Home » Archived » XML Schema Definition (XSD) » Running XSD in Eclipse 2.1 M5
Running XSD in Eclipse 2.1 M5 [message #11301] Sat, 08 February 2003 18:00 Go to next message
I try to run latest XSD in Eclipse 2.1 M5.
I create a Java Project and then do a New-> XSD Model file.
The XSD editor invoked. but when I click on the "Documentation" tap, I got
this error message "The Source page hasa errors. Other pages can not be used
until these errors are corrected."
and it does not have anything in the log file.
Could someone please tell me how to fix this?
Thank you.
Re: Running XSD in Eclipse 2.1 M5 [message #11338 is a reply to message #11301] Sat, 08 February 2003 18:04 Go to previous messageGo to next message
Sorry, I figure out this problem.
Sorry for the confusion.
"Hal" <otaconss2@hotmail.com> wrote in message
news:b240op$jf3$1@rogue.oti.com...
used
> Thank you.
Re: Running XSD in Eclipse 2.1 M5 [message #18993 is a reply to message #11338] Thu, 01 May 2003 10:58 Go to previous messageGo to next message
Originally posted by: spambort.rogers.com
I have this problem also. How did you fix it?
news:b2410u$jih$1@rogue.oti.com...
got
> used
> > Thank you.
Re: Running XSD in Eclipse 2.1 M5 [message #19020 is a reply to message #18993] Thu, 01 May 2003 12:52 Go to previous messageGo to next message
--------------29CCDBCBB97AF60535775499
Content-Type: text/plain; charset=us-ascii
Bort,
There are two editors registered against .xsd:
[Image]
The "Extension Point Schema Editor" is the "default" default and that's the one
you are having problems with.
You can use "Window->Preferences" to change the default to the editor provided
by XSD:
[Image]
> got
> > used
> > > Thank you.
Content-Type: multipart/related;
boundary="------------B59294648617A8D25336FD09"
--------------B59294648617A8D25336FD09
Content-Type: text/html; charset=us-ascii
<!doctype html public "-//w3c//dtd html 4.0 transitional//en">
<html>
Bort,
<p>There are two editors registered against .xsd:
<blockquote><img SRC="cid:part1.3EB150DD.6374FBE5@ca.ibm.com" height=179 width=371></blockquote>
the one you are having problems with.
<p>You can use "Window->Preferences" to change the default to the editor
provided by XSD:
<blockquote><img SRC="cid:part2.3EB150DD.6374FBE5@ca.ibm.com" height=493 width=604></blockquote>
<p><br>bort wrote:
<blockquote TYPE=CITE>I have this problem also.&nbsp; How did you fix it?
<p>"Hal" &lt;otaconss2@hotmail.com> wrote in message
<br><a href="news:b2410u$jih$1@rogue.oti.com">news:b2410u$jih$1@rogue.oti.com</a>...
<br>> Sorry, I figure out this problem.
<br>> Sorry for the confusion.
<br>>
<br>>
<br>> "Hal" &lt;otaconss2@hotmail.com> wrote in message
<br>> <a href="news:b240op$jf3$1@rogue.oti.com">news:b240op$jf3$1@rogue.oti.com</a>...
<br>> > I try to run latest XSD in Eclipse 2.1 M5.
<br>> >
<br>> > I create a Java Project and then do a New-> XSD Model file.
<br>> > The XSD editor invoked. but when I click on the "Documentation"
tap, I
<br>got
<br>> > this error message "The Source page hasa errors. Other pages can
not be
<br>> used
<br>> > until these errors are corrected."
<br>> >
<br>> > and it does not have anything in the log file.
<br>> >
<br>> > Could someone please tell&nbsp; me how to fix this?
<br>> > Thank you.
<br>> >
<br>> >
<br>>
<br>></blockquote>
</html>
Content-Type: image/jpeg
Content-ID: <part1.3EB150DD.6374FBE5@ca.ibm.com>
Content-Disposition: inline; filename="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\nsmail1V.jpeg"
/9j/4AAQSkZJRgABAQAAAQABAAD/2wBDACAWGBwYFCAcGhwkIiAmMFA0MCws MGJGSjpQdGZ6
eHJmcG6AkLicgIiuim5woNqirr7EztDOfJri8uDI8LjKzsb/2wBDASIkJDAq MF40NF7GhHCE
xsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbGxsbG xsbGxsb/wAAR
CACzAXMDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
AgEDAwIEAwUFBAQAAAF9AQIDAAQRBRIhMUEGE1FhByJxFDKBkaEII0KxwRVS 0fAkM2JyggkK
FhcYGRolJicoKSo0NTY3ODk6Q0RFRkdISUpTVFVWV1hZWmNkZWZnaGlqc3R1 dnd4eXqDhIWG
h4iJipKTlJWWl5iZmqKjpKWmp6ipqrKztLW2t7i5usLDxMXGx8jJytLT1NXW 19jZ2uHi4+Tl
5ufo6erx8vP09fb3+Pn6/8QAHwEAAwEBAQEBAQEBAQAAAAAAAAECAwQFBgcI CQoL/8QAtREA
AgECBAQDBAcFBAQAAQJ3AAECAxEEBSExBhJBUQdhcRMiMoEIFEKRobHBCSMz UvAVYnLRChYk
NOEl8RcYGRomJygpKjU2Nzg5OkNERUZHSElKU1RVVldYWVpjZGVmZ2hpanN0 dXZ3eHl6goOE
hYaHiImKkpOUlZaXmJmaoqOkpaanqKmqsrO0tba3uLm6wsPExcbHyMnK0tPU 1dbX2Nna4uPk
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwDXNlabwPssHIJ/1a+1WaY2 fMUA44P8x70o
D92X/vn/AOv9aLgRSTlN5PlqiEAs77ew9velguUmJUEBhzgHOR2I9qgukDK5 Pm5WUENGu4qd
o5x3HNFpu3w74xG3lvkBcfxDnHbPX8adtAKd3qVzb3rWltDGyoAFUIScYB6A 1W/t+6/55w/k
f8adfNHHqN3I8rRvhFQoMsMgEkcjsMfjVGdENy8kDR7S6lVOBjdzjHTA6GtU kQ2y5/b91/zz
h/I/40qa5eOcLFCSAT0PQDJ7+1QJ5Xmjy1iKbTglgNrcZOH6j0B7e+asx2k2 AYY1eOSOTLhF
BJO7GO4yNvA/xoaiGprafcPdWUc0gUM2chenUirNU9MjeCwiilUq65yMZ7mr W4e/5GsnuWh1
FN3D3/I0bh7/AJGkA6im7h7/AJGjcPf8jQA6im7h7/kaNw9/yNADqKbuHv8A kaNw9/yNADqK
buHv+Ro3D3/I0AOoppdQCTkAdSQaEdZEV1OVYZB9qAHUUUUAFFFFABRRRQAU UUUAFFFFABRR
RQAUUUUAQz/4f1qGpp/8P61DSGUrf/j8l/3j/KtO1/1I/wB5v5msy3/4/Jf9 4/yrStmAh7/e
bt7mmInopu4e/wCRo3D3/I0AOqt9rVZJlkz8j7VCKWJG1TnAz6/yqfcPf8jV VrdhcPPFJtdi
fvRkgAhQe4/uCgCdbiJ5AiMXJGcqpK9M9RwOP5ionvolKYWQ7n2keWwYcE52 4yen8/SmR2ph
RoopWWJlAPyHeCFC5Ddug7VHHYmOQyI0SOCpURwFVyAw5GeeGPcdBQBeikEi FhjhmXj2JH9K
KZAghQrknLs2dp7sT/WigCQ/6xR7H+lOpjZ8xQDjg/zHvSgP3Zf++f8A6/1o AqzrHvkkdVVV
IBZpig6CltDAzkpxIB/fLZU9x7dKbdIGVyfNysoIaNdxU7RzjuOaLTdvh3xi NvLfIC4/iHOO
2ev407aAQX+n2L3BmubgxNJ2LqoOABxkUn9gWv8Az0m/Mf4VYvci6hfdMihH BaKPec5Xg8H0
P5U5MpZrC0ciOkScR9j0wD7Ed+PXinzMVkVf7Atf+ek35j/CrIjEUaRrkhF2 jPtUM3neWm7z
Wlyd8a71DtxjDr90emePXnJFmX735/zNJtvcaQyiiipGQNdxq06kNmFdx4+9 xk4/MfmKkM0Q
ZlMiBlGWG4ZA9TVa5tJJEn8sqHdvlJPGCoUg/ln8BSfYdzOr/cYud3mNn5s9 F6Dr15/WgC3v
XONwznGM98Zx+VOqrHbMJY5HbJ5ZwDxv5HHthiPwX0q1QAUUUUAFFFFABUUl xHFNHE5w0mdu
ehIxx+tS1XubOO5mieXlY8/L2JOOv5UATS/6p/8AdNWLP/jzg/65r/Kq8v8A qn/3TViz/wCP
OD/rmv8AKgRNRRRTAKKKKACiiigAooooAKKKKACiiigAooooAhn/AMP61DU0 /wDh/WoaQylb
/wDH5L/vH+Vadr/qR/vN/M1mW/8Ax+S/7x/lWlbE+T90n5m/maYieim7j/dP 6Ubj/dP6UAOq
ubtRMyGOTarhDJxtBOMDrnuO1Tbj/dP6VC0CtvyH+eRZDyOq7cf+gigCM6lC JJIwrM6HG1WU
k/MF9eOSOuKU6hEqM0iugAON2OSCFI69iQOcD8OaaLFQyZaYrGAEUlcKAynH TP8ACOtOazjO
OJMgsQcjgswbP4ED/wCvQBF/bViOHm2N3GN2PxXI/Wipvsqnl3uHbufNK5/B SB+lFAFg/wCs
Uex/pTqY2fMUA44P8x70oD92X/vn/wCv9aAKs6x75JHVVVSAWaYoOgpbQwM5 KcSAf3y2VPce
3Sm3SBlcnzcrKCGjXcVO0c47jmi03b4d8Yjby3yAuP4hzjtnr+NO2gFuSRIk LyOqKOrMcAUR
yJKgeN1dT0ZTkGobjKTxTMrNGgYEKCxBOMHA/EcevpmnGZXT7ku1kYkhGBGO MeoPPH0pATVW
lzu4GevcDufWq8nneSfMaYPuGQFY7lwcDKdD6kd/UYFSjPlx7lKtt5UtuIPp nv8AWgBPm/55
n/vpf8aPm/55n/vpf8aWikMT5v8Anmf++l/xo+b/AJ5n/vpf8aR5Y0ZVd1Us cKCcZ+lOoAT5
v+eZ/wC+l/xo+b/nmf8Avpf8aWigBPm/55n/AL6X/Gj5v+eZ/wC+l/xpaKAE +b/nmf8Avpf8
aPm/55n/AL6X/GlooAT5v+eZ/wC+l/xo+b/nmf8Avpf8aWigBkm7ynypHynu D/I1Zs/+POD/
