| [CDO 0.8.0] eDirectResource return always NULL [message #122904] |
Thu, 22 May 2008 19:41  |
I tried to complete my automatic persistence mechanism,
I have one case I do not handle and it seems to be because one value in
BasicEObject that is not set properly. In fact it is never set.
eDirectResource is always null when we use CDO. Did we never want to set it
? (when we attach an object and/or when we load an object) ?
Usually it is set when we attach an object to a resource...
Simon
| Re: [CDO 0.8.0] eDirectResource return always NULL [message #122907 is a reply to message #122904] |
Fri, 23 May 2008 03:01   |
Originally posted by: stepper.sympedia.de
Hi Simon,
I'm not really sure about the expected semantics of eDirectResource and
eInternalResource. The JavaDoc is not very helpful:
* Returns the containing resource, or <code>null</code>.
Resource eResource();
* Returns the containing internal resource, or <code>null</code>.
Resource.Internal eInternalResource();
* Returns the directly containing internal resource, or
<code>null</code>.
Resource.Internal eDirectResource();
As I understand it, there are basically two approaches to determine the
resource of an object:
1) walk up the containment relationship (eContainer) until that is null
(top level object) then return its resource (eDirectResource)
2) A non-top level object has for some reasons directly stored its
resource (eDirectResource), then return it (or null)
eResource() is just a public wrapper for the eInternalResource() which
does 1)
eDirectResource() does 2)
If that's correct, I'd say for most non-top level objects
eDirectResource() would return something (null) different from
eInternalResource() and eResource().
Ed, is that correct?
Can you please explain how these methods relate/differ to/from each other?
In any way a CDOObjectImpl should behave exactly according to the
sematics implied by EObject and InternalEObject. If that is not the
case, please file a Bugzilla.
Cheers
/Eike
> Simon
| Re: [CDO 0.8.0] eDirectResource return always NULL [message #618155 is a reply to message #122904] |
Hi Simon,
<code>null</code>.
does 1)
Cheers
/Eike
> Simon
FUDForum. Page generated in 0.04484 seconds
