| AGR to test different workbench [message #123829] |
Sun, 24 February 2008 08:19  |
Originally posted by: nyakar.cisco.com
Hello
I would be grateful if you could give me some help regarding a TPTP issue
I am facing for a while now. My problem is as follows:
I need AGR to test my application, which is an eclipse application, but it
only opens the REGULAR DEVELOPMENT eclipse workbench.
I defined '.deployment', '.artifact' and '.location' files that describes
the context of my application.
Those are the main '.location' file properties I configured:
- 'ECLIPSE_STARTUP_PATH' = path to the equinox.launcher jar file used by
my application.
- 'eclipse location' = path to the eclipse installation my application
uses.
- 'workspace data' = the absolute path of the workspace that my
application.
- all other properties have been copied from the run dialog of my
application, besides which plugins to use, which doesn't include the
plugins defined in that run dialog (why can't I pick them from the
location file? is it important??)
I would appreciate any help given to me on that matter.
Nadav
| Re: AGR to test different workbench [message #125822 is a reply to message #125594] |
Mon, 10 March 2008 06:27  |
Hi Nadav,
The AGR uses the workbench defined as the current context in the
Overview tab of the AGR test suite editor when running the AGR test suite.
This is not consistent with the other TPTP test types that use the Eclipse
workbench defined in the workbench location.
Paul
"Nadav" <nyakar@cisco.com> wrote in message
news:a404c169704339febe78a3753f3c23a3$1@www.eclipse.org...
> Problem solved. Apperantly the issue was that the application uses the
> actual eclipse workbench it is being developed on, while running it from
> the code.
> Many thanks
FUDForum. Page generated in 0.29657 seconds
