[Teneo] Is hibernate.hbm.xml enough [message #122927] |
Fri, 23 May 2008 08:19 |
I have a remote machine that does not have Eclipse or Teneo on it. I
need to generate the Database on that machine. Can I use the
hibernate.hbm.xml with the hbm2dll tool to generate the DDL SQL and copy
across to that machine and generate the database? In other words is the
Teneo doing any extra work on the generate database above and beyond
what Hibernate will do?
Thx.
David
Re: [Teneo] Is hibernate.hbm.xml enough [message #122931 is a reply to message #122927] |
Fri, 23 May 2008 08:18  |
Hi David,
Yes this should work, so Teneo is not doing anything extra than hibernate.
gr. Martin
david wrote:
> Thx.
> David
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Re: [Teneo] Is hibernate.hbm.xml enough [message #618164 is a reply to message #122927] |
Hi David,
gr. Martin
david wrote:
> Thx.
> David
The Netherlands
FUDForum. Page generated in 0.07701 seconds
