eclipse ganymede.
You can find it here:
http://www.miketech.net/bpel-designer.zip
Just unzip and copy the plugins folder into your eclipse folder.
Greetings
Michael
Re: BPEL-Designer - Jars for Ganymede created [message #11449 is a reply to message #11337] Mon, 23 February 2009 23:00 Go to previous messageGo to next message
I installed BPEL Designer plug-in jars in my eclipse plug-in folder. I
could create a BPEL project in eclipse. Is there any other thing I need to
configure in addition to plug-ins to be able to create BPEL Projects.
Sanjay
Re: BPEL-Designer - Jars for Ganymede created [message #11523 is a reply to message #11449] Fri, 06 March 2009 03:32 Go to previous messageGo to next message
Hi Sanjay,
you could create a BPEL project or you could not?
Try to use Ganymede and Eclipse JEE version.
Greetings
Michael
> to configure in addition to plug-ins to be able to create BPEL Projects.
> Sanjay
Re: BPEL-Designer - Jars for Ganymede created [message #11596 is a reply to message #11337] Mon, 23 March 2009 10:48 Go to previous messageGo to next message
Hi Michael,
I downloaded your BPEL jars and installed to my eclipse-jee-ganymede
version 3.4.2 (it is a fresh installation, in order to test the BPEL
designer).
I encountered this error when i opened a bpel file:
'Reading XPath Function Registry ...' has encountered a problem.
java.io.FileNotFoundException: /functions/functions.xml
And when I try to edit the Xpath expression in the Assign (in my bpel
diagram) properties, i encountered this error:
An error has occurred. See error log for more details. An error has
occurred when activating this view. An error has occurred when activating
this view
I extracted the following error message from the eclipse error log:
!ENTRY org.eclipse.bpel.ui 4 0 2009-03-23 22:20:11.057
!MESSAGE java.io.FileNotFoundException: /functions/functions.xml
!STACK 0
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1Diagnos ticWrappedException:
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDe mandLoadException(ResourceSetImpl.java:315)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:274)
org.eclipse.bpel.common.BPELResourceSet.getResource(BPELReso urceSet.java:92)
org.eclipse.bpel.common.extension.model.Activator.load(Activ ator.java:168)
org.eclipse.bpel.fnmeta.FunctionLibrary.getRegistryForLangua ge(FunctionLibrary.java:72)
at org.eclipse.bpel.ui.expressions.Functions.<init>(Functions.java:35)
org.eclipse.bpel.ui.expressions.Functions.getInstance(Functi ons.java:52)
at org.eclipse.bpel.ui.BPELUIPlugin$2.run(BPELUIPlugin.java:302 )
Caused by: java.io.FileNotFoundException: /functions/functions.xml
org.eclipse.osgi.framework.internal.protocol.bundleentry.Han dler.findBundleEntry(Handler.java:44)
org.eclipse.osgi.framework.internal.core.BundleResourceHandl er.openConnection(BundleResourceHandler.java:168)
at java.net.URL.openConnection(Unknown Source)
org.eclipse.core.internal.boot.PlatformURLConnection.connect (PlatformURLConnection.java:110)
org.eclipse.core.internal.boot.PlatformURLConnection.connect (PlatformURLConnection.java:91)
org.eclipse.core.internal.boot.PlatformURLConnection.getInpu tStream(PlatformURLConnection.java:229)
org.eclipse.emf.ecore.resource.impl.URIHandlerImpl.createInp utStream(URIHandlerImpl.java:178)
org.eclipse.emf.ecore.resource.impl.ExtensibleURIConverterIm pl.createInputStream(ExtensibleURIConverterImpl.java:301)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1212)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo ad(ResourceSetImpl.java:255)
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLo adHelper(ResourceSetImpl.java:270)
... 7 more
!ENTRY org.eclipse.bpel.ui 4 0 2009-03-23 22:20:11.791
!STACK 0
... 7 more
!ENTRY org.eclipse.ui.workbench 4 2 2009-03-23 22:20:50.338
!MESSAGE Problems occurred when invoking code from plug-in:
"org.eclipse.ui.workbench".
