Home » Newcomers » Newcomers » Can't use hovers...
Can't use hovers... [message #123387] Sun, 11 December 2005 08:22 Go to next message
Originally posted by: tomz814.yahoo.it
Since a week ago I used Eclipse 3.1.1 whit java 1.5 normally.
Now,eclipse shows me the code assistant,but if i select an item (for
example,BufferedReader),the help about the command i selected doesn't
appears (is this hover,isn't it?).Why?what i need to do?
I'm a student,and it was a very helpfull things to learn java....
Re: Can't use hovers... [message #123400 is a reply to message #123387] Sun, 11 December 2005 10:19 Go to previous messageGo to next message
Originally posted by: hendrik_maryns.despammed.com
toto uitte de volgende tekst op 11/12/2005 14:22:
Are you looking for the Javadoc view? Look under Window -> Open View...
Otherwise, try hitting F1, otherwise you’ll have to look into the
hovering settings (type hover in the filter field in the preferences).
H.
Hendrik Maryns
www.lieverleven.be
http://aouw.org
Re: Can't use hovers... [message #123578 is a reply to message #123400] Mon, 12 December 2005 08:59 Go to previous message
>Are you looking for the Javadoc view? Look under >Window -> Open View...
Previous Topic:How to place more than one EJB in one same dir.(Tree View)
Next Topic:Multi monitor
Current Time: Tue Dec 02 13:21:07 EST 2025
Powered by FUDForum. Page generated in 0.08435 seconds
