cannot open Eclipse(Suse 10.0) [message #123356] |
Sun, 11 December 2005 05:22  |
Originally posted by: devaslinux.gmx.de
When i try to open eclipse, i get this message(in the log-file):
!SESSION 2005-12-10 18:04:59.383
eclipse.buildId=I20050627-1435
java.version=1.5.0_03
BootLoader constants: OS=linux, ARCH=x86, WS=gtk, NL=de_DE
Command-line arguments: -os linux -ws gtk -arch x86 -data /home/devastator/.eclipse
!ENTRY org.eclipse.osgi 2005-12-10 18:06:23.410
!MESSAGE Application error
!STACK 1
java.lang.UnsatisfiedLinkError: /usr/share/eclipse/configuration/org.eclipse.osgi/bundles/79 /1/.cp/libswt-pi-gtk-3138.so: /usr/share/eclipse/configuration/org.eclipse.osgi/bundles/79 /1/.cp/libswt-pi-gtk-3138.so: cannot open shared object file: No such file or directory
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1751)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1660)
at java.lang.Runtime.loadLibrary0(Runtime.java:822)
at java.lang.System.loadLibrary(System.java:992)
at org.eclipse.swt.internal.Library.loadLibrary(Library.java:12 3)
at org.eclipse.swt.internal.gtk.OS.<clinit>(OS.java:19)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 63)
at org.eclipse.swt.internal.Converter.wcsToMbcs(Converter.java: 54)
at org.eclipse.swt.widgets.Display.<clinit>(Display.java:122)
at org.eclipse.ui.internal.Workbench.createDisplay(Workbench.ja va:381)
at org.eclipse.ui.PlatformUI.createDisplay(PlatformUI.java:155)
at org.eclipse.ui.internal.ide.IDEApplication.createDisplay(IDE Application.java:128)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:79)
at org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
the file allready exists und the phath is right.
I hope someone can help me.
Re: cannot open Eclipse(Suse 10.0) [message #123426 is a reply to message #123356] |
Sun, 11 December 2005 11:22  |
Originally posted by: myersj.gmail.com
Devas,
Are you using 32 bit or 64 bit linux? And which version of Eclipse did
you install?
- Jeff
> !STACK 1
FUDForum. Page generated in 0.08742 seconds
