Creating report off an XML schema only [message #122940] |
Wed, 01 February 2006 19:31 |
Originally posted by: mbd_int.no_spam_hotmail.com
I was able to create XML Data Source just fine (although a warning dialog
had to be dismissed). However when trying to add column mappings for the
data source I get following errors:
A BIRT exception occurred.
Plug-in Provider:Eclipse.org
Plug-in Name:BIRT Data Engine
Plug-in ID:org.eclipse.birt.data
Version:2.0.0
Error Code:odaconsumer.CannotOpenConnection
Error Message:Cannot open the connection for the driver:
org.eclipse.birt.report.data.oda.xml
Some connection properties are missing.
Also the error is always displayed when I double-click my Dataset.
My expectation is that I should be able to create: Data Source, Data Set and
add column mappings to Data Set based on schema only. I do expect the
preview being unavailable due to lack of real data.
Is this a bug?
-Boris
FUDForum. Page generated in 0.03850 seconds
