Home » Modeling » Epsilon » [Eugenia] Generate GMF ... does nothing!?
[Eugenia] Generate GMF ... does nothing!? [message #11332] |
Fri, 06 February 2009 04:35  |
Hi - I wanted to give Eugenia a try but ran into a problem (or bug?):
I downloaded/installed Epsilon from
http://download.eclipse.org/modeling/gmt/epsilon/updates/ and then
exactly followed the screencast at
http://www.eclipse.org/gmt/epsilon/cinema/Eugenia.htm.
I copy-pasted the File system example found a
http://epsilonlabs.wiki.sourceforge.net/EuGENia into the Emfatic editor
as suggested and was able to create the .ecore file from the .emf file -
no problems.
I then created the .genmodel file as instructed and next issued the
Eugenia => Generate GMF tool, map and graph models command.
But, alas, in contrast to the screencast nothing happens here, i.e.
there are no .gmf* files showing up in the model folder (nor anywhere
else).
What am I missing? This is using Eclipse 3.4.1 (Ganymede) and Epsilon
0.8.3.
There are no problems, i.e. all files seem fine and have no syntax
errors.
I also checked the eclipse log file and it show no entry.
Hints, ideas, suggestions?
Michael
Re: [Eugenia] Generate GMF ... does nothing!? [message #11405 is a reply to message #11332] |
Fri, 06 February 2009 04:45   |
Hi Michael,
I'm not really sure what might be going wrong. I know that quite a few
people have been using EuGENia but there have been no similar problems.
The only thing I could suggest is to start Eclipse via the command
line and see if any stacktrace shows up there...
Dimitris
> no problems.
> else).
> 0.8.3.
> There are no problems, i.e. all files seem fine and have no syntax errors.
> Michael
Re: [Eugenia] Generate GMF ... does nothing!? [message #11479 is a reply to message #11442] |
Fri, 06 February 2009 07:09   |
Hi Michael,
You seem to have done everything correctly... Would you mind creating a
zip of the project and sending it to me (either through the newsgroup or
in private)?
Dimitrios
> Dimitris Kolovos wrote:
>> Hi Michael,
>> problems. The only thing I could suggest is to start Eclipse via the
>> command line and see if any stacktrace shows up there...
>> Cheers,
>> Dimitris
> Nope - nothing appears:
> C:\>C:\eclipse_3.4.1\eclipse\eclipse.exe -clean -vm
> C:\IBMJSDK1.6.0\bin\javaw.exe -vmargs -Xms50M -Xmx750M -Xss512k
> -Duser.language=en_US
> C:\>
> Eclipse's .log-file also show nothing relevant (a couple of key binding
> conflicts and "Unable to retrieve system properties" which it has shown
> on my system already for ages...).
> I then decided to try a last time from square zero:
> I painstakingly followed the installation guide at
> http://www.eclipse.org/gmt/epsilon/doc/P2InstallationGuide.p df, i.e. I
> 1. I downloaded eclipse-ganymede-modeling-SR1
> 2. I added http://download.eclipse.org/modeling/gmt/epsilon/updates/ as
> new download site
> 3. from that installed Epsilon (the entire thing)
> 4. lastly, I installed Emfatic from
> http://www.scharf.gr/eclipse/emfatic/update/.
> I then directed the new eclipse installation to the existing project,
> containing the filesystem.emf file and restarted from there, i.e.
> recreated the .ecore file, from that the .genmodel file, from that did a
> Generate All.
> Finally I selected the filesystem.ecore again and issued the Eugenia =>
> Generate GMF... and - again - nothing! And also again: nothing in the
> log nor on the console. :-(
> Is there anything else I could provide or try to debug this?
> Michael
> PS.: I must have some bad aura for eclipse projects...
Re: [Eugenia] Generate GMF ... does nothing!? [message #11626 is a reply to message #11590] |
Tue, 10 February 2009 04:32  |
Hi Michael,
(I think) I've now fixed this. If you check out the code from the SVN
you will be able to pick up the fix immediately. Otherwise, the 0.8.4
binaries should be out sometime during next week.
Thanks again for reporting this and for your patience in isolating the
exact nature of the bug!
Dimitris
>> Hi Michael,
>> Thanks for reporting this back to the newsgroup! Could you also please
>> post the link to the bug when you create it?
>> Cheers,
>> Dimitris
> Here you go: https://bugs.eclipse.org/bugs/show_bug.cgi?id=264257
> Happy fixing! ;-)
> Michael
Re: [Eugenia] Generate GMF ... does nothing!? [message #564805 is a reply to message #11332] |
Fri, 06 February 2009 04:44  |
I forgot to mention that I have also created the EMF editing code
between these two steps, i.e. I selected filesystem.genmodel =>
Generator => Generate All.
Just in case...
Michael
Re: [Eugenia] Generate GMF ... does nothing!? [message #564826 is a reply to message #11332] |
Hi Michael,
Dimitris
> no problems.
> else).
> 0.8.3.
> Michael
Re: [Eugenia] Generate GMF ... does nothing!? [message #564837 is a reply to message #11405] |
Fri, 06 February 2009 07:04  |
> Hi Michael,
> Cheers,
> Dimitris
C:\IBMJSDK1.6.0\bin\javaw.exe -vmargs -Xms50M -Xmx750M -Xss512k -Duser.language=en_US
C:\>
new download site
Generate All.
Michael
Re: [Eugenia] Generate GMF ... does nothing!? [message #564853 is a reply to message #11442] |
Hi Michael,
in private)?
Dimitrios
>> Hi Michael,
>> Cheers,
>> Dimitris
> C:\>
> new download site
> Generate All.
> Michael
Re: [Eugenia] Generate GMF ... does nothing!? [message #564874 is a reply to message #11479] |
Mon, 09 February 2009 07:40  |
Just for the benefit of others in the NG:
in private conversation and tests Dimitris and myself found out and
verified, that there is a problem with the file generation, if the
project is *not* located in the eclipse workspace, but located somehwere
else in the fileystem tree (as was the case in my setup). Dimitris
intends to have this fixed in v0.8.4 which should be out in a couple of
weeks.
Michael
Re: [Eugenia] Generate GMF ... does nothing!? [message #564902 is a reply to message #11516] |
Mon, 09 February 2009 07:42  |
Hi Michael,
Dimitris
> weeks.
> Michael
Re: [Eugenia] Generate GMF ... does nothing!? [message #564940 is a reply to message #11590] |
Hi Michael,
Dimitris
>> Hi Michael,
>> Cheers,
>> Dimitris
> Happy fixing! ;-)
> Michael
Current Time: Wed Jul 30 19:13:31 EDT 2025
Powered by FUDForum. Page generated in 0.05969 seconds
