Home » Archived » Test and Performance Tools Platform (TPTP) » Re: Generic Log Adapter Example
Re: Generic Log Adapter Example [message #11247] Mon, 21 March 2005 09:57 Go to next message
Hi Andreas,
The GLA documentation will be upgraded from Hyades v3.2 to TPTP 4.0 in
the next few weeks. In the meantime, we will identify the associated Hyades
version (e.g. v3.2) required for the samples.
Please consult the org.eclipse.hyades.logging.adapter.config plug-in for
working examples of several adapter files (see runregex.bat) for Apache
(access.log and error.log) and XML (Common Base Event) log files.
Paul
"Andreas Voss" <eclipse@a-voss.de> wrote in message
news:cvqql7$oua$1@www.eclipse.org...
> Is there somewhere a *working* example for the rule based Generic Log
> Adapter? I have tried several versions of Eclipse (3.0.1, M4, M5a), EMF
> (2.0.1, 2.1.0) and hyades/tptp (3.1.0, 3.2.0, tptp-4.0.xx), and
> different versions of the samples (tutorial, flash demo) but always get
> NPEs and that kind of stuff. It would be very helpful if someone could
> provide the exact versions of eclipse, emf and tptp to get - for example
> - the demo at
http://www.eclipse.org/tptp/platform/documents/tutorials/gla /GLA_CreatingLogParser/GLA_CreatingLogParser.viewlet/samples /myLogParser.zip
> to run.
> Thanks a lot.
> Andreas
Re: Generic Log Adapter Example [message #18716 is a reply to message #11247] Wed, 25 May 2005 20:49 Go to previous messageGo to next message
Originally posted by: tvalence1.cox.net
Thanks for the myLogParser.zip sample project. I am encountering the
following issue with rule-based parsers (including myLogParser) and would
appreciate any help that you can provide.
I followed the "Testing the log parser in the Log and Trace Analyzer"
procedure in the online help for testing the myLogParser plugin in a new
run-time workbench session. However, no output (i.e. 0 matches) was
displayed in the Log Viewer.
I was able to view the output only after attaching to the Sample log (i.e.
myLogParser) logging agent from the LTA in my startup workbench session.
The logging agent was initiated via a Log File Import in a new run-time
workbench session. The progress bar in the Log File Import dialog appeared
to be "frozen" at ~50% during this test.
The above output behavior is consistent with the rule-based parsers that I
have prototyped thus far with TPTP 3.2A. Note that static parsers such as
the OOTB LogParserProject do not exhibit the same output issues.
I ran the myLogParser project in the following configuration of TPTP :
TPTP 3.2A
Eclipse 3.0.2
JDK 1.4.2_08
Windows XP Professional
I suspect that a user/configuration error is behind this output issue, but
have seen no direct references to a similar problem in the newsgroup.
Thanks in advance for your help!
- Ted
"Paul Slauenwhite" <paules@ca.ibm.com> wrote in message
news:d1ms3q$ged$1@news.eclipse.org...
> Hi Andreas,
> Hyades
> for
> Paul
>> - the demo at
>> to run.
>> Thanks a lot.
>> Andreas
Re: Generic Log Adapter Example [message #18762 is a reply to message #18716] Fri, 27 May 2005 00:25 Go to previous messageGo to next message
Originally posted by: nobody.nobody.com
Ted,
Since you can attach to a logging agent generated from a log import
operation in another workbench, it appears that the adapter file for your
parser is not configured correctly for use in a log import scenario. To use
the adapter in a logParser exension to the Log Import wizard of Log and
Trace Analyzer, the executable class of the Outputter component in the
adapter configuration file must be
org.eclipse.hyades.logging.adapter.config.outputters.StaticP arserOutputter.
The help information for "Configuring the outputter component for a
rules-based parser" is not very clear about this. It is clearer in the
upcoming 3.3 version of the help. You can follow the instructions in
"Configuring the outputter component for a static adapter" to configure the
outputter correctly for the log import scenario. The StaticParserOutputter
class is poorly named and is deprecated in TPTP 4.0 and replaced with
LogImportOutputter.
Dave
"TVal" <tvalence1@cox.net> wrote in message
news:d736lu$dvp$1@news.eclipse.org...
appeared
> TPTP 3.2A
> Eclipse 3.0.2
> JDK 1.4.2_08
> - Ted
> > Hi Andreas,
in
> > Hyades
> > for
> > Paul
example
> >> - the demo at
> >> to run.
> >> Thanks a lot.
> >> Andreas
Re: Generic Log Adapter Example [message #18805 is a reply to message #18762] Fri, 27 May 2005 15:29 Go to previous messageGo to next message
Thanks Dave and Paul.
I'm now able to view parser output using log import and logging agent attach
scenarios using two separate adapter configurations, i.e.
import adaptor config has the outputter component executable set to :
live monitoring adaptor config has the outputter component executabl set to:
org.eclipse.hyades.logging.adapter.config.outputters.CBELogO utputter
- Ted
"Dave Smith" <nobody@nobody.com> wrote in message
news:d767mv$m6k$1@news.eclipse.org...
> Ted,
> use
> the
> LogImportOutputter.
> Dave
>> (i.e.
> appeared
>> I
>> as
>> TPTP 3.2A
>> Eclipse 3.0.2
>> JDK 1.4.2_08
>> but
>> - Ted
>> > Hi Andreas,
> in
>> > Hyades
>> > for
>> > Paul
>> >> EMF
>> >> get
> example
>> >> - the demo at
>> >> to run.
>> >> Thanks a lot.
>> >> Andreas
Re: Generic Log Adapter Example [message #18828 is a reply to message #18805] Mon, 30 May 2005 16:39 Go to previous message
Hi Ted,
You may also want to consult the source code from our EclipseCon
tutorial:
http://www.eclipse.org/tptp/ >> Documentation >> Using TPTP Logging and
Monitoring Tools (source)
Paul
news:d77sm7$gnb$1@news.eclipse.org...
attach
to:
> - Ted
> > Ted,
your
> > use
> > the
> > LogImportOutputter.
> > Dave
> >> Hi,
would
new
> >> (i.e.
session.
> > appeared
that
> >> I
> >> as
> >> TPTP 3.2A
> >> Eclipse 3.0.2
> >> JDK 1.4.2_08
> >> but
> >> - Ted
> >> > Hi Andreas,
4.0
> > in
> >> > Hyades
plug-in
> >> > for
Apache
> >> > Paul
Log
> >> >> EMF
> >> >> get
could
> > example
> >> >> - the demo at
> >> >> to run.
> >> >> Thanks a lot.
> >> >> Andreas
Previous Topic:cant start profiling -> error
Next Topic:Newbie: How to troubleshoot Eclipse freezes
Current Time: Wed Jul 16 17:40:43 EDT 2025
Powered by FUDForum. Page generated in 0.04806 seconds