AK5r/Kq8v+qf/dNWLP8A484P+ua/ypiJqKKKACiiigAooooAKKKKACiiigAo oooAKKKKAIZ/
8P61DU0/+H9ahpDKVv8A8fkv+8f5Vp2v+pH+838zWZb/APH5L/vH+VaVtu8n gD7zd/c0xE9F
Ny3oPzoy3oPzoAdVVrp1mcGJfKSRYy2/5sttxxj/AGh3qxlvQfnVdbQfaJJm +Yu4YLvO0YAH
Toemc4/lQBBLqDklIkAYspjbna671B5K99w6Z/ll8dxNHNMZEUx+aiHDklSV QYAx0yfbvxUg
sogSfL7bQPMbCjIPA7dB06Yp4t0CldmQWVjlySSMYOf+AigCeim5b0H50UAB /wBYo9j/AEp1
MbPmKAccH+Y96UB+7L/3z/8AX+tAFWdY98kjqqqpALNMUHQUtoYGclOJAP75 bKnuPbpTbpAy
uT5uVlBDRruKnaOcdxzRabt8O+MRt5b5AXH8Q5x2z1/GnbQCzLPDBjzpY489 N7AZp6sHUMpD
KRkEHgiqd7kXUL7pkUI4LRR7znK8Hg+h/KnFma4Vl87ySQW4I+btx1x6/h/t UgLdVpfvfn/M
1R/0l5Sv74CQgyKBINh3rkBicdC3K4H6U7UbsWPlKIy4II5bng+vei19EBZo rJ/tr/p3/wDH
/wD61H9tf9O//j//ANanySFzIutiOWbzI2kEpG3C7sjAG0+nOevHP1qvCJFk KF5WnR0XOWK4
2ru9vXrzUX9tf9O//j//ANagawASRbAEnJ+fr+lPkkF0PjW4KYd5SxKiQBWX B3DODn0z93j9
Ku24ZTKh3bVfCbiTxgHqevOaz/7a/wCnf/x//wCtR/bX/Tv/AOP/AP1qOSQX RrUVk/21/wBO
/wD4/wD/AFqVdYLMFW2JJOAA/X9KXJIOZGrRWT/bX/Tv/wCP/wD1qP7a/wCn f/x//wCtRySD
mRrUVk/21/07/wDj/wD9aj+2v+nf/wAf/wDrUckg5kakv+qf/dNWLP8A484P +ua/yqlY3Iu7
d5DGBhtuCc9qsq+1QqgADgAE8Uthlqiq3mH/ACTTTcKDgsoPux/xoAt0VVEu RkYI9if8aXzD
/kmgCzRVbzD/AJJo8w/5JoAs0VW8w/5Jo8w/5JoAs0VW8w/5Jo8w/wCSaALN FVvMP+SaPMP+
SaALNFVvMP8AkmjzD/kmgB8/+H9ahpxfPUA/iaTcP7o/WkMo2/8Ax+S/7x/l Wna/6kf7zfzN
QgIGLCNAT1IFOD7RgAAexNAi1RVbzD/kmjzD/kmmBZqhe3MsXnAgImxtmVJ8 whSfvA/L+Ppw
fSbzD/kmoykRd3MMZZxtZscsPQ+tACS3NxGZWTy5YwQi4TB3FgAOvOM89OeM 9cT2kssiN5yB
XVtpxj0B6AnHX19+9QCKEM7CCMM4IY7eWB659afGViQJGioo6KuQBQBborKu LqZZmCuQPSig
DTP+sUex/pTqY2fMUA44P8x70oD92X/vn/6/1oAqzrHvkkdVVVIBZpig6Clt DAzkpxIB/fLZ
U9x7dKbdIGVyfNysoIaNdxU7RzjuOaLTdvh3xiNvLfIC4/iHOO2ev407aAWn mjjZVkkRWc4U
MwBY+1MS7tpDhLiJj6K4PfH8yKZdHE9p8rnEpJKqSANrDnHTkioLeF49OiEh llJjRfKYAbTx
jkDIwe/brSAvGRBnLrwQp56E4wP1H51heIfvQf8AAv51elXZagSRO8qToS4Q sXIIJYYHp+XQ
VFq1nJdtF5ZUbd2dx9TVRdmJ7HPUVof2Pcf34vzP+FH9j3H9+L8z/hWvMiLM jj87yI/su7GD
5uOmcn73tjHXjr71LLBCU3RwYgZXYTfNwQW2jk47KPxpP7HuP78X5n/CnNpV 0wUNJEQgwOTw
Mk+nuaV13HZjpLa2R+IWIUOVLAgSAKxzndz0HIwOfcVUdhDJbzxoqkgSbeSA QxH17VP/AGPc
f34vzP8AhR/Y9x/fi/M/4UXXcLMfthhxsdj5BMy575+7n8o/++j+D4x81oFj 34ljLMSSUysf
v35HPpxUP9j3H9+L8z/hR/Y9x/fi/M/4UXXcNStMEaCOVY1jLMylVJxwAc8k +tQVof2Pcf34
vzP+FH9j3H9+L8z/AIU+ZdwszPq9ZSWyWd0tyN27bsUdSeeR6fWnf2Pcf34v zP8AhR/Y9x/f
i/M/4UOUX1CzLmif8eMn/XX+lX6radbPa2rpIVJL5+X6VZrCWrLWwEgAknAH eo0uQoZYmUsz
9eoA2/8A1qeRkEHvVZ4GjyYQTz03ZyMe/wDjTjbqJ36EyjDRyAn98hcr2B4/ xqCGeWSR+hCs
w2iIjOCQMMTjNToHxEGVQI49vBznp7e1NS3KFts8gUljtwuATk+nqaljGPdH MflRs4Z9p4xn
gnAyRyMc/l1prahAruuSSgboRyQDkYznseoqU2y4wjOuDuXBzg8gnnPXPP59 eaRrVWV18yQI
4b5ARgE5yeme560DEa7VOHjdZCQAhIyc5xznHY9+30oF187II3ZwfuAAEDCk 85x/EP8APNOl
txIzHeyl1CtgA5AzxyD600WaJzE7xkdCuDgYAxyD/dFAAt4jn5Ucx5UeZxjJ AI757jtTLm6a
KdkDxjagYIw+aQ5PA59h2PWpVtY1QouQu5Wxnptxj/0EVIIwJWk5yyhT+Gf8 aAIJbtURztYA
Bgr4BBIByMZz2Pp0pst7tikYRsNocKzYwzLnjg57GnvZo4ZWd9h3YXjCk5yR xnufzpzWsbIE
bJXczYz13Zz/AOhGgBXkcQF1jIb+63JHPXjr64FRpcHaAczSEn5UTYQBjqGP uPzFTbG8rZ5r
7v7+Bn+WP0qP7KAdwlkEmTmTjJzj2x2HbtQBHHd7VYzhlUO4D4GDgnjjnoPT tQl/HJgIjO5b
G1WU9ieucdj3qVrWNkCNkruZsZ67s5/9CNAg+ZWeWR2Vsgtj0I6AY7mgBv2y PymkwQFAYZIG
VPQ8nH580kl0DZieEjlgBkbsfMAeB1/ClFmihdrurIqqrDGRjI9PQmnfZh9n 8re/3t+7jOd2
70x19qAGrOwVdwMrtkgKmw4HXhj7/rUNrdySGFSpcsmWIAGDhDnr0+arBtyc EzybxnD4XODj
jpjsO1Nis0i2lHcFcc8cjAGOn+yKAEN7GFDFJArAFDjO4EgZAHPce/NWFJKg kEEjoe1QCzQb
QXchMbAcfKAQcDj2HX0qxQAUUUUAULn/AF7fh/Kii5/17fh/KimI2T/rFHsf 6UkrFInYdVUm
hs+YoBxwf5j3pk4f7PJll+4f4fb6/WgCGaFNxeWVFJOCcsvP/fVJCYobvyiH 8w/KrYfaeM4y
cjt69qr3aKrPHHKY2LEkkqeCBnqwPYdf8KdDHGslqYy2PMCcsD0jYduM/wCf SqaVrkpu5oSz
RwrulkSNScZZgBmkWeFgxWWMhAGYhhwCMgn8Kiu9gZHLTI4BAaKMuccZB4I7 D8qrQ2ss0jyT
L5bO6+ao6MNinHv8wx9C1SUXVuYHkEazxs5GQocZIxnp9KjlALcgHr1Ge5qj bK4sZLYxSLM6
psJQgKfLUZzjAwR9ePWr0v3vz/maAI9qf884/wDvgUbU/wCecf8A3wKSRxGh Y/8A66SNs7UB
LsBlmA4HfrSGO2p/zzj/AO+BRtT/AJ5x/wDfAoyckKpbHXBHH50MwVSSemel ABtT/nnH/wB8
Cjan/POP/vgUoIIyCCPUUUAJtT/nnH/3wKNqf884/wDvgUtFACbU/wCecf8A 3wKNqf8APOP/
AL4FLRQAm1P+ecf/AHwKNqf884/++BS0UAQX0jQWErxYRgVxhR61jf2ld/8A Pb/x0f4Vr6n/
AMgyb6r/ADqrov2HyJPtPk+Zu/5a46Y4xn8a1jblvYh7lL+0rv8A57f+Oj/C pop9TmTfFudf
UIP8Koz+X58nlf6vcdv0zxWzYB20lBG4UmU/Lv2b/YHt6/hVSSXQSKEl/fRO UeQqw6gqP8Kb
/aV3/wA9v/HR/hVjVBG1tbyJvJbIJc5PB6fn+dQKPtEHlwBQwC5QxrzyBw/X kkfnQrW2Bif2
ld/89v8Ax0f4Uf2ld/8APb/x0f4VI1tbCJplZnjCn5VfuCo6lR/e9O1D2kMY lZvMYRFlIDAb
iGUZ6cD5unt1p+72DUj/ALSu/wDnt/46P8KP7Su/+e3/AI6P8Kn+zReQodys alpOT6iPAyAf
73p27VW8tUvNka+ahHQ8cFeuSO2euO2aLLsGo7+0rv8A57f+Oj/Cj+0rv/nt /wCOj/CpgkQh
kjKpsYoiSkDJzuIbPbkDPoBjqKbdiJrJZIo1UfIAdoBIzIOfc4GaNOwakf8A aV3/AM9v/HR/
hR/aV3/z2/8AHR/hUdtJHHu3jBOMN5YfHtg8enPt71ZjhWC+t1kBaZpQcqQF GHI6Y9j6daLL
sGpF/aV3/wA9v/HR/hR/aV3/AM9v/HR/hToreCVPOy0cYDZDNnoVHUD/AGvT t78ONrAB1kbJ
Ygg44VA2ORznOM8euKPd7BqR/wBpXf8Az2/8dH+FH9pXf/Pb/wAdH+FSR2UT ShXcqJSojJbu
QDjgHONw9P8ACO0aNLaZ3wDvQA+Ur9m7H6UWXYNQ/tK7/wCe3/jo/wAKP7Su /wDnt/46P8Kf
AqLh2DGSWGRwQQFXhhjGPb260+6gh89Y9rAgSMWGBkKz8Yx146/pRZdg1If7 Su/+e3/jo/wo
/tK7/wCe3/jo/wAKHghW2M/7wBgNq5BxncOTj/Zz09veqlFl2Fdlv+0rv/nt /wCOj/Cj+0rv
/nt/46P8KqUU+Vdguy3/AGld/wDPb/x0f4Uf2ld/89v/AB0f4VUoo5V2C7Ng sXCuxyzIpJ/A
UUi/6uP/AK5r/wCgiiudmhvH/WKPY/0okTzI2QkjcCMjqKRs+YoBxwf5j3pQ H7sv/fP/ANf6
0AUpFlQuWvHVEIBZ2Rew/wBj3otgs0yM9zI7xHcFJTByCM8AZGDTrpAyuT5u VlBDRruKnaOc
dxzRabt8O+MRt5b5AXH8Q5x2z1/GnbQC1LNHCu6WRI1JxlmAGaRZ4WDFZYyE AZiGHAIyCfwq
K72BkctMjgEBooy5xxkHgjsPyqtDayzSPJMvls7r5qjow2Kce/zDH0LUgLq3 MDyCNZ42cjIU
OMkYz0+lQ3ClgQP1+tU7ZXFjJbGKRZnVNhKEBT5ajOcYGCPrx61el+9+f8zQ BSkjVGBkIYD5
mVTgYJ6CrZyPlwAB2HAFJgZBwCR0JGcUUhiYYE7duCc8nH+elIUJG3KhRu55 yc57fjTqKAFJ
LHLYyewOcUlFFABRRRQAUUUUAFFFFAFbU/8AkGTfVf51ztdZ/Ae3I/rTcN/z 0H/fH/16uM+V
EtXOVq5BqDQ23keVG6ZyQ4zmt7Df89B/3x/9ejDf89B/3x/9em536C5Tn7u9 a6REZFQJ90KM
AVA00rxiN5XZF6KWJA/Cunw3/PQf98f/AF6MN/z0H/fH/wBehTS6BynMyXE0 gxJNI4xj5mJ/
z0FOjupo95WRgXBy245GSCT9eBXSYb/noP8Avj/69GG/56D/AL4/+vT9p5By nMCaUPvErhgS
chjnJ6mk3vvL7m3HOTnk5611GG/56D/vj/69GG/56D/vj/69HtPIOU5cu5QI WbaO2eO/+J/O
nR3E0YxHNIgxj5WI/wA9TXTYb/noP++P/r0Yb/noP++P/r0e08g5TmIppYc+ VK6Z67WIzQk0
qJsSV1XOcBiBn1/Sunw3/PQf98f/AF6MN/z0H/fH/wBej2nkHKcwkskZBR2U qSRg4xnrQZZC
SS7ZJJ6+vX866fDf89B/3x/9ejDf89B/3x/9ej2nkHKcylxNGSUmkUkAHaxG cdKSKaWHPlSu
meu1iM10+G/56D/vj/69GG/56D/vj/69HtPIOU5kXEwVlE0gDklhuPzZ65pP Ol/56v8Ae3/e
P3vX6+9dPhv+eg/74/8Ar0Yb/noP++P/AK9HtPIOU5h5ZJCS7sxYgnJznHSm V1WG/wCeg/74
/wDr0Yb/AJ6D/vj/AOvR7TyDlOVorqsN/wA9B/3x/wDXow3/AD0H/fH/ANej 2nkHKcrRXVYb
/noP++P/AK9GG/56D/vj/wCvR7TyDlMxf9XH/wBc1/8AQRRUtz/r2/D+VFZl Gyf9Yo9j/SnU
xs+YoBxwf5j3pQH7sv8A3z/9f60AVZ1j3ySOqqqkAs0xQdBS2hgZyU4kA/vl sqe49ulNukDK
5Pm5WUENGu4qdo5x3HNFpu3w74xG3lvkBcfxDnHbPX8adtALMs8MGPOljjz0 3sBmnqwdQykM
pGQQeCKhvFLQqFBJ82M8DsHGarSC4OoE+ZIBvXYAjEFcDPOdv97qM+nakBfL AEAkAscDJ6mq
l19x/wDdP9aqhHcI0ondEkDNKPMVm+VhwnVeSPu8c+2BbuBuDKOpBH6mgCJ1 jMmMKipk5Tap
6gdc+9G5llA5aNjhWyOuM44/Ggu4fdICMg8oWbuD7YoaQOYlAclWJJKsOx9a BajS8skjrEyI
