Home » Eclipse Projects » Equinox » Fire Events Periodically ??
Fire Events Periodically ?? [message #123555] Wed, 31 December 2008 10:11 Go to next message
my application needs to kick off event at regular intervals ( say daily or
weekly ).. is there any way to
do this?
-Walter.
Re: Fire Events Periodically ?? [message #123568 is a reply to message #123555] Wed, 31 December 2008 15:28 Go to previous messageGo to next message
On 12/31/2008 10:11 AM, Walter Prabhakar wrote:
> or weekly ).. is there any way to
> do this?
The EPP project's Usage Data Collector
(http://www.eclipse.org/epp/usagedata/) does something like that; it
periodically uploads usage data on a user-configured schedule.
There are links to view or get the source code on that web page, and the
newsgroup to ask questions about it is eclipse.technology.packaging
(where EPP questions, in general, belong).
If that does not provide any help, I'd take a look at the Quartz
framework: http://www.opensymphony.com/quartz/ - I've used that several
times, though not in an Eclipse plugin or RCP app.
Hope this helps,
Eric
Re: Fire Events Periodically ?? [message #123591 is a reply to message #123555] Thu, 01 January 2009 14:58 Go to previous messageGo to next message
Originally posted by: fakemail.xyz.de
Walter Prabhakar schrieb:
> do this?
> -Walter.
With a few lines of code you can do it yourself...
Use a preference value to store the last kick off..
Use a ScheduledExecutorService on start of your Application to schedule
the next kick off...
Christian
Re: Fire Events Periodically ?? [message #123602 is a reply to message #123591] Fri, 02 January 2009 07:24 Go to previous messageGo to next message
Or better, use the Jobs API. It allows to schedule a job to start in the
future.
-Gunnar
Gunnar Wagenknecht
gunnar@wagenknecht.org
http://wagenknecht.org/
Re: Fire Events Periodically ?? [message #123615 is a reply to message #123602] Fri, 02 January 2009 10:44 Go to previous messageGo to next message
> future.
> -Gunnar
So does the ScheduledExecutorService.
I have found Jobs to be nice if you need to show progress in the GUI
(and cancelling). Or if you depend on resources to be locked.
Though for simple stuff Jobs api is often Overkill and creating a
ScheduledExecutorService for the app will be easier.
Might be a matter of preference. Usually when I need some functionality
and the stdlib provides an equally good solution I would choose the java
stdlib over other api.
Christian
Re: Fire Events Periodically ?? [message #123628 is a reply to message #123555] Fri, 02 January 2009 14:30 Go to previous messageGo to next message
Walter,
The Timer and TimerTask classes in java.util are also quite interesting.
Cheers
/Eike
> daily or weekly ).. is there any way to
> do this?
> -Walter.
Re: Fire Events Periodically ?? [message #124194 is a reply to message #123628] Sat, 10 January 2009 09:57 Go to previous message
Thanks. it works.
- Walter
"Eike Stepper" <stepper@esc-net.de> wrote in message
news:gjlq0s$a4h$1@build.eclipse.org...
> Walter,
> Cheers
> /Eike
> http://thegordian.blogspot.com
>> do this?
>> -Walter.
Previous Topic:Equinox Transforms
Next Topic:Eclipse with P2
Current Time: Tue Jul 15 11:31:24 EDT 2025
Powered by FUDForum. Page generated in 0.08891 seconds
