Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [CDO 0.8.0] eDirectResource return always NULL
[CDO 0.8.0] eDirectResource return always NULL [message #122904] Thu, 22 May 2008 19:41 Go to next message
I tried to complete my automatic persistence mechanism,
I have one case I do not handle and it seems to be because one value in
BasicEObject that is not set properly. In fact it is never set.
eDirectResource is always null when we use CDO. Did we never want to set it
? (when we attach an object and/or when we load an object) ?
Usually it is set when we attach an object to a resource...
Simon
Re: [CDO 0.8.0] eDirectResource return always NULL [message #122907 is a reply to message #122904] Fri, 23 May 2008 03:01 Go to previous messageGo to next message
Originally posted by: stepper.sympedia.de
Hi Simon,
I'm not really sure about the expected semantics of eDirectResource and
eInternalResource. The JavaDoc is not very helpful:
* Returns the containing resource, or <code>null</code>.
Resource eResource();
* Returns the containing internal resource, or <code>null</code>.
Resource.Internal eInternalResource();
* Returns the directly containing internal resource, or
<code>null</code>.
Resource.Internal eDirectResource();
As I understand it, there are basically two approaches to determine the
resource of an object:
1) walk up the containment relationship (eContainer) until that is null
(top level object) then return its resource (eDirectResource)
2) A non-top level object has for some reasons directly stored its
resource (eDirectResource), then return it (or null)
eResource() is just a public wrapper for the eInternalResource() which
does 1)
eDirectResource() does 2)
If that's correct, I'd say for most non-top level objects
eDirectResource() would return something (null) different from
eInternalResource() and eResource().
Ed, is that correct?
Can you please explain how these methods relate/differ to/from each other?
In any way a CDOObjectImpl should behave exactly according to the
sematics implied by EObject and InternalEObject. If that is not the
case, please file a Bugzilla.
Cheers
/Eike
> Simon
Re: [CDO 0.8.0] eDirectResource return always NULL [message #122910 is a reply to message #122907] Fri, 23 May 2008 06:49 Go to previous messageGo to next message
This is not the case.
I will fill a bugzilla! (I tested my stuff with XMIResourceImpl and do not
behave the same way!)
"Eike Stepper" <stepper@sympedia.de> a
Re: [CDO 0.8.0] eDirectResource return always NULL [message #122914 is a reply to message #122910] Fri, 23 May 2008 06:55 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=233644
"Simon McDuff" <smcduff@hotmail.com> a
Re: [CDO 0.8.0] eDirectResource return always NULL [message #618155 is a reply to message #122904] Fri, 23 May 2008 03:01 Go to previous message
Hi Simon,
<code>null</code>.
does 1)
Cheers
/Eike
> Simon
Re: [CDO 0.8.0] eDirectResource return always NULL [message #618156 is a reply to message #122907] Fri, 23 May 2008 06:49 Go to previous message
Re: [CDO 0.8.0] eDirectResource return always NULL [message #618158 is a reply to message #122910] Fri, 23 May 2008 06:55 Go to previous message
Previous Topic:[CDO 0.8.0] eDirectResource return always NULL
Next Topic:[CDO 0.8.0] Performance
Current Time: Tue Jul 15 04:21:01 EDT 2025
Powered by FUDForum. Page generated in 0.29929 seconds