IztJZS2TgH1HqKa94iBmZH2DdhuMMRnIHOex/KnvDuYskjxk/e245/MGoprM PHIqueQ21T91
WIOT0z3P50iiQXI3BXR0bIGGxxnODkHHJGPrUkcglQOucEnGe/PX6VC9sTG4 3l3faC7YBAB7
YHUZJHvU6qFUKoAAGAB2oAWiiigAooooAKKKKAFH3D9R/WkpR9w/Uf1pKACk G5iQkbNg4JGP
8aWmBcknbnDH+HPZf9k0ITdhVYMSOQQcEGnUx1AnjbaAzIxY4wTyOvAqq8ax 3NzLFChlWIMu
F5LfN/OgC7RVCKeXYx85JSCNgVg288/LkAD/AA6ninwnN4GM5O6MADAG8gtk YPPHp1HegZcp
Nw3BcjJGQKoqIf7RlMjW+7zBgOo3/dXGDn19qi80vLAxlDyFRvQhf3ZLpkYx kfjzxQBqUVnQ
SeXbwI1yY1CYZjtGxgB8nIx3PB54qezkmlLtKcY2jZtxglVJ/U/57AFqiiig AooooAKKKKAC
iiigAooooAKKKKACiiigChc/69vw/lRRc/69vw/lRTEbJ/1ij2P9KdTGz5ig HHB/mPelAfuy
/wDfP/1/rQBVnWPfJI6qqqQCzTFB0FLaGBnJTiQD++Wyp7j26U26QMrk+blZ QQ0a7ip2jnHc
c0Wm7fDvjEbeW+QFx/EOcds9fxp20Au0jMEUsxCqBkkngCqt/vKoq71Ukkuo diD2GEIPPPPT
iqu2ae2kWcTG4khwgwwXmMZzj5Qd27r/AIUgNTcCxXI3AZIzyB/kGq8pwcnp z/M1Wbd5g2fa
fs2F3ff3fx5/2uu3p2x2qSbH2f5d2Nhxuznv1zz+dAEbXMattyT7jpUqsGGV II9qzo08xwuc
dTn6c1dt8IDECGA+bcCPb0NICWimKCzng8OPm3cAYGeM/XtQGc9BnIyOg4yP f39qBj6KjDcO
+7IVc/dxnr78dKeu4ZD4BH0/lk0ALRRRQAUUUUAFFFFACj7h+o/rSUo+4fqP 60lABTNjZJWV
0zyQMf4U+kUMxb5sAHAwhbsPT60CGhDvDtI7kDA3Yp9MVyJGjcEMM4OCARmk E6NJsXcTnGQh
x+eMUDJKKKarqxYA5KnB9jgH+ooAdRRTXdY0Z3OFUEk+1ADqKZHKsudocY/v IV/mKalwjEDk
EsVGR1Iz/wDEmgCWiiigAooooAKKKKACiiigAooooAKKKKACiiigChc/69vw /lRRc/69vw/l
RTEbJ/1ij2P9KdTGz5igHHB/mPelAfuy/wDfP/1/rQBVnWPfJI6qqqQCzTFB 0FLaGBnJTiQD
++Wyp7j26U26QMrk+blZQQ0a7ip2jnHcc0Wm7fDvjEbeW+QFx/EOcds9fxp2 0Au1GJ42mMQb
5xnIx6YP/sw/OoL/AHlUVd6qSSXUOxB7DCEHnnnpxVW089ZjcTRSFvKZmwnJ OyLgD1yD+VID
VqrOu4FemQR+poff9qGPN8rI34/vdsd8euOOn+1TRny49zFm28sV2kn1x2+l AFdbYxsGjkBP
I+YYHT2qZFcMS7KflwMMx7j1+lJ50e9k3jcoyR6UsciyoHQ5U96Vx2Y7/wDX SbV5+Reevyjm
m+dF5vleYnmf3Nwz+VK7rGjO5wqgkn2oAdxkHA4GBx0+lAAAwAAPQDFIzBVL MQABkk9qWgAo
oooAKKKKACiiigBR9w/Uf1pKUfcP1H9aSgApoQOW+5wx+8R6D1Bp1MaKNjlk Un1IoE1cV8Ca
IAjhG6fUVWMJeYqIpEjYsJMv8rAg9ADwScHoO9WVjRDlUVT7DFOoAoeU81uJ W3Ss5GMBcMoB
xkEgYOScdefag2r7JR5Sh3CnfGBjACgqM/Q8Hir9FAzNNm+w7YzwkmwMVyrH bjGOB0PT+tTt
AwtruJEADAiNRgDlR09Oc1booAptGzRqPs8pRX3Mkjht4wR3Y98HmoEtHyGe 3BjDZ8r5emZO
MZxxuFadFAGfNbSOsgWL94fMzJkfOCGwuevdevHH0q8iLGoVRgCnUUAFFFFA BRRRQAUUUUAF
FFFABRRRQAUUUUAULn/Xt+H8qKLn/Xt+H8qKYjZP+sUex/pTqY2fMUA44P8A Me9KA/dl/wC+
f/r/AFoAqzrHvkkdVVVIBZpig6CltDAzkpxIB/fLZU9x7dKbdIGVyfNysoIa NdxU7RzjuOaL
Tdvh3xiNvLfIC4/iHOO2ev407aAWy6iRYyfmYFgPYYz/ADFOqleqpuoWkE2w I4zEHyDlcZ28
9jUDNd+ZAX8xZR5asArMGzjccg7R1bqO30pAalVpfvfn/M1SxcGIgNLt3jfK VkywweiZBHO3
7vHPoCKtDiOPkn5epBBP58/nQBjXShrqQIpCqSSD29T9P8av6ft+z8KQdxye xPqP89qs4GSc
DJ4zQAFAAAAHAA7VCVnc2nV5oqPYpyZY3UQR98jZQ7TgfKuDnpwR+lQzJO32 gFpCSsg2BGwR
g7ec49Ogz+tadFUZGbJHcSGddzlmDjbtOMYO3knb6dBn9adKJCy+S8ypt+TK Ox3ZOc8j2+9x
+taFFABRRRQAUUUUAFFFFACj7h+o/rSUF1VDuYDJ7mm+bH/fX86AHUU3zY/7 6/nR5sf99fzo
AdVJMqvmh3LtOUwWJBG8jp7Dnj0+tW/Nj/vr+dRqLZHLoIldurDAJoAptcTz wAMgRZdhXOOh
ZRjG7LDB9v1qdp3idERQ0aFY32rgAnHTnjqOx+vpKBbKWIEQLHLEY5PXJoYW zuHcRM69GOCR
QBWlnaSG1yB+8COceu9P8TTlaUaOXeTL+RuDDII+X69fepglqHLhYQxOScDJ 5z/OnDyArKPL
AcksOOc9c0AQgSQhVACvK+0FpGkAwCc849KrxPN5qxq4DeYcnBweZc8Z9quC O0VWUJAFb7wA
GD9aNlrsKbYdhGCuBjrn+dAEMt3LHG0oCFcuqrg5BUNyTnn7vT3q2m7aN+N3 fb0FRkWxZmIi
LMMMeMkehqTzY/76/nQA6im+bH/fX86PNj/vr+dADqKb5sf99fzo82P++v50 AOopvmx/31/O
jzY/76/nQA6im+bH/fX86PNj/vr+dADqKb5sf99fzo82P++v50AOopvmx/31 /OjzY/76/nQB
Suf9e34fyopLggzMQQRx0+lFMRt45zS0UUAQvbRO5Zg2T1wxH9aWO3jifcgO 7GMlif50UUAS
0UUUAFVpfvfn/M0UUAMooopDMz7XP/bv2bf+5/u4H93PX61eunaO1mdDhlRi D74oooAeiBFC
gkgf3mJP5mmXDskYKnB3oPwLAGiigCWiiigAooooAKiZ2F1GgPylGJHuCv8A iaKKACeKN0Zm
RWIU4JGamtLW3a0hZoIiSikkoOeKKKYiX7Jbf8+8X/fAo+yW3/PvF/3wKKKA D7Jbf8+8X/fA
o+yW3/PvF/3wKKKAD7Jbf8+8X/fAo+yW3/PvF/3wKKKAD7Jbf8+8X/fAo+yW 3/PvF/3wKKKA
D7Jbf8+8X/fAo+yW3/PvF/3wKKKAD7Jbf8+8X/fAo+yW3/PvF/3wKKKAD7Jb f8+8X/fAo+yW
3/PvF/3wKKKAGPaW+4fuIuf9getNFrbnH7iL/vge3+NFFAFaSCH7Uo8qPGwH G0VZt7W3aEEw
RE5PVB6miigCX7Jbf8+8X/fAo+yW3/PvF/3wKKKAD7Jbf8+8X/fAo+yW3/Pv F/3wKKKAD7Jb
f8+8X/fAo+yW3/PvF/3wKKKAD7Jbf8+8X/fAooooA//Z
Content-ID: <part2.3EB150DD.6374FBE5@ca.ibm.com>
Content-Disposition: inline; filename="C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\nsmailUC.jpeg"
CAHtAlwDASIAAhEBAxEB/8QAHwAAAQUBAQEBAQEAAAAAAAAAAAECAwQFBgcI CQoL/8QAtRAA
5ebn6Onq8vP09fb3+Pn6/9oADAMBAAIRAxEAPwC5f3xszGBGG3jvxjAHt71V GtE9IF/P/wCt
RrQzLbgnGQf5Co5MeWkOQFRRjGOffrWsYpq4h/8AbZ5/cKcf7X/1qT+3D/z7 j/vof4VQnjRQ
SrZPpxWneR2pupLZhGC8kaxrGm0pn72Tj396OWPYGyP+3D/z7j/vof4Uv9tn /n3H/fQ/wqIW
VruuT5kgS3IU7uMksR1APGB6flUqRxCyaO2lYrLciMSDgkEdD6jk8UWj2Fdh /bZ/59x/30P8
KP7bP/PuPzH+FNWxs3vFt0mfdvZWUHJwAec4A6jpzUcNraNAZ3lkEfmCMZ4P TJPAP5frRaPY
Lsn/ALaP/PuPzH+FH9tH/n3H5j/CmRWFvILdQ8jGcyAOCABtzg4x/WomtYla 2iy5knVW35GF
3H0x/Wi0RXZY/to/88B+Y/wpf7ZP/PAfmP8ACoZLWyW4WL7QVxIVfPOB65wM c8d+tQXkAt5g
oHylQwO/cCPUHAo5Yhdl3+2T/wA8B+Y/wo/tg/8APAfmP8Ky6KfJEOZmp/bB /wCeA/Mf4Uv9
sH/ngPzH+FZdLRyRDmZp/wBrn/ngPzH+FH9rn/ngPzH+FZlLRyRDmZp/2uf+ eA/Mf4Uf2sf+
eI/Mf4VmUtHJEOZml/ax/wCeI/Mf4Uv9rH/niPzH+FZtFHIg5maX9qn/AJ4j 8x/hR/ap/wCe
I/Mf4VnUUciDmZo/2of+eI/Mf4Uv9qH/AJ4j8x/hWdS0ciDmZof2of8AniPz H+FH9pn/AJ4j
8x/hWfS0ciDmZof2mf8AnkPzH+FH9pH/AJ5D8x/hVCijkQczL/8AaR/55D8x /hS/2kf+eQ/T
/CqFFHIg5mX/AO0T/wA8h+n+FH9on/nkP0/wqjRRyIOZl/8AtE/88h+n+FH9 oH/nkP0/wqjS
0uRBzMu/2gf+eQ/T/Cj+0D/zzH6f4VSpaORBzMu/bz/zzH6f4Ufbz/zzH6f4 VToo5UHMy59v
P/PMfp/hS/bj/wA8x+n+FU6KOVBzMufbj/zzH6f4UfbT/wA8x+n+FVKWjlQc zLf20/8APMfp
/hR9tP8AzzH6f4VUpaOVBzMtfbD/AHB+n+FL9sP9wfp/hVSlo5UHMy19sP8A cH6f4Ufaz/cH
6f4VWoo5UHMyz9rP9wfp/hS/az/cH6f4VWoo5UHMyz9qP9wfp/hR9qP9wfp/ hVelo5UHMyx9
pP8AcH5Cj7Sf7o/IVXpaOVC5mT/aT/dH5Cl+0H+6PyFQUUcqDmZP9oP90fkK PtB/uj8hUNFH
Kh8zJvPP90fkKXzz/dH5CoaKXKhczJvPP90fkKPOP90fkKipaOVBzMl84/3R +Qo80+g/IVFS
0cqDmZJ5p9B+QpfNPoPyFR0UcqDmZKHZjgAfkKXL+ifpTI/vfgf5UhdAcF1B 9zUysi1qPLkM
qnZljgDj0zS5f0T9Kryf8fVv/wAC/wDQTVWLTrWcPJLFudpHydxH8R96m47G g8mwqG25Y4A4
Oad8/ov6VmwIsYt0QYVZZQB7Zap9ScoVMTsJ958tBzv9QR6e/amItO5jQu+w KoyTxQHJHQfk
KzA5eyuDK7Gf/lojcbPQAenv3rRHSl0H1KWrW8s7w+UpbaDnBAxkD1ql9ivN oUR8D7vK8frW
4/X8B/KkpqbSsFjA/s675zGST/tL/jTjY37SeYysZM53Fxn881u0U/aMTVzD Sz1BJC6B1dur
CQAn8c0PZ6hICJA7AnJDSA89M9a3KKPaMOUxjBqZIJaUkHI/e9P1psdpfxZ8 oOmeu2QDP61t
0Ue0Ycpi/ZtQ3K37zKkkHzBxnr3o+yX/AJXlYfy/7nmDH5Zraoo9ow5TIMOp EglpSRyP3vT9
ajeyvJGLOhZj1JcE/wA626KPaMOUw/7Puv8Anl/48P8AGl/s+6/55f8Ajw/x rbop+0YcqMT7
Bdf88v8Ax4f40fYLn/nl/wCPD/Gtuij2jDlRi/YLn/nn/wCPCj7Bc/8APP8A 8eFbVFL2jDlR
jfYbn/nn/wCPCj7Dc/8APP8A8eFbNFHtGHKjH+w3P/PP/wAeFH2G4/55/wDj wrYoo9ow5UZH
2K4/55/+PCj7Fcf88/8Ax4Vr0Ue0YcqMn7Fcf88//HhR9iuP+ef6itaij2jD lRk/Y7j/AJ5/
qKX7HP8A88/1FatFHtGHKjK+xz/88/1FL9kn/ufqK1KKPaMOVGX9kn/ufqKX 7JP/AHP1FadF
HtGHKjM+yT/3P1FL9lm/ufqK0qKPaMOVGb9lm/ufqKX7LN/c/UVo0Uc7DlRn fZZv7n6ij7NN
/c/UVo0Uc7DlRn/Zpv7n6ij7NN/c/UVoUUc7DlRQ+zS/3P1FH2eX+5+oq/RR zsOVFH7PL/d/
UUfZ5f7v6ir1FHOw5UUvs8v939RR5Ev939RV2ijnYcqKfkSf3f1FHkSf3f1q 5RRzsOVFPyJP
7v60vkyf3f1q3RRzsOVFTyZP7v60vkyf3f1q1RRzsOVFXyX/ALv60vlP/d/W rNFHOw5UVvKf
+7+tL5T+n61Yoo52HKiv5b+n60vlv6VPRRzsOVEHlt6UeW3pU9FHOw5UQ7G9 KNjelTUUc7Dl
