Home » Eclipse Projects » Remote Application Platform (RAP) » Shell activate and deactivate events doesn't fire properly
Shell activate and deactivate events doesn't fire properly [message #123784] Wed, 04 March 2009 11:39 Go to next message
having two shells with ShellListeners attached and a button for activate
the other shell, the shellActivated and shellDeactivated events doesn't
fire when the setActive method is called.
Also, shellDeactivated event doesn't fire in active shell when another
shell is created.
I use shellActivated and shellDeactivated events to show/hide an Adobe
Reader plugin, because the plugin stays always on top of other shell. If
these events aren't handled correctly, I don't know if there could be a
workaround for me...
Here's a snippet with a simple log:
public class RapTest implements IEntryPoint {
private Display d;
private Shell s1;
private Shell s2;
public int createUI() {
d = new Display();
s1 = new Shell(d, SWT.SHELL_TRIM | SWT.NO_FOCUS);
s2 = new Shell(d, SWT.SHELL_TRIM | SWT.NO_FOCUS);
s1.setBounds(0, 0, 400, 200);
s2.setBounds(400, 0, 400, 200);
s1.setLayout(new FillLayout());
s2.setLayout(new FillLayout());
s1.addShellListener(new ShellAdapter() {
public void shellActivated(ShellEvent e) {
System.out.println("s1: shellActivated");
public void shellDeactivated(ShellEvent e) {
System.out.println("s1: shellDeactivated");
s2.addShellListener(new ShellAdapter() {
System.out.println("s2: shellActivated");
System.out.println("s2: shellDeactivated");
Button b1 = new Button(s1, SWT.PUSH);
Button b2 = new Button(s2, SWT.PUSH);
b1.setText("activate s2");
b2.setText("activate s1");
b1.addSelectionListener(new SelectionAdapter() {
public void widgetSelected(SelectionEvent e) {
System.out.println("b1: widgetSelected");
s2.setActive();
b2.addSelectionListener(new SelectionAdapter() {
System.out.println("b2: widgetSelected");
s1.setActive();
s1.open();
s2.open();
while( !s1.isDisposed() && !s2.isDisposed() )
if( !d.readAndDispatch() )
d.sleep();
d.dispose();
return 0;
In SWT the events are always fired correctly.
Enrico
Re: Shell activate and deactivate events doesn't fire properly [message #123799 is a reply to message #123784] Wed, 04 March 2009 12:01 Go to previous messageGo to next message
Hi Enrico,
if the events differ from the shell events in SWT please file a bugzilla
about it.
Best,
Ivan
Enrico Zanaga wrote:
> activate the other shell, the shellActivated and shellDeactivated
> events doesn't fire when the setActive method is called.
> shell is created.
> If these events aren't handled correctly, I don't know if there could
> be a workaround for me...
> private Display d;
> private Shell s1;
> private Shell s2;
> @Override
> d = new Display();
> @Override
> @Override
> @Override
> @Override
> @Override
> s2.setActive();
> @Override
> s1.setActive();
> s1.open();
> s2.open();
> d.sleep();
> d.dispose();
> return 0;
> Thanks
> Enrico
Re: Shell activate and deactivate events doesn't fire properly [message #123811 is a reply to message #123799] Wed, 04 March 2009 12:35 Go to previous message
Bug 267056 opened:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=267056
Ivan Furnadjiev ha scritto:
> Hi Enrico,
> about it.
> Best,
> Ivan
>> shell is created.
>> private Display d;
>> private Shell s1;
>> private Shell s2;
>> @Override
>> d = new Display();
>> @Override
>> @Override
>> @Override
>> @Override
>> @Override
>> s2.setActive();
>> @Override
>> s1.setActive();
>> s1.open();
>> s2.open();
>> d.sleep();
>> d.dispose();
>> return 0;
>> Thanks
>> Enrico
Previous Topic:Server delay message dialog
Next Topic:Confuse Service Release and Release version
Current Time: Thu Jul 17 23:23:12 EDT 2025
Powered by FUDForum. Page generated in 0.30230 seconds
