NooBee JSP Question [message #123472] |
Mon, 01 December 2003 16:21  |
Originally posted by: greg.smith.dss.virginia.gov
I downloaded eclipse and myeclipse. neither seem to have the plugins for
jsp's and html. i'm confused. am i supposed to go someplace else and get
plugins for them?
greg
Re: NooBee JSP Question [message #124086 is a reply to message #123863] |
Wed, 03 December 2003 08:51   |
riyad,
ic now, i downloaded eclipse 3.0 not the myeclipse ide plugins. the plugins
are now working.
i'm still disappointed though, the jsp plugin is very anemic. no hinting at
all.
greg
"Riyad Kalla" <rsk@email.arizona.edu> wrote in message
news:bqij7e$ibc$1@eclipse.org...
> Geez yea there should, I'm not sure whats wrong. Did you use the
> MyEclipseIDE installer? In your <MyEclipseIDE Install
> DIR>/eclipse/plugins directory, do you have a whole bunch of plugins?
> When you click on Help->About, do you see a My Eclipse icon on that
> dialog? When you click on plugin details do you have a whole butt-load
> of plugins from Genuitec, LLC listed?
> These are all things I have, maybe try rerunning the installer? Do you
> have admin privaledges on the machine? Do you have read access to the
> plugins in the MyEclipse install dir? Maybe check the Eclipse log file
> for reported loading errors?
> Best,
> Riyad
> Gregory Smith wrote:
> > riyad,
> > thanks for the assist. i was able to associate .jsp and .html files with
the
> > java editor but i didnt get the results i wanted.
> > i wasnt able to find a html editor for myeclipse. when i edit .jsp files
i
> > dont get syntax coloring or hinting.
> > shouldnt there be a plug-in for html and jsp?
> > greg
> > news:bqgds0$2mr$1@eclipse.org...
> >>MyEclipse should have installed the association between itself and
> >>JSP/HTML pages. If not try right-clicking on the file and selecting
> >>"Open with" and choose the MyEclipse editor.
> >>If not, you can do Preferences->Work Bench->File Associations and set
> >>the association to JSP and HTML manually.
for
get
> >>>plugins for them?
> >>>greg
Re: NooBee JSP Question [message #124248 is a reply to message #123863] |
Wed, 03 December 2003 13:33  |
okay, i'm a NuB
apparently your code must be syntactically correct before the hinting starts
up. now it works.
many thanks
greg
> Best,
> Riyad
> > riyad,
the
i
> > greg
for
get
> >>>plugins for them?
> >>>greg
FUDForum. Page generated in 0.05916 seconds