RFsb0o2N6VLRRzsOVEe1vSjafSpKKOdhyoZtPpRtNPopc7DlQwhwDsIDYwCR mofJnJyZIyfU
xA1ZoocrhaxWMVw0iu0yllzj5PUY9ajaxLMWYQEk5JMA5q7RSuOxVjtnRo8u m1CSFVNo5p7J
csxPnKMnPEf/ANep6KLhYqyQTyIUadSCMH5P/r1ZHSloouFhX6/gP5VDcM4C BG2lnC5xnrUz
9fwH8qguOsP/AF2T+dIZL9kuP+fpf+/X/wBej7Jcf8/S/wDfr/69S3ClpFxG kjbWwrnA6j2N
NiVlmXdDFGxVuEbIIyvfA96Yhn2S4/5+l/79f/Xo+yXH/P0v/fr/AOvS3pki 8ueNQZADHgnj
5un/AI8FH4n8K6eZEp/hFsBAG9FLDJP0QIc9OT9AAT/ZLj/n6X/v1/8AXpot 5SEIvYyH+6fL
HzcZ4554pIJpZbpI0n3wjcQ+AfMA2dxx1Yjj+fNVY5cW1gs8/kfdKngAL5bc gkc9cH04+pAL
v2S4/wCfpf8Av1/9ej7Jcf8AP0v/AH6/+vVZ7u5yu2WNQAShc4835mA42ndw FOFx973GJGnu
I4zKjtKzSSosZUY+XeRjAz/CO/egCT7LOGC/a03EZA8vkj8/cUv2S4/5+l/7 9f8A16jUCa6h
8q9eTCSfvF2E9U46Yq5ayGa1hlYAM6Kxx0yRQBX+yXH/AD9L/wB+v/r0fZLj /n6X/v1/9ert
FAFL7Jcf8/S/9+v/AK9H2S4/5+l/79f/AF6u0UAUvslx/wA/S/8Afr/69H2S 4/5+l/79f/Xq
7RQBS+yXH/P0v/fr/wCvR9kuP+fpf+/X/wBertFAFL7Jcf8AP0v/AH6/+vR9 kuP+fpf+/X/1
6u0UAU1t5Y2zJOHGDwEx2+tFWZfu/n/I1WpASRxB03FmHJ6Y9ad9nH99v0/w qrfzyW2kSSwt
tdTwcZ/ixUF5czQRrGzXCtIkpBcoCMJkfdH9RTA0fs4/vt+n+FH2cf32/T/C s6DVXWKONbeS
do4ozIRksSwB4wD+pFWdVujbQxqkqxPLIEDnHyju2D1/+vQBY+zj++36f4Uf Zx/fb9P8Kzo9
ZC6fbTSKGZyUdiflUj1wDgnrjFT/ANpj7alsVjUuFIZnOGz/AHTjn8cZNAFr 7OP77fp/hR9n
H99v0/wqkmsArHI8JEUqyMhDZbCdcjt09TTnvZvJtJWjEazyoF2SZOGHfK/y /OgC39nH99v0
/wAKPs4/vt+n+FUJ9Wx5iRqPmSQxSqSQSoJ7gA9OxNA1CWKOye4B/eRM7bGB 3AIDkgjr7Aj8
aAL/ANnH99v0/wAKPs4/vt+n+FUJNYMUJeS3G7yVmULJkFSQOTjg8+9Pm1Uw CcSwfPC6K21i
VAYZBJxn9PSgC59nH99v0/wo+zj++36f4UttMLi3SUFCGGfkbI/PA/lUtAEP 2cf32/T/AAo+
zj++36f4VNRQBD9nH99v0/wo+zj++36f4VNRQBD9nH99v0/wo+zj++36f4VN RQBD9nH99v0/
wo+zj++36f4VNRQBD9nH99v0/wAKPs4/vt+n+FTUUAQ/Zx/fb9P8KPs4/vt+ n+FTUUAQ/Zx/
fb9P8KPs4/vt+n+FTUUAQ/Zx/fb9P8KPs4/vt+n+FTUUAQ/Zx/fb9P8ACj7O P77fp/hU1FAE
P2cf32/T/Cj7OP77fp/hU1FAEP2cf32/T/Cj7OP77fp/hU1FAEP2cf32/T/C j7OP77fp/hU1
FAEP2df77fp/hSeQv99v0/wqX8RSHn06UAR+Sn99v0/wo8lP77fp/hUn4j8q TPuPyosAzyV/
vv8Al/8AWpPKT++/5f8A1qf+I/Kj8R+X/wBanYBnlx/89G/T/Cjy4/8Ano36 f4U7P+0v5Umf
dfyosFxPLj/56N+n+FHlx/8APR/y/wDrUufdfyoz7r+VFguN2R/89G/z+FAj QkDzGyf8+lLn
/aX8v/rUqn5h8y9fT/61FhXIVOVB9qWkX7g+lLUlCv1/AfyqC46w/wDXZP51 O/X8B/KoLjrD
/wBdk/nQBoPGj43orY6ZGabFGiqrKiqxHJAwf5VJTY+I1HTgUxDqTPzEY7da WmHIkJUA8Drx
6+3+f5gD6Kjll8mGSVx8qKWO05JArKSSW0RkdXt2lCO7kqRu3gSN1OPvD2oA 2aKy/tR85Ue+
2Q/Ptmyg8zGzuRjqWHHpRHdXT3EYdo4ydmYicFgQCx27STyTzkAY56GgDUor I+3TtKVjmT5y
CFYhmj+dRggAY4Y5BJ6damuLqSG6jQSjhkQrIygvkgFgu3J69QRyDxxyAaNF Za3FwlvAzTM/
nRB2ZlX5OUBIwOwYnnPT60T3Mqsoguo2TZlHdh+9bJyOFO7GBwuDz70AalFF FABRRRQAUUUU
AFFFFADJfu/n/I1WqzL938/5Gq1ICTyI7m0MUy7kYnIzjvmnT2sNwytMm4qG UckcMMH9Kh4/
ur/3yKOP7q/98igB4sLcEFFdDtC/JIy5A6ZwealeCOSaOVly8Wdhz0zwar8f 3V/75FHH91f+
+RTAe1hbsrrtcLIzM4WRgGJ65wacbOAyI5QnYQVXcdqkDAwucD8qi4/ur/3y KOP7q/8AfIoA
elhao2REOAwCkkqAeuAeBn2oWwt1VF2uVjZWQNIxCkdMZNM4/ur/AN8ijj+6 v/fIoAcunWiu
rCL7u7apYlRu64XOOaVbC2Xy/wB2WEYIUM5YAEYI5PTHamcf3V/75FHH91f+ +RQAv9mWhjZD
EWVlCHc7EhQcgAk8D6VI1pC0kkmHV5CCxWRlJwMDoai4/ur/AN8ijj+6v/fI oAswxRwRLFEo
VFGABT6p8f3V/wC+RRx/dX/vkUAXKKp8f3V/75FHH91f++RQBcoqnx/dX/vk Ucf3V/75FAFy
iqfH91f++RRx/dX/AL5FAFyiqfH91f8AvkUcf3V/75FAFyiqfH91f++RRx/d X/vkUAXKKp8f
3V/75FHH91f++RQBcoqnx/dX/vkUcf3V/wC+RQBcoqnx/dX/AL5FHH91f++R QBcoqnx/dX/v
kUcf3V/75FAFyiqfH91f++RRx/dX/vkUAXKKp8f3V/75FHH91f8AvkUAXKTm qnH91f8AvkUc
f3V/75FAFvBpMHrVXj+6v/fIo4/ur/3yKLgWdp9qMH2/Kq3H91f++RRx/dX/ AL5FFwLBB9vy
o2n2/L/61V+P7q/98ijj+6v/AHyKLhYnKt7flRtb2/KoOP7q/wDfIo4/ur/3 yKLhYmw3t/3z
/wDWo2t7f981Dx/dX/vkUcf3V/75FFwsTbW9v++f/rUBW3Dp1/u//WqHj+6v /fIo4/ur/wB8
ii4WEX7g+lLRRSGK/X8B/KoLjrD/ANdk/nU79fwH8qguOsP/AF2T+dAGlTY+ I1HTgU6mx8Rq
OnApiHU0f6xj7D+tOphyJCVAPA68evt/n+YA+muiyKFcZAIb8Qcj9RTJ/O+z y+UAJNh2YPfn
HX8KqF7SNGa0MSzcB2GN6qWAYtnnjqc9xzQBeKKZFkI+ZQVB9jjP8hTqynup hvMdwXjiSR1f
CkS7Qh5OOmSw4x0pz3DJdeRLeGJELDzDsBY4QjORj+I9BQBp0VltezeZAWZY 2Plq8TsFJLYy
QuMnGfXqD6cobi5Frau1wi+am9pGIjAOBgZII7k/geg4oA1NwDBcjcRkDPJH +SKWsq53TrmR
EdlWFcEELuZwWByM9l4IyB9afLvtIggeO33uWGHCxoAANoJU9euMDv6cgGlS bgWK5G4DJGeQ
P8g1lQXDmOWYy7Hl8tynGApVAzjPPHPPTinO7K1xPDdNJ5durhhtIfBfg4Ht jjFAGpRRRQAU
UUUAFFFFADJfu/n/ACNVqsy/d/P+RqtSApi+G6TPkAIX4MvzfLntj2qRLpNp 8w4IZhwpIADE
An06dT7042+bWWHd/rN/OOm4k/1qFrBWYsTGxJOd8YbALE8eh+b37UDJ5JhH PHGVJ3gnIBOM
Een160jXUKojljh13LhScjIHT8RTnjLSpIrAFQQcjOQcZ/HgVXa2fy5CihXa VSAecAPn157n
8cUATfaYtoOWJJxtCEt+WM9x+Y9acs8bOFUliRnKgkdM9elQPZbzvcxvISSd 8eV5AHAz/sjv
609LXZMrhgFUAYVdpbjHzY4P5cUATI6yIrocqwBB9qdTUDKih23MAAWxjJ9a dQAUUUUAFFFF
ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
UUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAK/X8B/KoLjrD/wBdk/nU79fw H8qguOsP/XZP
50AaVNj4jUdOBTqbHxGo6cCmIdTR/rGPsP6024/495f9w/yqlIkgmnBtoRCI 8qw6/wAXI+Xr
04zxQBo0VWv8/wBn3WQB+6fofY1VR4Yoh5M9qoZwJZbdVUIuCRnkjqMc+tAG krBhlSCMkcHu
OtIUUyLIR8ygqD7HGf5CsWJgZEPn7Y1kLGcbehaYZJxjnj25461YuLuVFlZJ v3o8zMWB+7UB
trYxnnC9ePm9xQBqUVRllliuoY3n3Zx8se0MSTzlSPu/Q5HPXqL1ADVRUZ2U YLnc3ucAfyAp
1FFABRRRQAUUUUAFFFFABRRRQAyX7v5/yNVqsy/d/P8AkarUgIY/tMzSeUIt qOV+YkH/ADzS
bp/+elp/38P+FS2UiRpOXdVHnEZY47Cmrc7o44l2lCqqxx68cGmlcLi+Te+l v/30f8KPJvfS
3/76P+FTRboYplBL+UflB/3QccD39KLO4kuA5kiMe1iBnvhiPp29f0xkAh8m 99Lf/vo/4UeT
e+lv/wB9H/Cp/ttvkgsw2kgko2ODgnOOg7noKebmEEguAQSDnjGOpPoOnPuP UUAVfJvfS3/7
6P8AhR5N76W//fR/wqx9riCg4k5OAvlNuPvjGccjmnWshmtYZWADOiscdMkU AVfJvfS3/wC+
j/hR5N76W/8A30f8Kv0UAUPJvfS3/wC+j/hR5N76W/8A30f8Kv0UAUPJvfS3 /wC+j/hR5N76
W/8A30f8Kv0UAUPJvfS3/wC+j/hR5N76W/8A30f8Kv0UAUPJvfS3/wC+j/hR 5N76W/8A30f8
Kv0UAUPJvfS3/wC+j/hR5N76W/8A30f8Kv0UAUPJvfS3/wC+j/hR5N76W/8A 30f8Kv0UAUPJ
vfS3/wC+j/hR5N76W/8A30f8Kv0UAUPJvfS3/wC+j/hR5N76W/8A30f8Kv0U AUPJvfS3/wC+
Kv0UAUPJvfS3/wC+j/hQYrwDOIP++j/hV+mv0/EfzoAz9t36W/8A32aA06zx JKIgJGx8pJPS
obu8kgnRI7aWVc/OyqeB7ep/z9JmIa6tCM4LE8jHakBOoHOewoyvofzoXo30 /rSUDFyvofzo
yvofzpKp3115DKolVCFMhBI+YD+H8fX2oAu5X0P50ZX0P51TmuGf/VY8tZI1 Lh+TkqeOORgj
vRFNJLcRMVCxvEzKA2c8rjIxwefegC5lfQ/nRlfQ/nSUUALlfQ/nSOyqhbaT gZ6//Wopsv8A
qn/3TQAkLl4Uc4yygnFPqO2/49ov9wfyqSgBX6/gP5VBcdYf+uyfzqd+v4D+ VQXHWH/rsn86
ANKmx8RqOnAp1Nj4jUdOBTEKQCCCMg9QaiEEW8/ukxgfwj39qmphyJCVAPA6 8evt/n+YA+iq
1/n+z7rIA/dP0PsarwtFFCxtZLV5dw+W3QKH4OFPJ9+e3XoDQBo0VmGR1mkl SYvIYMou0ASs
C5K468ccDkd6SKe4kaNFuY2V5Au9CH/hYkZ2gdh9O/BxQBqUhYAgEgFjgZPU 1QWeWPbKzySh
pZE8sKOi7yMYGc/KOp71DBcPLdwxvNHKEkDBkcP1STjIA9PSgDWoqnLBC2qQ uYoyxjdtxUZy
CmD+FV1u5SikTbiyAzDA/cHcoI6cYBb72fu+xoA09wDBcjcRkDPJH+SKWslp 383ck8ZCo6pN
IwAYZjycgY6kjp1FaFo/mWyPmQ5zzJjJ59uPy7UATUUUUAFFFFABRRRQAyX7 v5/yNVqsy/d/
P+RqtSAZaRJNHOsgJHnE8EjsPSoxaTxyRhVBQFSfnyAQc/X+dT6d0uP+ux/k KRdzRAfvNxQY
bc55I+mKpNoTsWIVdTIzhQXbOFOewH9Ke4ZlARtpyDnGeM8j8RxUMczLDK0w GYiQSCOcDPfA
otLtboPtVlKkj5hjuR0PPb+nY0hkb2O5HXzMbklXO3++2f0qRrdi7vvUlwVY MmVK84GPbP45
Pth4uYCzqJ4yyAlhvGVA659KVp4VKhpYwXJVQWHJBwQPxoArx2ckW1o5lEg3 DlCUAOOAM8fd
Hf1/CxbxeRbxRZ3eWgXOMZwMUJPDJI0aSxs69VDAkfhSLcwMm9Z4ymSNwcYy Bk/pzQBLRUEd
3FK21GBYOUK7hkEZ6jP+yacLmAxGUTxmNTguHGAfrQBLRSKwdQykMpGQQeCK WgAooooAKKKK
ACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAqObf5 RMYUsOm44FSU
1/umgChsvPSD/vo/4ULDcG5heXygqN/CTnnj0q3/AJ/z/n/6x3H1H+f8/wD6 kBEvRvp/Wkpr
xiVdpDEegJH8qj+wx/8APN/++m/xoGTU0IocuB8xABPsM/4mo/sMf/PN/wDv pv8AGj7DH/zz
f/vpv8aAAWkI24UgLjADEDjpkZ56Dr6UfZIfm+U4ZSmCxwAeoAzx+FH2GP8A 55v/AN9N/jR9
hj/55v8A99N/jQA94UffuXO9djc9Rz/iafUP2GP/AJ5v/wB9N/jR9hj/AOeb /wDfTf40ATU2
X/VP/umo/sMf/PN/++m/xo+wx/8APN/++m/xoAdbf8e0X+4P5VJTUCiNQmNo Axg9qdQAr9fw
H8qguOsP/XZP51O/X8B/KoLjrD/12T+dAGlTY+I1HTgU6mx8RqOnApiHU0f6 xj7D+tOphyJC
VAPA68evt/n+YAsj7FzjNRNchVLMAABkknpUWp5/s+fIA+Ruh9jWZdwm3tmG 2Abww/dxbf4H
9zQBs+f/ALP60ef/ALP61mQzTNeFWdMbmBjzyAM4OMZHbknHPuKZdO32h5RE 7C2xhgR8vd+/
OVIpAa3n/wCz+tHn/wCz+tZTXEgeYCZAV77l2IMgcnGQ31yP5UhuX8vcJXUh N0YcLmVsnjjr
0HT196ANbz/9n9aPP/2f1rLaUtu3SjeJVHlELwPMABxjPTB/H6VC9w8rFPMG 0kORuBaPDr1G
OMAnrnpQBtef/s/rR5/+z+tZQmxK6m4EcRb/AFvyjJ2pjnGOck/hRHNOymV3 KkPGpj2gAbgu
e2f4j3oA1hNlgNvX3qWsvT5Wlc7pN5BGSpBT6KRz+ftWpTAKKKKACiiigBkv 3fz/AJGq1WZf
u/n/ACNVqQBp3S4/67H+QpibAq7o5twAB/c56DHXFQrHJLG6RSGNjcnnJGRt 6cEGoZrO6gUZ
vnZm+6u58n/x7pVJK2rE9TUtiWMrbWUM+RuGD0FSMpVMQhAdwJyOME/N+PX8 apWMsm59zvIi
JhmwTk+w+lWra6iulZoW3BSQSOnUjr+GfoR61KdymrFJrWe4t5IiqIoeYqST klt4GRjgfNnP
P61PcWrt5iwiMJLEIjk42AZ5Axz97px0q5RTEZv2Wa5haJwsaCSUhsksd28d MD+9nr/Onx2L
GaOSREG1wxBkaQ4AbHLe7dMVceQI8akHMjbRj1wT/Sn0AUJbKSWIw7kCb3YP kk4cP29iw78+
1J9jkwXEaiXI2n7Q5K4B53EH+8eMY69a0KKAGxhljVXbewABbGMn1xTqKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACmv8AdNOp r/dNAEf+f8/5
/wDrHcfUf5/z/wDqP8/5/wA//WO4+o/z/n/9SAiXo30/rSUq9G+n9aSgY13W NGdzhVBJPtSR
ypLnbnI6hlKn8jTbpGktZkQZZkYAe+Kglt5Ssq7mkLhfn4B2g8rjp3P54NAF yis02b7DtjPC
SbAxXKsduMY4HQ9P61I1uVlbNuJIAx2xDbgZC8gHjqG/P3oAvUVUjtpFMau2 5SFaQ9cuoA69
eeD/AMB96bY27wvlw+7bh2JXDH14GT35PPPuaALtNl/1T/7pp1Nl/wBU/wDu mgBtt/x7Rf7g
/lUlR23/AB7Rf7g/lUlACv1/AfyqC46w/wDXZP51O/X8B/KoLjrD/wBdk/nQ BpU2PiNR04FO
psfEajpwKYh1NH+sY+w/rTqYciQlQDwOvHr7f5/mALIm9cZxUfkf7X6Uy/z/ AGfdZAH7p+h9
jUBiNmo+aCFJHAeSKIJtGCcnJI64HPr70AWvI/2v0o8j/a/SqP2i4KTyCZgI Yt6gKuJPmfBP
HcKOmOvFHmtBDLi5VD57bkZlUqCzEbcjqeDz1HpQBe8j/a/SjyP9r9KfCxaG NjvyVB+cYbp3
HrT6AIfI/wBr9KPI/wBr9KmooAh8j/a/SjyP9r9KmooAiEOGB3dPapaKKACi iigAooooAZL9
38/5Gq1WZfu/n/I1WpAQRyeTbzzZGI5yxz3+UD8+aZslvGYxMGyBukzgfRTV iyjSWO5SRFdT
McqwyDwKkWWUxArtztyFETY6ZxnNDVxp2JYYVS2WFlUgLtYY4PrR5YhBMMQL M3PODgtknPtk
nFEU6vEzt8mzO/dxtx9adHLHLnYwJUkEdxgkfzB/KmIoSWTG3I2MS07O6jaS y5bA+bjuDg+/
eo7i0nNsiLHIxRD5RHllkYk9ScY/hxt6YPoK1VYMMqQRkjg9x1o3AsVyNwGS M8gf5BoAyrqz
lkDhbbdKTKfOyvzAqwUZznuo/CpJLKQNJ9mRYiXIRl+Xahj9ug3849ea0qKA Ken25g8z5JEV
sYV9g555wgx6c9eParlFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAU1/umnU1/umgCP8Az/n/AD/9Y7j6j/P+f/1H+f8A P+f/AKx3H1H+
f8//AKkBA7siHahcnjAIH86h86f/AJ9m/wC+xU9FAyDzp/8An2b/AL7FHnT/ APPs3/fYqeig
CDzp/wDn2b/vsUedP/z7N/32KnooAg86f/n2b/vsUedP/wA+zf8AfYqeigCD zp/+fZv++xSP
JOyFfszDIx98VYooAZApSCNWGCFAP5U+iigBX6/gP5VBcdYf+uyfzqd+v4D+ VQXHWH/rsn86
ANKmx8RqOnAp1Nj4jUdOBTEOpo/1jH2H9adTDkSEqAeB149fb/P8wB9FVr/P 9n3WQB+6fofY
1WllkiizuVLhnAmdm2hRgkEEggLkYHHc980AaVFZ4mufKj+dWMw2Iy9FYE/N yBn5eew+XjqK
ktpme8ljaTfjPEZUoozgA8ZDex46/gAXKKKKACiiigAooooAKKKKACiiigAo oooAZL938/5G
q1WZfu/n/I1WpAGndLj/AK7H+QpscYKo2Y/ur1Iz0H+z/WktJUghuZJCQomO SAT2HpTTdabu
IMYyDyPIb/CqSb2E7FmEBzcDJwXxkHH8I7iiKCKyQ+TG2GfkKPVvT2z+Q9qS 3ljaVo4IgIwM
lwMDPpirCsGGVIIyRwe460hlCNHjSVYxKLgysy53bOWYj2xg84/ninQJi8Ej Cf5owoLZ+8C2
7djjvx29KvUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUU AFFFFABRRRQA
UUUUAFFFFABRRRQAUUUUAFNf7pp1Nf7poAj/AM/5/wA//WO4+o/z/n/9R/n/ AD/n/wCsdx9R
/n/P/wCpAQ0UUUDCiiigAooooAKKKKACiiigAooooAV+v4D+VQXHWH/rsn86 nfr+A/lUFx1h
/wCuyfzoA0qbHxGo6cCnU2PiNR04FMQ6mj/WMfYf1p1MORISoB4HXj19v8/z AH0VWv8AP9n3
WQB+6fofY1Fd3iNGn2e4jAJOZPMUKMdskHnnpjsaALe2Npd4wXQFeD0zgkfo KczBRliAMgcn
uelZNrcszmQTATSPGTAMYIKJk468Anv2+tIlxPMi+bJG2XjLIGyY28xeMBRt 78Ek8exoA2KK
z5/sv9oyfafL3eUmzP3s5f7vfPTpz0qOO4uxcRxyyRq42Axlhl8gbjtCknkn kEDj2NAGpRWa
lyxgjZrvazked939xwTjpxyAPmz+dOt7iZpJGZ2eOKPcFVATJ8zgH8QAeOvG MDqAaFFYwuHl
kRZLpNkTqxmR1bblXHJ2gDoO3f6VIbmRFlxKIypcxIAo81t7/L056L05596A NWis7z50XzPP
B3yyoFkACKF34OQM/wAI7+tWLCUywkl3fDY3MVIPA+6VABH/ANegCzRRRQAU UUUAMl+7+f8A
I1WqzL938/5Gq1ICKBFkt7hHUMpuACD35WnSafH5yrDbxxKBkygDP0HvS2SL JHcKwyDMe+Ow
pfLh8vzPIm243Z8zt/31T6WAkt41azMWMKS69AeMkd+v40kEEdirMXY73xlu erHA9f4v69zU
0AjWICL7nOOT+PWpKAM57x12xiaNZ/NkBVyBhQHKkjqBwvNFtPLNNEizuUw5 ZiFYNgp90gAY
5POPXoemjRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
f8//AKkBDRRRQMKKKKACiiigAooooAKKKKACiiigBX6/gP5VBcdYf+uyfzqd +v4D+VQXHWH/
AK7J/OgDSpsfEajpwKdTY+I1HTgUxDqaP9Yx9h/WnUw5EhKgHgdePX2/z/MA fRVa/wA/2fdZ
AH7p+h9jVe6uQ8sRtpkIYbS6bWIy8YPPPY0AaG4BguRuIyBnkj/JFLWW0kwv dgZnMYdS+0Ft
v7sk4AwTz/8AWPQoLy5aSVo3jfAcrEDuJAB2naBnnA5Jwc8dRQBqbgWK5G4D JGeQP8g0tUbJ
ke9nKXP2geWnzZU45fj5QKq2e+3tY5EhjjY22UCc+c2ARngcjHTn7xx0NAGx RWULqYQsTdQl
Aw+cSqT0OQG2hc8Dgj15GRUguZDIv711fcgWFwoZ1IXLEYzkZbpx8vsaANGi so30rJbJHOnn
FF80YBKtvQcjt1bjippJ5I3mXzyZY1PlRELmX5M5xjJ5z0x0oAv0VlC6mELE 3UJQMPnEqk9D
kBtoXPA4I9eRkVpQsWhjY78lQfnGG6dx60APooooAKKKKAGS/d/P+RqtVmX7 v5/yNVqQBp3S
4/67H+QqA3JZI1T7sQG8MMbuMYx6detT6d0uP+ux/kKjaNXWNmkysY4Pktgj 3557UwJbbbLB
MYR5aufl4Ix8o9MfofxpbSBrVX82bcGc43HpliR6DnI7dfwxJH+7VnZw/mNu yowOgHr7UNLG
wwy5GQeR3HSgCCe7kj+0BfLLQo0meeRjIGPUcZ/D+9xFcXc8Ucwfy227k+UF cnyy+evHpj8c
9qtEwMu1ogVyTgqMZOc/nk/nQxgfO6INk5OVHJxj+XFAFiiovPX0NHnr6GgC WiovPX0NHnr6
GgCWiovPX0NHnr6GgCWio1lVmwAakoAKKKKACiiigAooooAKKKKACiiigAoo ooAKKKKACiii
gAooooAKKKKACiiigApr/dNOpr9PxH86AI+fQ/l/n/P6NLqrorHBZsAY6/5x UdQv/wAflr/v
H+VICaiiigYUUUUAFFFFABRRRQAUUUUAFFFFACv1/AfyqC46w/8AXZP51O/X 8B/KoLjrD/12
T+dAGlTY+I1HTgU6mx8RqOnApiHU0f6xj7D+tOphyJCVAPA68evt/n+YA+iq 1/n+z7rIA/dP
0Psajmu43aPZdpHCQ26VWUjcMYXJyOhJ9eKALtIWAIBIBY4GT1NUIbpyd1w7 JIqBhbqAC/yA
nAPJ5yOD2+tQwXDy3cMbzRyhJAwZHD9Uk4yAPT0oA1qKy7oTGHUykkYTnIKE k/u175/pSpcO
JkTzAFMrgJHt3H94wyQR93A6jnr9QAadFZVvL5drbRvdmNAmHc7QUYBfk5GB 1PB54qWCW7mi
lkLYdNuItoHO1WIyfXke2T14wAaFFQ2rtLGZSflkO5B6L2/Pr+OO1TUAFFFF ABRRRQAUUUUA
Ml+7+f8AI1WqzL938/5Gq1IA07pcf9dj/IVWuCVSJ2kbylhUsqSYZf8Aax0Y ex9KnspEijuX
kdUUTHLMcAcCoi9s2zdfWbeX90sqkj9apOwEu0rDOkZIxIQuW6fKD1Oe5qK1 WdQ/nsGyxxj6
n+mO/t25sxJvhLpKs29925OnTHr7Uj25cYZcjIPXuDkVIEDTsrOvlElAWO05 yOcY9ScdPY+2
Y0unk2qiRtIcnAkOABjOeMg8jjFWTZgknYQSSchsHnrz/noPQU37Cu0DawIO dwchvzznsPyH
pQMZaMWs4GYkkxqST34qalS3MaKiLhVAAGe1O8p/7v60AMop/lP/AHf1o8p/ 7v60AMop/lP/
AHf1o8p/7v60AEX+sFWagjjZXBI4qemIKKKKACiiigAooooAKKKKACiiigAo oooAKKKKACii
igAooooAKKKKACiiigApr9PxH86dTX6fiP50AVahf/j8tf8AeP8AKpqhf/j8 tf8AeP8AKkMm
ooooAKKKKACiiigAooooAKKKKACiiigBX6/gP5VBcdYf+uyfzqd+v4D+VQXH WH/rsn86ANKm
x8RqOnAp1Nj4jUdOBTEOpo/1jH2H9adTDkSEqAeB149fb/P8wB9FVr/P9n3W QB+6fofY1VlW
a0TdGsNssjBSEbCoAGO7JXAJOB09PwANOis6Ge5feTPGBHCHBI+UnLgEnA4w ATgc9Rx1jW6y
0YkvXiQh8yMY8MRt+6cYI5Pv19KANWisuO6unuIw7Rxk7MxE4LAgFjt2knkn nIAxz0NIZfNj
t5HuyrBw0uNv7glG46ccnHzZoA1abIiyxtG4yrgqR6g1QWWcKVQj968kaEAD Ywduff5cn/gP