!STACK 0
org.eclipse.bpel.ui.expressions.XPathExpressionEditor.addExt raStoreCommands(XPathExpressionEditor.java:649)
org.eclipse.bpel.ui.properties.ExpressionAssignCategory.newS toreToModelCommand(ExpressionAssignCategory.java:179)
org.eclipse.bpel.ui.properties.TextSection$2.createApplyComm and(TextSection.java:98)
org.eclipse.bpel.common.ui.command.EditModelCommandFramework .finishCurrentChange(EditModelCommandFramework.java:175)
org.eclipse.bpel.common.ui.command.EditModelCommandFramework .applyCurrentChange(EditModelCommandFramework.java:103)
org.eclipse.bpel.ui.properties.ExpressionSection$4.focusOut( ExpressionSection.java:692)
org.eclipse.bpel.ui.expressions.AbstractExpressionEditor.not ifyFocusOut(AbstractExpressionEditor.java:84)
org.eclipse.bpel.ui.expressions.XPathExpressionEditor$2.focu sLost(XPathExpressionEditor.java:232)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:137)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1027)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1008)
at org.eclipse.swt.widgets.Control.sendFocusEvent(Control.java: 2429)
at org.eclipse.swt.widgets.Widget.wmKillFocus(Widget.java:1765)
at org.eclipse.swt.widgets.Control.WM_KILLFOCUS(Control.java:41 30)
at org.eclipse.swt.widgets.Canvas.WM_KILLFOCUS(Canvas.java:429)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3820 )
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:337)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4541 )
at org.eclipse.swt.internal.win32.OS.SetFocus(Native Method)
at org.eclipse.swt.widgets.Control.forceFocus(Control.java:974)
at org.eclipse.swt.widgets.Control.setFocus(Control.java:2811)
at org.eclipse.swt.widgets.Composite.setFocus(Composite.java:92 7)
org.eclipse.bpel.common.ui.tray.GraphicalEditorWithPaletteAn dTray.setFocus(GraphicalEditorWithPaletteAndTray.java:118)
org.eclipse.ui.part.MultiPageEditorPart.setFocus(MultiPageEd itorPart.java:1016)
org.eclipse.ui.part.MultiPageEditorPart.setFocus(MultiPageEd itorPart.java:998)
at org.eclipse.ui.internal.PartPane.setFocus(PartPane.java:325)
at org.eclipse.ui.internal.EditorPane.setFocus(EditorPane.java: 127)
at org.eclipse.ui.internal.WorkbenchPage$3.run(WorkbenchPage.ja va:622)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
at org.eclipse.core.runtime.Platform.run(Platform.java:880)
org.eclipse.ui.internal.WorkbenchPage.activatePart(Workbench Page.java:617)
org.eclipse.ui.internal.WorkbenchPage.setActivePart(Workbenc hPage.java:3487)
org.eclipse.ui.internal.WorkbenchPage.requestActivation(Work benchPage.java:3034)
at org.eclipse.ui.internal.PartPane.requestActivation(PartPane. java:272)
org.eclipse.ui.internal.EditorPane.requestActivation(EditorP ane.java:98)
at org.eclipse.ui.internal.PartPane.handleEvent(PartPane.java:2 36)
at org.eclipse.swt.widgets.Shell.setActiveControl(Shell.java:13 53)
at org.eclipse.swt.widgets.Shell.WM_MOUSEACTIVATE(Shell.java:21 95)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3830 )
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.j ava:1576)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:1937)
at org.eclipse.swt.internal.win32.OS.DefWindowProcW(Native Method)
at org.eclipse.swt.internal.win32.OS.DefWindowProc(OS.java:2366 )
at org.eclipse.swt.widgets.Scrollable.callWindowProc(Scrollable .java:79)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:3877 )
at org.eclipse.swt.internal.win32.OS.PeekMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.PeekMessage(OS.java:2880)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3417)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2384)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2348)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 00)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:495)
org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:288)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:490)
org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:193)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:386)
... 133 more
Actually, before I download and install your BPEL jars, i have tried with
the CVS version (downloaded on 17 March 2009) of the BPEL Designer.
Everything was fine if I run the designer using the Run Configuration. But
when i exported all plugins as jar files and installed as the Eclipse
plugins, the above errors were encountered. Exactly the same errors
observed when using your BPEL jars.
Any clues of the problems? When i searched through the source directory of
the plugins, i only found a functions.xml file under the folder
org.eclipse.bpel.examples.extensionPoints\functions
Thanks!
Chai
Re: BPEL-Designer - Jars for Ganymede created [message #11632 is a reply to message #11596] Mon, 23 March 2009 12:29 Go to previous message
Hi Michael,
I resolved the problems (the java.io.FileNotFoundException:
/functions/functions.xml) by deleting the jar
org.eclipse.bpel.examples.extensionPoints_0.3.0
Just wonder whether this will omit any functionalities of the BPEL
Designer?
Thanks!
Chai
Previous Topic:New Version?
Next Topic:Using the BPEL plugin to debug??
Current Time: Wed Jul 30 21:17:23 EDT 2025
Powered by FUDForum. Page generated in 0.04798 seconds
