Home » Language IDEs » AspectJ » Problems with New Aspect Wizard
Problems with New Aspect Wizard [message #11328] Tue, 19 November 2002 13:18 Go to next message
Originally posted by: eclipse.phota.to
I just installed the AspectJ plugins for Eclipse and followed the post
install instructions, but am having a problem.
The "Finish" button in the New Aspect Wizard does nothing. The Wizard
doesn't go away, and no new files are added to my project.
I am running Eclipse M3 on Windows XP. I'm attempting to add the aspect
to a pre-existing Java project. The results are the same when I create a
new AspectJ project then try to add an aspect to it.
Any ideas?
Thanks-
Andrew Molloy
Re: Problems with New Aspect Wizard [message #11401 is a reply to message #11328] Fri, 22 November 2002 11:50 Go to previous message
> Any ideas?
> Thanks-
> Andrew Molloy
Hmmm. I think you might be on a more recent version of Eclipse than we
have tested on. The 'new aspect' wizard is based on the underlying JDT
internal 'new class' wizard (which is a bit naughty) - any serious changes
to the underlying class might require us to change our wizard. We'll take
a look once we're back on a stable codebase. Hopefully we'll see the
problem straight away as a plugin compilation error against the most
recent eclipse classes.
Andy (AJDT Development)
Re: Problems with New Aspect Wizard [message #562962 is a reply to message #11328] Fri, 22 November 2002 11:50 Go to previous message
> Any ideas?
> Thanks-
> Andrew Molloy
Previous Topic:Icons dont't display properly what can I do (bug?)
Next Topic:Project References
Current Time: Mon Jul 14 16:15:33 EDT 2025
Powered by FUDForum. Page generated in 0.08140 seconds