qaaLq5+0SjzYVwXGx2+6BnDEBcgcA5Jxz7igDToqtYSmWEku74bG5ipB4H3S oAI/+vVmgAoo
ooAKKKKACiiigBkv3fz/AJGq1WZfu/n/ACNVqQFdP+PeX/r7T/0JKmna4QGJ X3PJkhgQuOOg
BP61FGrvbT+Whdhcq20EZIBUnr9KVI5I5FZLW4wBghvLJPzbuu717/15p2uJ q4+3SW3nu41b
fkeag29Cxb1PsO4/mams3uXD/aUC4Y7cem4/Ttjt79+I7GJo5X/dSRoI0RfM ZSTgsT0J9RVt
03qBuZeQcqcdDnFAyJrqNC4cOuwEvx91R/F9D2/+scNF5uVCsEhZwSqgqSVG Pmzuxjkd6f8A
ZxvLiSQO2csCOnYY6cdv/rnMa2KJ80csiSEkmQBctnGeMY7Dt2+tAEcE9w0V q5MbGRFJXHzN
wNzZ6DGfT055pY9Ut5d2wknAKgEEtkgDoeOSOuOv1p8NkIGUxzygAKu07TkK MAdM/wD6zSiy
UR+X5shRQAgyMJggjHHOMDrnp7nIAPeBAd8Mg2rvkHy/u155PPPQ9M9Ka+oR JGzsrhQ5jBbC
hmBOcEnHbr/XinPZhwd80h3LskPy/vF54PHHU9MdacbVfLCq7qVdpFYYyCSc 9Rj+IigB8EyX
EKyxnKt/Tg1JTY02IF3M2OpY5Jp1ABRRRQAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABTX6fiP506mv0/EfzoAq1C//H5a/wC8f5VNUL/8 flr/ALx/lSGT
UUUUAFFFFABRRRQAUUUUAFFFFABRRRQAr9fwH8qguOsP/XZP51O/X8B/KoLj rD/12T+dAGlT
Y+I1HTgU6mx8RqOnApiHU0f6xj7D+tOphyJCVAPA68evt/n+YA+io5eYZA7e Wu05dWwVHrnt
WZ5vkowtTaqpZQ88QCKBhuCfmGQQOv8AeHTrQBr00opkWQj5lBUH2OM/yFZd xezRWyP5sauq
F8lwFl5OAMr83TnGOox1FTedKIt8k+xGndC+APLUFscnjqAMn2780AXwwJIB BKnBwehpazUZ
keaaOdnXz41x8pVwVQZ4Hv24rSoAKKKKACiiigAooooAKKKKACiiigBkv3fz /karVZl+7+f8
jVakBHbf8et5/vt/6CKHBjmj8pMOXKrztBGCefl6YHvT7BQyXKsMgykH8hTp bZA0SCPejv8A
OH+cY2tjrnHOKpAIL0vYz3CIAY03AE5z8gb+tTJdROwUFgzHAVkKnoT0I9jz 7VUto5Z7aeGT
cvmRAEtHt2uQQQOBkDj/ABqY2kjSec0yeeCNpCHbgBhyM5/iPf0/EaswB71B OiKybNxDscjA
AfP6p/OnwXPnXEiKGCoikbkKnJLev0FV/wCzN2fMmzuzu2rjr5mccnH+s/Sp 0gnEryPOm9gg
+WPAwpJI5J65IpAKb23G/LMAm7JKMB8uc4OOeh6elKbyAAHeSCM5CkgD1Jxw Pc8VW+wyzQyR
yyKql5SgC8jduAJOeeGzjip7i1MzPtkCrKnlyArkleenPB+Y+vagBwvICzDe V2kgsylVyOvJ
GD0P5GkN7bgAszKSdoVkYEnBI4Izzg49elQLZSSxtHO4Ee+Qqqr83zFhnOSO jHt6U+GxEbo/
7pSr7sRRBAflYev+1+lADkvkb7w2YkZCWyBxu5Bxg/d/Cn/a4dpOXBBxtMbB j9Fxk9D27H0q
KSx8xTG0n7rezABfm+YMDz/wLjjt3po0/EbBRbKxIPywbQMZ5GDnPPXNAF1W DKGGcEZ5GD+V
LTY08uNU3M20AbmOSfc06gAooooAKKKKACiiigAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACmv0/Efzp1Nfp+I/nQBVqF/+Py1/wB4/wAqmqF/+Py1/wB4/wAq QyaiiigAoooo
AKKKKACiiigAooooAKKKKAFfr+A/lUFx1h/67J/Op36/gP5VBcdYf+uyfzoA 0qbHxGo6cCnU
2PiNR04FMQ6mj/WMfYf1p1MIYOWUA5GOTj19qAH0VHLzDIHby12nLq2Co9c9 qyx5SsnlvBHG
kgZri3RVUZVxg5yPT/voUAbFFZN3fSxyy+XKo4cCNmBZcKTu24z1Hcng9OeJ J/NinmYTt5xt
/kAUfvGG84AxzjI4HtnNAGlRWZPfK10FjvESDKBnUqQCRIepyP4Vq7aO0luG Y7uWAb+8ASAf
xGD+NAE1FFFABRRRQAUUUUAFFFFABRRRQAyX7v5/yNVqsy/d/P8AkarUgG2T rFDdSOcKkjMT
6AAVF9rP9ozxyqyxRqWLBjwABzwfr2p9sQtvdsZGiCyFi6gEgAA9wazlJju2 V1kQRjc2ADsA
xzjG306ehx2pgarTSWom3gOqxtIvzc4HbpViOeGUAxyxuCdoKsDk4zj8qqzI 9wHiUPkwOm6R
cZJx14pWt53nFyVjEilcRhyQQAw+9jj7/p29+ACZrpRPHEuG3NtJDDjhv/iS P/1UQ3Uc80iR
OjqiqdysCMknj9P1qkdNmk3b2jXfuzgk4z5vsM/6wfkatIlz58krLEpYIoAc twCSew7HigCc
zRqu5pEC5IyWGMjOfywfyqKS8hWCSSOSOQpGZAquOQP/AK/FRT2kkn2gr5Ya ZGjxzwMYBz6n
jP4f3eW3VlJMswVkG92YZJ6GLZ/OgC/RRRQAUUUUAFFFFABRRRQAUUUUAFFF FABRRRQAUUUU
AFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFNfp+I/nTqa/T8R/OgCrUL/APH5 a/7x/lU1Qv8A
8flr/vH+VIZNRRRQAUUUUAFFFFABRRRQAUUUUAFFFFACv1/AfyqC46w/9dk/ nU79fwH8qguO
sP8A12T+dAGlTY+I1HTgVDcKWkXEaSNtbCucDqPY1DZCQJA0sSJI0fzY4z93 k8DB68UxF6iq
OofvfJtmhaVZMtIiEDKj3JH8RX8qgW5uGgkkMro8EAZkwuGcFw2eOmV7EUAa tFVLDjzlMhLC
VyYzj5AWYj35HPNW6ACiiigBrIrsjMMlDuX2OCP5E06iigAooooAKKKKACii igAooooAKKKK
AGS/d/P+RqtVmX7v5/yNVqQDLUkW14QcEO2CP90U+ZkXKxu4ZSBuMhwD/n2p lopa3u1UZJkY
D/vkVBO06SIHVow7EgKcnlhnp14z2/8ArNK4XL8VwDamaQqAgJcryBjqaljY ugZkZCf4Wxkf
kTVIQ3D2F0joPMlVtoz3K4x/k0y6sS0q+VGwjCARiPYAjZJJ5Hy9RyvPH0oA 0JHWKNpHOFQF
ifQCnVlXNnPNPIVQq0gdWcbAhUqQvP3j/DnPGfwp80MghnEFoyiaDy1Rdg2H 5uvOOd3bNAGl
RWbJZMbcjYxLTs7qNpLLlsD5uO4OD796sQo0dssLQs6bGyGZSevC44HQ/QYx QBapjyBHjUg5
kbaMeuCf6VS+xs7RLPEsgEm5mY7gV2sAOeeCQPfr1JptvazRy2zMmAAjScj7 +1wxPqclee9A
GlRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA FFFFABRRRQAU
1+n4j+dOpr9PxH86AKtQv/x+Wv8AvH+VTVC//H5a/wC8f5Uhk1FFFABRRRQA UUUUAFFFFABR
RRQAUUUUAK/X8B/KoLjrD/12T+dTv1/AfyqC46w/9dk/nQBoPGj43orY6ZGa bFGiqrKiqxHJ
Awf5VJUce4IoCjGB3x6e31piJKKzdREZubfzmt0Hlv8A69dy5yvTJHNJHdvH CsckhSUvEESQ
jeVITP16tz9aANIMCSAQSpwcHoaFYOoZSGUjIIPBFY9nORGN84t43AZpAFUb vLjwORgdTx7V
Zj/5Bllu/wBTsTzfTbs7+2cZ9uvGaANCkLAEAkAscDJ6ms4MRMiWUipbSOFB QArna5bb+S9O
M/jUdxcP5qMJd06SSbbfjjCvtOPvcjHfv9KANaisuKe4kaNFuY2V5Au9CH/h YkZ2gdh9O/Bx
WpQAUUUUAFFFFABRRRQAUUUUAFFFFADJfu/n/I1WqzL938/5Gq1IA07pcf8A XY/yFSBpzAJA
UJK7goQ+nTrVe2EzRTiBgreeevpgexqJLib90m4jacYVc5+XPQde1MdjQjnV 4mdvk2ff3cbf
z7U+NxIgZQwB/vKVP5Gs9lnezvAQTujYberbiv0qYRyR3Ehj811jiBRDIcM2 W7n8PzHoKSEX
KKyYvODMrNO1uCpYhJFbo2cZJbqE6f40kIlkDMrXBUMFXLP0MrBs++3HXke1 MDXpGYIpZiFU
DJJPAFZUguy2PMlQLuEeEZiSHYDOCB028twfzp00E7W77PNaSV5kIZiRtw+3 g8DovP8AjQBq
UVXR4xCEVZ9hRjuIfcMdufmzzx9Kr7JpGiWUzgmT58MVGza2OV464z7+2KAL zOqMiscFztX3
OCf5A06syBZzNamQSEYSR9wPDFJN307cdB+NadABRRRQAUUUUAFFFFABRRRQ AUUUUAFFFFAB
RRRQAUUUUAFFFFABRRRQAUUUUAFFFFABTX6fiP506mv0/EfzoAq1C/8Ax+Wv +8f5VNUL/wDH
5a/7x/lSGTUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAr9fwH8qguOsP8A12T+ dTv1/AfyqC46
w/8AXZP50AaVNj4jUdOBUNwpaRcRpI21sK5wOo9jUNkJAkDSxIkjR/NjjP3e TwMHrxTEXqKo
Xn2f7Xb/AGzyQnlv/rMYzlPX8age4uoyqiRYwATH5rYL/M2BjaS3AXgYPPqa ANVWDDKkEZI4
PcdaWsgTyRxyrbTl5d82YgFJTlyDjGeoHX1+lTS3oe4KxXKCDCbpFKkJnf36 dQo59fegDRoq
vYyGW2DGTzPncB+PmAYgHjjoKsUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUA Ml+7+f8AI1Wq
zL938/5Gq1IA07pcf9dj/IU0KrR7gtsZCm7Z5fOOuOtMt2mWKcwIGbzzwfTA 9xUCSBXTzGK/
Nz/Dj5Mf4VSWlxNmlbNG0Z8uPy8HDLtxg/5xUpYAgEgFjgZPU1niaZLS6kXI 2xlg7AZ3Bf8A
PaobieQkfZ5zcbCWjkAVjv8ALk44GD0HHvSGaskaSoUkRXU9VYZBpVUIoVQF UDAAHAFZ8t6H
uCsVyggwm6RSpCZ39+nUKOfX3qGGeWadEW4OHbb5qquWUGXHOMfwj/JoA16K qw3AaErLLtf9
4N/A4Vtu709Kh86aRokMzRO8m0hUAIXaxBwwPXGfbp1BoAvlgCASAWOBk9TS 1lwzySz2nmNu
3bJenQskmQPbj6+9alABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUU UAFFFFABRRRQ
AUUUUAFFFFABRRRQAU1+n4j+dOpr9PxH86AKtQv/AMflr/vH+VTVC/8Ax+Wv +8f5Uhk1FFFA
BRRRQAUUUUAFFFFABRRRQAUUUUAK/X8B/KoLjrD/ANdk/nU79fwH8qguOsP/ AF2T+dAGg8aP
jeitjpkZpsUaKqsqKrEckDB/lUdwpaRcRpI21sK5wOo9jUNkJAkDSxIkjR/N jjP3eTwMHrxT
EXqKpziU30HlsiP5T53KWHVPcVSE9zENiyxphnI3HaJG8xsgDBJ6DgEHn3FA GwrBhlSCMkcH
uOtJIgkQqxYA/wB1ip/MVkrcNGZ1W42Mu9o4vl/eN5knHIyegHFbFADY0WNA iDAFOoooAKKK
KACiiigAooooAKKKKACiiigAooooAZL938/5Gq1WZfu/n/I1WpAGndLj/rsf 5CgLB/r/ALK2
Nuc8Yxj0zRp3S4/67H+QrOluPlUvuDoABx90Y/r+tUhpXNgJFLAyBR5cgIYD jPY1LVO0LrbS
ssIEmciIfLztHHtn+tVpbmZiiCQCXcAfkZdp3x8Ebufvdc/Q+qEaciCRCrFg D/dYqfzFEaLG
gRBgCqZurgXJTy1aNHWN2wACSBzktx97pg/Xnia4ufJQSKY2XJUgtjn6+2Dn 0GT2wQCxRVEz
3PnmMNF/rBED5Z67A5P3vqMfrTtOl88TS42+Y6tjOcZjQ0AXKKKKACiiigAo oooAKKKKACii
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAqObeIj5YB fjAY4HWpKa/T
8R/OgDP23fpb/wDfZpuJheW3m+WPmONjZ7Go7uS+SdBbJE8bnGWB+X689Kmb P2q03EE7jkgY
7UgJqKKKBhRRRQAUUUUAFFFFABRRRQAUUUUAK/X8B/KoLjrD/wBdk/nU79fw H8qguOsP/XZP
50AaDxo+N6K2OmRmmxRoqqyoqsRyQMH+VR3ClpFxGkjbWwrnA6j2NQ2QkCQN LEiSNH82OM/d
