Home » Eclipse Projects » Eclipse Platform » Table with ScrollBars and SetSize.
Table with ScrollBars and SetSize. [message #122954] Fri, 05 September 2003 09:03 Go to next message
Originally posted by: pkumar.louveciennes.sema.slb.com
hello
I am trying to create a table . But I am unable to set it's size.to be
more precise, the size changes according to the no of elements. But my
requirement is to show only 10 elements in table with scroll bars. I
tried variuos methods but , no effects.
I tried to use the redraw methos which sets the size with scrollbars ,
but nothing appears in the table.
please find attached the method where I am creating table.
thanks
Prameela
----------------------code ---------------------------------------
public void someMethod
Rectangle rect = Display.getCurrent().getClientArea();
System.out.println("Rectangle "+ rect.height+" width "+rect.width);
//create Table group
tabItem1 = new TabItem(tabFolder, SWT.NONE);
Group tableGroup = new Group(tabFolder, SWT.NONE);
GridLayout layout = new GridLayout();
layout.numColumns = 2;
tableGroup.setLayout(layout);
GridData gd = new GridData(GridData.FILL);
tableGroup.setLayoutData(gd);
gd.widthHint = rect.width - tabFolder.getSize().x;
gd.heightHint = rect.height - tabFolder.getSize().y / 2;
//create table
classTable = new Table(tableGroup, SWT.V_SCROLL | SWT.H_SCROLL |
SWT.CHECK);
classTable.setLinesVisible(true);
classTable.setHeaderVisible(true);
gd = new GridData(GridData.FILL_VERTICAL);
gd.horizontalSpan = 2;
gd.grabExcessHorizontalSpace = true;
gd.grabExcessVerticalSpace = true;
gd.horizontalIndent = 10;
classTable.setLayoutData(gd);
classTable.setBackground(tableBGColor);
//create columns
/* Fill the table with data */
for (int i = 0; i < columnTitles.length; i++)
TableColumn tableColumn = new
TableColumn(classTable, SWT.NONE);
tableColumn.setAlignment(SWT.CENTER);
tableColumn.setWidth(51);
tableColumn.setText(columnTitles[i]);
tableColumn.setResizable(true);
//create Items
for (int j = 0; j < 15; j++)
TableItem tableItem1 = new TableItem(classTable, SWT.NONE);
tableItem1.setText(data);
for (int i = 0; i < classTable.getColumnCount(); i++)
TableColumn tableColumn = classTable.getColumn(i);
tableColumn.pack();
//classTable.setRedraw(false);
classTable.pack();
tabItem1.setControl(tableGroup);
tabItem1.setText("Applets");
Re: Table with ScrollBars and SetSize. [message #122957 is a reply to message #122954] Fri, 05 September 2003 09:29 Go to previous message
Prameela schrieb:
> hello
> thanks
> Prameela
Hi Prameela,
don't pack your table. If you pack it it will be resized and that is
what you want to avoid. Set the size of your table explicitely.
Ralf
> //create table
> SWT.CHECK);
> //create columns
> TableColumn tableColumn = new TableColumn(classTable,
> SWT.NONE);
> //create Items
> tableColumn.pack();
> classTable.pack();
Previous Topic:When is workbench Initialization completed?
Next Topic:current directory
Current Time: Sat Jul 26 07:40:19 EDT 2025
Powered by FUDForum. Page generated in 0.05844 seconds
