Home » Language IDEs » Java Development Tools (JDT) » Export filtering based on changes
Export filtering based on changes [message #122917] Fri, 28 November 2003 21:55 Go to next message
I would like to be able to export files from a project based on
differences from a baseline. Where this is useful is if I check a
baseline project into the repository such as a user configurable jar or
war and later want to see what files have dynamically changed during
runtime operations, I can reimport the runtime version into the project
and then sync with repository which will show me everything that is
different. It is these differing files that I would like to be able to
filter on and export into an external zip file. I have not found a way
to do this currently but if this is possible please let me know. If
not, I would like to suggest adding this as a feature enhancement.
Re: Export filtering based on changes [message #122921 is a reply to message #122917] Fri, 28 November 2003 21:59 Go to previous message
Just to be perfectly clear, the baseline would be the expanded jar or war
and that is what would be checked into the repository.
Previous Topic:Free/OSJsp/Html/Xml editor anywhere?
Next Topic:eclipse-plugins.2y.net could not be found??
Current Time: Mon Jul 21 21:48:58 EDT 2025
Powered by FUDForum. Page generated in 0.05085 seconds
