Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » RE: EMF Compare of two Domain Specific Models
RE: EMF Compare of two Domain Specific Models [message #122657] Mon, 19 May 2008 06:19 Go to next message
Hi all,
I am trying to merge two DSLs together using EMF Compare. I have 3 ecore
models, A.ecore (namespace - http://www.abc.com/#A), B.ecore and C.ecore.
A.ecore is the metamodel of B.ecore and C.ecore. I want to merge B.ecore
and C.ecore, and I am using EMF compare to do this. I register A.ecore as
a metamodel using AM3 - this works as I can see B.ecore and C.ecore using
the Ecore Model Editor. When I run my EMF Compare program I get the
following error - any ideas (thanks in advance :)):
org.eclipse.emf.ecore.resource.Resource$IOWrappedException: Package with
uri 'http://www.abc.com/#A' not found.
(file:/home/mmelia/workspace3/AATest/model/B.ecore, 3, 101)
org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.handleErrors(XMLL oadImpl.java:83)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:191)
org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLRes ourceImpl.java:180)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1414)
org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(Resour ceImpl.java:1210)
at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :335)
at org.eclipse.emf.compare.util.ModelUtils.load(ModelUtils.java :217)
at test.Test.main(Test.java:25)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package
with uri 'http://www.abc.com/#A' not found.
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(X MLHandler.java:2566)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefi x(XMLHandler.java:2398)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType (XMLHandler.java:1276)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XM LHandler.java:1445)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XML Handler.java:1010)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMI Handler.java:83)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:992)
org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHa ndler.java:712)
org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHa ndler.java:167)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .startElement(AbstractSAXParser.java:501)
com.sun.org.apache.xerces.internal.parsers.AbstractXMLDocume ntParser.emptyElement(AbstractXMLDocumentParser.java:179)
com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator. emptyElement(XMLDTDValidator.java:788)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanStartElement(XMLDocumentFragmentScannerImpl.j ava:1337)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$ContentDriver.scanRootElementHook(XMLDocumentScannerImpl. java:1289)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl$FragmentContentDriver.next(XMLDocumentFragmentSca nnerImpl.java:3084)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl$PrologDriver.next(XMLDocumentScannerImpl.java:912)
com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerIm pl.next(XMLDocumentScannerImpl.java:645)
com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentS cannerImpl.scanDocument(XMLDocumentFragmentScannerImpl.java: 508)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:807)
com.sun.org.apache.xerces.internal.parsers.XML11Configuratio n.parse(XML11Configuration.java:737)
com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(X MLParser.java:107)
com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser .parse(AbstractSAXParser.java:1205)
com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSA XParser.parse(SAXParserImpl.java:522)
at javax.xml.parsers.SAXParser.parse(SAXParser.java:395)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl. java:181)
... 6 more
Re: EMF Compare of two Domain Specific Models [message #122662 is a reply to message #122657] Mon, 19 May 2008 08:30 Go to previous messageGo to next message
--------------080206090801000009050208
Mark,
I think I will need a little more informations here... What is the exact
use case? You're using a main() method to launch EMF Compare on two
models in the same Eclipse where you registered A.ecore MetaModel? Or
did you try registering and reading your model files in another Eclipse?
AFAIK, AM3 registers the metamodel in the global EMF registry through
EPackage.Registry. If it is the case -and you're using EMF Compare in
the same Eclipse instance-, the comparison should run smoothly since we
simply delegate the resource loading Resource#load() which should in
turn use this registry (Ed might be able to confirm/infirm this).
You didn't provide us the code you use to compare models, I believe you
tried the snippet I gave to Lars sometime before this :
EObject model1 = ModelUtils.load(model1, resourceSet);
EObject model2 = ModelUtils.load(model2, resourceSet);
MatchModel match = MatchService.doMatch(model1, model2,
Collections.<String, Object> emptyMap());
DiffModel diff = DiffService.doDiff(match, false);
You'll probably need to register the metamodel yourself in order to have
your resources loaded as expected. This can be achieved by a code like :
// Assuming the first root of the metamodel is an EPackage
EPackage model = (EPackage)ModelUtils.load(metamodel, resourceSet);
// In your example, nsURI should be http://www.abc.com/#A
EPackage.Registry.INSTANCE.put(nsURI, model);
This should be made before you load the two other models.
