Home » Eclipse Projects » Eclipse Platform » Absent line number attribute while debugging!
Absent line number attribute while debugging! [message #122933] Fri, 05 September 2003 06:47 Go to next message
Originally posted by: markus.wurz.home.se
I am using eclipse 2.1.1 and receiving a "Absent line number attribute"
error when the debugger is reaching a breakpoint. I have been searching
the web for information and I can't figure out if it is a bug as noted in
http://dev.eclipse.org/newslists/news.eclipse.tools.jdt/msg0 2976.html (but
this is eclipse v3 only, right?)or did I miss something? The line number
flag in Preferences > Java > Compile is set. I am debugging an application
running on weblogic server.
Re: Absent line number attribute while debugging! [message #123180 is a reply to message #122933] Fri, 05 September 2003 11:36 Go to previous message
But what code are you debugging in? A JAR that is not compiled by Eclipse? A
system library?
Has this code been compiled with the required debugging information?
HTH
Darins
"Markus Wurz" <markus.wurz@home.se> wrote in message
news:bj9pks$6ct$1@eclipse.org...
Previous Topic:listener attempted to access system.err - infinite loop terminated
Next Topic:new File(".")
Current Time: Mon Jul 21 21:21:17 EDT 2025
Powered by FUDForum. Page generated in 0.23328 seconds
