Problem with importing EMFT JET Transformation Project [message #11276] |
Mon, 10 December 2007 23:51  |
Originally posted by: zl_zela.hotmail.com
hi,
First thanks a lot for the great SVN client.I like it very very much:)
Now I have a problem when importing a EMFT JET Transformation Project.
At the initialization, there are three .java files (eg. "_jet_dump.java,
_jet_main.java") which are generated by jet engine according to the .jet
file in "templates" directory(eg. "dump.jet, main.jet"). When I
"Team->Share Project->...", the three .java files are not in the commit
list. And when I manually "Team->Add to version control", I saw the file
is initially "Ignored" in Content column.
Although only .jet files is enough, but I don't know how they are ignored
and how to configure this ignore list. And I still want to make the
generated .java files default to be imported. Can anyone help me to solve
this problem? Thanks very much.
Env:
Eclipse 3.2.2
Subversion 1.4.5 r25188 installed on the same computer
Subversive 1.1.9.02
JET 0.7.3.v20070504
Re: Problem with importing EMFT JET Transformation Project [message #11350 is a reply to message #11314] |
Thu, 13 December 2007 23:50  |
hi Alexander,
Thanks very much :) This exactly solved my problem.
Here I has a suggestion.
Maybe new eclipse version control system client users like me will be
confused by the default behavior. As for me, because I don't know why some
files are initially ignored, I'am afraid that some important files will be
also initially ignored accidentally when I import a large project.This
misunderstanding discouraged me a lot.
So I think in Commit Dialog a message that tell users the ignoring
mechanism and a additional list that shows the ignored files would help a
lot :)
Again thank you very much!
Best Regards,
Roy Chong
FUDForum. Page generated in 0.05793 seconds
