eclipse with database plug-inns [message #123732] |
Mon, 12 December 2005 14:41 |
Originally posted by: elprogramx.gmail.com
Hi forum members. I'm very new in eclipse At this time I'm writing
programs that connect with several databases :
mysql,oracle,sybase,postgresql
But I would like to know ,if:
Does exist any plug-inn that help me making automatic generation of code
to connect with a database?
For example there is a window designer plug-in called windowbuilder-pro,
in that plug-in if I drag and drop a (for example) Jtext, the plug-in
automatic generates the code of the Jtext componet? Is there a database
plug-inn which could do the same but with database connectivity??
Or similar to MS VB, there I can create recordset and I just called in
order to set or get database information instead of typing code by hand,
is there a plug-inn similiar like that?
Thanks in advance
FUDForum. Page generated in 0.09265 seconds