5PAwevFMReoqleeV9osfO8sP5pxux/dPT8dv44qBbi4S2hY3KkzQeYWl2qFO V6EDj7x655xQ
BpBFEjSAfMwCk+wzj+ZoeRIxl3VR6scds/yBrOgmxOZ2kmOYRtRgu6XBfpjr 2Ix6iqlzcPLD
JG80coQFgyOH6xycZAHp6UAbu4FiuRuAyRnkD/INLWc7AXf2hyAiT7d5OAFE Z79PvMR9Tio/
tC/a3P2sQwSszCQFcOQsY4JBH97p6UAajMFGWIAyBye56UtZL3DyrH9ol8qT zIcQcDdkoScH
nqT0Pb60yS6kmYp5o2ErIRuUtCBIvUbRtwCc5z09uQDZorN+0TfbFRZ4ymVC gsMyKQMtgLz1
PIIHHsa0qACiiigAooooAKKKKACiiigBkv3fz/karVZl+7+f8jVakAtoDCJd 2PnkLDBHTA/w
pptoyyMXctGMKTs4/SloouMlVUCurkyBz82/bzxj+lASBUCCGMKAV2gLjB6j 8aiooEShIA6O
IYwyDarYXKj0HpTgY1IIRQRnkY7nJ/M1BRQBMohTG2NFwcjAHBxj+XFKhjjG ERVHouB2x/IC
oKKALPmD/JFHmD/JFVqKALPmD/JFHmD/ACRVaigCz5g/yRR5g/yRVaigCz5g /wAkUeYP8kVW
ooAs+YP8kUeYP8kVWooAs+YP8kUeYP8AJFVqKALPmD/JFHmD/JFVqKALPmD/ ACRR5g/yRVai
gCz5g/yRR5g/yRVaigCz5g/yRR5g/wAkVWooAs+YP8kUeYP8kVWooAs+YP8A JFHmD/JFVqKA
LPmD/JFHmD/JFVqKALPmD/JFHmD/ACRVaigCz5g/yRTJZGMZ8sKX7bmAFQ0U AQ7bv0t/++zQ
kU7XMLy+UFQk/K3tU1FAwooooAKKKKACiiigAooooAKKKKACiiigBX6/gP5V BcdYf+uyfzqd
+v4D+VQXHWH/AK7J/OgDQeNHxvRWx0yM02KNFVWVFViOSBg/yqO4UtIuI0kb a2Fc4HUexqGy
EgSBpYkSRo/mxxn7vJ4GD14piL1FUtT8prGSObyzIyN5aNgktjjb6nmonuZW vvJjmVN5ZArE
Fkwp+bbjPUZ5J4PvwAaVFZ73UrQNKT5IYhBlgAhGdxLEHHOV6dQPWrFhM09o ruVY5Zcqcg4Y
jOe/SgCZEWNSqDAJLfiTk/qaCimRZCPmUFQfY4z/ACFOooAKKKKACiiigAoo ooAKKKKACiii
gAooooAZL938/wCRqtVmX7v5/wAjVakAUUUUDCiiigAooooAKKKKACiiigAo oooAKKKKACii
igAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKK ACiiigAooooA
KKKKACiiigAooooAKKKKACiiigBX6/gP5VBcdYf+uyfzqd+v4D+VQXHWH/rs n86ANB40fG9F
bHTIzTYo0VVZUVWI5IGD/Ko7hS0i4jSRtrYVzgdR7GobISBIGliRJGj+bHGf u8ngYPXimIvU
gYEkAglTg4PQ1RvIzLd24MEMx8tyVkPA5T2P8qjt5DaXLpPMPLB2tI5wGYJH jk9/vUAadFZM
d5K0cLSXOyRjEBHhR5gbbk4Iz3bp6VPcEGey+1JCsnnHaN27jafUDvj9KAL9 FUbKWU/ZvMla
TzoPMO4AYI29MAf3jUMHk5PkeX9r+0Nu243bfMOd3tt9fbvigDUorLtri7lV iJI2fZvMYYEq
wIOz7o255HJJ/I0s11OVjkWVIopSzKzMEAHAUZKnry2MZ/KgDSDAkgEEqcHB 6GlrKjncSv50
4t1dtzyABRu2R8fMOOp4PPH1pYbuV3+ebbNvjH2fAHBVSxxjdxlj17UAalFZ cFxcbInaZnyk
LkFV53tgjgdscfrmmR3V06fNMgZigYKQzRkuoIxt+XqeDk8exoA16KzQzf2g iyTsBEWjDnaN
5IjYKeMc5PTB4rSoAKKKKACiiigBkv3fz/karVZl+7+f8jVakBQ+0f6bvzJs 3+Vja2zGOvpn
dxTxcXBVgUAkBBZdhPlg556/N07f/Wq1sXGNoxnOMd85z+dM+zQbNnkR7M52 7BjPrQMhW5dh
5ilGjDIh+Ugtu28jnj73T2pPtDiOCeVlEbndgAjaNjHnnn8qtGKMyCQopcDA bHI/GkWGJWLL
GgYnJIUZJ9f1P50AU/OuXmjibEbhwcleCCr9QGP931pWvJlMjmIeUpcDkDO3 PfOT06Y/lVkW
0CqyiCMK33gEGD9aeIoxIZAihyMFscn8aAIIBILybzGVj5acquO7e5qGO8nZ FZowokAKZxxk
gepJ+97frVyOGKLPlRomeu1QM0CGIb8RoN/38KPm+vrQBnu8yTyJvG8yD5gC B1iHTPvVkzyq
zZKFUdY2G05YnHIOePvdOelTLbwopVYo1BBBAUd+v8hSiGIMrCNAyjCnaMge goAq/aZ/ssUz
BFVl3swUsEGB2zn/AA/WraMSzglSA2BjqOB19/8A61IYYjszGh2fcyo+X6el OCgEkAAk5PvQ
AtFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQA UUUUAFFFFABR
RRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAr9fwH8qguOsP/XZP51O/X8B/ KoLjrD/12T+d
AGg8aPjeitjpkZpsUaKqsqKrEckDB/lUlRx7gigKMYHfHp7fWmIkorPvkMlz B/o0U7CKQ+W5
46p0yDzUUlxPGIkiuEwsS4aQ4MrcgjGCSeBkDB5oA0XgR5FdtxK9BuO38ulP 3AsVyNwGSM8g
f5BrMnvZkuWETKx+dRCzAtkKSDtAzyR6ng+/DVkL3+2C9aQPsVpF2EjiQ44G Ow7UAa1FZJvL
jykPmKPMSORnYhRHuDHGcEAZUAZB61LcsZNJDTPGcumWIypG8cnpkY+gPbig DRorPSRIoF+y
PA7EncsEfynpk4BzwMd+enUimzXbJcRCOdSuUXDuoMgJHzAAc9eoIGQeOOQD SpgWOIs3C72B
JJ6ngD+QFZ0FxcbInaZnykLkFV53tgjgdscfrmo0uGmgg/0jz9/ltJ939229 OOBxnJ6+lAGx
RWfp1xPNJ+9kjbKZZA2TG3HGAo29+CSePY1oUAFFFFABRRRQAUUUUAMl+7+f 8jVarMv3fz/k
arUgIbW1hnM7SqSRKQPmI4wPQ077NbeX5n2aXbjOfM7f99VJp3S4/wCux/kK qXflp5EjlXYR
LiJgQT7of73/ANaqSuBbSxtHUMqMQf8Abb/Gnf2da/3G/wC+2/xohTCXKRER neQpC/dO0c4q
FZHt98SqwuG27R5jSg5z/eIxwrenbr0pATf2da/3G/77b/Gj+zrX+43/AH23 +NV1vrh88Rpt
2qwZcncXZM8HtjOOfTPel+2zkTOPLCwIWYbTlyGcHBzxnZ79e9AE/wDZ1r/c b/vtv8aP7Otf
7jf99t/jVRLqeISJDEGWNpHcnGMGR+Mlhj7vXn/G5du0bI0bEvgjZgsCOMtg en/1upFACf2d
a/3G/wC+2/xo/s61/uN/323+NVY1mMkqQzSSRuVi3lySo2KdwPbILc+u2ptJ keS2Jd2Y/Jyx
z/yzQ/zJoAk/s61/uN/323+NH9nWv9xv++2/xps6vHcCWTc0ZdQNsrLtyQAN o4PPOT6+1RM8
862coeNTI4ZBsJ2gxscHnn9KAJ/7Otf7jf8Afbf40f2da/3G/wC+2/xqu1/c ZYRxK3lAmQ8A
HDMvUsNv3Se/X25Vr2dQ7/uyqiVwNpztRsYznqeOe3oaAJ/7Otf7jf8Afbf4 0f2da/3G/wC+
2/xpoupDeKoXMDuUDbcYIBzznJ5UjoPr6tjR5L+djuKJIAD57DHyKcbRweT+ tAEn9nWv9xv+
+2/xo/s61/uN/wB9t/jVRp5WltZ2KYlQFVUEFQzx8E556+30qW1luWt7WPzI y8kXmb2QngBe
Dzyfm65/CgCb+zrX+43/AH23+NH9nWv9xv8Avtv8aSxuZLrc5VFjAXAGSclV b9M/j7Y5Ykj/
AH02iWedo9zDIULuxx/wH16sT7UASf2da/3G/wC+2/xo/s61/uN/323+NU4r q4iR0jjV/LLv
I2AAcyP6sNv3Tzz+nMsTSRRyyLsaWWZlTEeWOGbgncM4AOORjFAE/wDZ1r/c b/vtv8aP7Otf
7jf99t/jUKX0rW9y5RVaGItg/wB4Fwc8/wCz/wDXNNsg73M8ZZTD825GXOcy SdOePyNAFj+z
rX+43/fbf40f2da/3G/77b/Gn2TFrcBiWKMyZJySFYgE+/FT0AVf7Otf7jf9 9t/jR/Z1r/cb
/vtv8atUUAVf7Otf7jf99t/jR/Z1r/cb/vtv8atUUAVf7Otf7jf99t/jR/Z1 r/cb/vtv8atU
UAVf7Otf7jf99t/jR/Z1r/cb/vtv8atUUAVf7Otf7jf99t/jR/Z1r/cb/vtv 8atUUAVf7Otf
7jf99t/jR/Z1r/cb/vtv8atUUAVf7Otf7jf99t/jSrZW8TK6IQwIxlif5mrN Nfp+I/nQBXUk
BiOOP60m9v7x/OhejfT+tJSGLvb+8fzpGm2Y3ybdxwMtjJ9KKp3kc08uyNFw sZwzMRhj0I4P
Ix+tAFx5dgyzkDIH4k4FBlw4QudxBIHsMf4is9y8pVpEmV2eNkUbtoX5Sc44 4O7rz+lLCWSV
ZGSdpFhbzMhj83y8LnjselAGhvb+8fzo3t/eP51G8m3f8jnYu7gdevA9+P1F PoAXe394/nTZ
HcROQzZwe9LTZf8AVP8A7poAbbf8e0X+4P5VJUdt/wAe0X+4P5VJQAr9fwH8 qguOsP8A12T+
dTv1/AfyqC46w/8AXZP50AaVNj4jUdOBUNwpaRcRpI21sK5wOo9jUNkJAkDS xIkjR/NjjP3e
TwMHrxTEXqKp6hFHLBGZY0ZhJGORnGXXNRNNMl8IUeOONWVUizgsuBkhduT1 PIIAx7GgDRor
I+2zNKUSYASEHG5WePLqMEbeDhjwc9PztWs0pnVXkLhhJ1A42MFHT1zk/pig C7RRRQAUUUUA
FNjRYo1jQYVAFA9AKdRQAUUUUAFFFFABRRRQAUUUUAMl+7+f8jVarMv3fz/k arUgDTulx/12
P8hVYXUaplXuwoHGNvT/ACP0PocPhuUtIZ5JASDORxj0HrWWHyEOcLhVwTx1 /D0Hft2x8txj
cTZry3FvaWhkkLzRytg5AJJxjBHHpVQarpoiMQtGEbHJQRrgn6ZpjRo1tHGy jY14oIHH8PP+
ePoOgznSOaVYovKDEfKY9+GPYHd0/wDr/lSihNs1V1fT0Xals6jjgRqOhyO/ rzTP7T00z+cb
Zy+BjKL8pBJyOeuTWeLaJ4o1RyZHlKK23hvu+/A5Pb8qVrOJdzG4yiruO0Kz dQOgbHf17Gny
xFdmk2r6exUtbOShLKTGvBJySOfWn/27Zlg3lS7gMA7RkD8/YVkGzAR23s2B uARQTjAOWGeB
yOee/wCLprNUldN+H+dlUL8u1Sc85yPun17c0csQuzUTW7KMYSGRR6Kijtj1 9AKYuq6akgkW
0ZXAwGEa5Axjrn0rLubZIvM2SM/lv5bbl2889OT6Gpnto2CRqsSM6x7GD5Ys ducjJwOSeg6C
jliF2X/7X0/zvO+zP5v9/wAtd3p1zQur6ejl1tnVidxYRqCTzz19z+dZ0Fmk 2DHISjHaCyYI
O5QeAf8AaH6/Wkjt4DFJKXcx7Tg7MMGDL2z6N60csQuzSbV9PYqWtnJQllJj Xgk5JHPrSnWb
Agg27kEEH5F6Hr371j23k/N5uzdxjzN23Hf7vOen61PFbol3CJhh3lH7oLlc b8EEk+x9aOVB
dmh/a+n+d532Z/N/v+Wu7065pG1XTWl81rRjJkHeY1zkdOc1mx2aSjekp8rB yWAU8Y9Tj+Id
/X8V+xIBzPnlsbVDDCqGPOeuD09R170csQuzRGq6aHLi0YOxyWEa5Jzn19ea G1XTXUq1ozKW
3kGNcFvXr1rOjsPMkKeZjO3yycANkAjqfcZxnr+bbVIjBK8giyGUAybschv7 v0o5YhdmuNds
wSRFKCxycKOT+dRnVrBjJvhldZSCyMqkEjv19h+VZ0EUf334Z4pHRAuVAAYd SfUe/an3FpEs
qxqxVsOWwvGFZuRk9cL0/WjliF2Xv7V00BALRsRnKfu1+U+3PFT2+o2d5ILU QMRIScOg2k9e
eaxGtUWAzeadmBtyvJzuHrxyv5flUui/8hSH/gX/AKCaHFWC7Oja0tmRUa3i KpnapQYGeuKc
0EZwQqqwztYKMqT1IqSisixsaLFGsaDCoAoHoBTqKKACiiigAooooAKKKKAC iiigAooooAKK
KKACmv0/Efzp1Nfp+I/nQBUeQRoxIY54AVcmoftQ/wCeU3/fs1YUA5ycYowv qfypDK/2of8A
PKb/AL9mj7UP+eU3/fs1YwvqfyowvqfyoAr/AGof88pv+/Zo+1D/AJ5Tf9+z VjC+p/KjC+p/