Laurent Goubet
Obeo
Mark Melia a
Re: EMF Compare of two Domain Specific Models [message #122667 is a reply to message #122662] Mon, 19 May 2008 10:05 Go to previous messageGo to next message
Hi Laurent,
That was it, I just needed to register the metamodel in the code as you
said - thanks!!!
One more thing I am now getting an error
org.eclipse.emf.compare.FactoryException: The feature name does not exist
in LearningContext - I am not sure what is going on here?
LearningContext is an eClass in the metamodel - A.ecore and does not have
a name attribute. B.ecore has an instance of the LearningContext - this
too does not have a name attribute in its definition.
By the way I am using the main method as described below, when you were
helping me before.
try {
final ResourceSet modelResourceSet = new ResourceSetImpl();
EPackage model = (EPackage)ModelUtils.load(new
File("/home/mmelia/workspace3/AATest/model/A.ecore"), modelResourceSet);
EPackage.Registry.INSTANCE.put("http://dcu.ie/#A", model);
Resource model1 = ModelUtils.load(new
File("/home/mmelia/workspace3/AATest/model/B.ecore"),
modelResourceSet).eResource();
Resource model2 =
ModelUtils.load(URI.createFileURI("/home/mmelia/workspace3/AATest/model/C.ecore "),modelResourceSet).eResource();
final MatchModel match = MatchService.doResourceMatch(model1, model2,
null);
// Detects differences
final DiffModel diff = DiffService.doDiff(match);//EXCEPTION HERE
// Merges all differences from model1 to model2
MergeService.merge(diff.getOwnedElements(), true);
} catch (Exception exception) {
exception.printStackTrace();
laurent Goubet wrote:
> Mark,
> Cheers,
> Laurent Goubet
> Obeo
> Mark Melia a écrit :
>> Hi all,
>> C.ecore. A.ecore is the metamodel of B.ecore and C.ecore. I want to
>> merge B.ecore and C.ecore, and I am using EMF compare to do this. I
>> register A.ecore as a metamodel using AM3 - this works as I can see
>> B.ecore and C.ecore using the Ecore Model Editor. When I run my EMF
>> Compare program I get the following error - any ideas (thanks in advance
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> .. 6 more
Re: EMF Compare of two Domain Specific Models [message #122673 is a reply to message #122667] Mon, 19 May 2008 10:34 Go to previous messageGo to next message
--------------090302040706040905030508
Mark,
Such exception usually mean your model isn't valid : you have defined
"LearningContext" in your metamodel with a set of attributes/references
which does not include an attribute named "name", yet in your model you
have created an instance of LearningContext and defined a "name" on it.
When registering your metamodel through AM3, can you open both of the
models your comparing in the ecore editor? If yes, you probably don't
register the good metamodel through code
("/home/mmelia/workspace3/AATest/model/A.ecore"). Otherwise, you'll need
to change the XML of your model to delete the wrong "name" attribute to
validate it.
Another option would be to set the loading option
"XMLResource.OPTION_RECORD_UNKNOWN_FEATURE" to true for your model ...
but this is a dangerous way to go since EMF will then simply ignore all
feature it doesn't know about and save them back only if you specify
this option for model.save() as well.
Laurent Goubet
Obeo
Mark Melia a
Re: EMF Compare of two Domain Specific Models [message #122677 is a reply to message #122673] Mon, 19 May 2008 12:23 Go to previous messageGo to next message
Hi Laurent,
Again thanks for your help!
