Getting Eclipse for OS X [message #123169] |
Sat, 10 December 2005 00:51  |
Originally posted by: colin_gordon.brown.edu
Hey,
I've installed Eclipse on Windows and Linux machines before, and I feel
like an idiot because for some reason, I cannot figure out how to get it
up and running on my Powerbook.
I've downloaded a couple different .tar.gz's for OS X
(eclipse-SDK-3.1.1-macosx-carbon.tar.gz and
eclipse-SDK-3.2M3-macosx-carbon.tar.gz for reference). When I unpack
them, they unpack into folders with their respective names, and inside
each is a folder called eclipse, inside of which is a folder named
plugins. This is filled with a bunch of .jar files. None of them have a
main class specified in their manifest files, so none of those are what I
should be running. Did I download the wrong files, or is there some step
to converting these files to some form runnable from the shell or Finder
that I'm just completely missing?
Re: Getting Eclipse for OS X [message #123181 is a reply to message #123169] |
Sat, 10 December 2005 02:41   |
Originally posted by: weconsul.ptd.net
Colin Gordon wrote:
> Hey,
> a main class specified in their manifest files, so none of those are
> what I should be running. Did I download the wrong files, or is there
> some step to converting these files to some form runnable from the shell
> or Finder that I'm just completely missing?
This article should solve your problems..
http://developer.apple.com/tools/eclipse.html
Thanks in Advance...
IchBin, Pocono Lake, Pa, USA
http://weconsultants.servebeer.com/JHackerAppManager
____________________________________________________________ ______________
'If there is one, Knowledge is the "Fountain of Youth"'
-William E. Taylor, Regular Guy (1952-)
Re: Getting Eclipse for OS X [message #123193 is a reply to message #123181] |
Sat, 10 December 2005 02:45   |
IchBin wrote:
> Colin Gordon wrote:
>> Hey,
>> feel like an idiot because for some reason, I cannot figure out how to
>> get it up and running on my Powerbook.
>> have a main class specified in their manifest files, so none of those
>> are what I should be running. Did I download the wrong files, or is
>> there some step to converting these files to some form runnable from
>> the shell or Finder that I'm just completely missing?
Forgot to mention, in case you don't know, the SDK-3.2M3 is the latest
bleeding edge. SDK-3.1.1 is the latest stable version.
Re: Getting Eclipse for OS X [message #123214 is a reply to message #123206] |
Sat, 10 December 2005 03:32   |
> Ironically, that's the article I was working from. My issue is that
> there is no clear Eclipse icon, anywhere inside the folder structure
> that shows up when I unpack it. The only folder that has anything in it
> is the plugins folder, and none of those are actually runnable.
> -Colin
Sorry, to hear you were looking at that doc. I have not worked on an
Apple since 1983. So I can't help to much. Only Google it. You figure it
has to be in the base Eclipse directory. You probity have a 'features'
and 'plugin' subdirectory. On all other OS's its in the base directory.
Re: Getting Eclipse for OS X [message #123275 is a reply to message #123249] |
Sat, 10 December 2005 15:42  |
Originally posted by: Colin_Gordon.brown.edu
Yeah, that did it. That's odd, I hadn't had problems with Stuffit
before. I guess I should keep the terminal in mind if something
unpacked seems wrong. Thanks a lot!
-Colin
Jeff Myers wrote:
> What are you using to unpack the tar.gz file? When I unpack
> eclipse-SDK-3.2M3-macosx-carbon.tar.gz I get an eclipse folder with the
> following items:
> Eclipse.app configuration eclipse epl-v10.html features
> notice.html plugins readme startup.jar
> Viewing this folder in Finder shows a very prominent Eclipse app
> launcher, or you can run "eclipse" from the Terminal. So it sounds like
> the package isn't being unzipped properly. Perhaps you should try
> unzipping it from the Terminal via the command "tar xvzf
> eclipse-SDK-3.2M3-macosx-carbon.tar.gz"
> Hope this helps,
> - Jeff
>>> it has to be in the base Eclipse directory. You probity have a
>>> 'features' and 'plugin' subdirectory. On all other OS's its in the
>>> base directory.
>> All I've got is a plugin subdirectory under the base directory.
>> Nothing else. Ah well. Perhaps in the morning someone actually
>> running it on their Mac will see this.
>> -Colin
FUDForum. Page generated in 0.10607 seconds