KgCv9qH/ADym/wC/Zo+1D/nlN/37NWML6n8qML6n8qAK/wBqH/PKb/v2aa9w GRlEU2SMf6s1
awvqfyoYoqliWwBnpQBFbgi3iBBBCDIP0qSmxP5kSPjG5QcU6gBX6/gP5VBc dYf+uyfzqd+v
4D+VQXHWH/rsn86ANB40fG9FbHTIzSLFGhyiKp9QMU+imIKKKKACiiigAooo oAKKKKACiiig
AooooAKKKKACiiigAooooAZL938/5Gq1WZfu/n/I1WpAGndLj/rsf5Cof7IQ SqyzOFXHGBnj
3GP8/QYm07pcf9dj/IVcqk2gsZl7YypaotpueRZhJ8xUYwMew9OKzmsNSb/l gi8EfKEXg9el
dJRTUmhWOb+waoc/u+SQ2dy5B9Qex4GT3oew1NwVMKhSMELsUdQeg+g/Kuko p87Cxzf2DUyp
XyV5AGfkzjGMZ69BStZaowbdECWJJOUzz1weoHJ4Hqa6OijnYWOZfTdSffui z5jb2+ZeTz7+
5pDpmpFw/lHcoABDqMYGB39q6eijnYuU50WeqhgyxKuOgXYB1B6DjqB+VMTT 9TjUKsI2gk4J
Qg5xnIPXoPyrpaKOdjsczFpuoxZ226HP97Y386etlqi4PlAkNuDMUJBznqee tdHRRzsOU5pN
P1ONQqwjaCTglCDnGcg9eg/KlNhqh6x/3v4l4yMH9Biukoo52HKc6lnqqEER KSMY3bDjAAGM
9Og/KmRafqUSsqwKQxBIbY3T6/U10tFHOwsc4LHVApUQrggj+DgHqB6Dk8D1 oNlqjNuMQJ3F
skp3zkfTk8dOa6OijnYWOafT9TkUq0I2kg4BQAYzjAHTqfzqbTNNu4L+KWWL ai5ydwPY+9b9
FHOwsFFFFQMKKKKACiiigAooooAKKKKACiiigAooooAKKKKACmv0/Efzp1Nf p+I/nQBWXo30
/rSUq9G+n9aSkMjuJDFbyyLglELDPsKgS7CpI8kkciIB+8j4BJOMdTz0796s yxiWJ42yA6lT
j3pjwK5Y5K7sE49RjB+ox/jmgCEahEygqrEYYsQQdoGMk4PPUdM1J9qBO0RS GTJzHxkYx747
jv3oa1V1IeSRiyMhJI6Nj2x2FK1sDI0iu6OxzuXHoBjkf7IoAFuo2AK5OSoU Y5YHkED06/kf
Sm297DcOUjPOMjkHI9eDx264p628aNGyjHlrtUe3b8ufzPrRDAIsAO5UDCqT wo9Pf8c0AS02
X/VP/umnU2X/AFT/AO6aAG23/HtF/uD+VSVHbf8AHtF/uD+VSUAK/X8B/KoL jrD/ANdk/nU7
9fwH8qguOsP/AF2T+dAGlRRRTEFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFF FFABRRRQAUUU
UAMl+7+f8jVarMv3fz/karUgDTulx/12P8hVyqendLj/AK7H+Qq5TAKKKKAC iiigAooooAKK
KKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooo oAKKKKACiiig
AooooAKa/T8R/OnU1+n4j+dAFN1LqVDsmepXrUX2Y/8APxN+Y/wqypIDEccf 1pN7f3j+dIZX
+zH/AJ+JvzH+FH2Y/wDPxN+Y/wAKsb2/vH86YtyjuUSZWdeqhskUARfZj/z8 TfmP8KPsx/5+
JvzH+FTvL5almcgClWRmUEM2CM85FAFf7Mf+fib8x/hR9mP/AD8TfmP8KneX YMs5AyB+JOBS
rIWUMrkgjIIPWgCv9mP/AD8TfmP8KDbEjBuJsfUf4VY3t/eP502R3ETkM2cH vQAiIEjVBnCg
AZp1R23/AB7Rf7g/lUlACv1/AfyqC46w/wDXZP51O/X8B/KoLjrD/wBdk/nQ BpUUUUxBRRRQ
AUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFADJfu/n/I1WqzL938/ 5Gq1IA07pcf9
dj/IVcqnp3S4/wCux/kKuUwCiiigAooooAKKKKACiiigAooooAKKKKACiiig AooooAKKKKAC
iiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACmv0/Efzp1Nfp +I/nQBWXo30/
rSUjyCNGJDHPACrk1D9qH/PKb/v2aQyeqSZZfKCOHWcvkqQAN5PX3HHHr9am +1D/AJ5Tf9+z
R9qH/PKb/v2aAKaxzumJGkYkp5g2sMHcucEn6/d4/SpZvNW4QJ5gCsqgYdty 5GSTnHc9Rnj6
VP8Aah/zym/79mj7UP8AnlN/37NAFUmV1t4yspZFXzMqcbg6d+h6HmrNinl2 qJhwygBg2euB
nGe304pftQ/55Tf9+zR9qH/PKb/v2aAJ6bL/AKp/901F9qH/ADym/wC/Zpr3 AZGURTZIx/qz
QBLbf8e0X+4P5VJUduCLeIEEEIMg/SpKAFfr+A/lUFx1h/67J/Op36/gP5VB cdYf+uyfzoA0
qKKKYgooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigBkv3fz/ AJGq1WZfu/n/
ACNVqQBp3S4/67H+Qq5VPTulx/12P8hVymAUUUUAFFFFABRRRQAUUUUAFFFF ABRRRQAUUUUA
FFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAU 1+n4j+dOpr9P
xH86AKtFFFIYUUUUAFFFFABRRRQAUUUUAFFFFACv1/AfyqC46w/9dk/nU79f wH8qguOsP/XZ
P50AaVFFFMQUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAUUUUAFFFFABRRRQAy X7v5/wAjVarM
v3fz/karUgDTulx/12P8hVyqendLj/rsf5CrlMAooooAKKKKACiiigAooooA KKKKACiiigAo
oooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACiiigAooooAKKKKACii igApr9PxH86d
TX6fiP50AVaKKKQwooooAKKKKACiiigAooooAKKKKAFfr+A/lUbx+YY/mA2u G59qkfr+A/lS
UAT+cPb8z/hR5w9vzP8AhUFFAifzh7fmf8KPOHt+Z/wqCigCfzh7fmf8KPOH t+Z/wqCigCfz
h7fmf8KPOHt+Z/wqCigCfzh7fmf8KPOHt+Z/wqCigCfzh7fmf8KPOHt+Z/wq CigCfzh7fmf8
KPOHt+Z/wqCigCfzh7fmf8KPOHt+Z/wqCigCfzh7fmf8KPOHt+Z/wqCigCfz h7fmf8KPOHt+
Z/wqCigCZpAw6j9fSoaKKBi2w8kSZYHe5bvx0/wqbzh7fmf8KgooET+cPb8z /hR5w9vzP+FQ
UUAT+cPb8z/hR5w9vzP+FQUUAT+cPb8z/hR5w9vzP+FQUUAT+cPb8z/hR5w9 vzP+FQUUAT+c
Pb8z/hR5w9vzP+FQUUAT+cPb8z/hR5w9vzP+FQUUAT+cPb8z/hR5w9vzP+FQ UUAT+cPb8z/h
R5w9vzP+FQUUAT+cPb8z/hR5w9vzP+FQUUAT+cPb8z/hR5w9vzP+FQUUAT+c Pb8z/hR5w9vz
P+FQUUAT+cPb8z/hR5w9vzP+FQUUAT+cPb8z/hR5w9vzP+FQUUAT+cPb8z/h R5w9vzP+FQUU
AT+cPb8z/hR5w9vzP+FQUUAT+cPb8z/hR5w9vzP+FQUUAT+cPb8z/hR5w9vz P+FQUUAT+cPb
8z/hR5w9vzP+FQUUAT+cPb8z/hQZQe46+/8AhUFFABRRRQMKKKKACiiigAoo ooAKKKKACiii
gD//2Q==
--------------B59294648617A8D25336FD09--
--------------29CCDBCBB97AF60535775499--
Re: Running XSD in Eclipse 2.1 M5 [message #19043 is a reply to message #19020] Thu, 01 May 2003 13:15 Go to previous messageGo to next message
Thanks for the information Ed. I've opened up the file successfully using
the Sample XML Schema Editor, but why wasn't the Extension Point Schema
Editor working?
bort
"Ed Merks" <merks@ca.ibm.com> wrote in message
news:3EB150DD.771944CB@ca.ibm.com...
Bort,
provided by XSD:
got
> used
> > Thank you.
Re: Running XSD in Eclipse 2.1 M5 [message #19060 is a reply to message #19043] Thu, 01 May 2003 13:32 Go to previous messageGo to next message
Bort,
I don't know why the Extension Point Schema Editor isn't working. This is part
of the Plugin Development Environment, i.e,. PDE. You'd have to ask them...
> Editor working?
> bort
> Bort,
> provided by XSD:
> got
> > used
> > > Thank you.
Re: Running XSD in Eclipse 2.1 M5 [message #19064 is a reply to message #19060] Thu, 01 May 2003 13:33 Go to previous message
Thanks....
bort
news:3EB15A2C.528420E8@ca.ibm.com...
> Bort,
part
them...
using
> > Editor working?
> > bort
> > Bort,
the
> > provided by XSD:
I
> > got
be
> > > used
> > > > Thank you.
Re: Running XSD in Eclipse 2.1 M5 [message #565153 is a reply to message #11301] Sat, 08 February 2003 18:04 Go to previous message
used
> Thank you.
Re: Running XSD in Eclipse 2.1 M5 [message #568359 is a reply to message #11338] Thu, 01 May 2003 10:58 Go to previous message
got
> used
> > Thank you.
Re: Running XSD in Eclipse 2.1 M5 [message #568440 is a reply to message #18993] Thu, 01 May 2003 12:52 Go to previous message
Bort,
[Image]
by XSD:
[Image]
> got
> > used
> > > Thank you.
<html>
Bort,
provided by XSD:
<br>>
<br>>
<br>> >
tap, I
<br>got
not be
<br>> used
<br>> >
<br>> >
<br>> > Thank you.
<br>> >
<br>> >
<br>>
<br>></blockquote>
</html>
gD//2Q==
Re: Running XSD in Eclipse 2.1 M5 [message #568508 is a reply to message #19020] Thu, 01 May 2003 13:15 Go to previous message
Editor working?
bort
Bort,
provided by XSD:
got
> used
> > Thank you.
Re: Running XSD in Eclipse 2.1 M5 [message #568568 is a reply to message #19043] Thu, 01 May 2003 13:32 Go to previous message
Bort,
> Editor working?
> bort
> Bort,
> provided by XSD:
> got
> > used
> > > Thank you.
Re: Running XSD in Eclipse 2.1 M5 [message #568632 is a reply to message #19060] Thu, 01 May 2003 13:33 Go to previous message
Thanks....
bort
> Bort,
part
them...
using
> > Editor working?
> > bort
> > Bort,
the
> > provided by XSD:
I
> > got
be
> > > used
> > > > Thank you.
Previous Topic:XSD and XPath
Next Topic:Generating JAVA classes from XSDs
Current Time: Wed Jul 30 21:33:12 EDT 2025
Powered by FUDForum. Page generated in 0.06418 seconds