I fixed up the models, so that they both have the same root model element
this solved this problem. I think EMF Compare needs to have a common point
of reference in order to work out the differences in the models - perhaps
you could correct me if I am wrong here?
Mark
> Mark,
> validate it.
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> said - thanks!!!
>> exist in LearningContext - I am not sure what is going on here?
>> have a name attribute. B.ecore has an instance of the LearningContext -
>> this too does not have a name attribute in its definition.
>> helping me before.
>> public static void main(String[] args) {
>> try {
>> modelResourceSet).eResource(); Resource model2 =
>> MatchService.doResourceMatch(model1, model2, null);
>> HERE
>>> Mark,
>>> exact use case? You're using a main() method to launch EMF Compare on
>>> two models in the same Eclipse where you registered A.ecore MetaModel?
>>> Or did you try registering and reading your model files in another
>>> Eclipse?
>>> we simply delegate the resource loading Resource#load() which should
>>> in turn use this registry (Ed might be able to confirm/infirm this).
>>> you tried the snippet I gave to Lars sometime before this :
>>> have your resources loaded as expected. This can be achieved by a code
>>> like :
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>> Hi all,
>>>> ecore models, A.ecore (namespace - http://www.abc.com/#A), B.ecore
>>>> and C.ecore. A.ecore is the metamodel of B.ecore and C.ecore. I want
>>>> to merge B.ecore and C.ecore, and I am using EMF compare to do this.
>>>> I register A.ecore as a metamodel using AM3 - this works as I can see
>>>> advance :)):
>>>> at
>>>> at
>>>> at
>>>> at
>>>> Package with uri 'http://www.abc.com/#A' not found.
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> .. 6 more
Re: EMF Compare of two Domain Specific Models [message #122687 is a reply to message #122677] Tue, 20 May 2008 02:39 Go to previous message
--------------020506060000080808050007
Mark,
When models have multiple roots, EMF Compare will try and match them as
it would for the roots' contents. If no roots can be matched together,
it will assume the two "first" roots are "identical" and begin matching
their respective contents; so EMF Compare does not need a common point
of reference to figure out differences (you can even compare a .ecore
with a .uml... I doubt the differences will be meaningful though ;)).
Laurent Goubet
Obeo
Mark Melia a
Re: EMF Compare of two Domain Specific Models [message #618066 is a reply to message #122657] Mon, 19 May 2008 08:30 Go to previous message
Mark,
Laurent Goubet
Obeo
Mark Melia a
Re: EMF Compare of two Domain Specific Models [message #618067 is a reply to message #122662] Mon, 19 May 2008 10:05 Go to previous message
Hi Laurent,
said - thanks!!!
helping me before.
try {
Resource model2 =
null);
> Mark,
> Cheers,
> Laurent Goubet
> Obeo
>> Hi all,
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> at
>> .. 6 more
Re: EMF Compare of two Domain Specific Models [message #618068 is a reply to message #122667] Mon, 19 May 2008 10:34 Go to previous message
Mark,
validate it.
Laurent Goubet
Obeo
Mark Melia a
Re: EMF Compare of two Domain Specific Models [message #618069 is a reply to message #122673] Mon, 19 May 2008 12:23 Go to previous message
Hi Laurent,
Mark
> Mark,
> validate it.
> Laurent Goubet
> Obeo
>> Hi Laurent,
>> said - thanks!!!
>> helping me before.
>> try {
>> HERE
>>> Mark,
>>> Eclipse?
>>> like :
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>> Hi all,
>>>> advance :)):
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> at
>>>> .. 6 more
Re: EMF Compare of two Domain Specific Models [message #618071 is a reply to message #122677] Tue, 20 May 2008 02:39 Go to previous message
Mark,
Laurent Goubet
Obeo
Mark Melia a
Previous Topic:RE: EMF Compare of two Domain Specific Models
Next Topic:Merging UML models
Current Time: Fri Jul 18 05:51:08 EDT 2025
Powered by FUDForum. Page generated in 0.10571 seconds
