Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare] How to use EMF Compare in Java
[EMF Compare] How to use EMF Compare in Java [message #122630] Sat, 17 May 2008 13:33 Go to next message
I am writing a Model Refactoring for EMF Plugin and I think it would be
great to use EMF Compare as a preview like Eclipse Code Refactoring
does. The problem I am having is how to compare the original resource
with the refactored resource. I need to know how to open a two-way
compare of the two different instances of EObject.
In this newsgroup I already found this snippet but it does not work
(anymore):
EObject eObject1 = ModelUtils.load(model1URI);
EObject eObject2 = ModelUtils.load(model2URI);
final MatchModel match = new MatchService().doMatch(
eObject1, eObject2, new NullProgressMonitor());
final DiffModel diff = new DiffMaker().doDiff(match);
- ModelUtils.load(...) also needs a ResourceSet
- MatchService has no visible constructor
- DiffMaker can not be resolved to a type
Are there tutorials or other code examples available?
Re: [EMF Compare] How to use EMF Compare in Java [message #122637 is a reply to message #122630] Sun, 18 May 2008 01:41 Go to previous messageGo to next message
I think that you should find an answer in the EMF Compare FAQ.
http://wiki.eclipse.org/EMF_Compare_FAQ
Stephane
Obeo
Lars Schneider a écrit :
> (anymore):
Re: [EMF Compare] How to use EMF Compare in Java [message #122647 is a reply to message #122637] Sun, 18 May 2008 12:00 Go to previous messageGo to next message
I already read through this wiki but couldn't find anything helping me
with my problem. I need a code snippet or a tutorial that describes how
to programatically load two models and compare them.
Stéphane LACRAMPE schrieb:
> Stephane
> Obeo
>> be great to use EMF Compare as a preview like Eclipse Code Refactoring
>> (anymore):
Re: [EMF Compare] How to use EMF Compare in Java [message #122652 is a reply to message #122647] Mon, 19 May 2008 02:52 Go to previous messageGo to next message
--------------020505000708090309090603
Lars,
An example showing how to use EMF Compare standalone
(org.eclipse.emf.compare.examples.standalone) is available on CVS. This
project contains code for loading, matching and differencing models.
Here is the corresponding snippet (where "model1" and "model2" can be
either URIs, Strings, IFiles or Files) :
EObject model1 = ModelUtils.load(model1, resourceSet);
EObject model2 = ModelUtils.load(model2, resourceSet);
MatchModel match = MatchService.doMatch(model1, model2,
Collections.<String, Object> emptyMap());
DiffModel diff = DiffService.doDiff(match, false);
Laurent Goubet
Obeo
Lars Schneider a
Re: [EMF Compare] How to use EMF Compare in Java [message #122752 is a reply to message #122652] Wed, 21 May 2008 09:07 Go to previous messageGo to next message
Thanks Laurent,
that worked. Can you tell me where the Compare-Viewer/Editor is loaded
in the Plugin? I have to open it explicitly after a Wizard is shown.
Lars
laurent Goubet wrote:
> Lars,
> Cheers,
> Laurent Goubet
> Obeo
>> how to programatically load two models and compare them.
>>> Hi,
>>> Stephane
>>> Obeo
>>>> Hi,
>>>> Refactoring does. The problem I am having is how to compare the
>>>> original resource with the refactored resource. I need to know how
>>>> to open a two-way compare of the two different instances of EObject.
>>>> (anymore):
Re: [EMF Compare] How to use EMF Compare in Java [message #122763 is a reply to message #122752] Wed, 21 May 2008 10:15 Go to previous messageGo to next message
--------------060606080103040501040007
Lars,
We never explicitly open our editor, org.eclipse.compare handles this
part through the extension points we extend.
You can take a look at the (very) small
org.eclipse.emf.compare.ui.editor.ModelCompareEditorLauncher which we
use to open emfdiff files (serialization of a comparison result).
I've never tried this from code, but I think something like :
ModelInputSnapshot snapshot =
DiffFactory.eINSTANCE.createModelInputSnapshot();
snapshot.setDiff(diff)
snapshot.setMatch(match)
CompareUI.openCompareEditor(new ModelCompareEditorInput(snapshot));
should do the trick.
Laurent Goubet
Obeo
Lars Schneider a
Re: [EMF Compare] How to use EMF Compare in Java [message #122779 is a reply to message #122763] Wed, 21 May 2008 11:56 Go to previous message
Laurent,
I really cannot express how happy I am. That was EXACTLY what I was
looking for. Thank you very, very much.
Lars
> Lars,
> Laurent Goubet
> Obeo
>> Thanks Laurent,
>> Lars
>>> Lars,
>>> This project contains code for loading, matching and differencing
>>> models.
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>> me with my problem. I need a code snippet or a tutorial that
>>>> describes how to programatically load two models and compare them.
>>>>> Hi,
>>>>> Stephane
>>>>> Obeo
>>>>>> Hi,
>>>>>> would be great to use EMF Compare as a preview like Eclipse Code
>>>>>> work (anymore):
Re: [EMF Compare] How to use EMF Compare in Java [message #618061 is a reply to message #122630] Sun, 18 May 2008 01:41 Go to previous message
Stephane
Obeo
> (anymore):
Re: [EMF Compare] How to use EMF Compare in Java [message #618063 is a reply to message #122637] Sun, 18 May 2008 12:00 Go to previous message
> Stephane
> Obeo
>> (anymore):
Re: [EMF Compare] How to use EMF Compare in Java [message #618064 is a reply to message #122647] Mon, 19 May 2008 02:52 Go to previous message
Lars,
Laurent Goubet
Obeo
Lars Schneider a
Re: [EMF Compare] How to use EMF Compare in Java [message #618086 is a reply to message #122652] Wed, 21 May 2008 09:07 Go to previous message
Thanks Laurent,
Lars
> Lars,
> Cheers,
> Laurent Goubet
> Obeo
>>> Hi,
>>> Stephane
>>> Obeo
>>>> Hi,
>>>> (anymore):
Re: [EMF Compare] How to use EMF Compare in Java [message #618089 is a reply to message #122752] Wed, 21 May 2008 10:15 Go to previous message
Lars,
Laurent Goubet
Obeo
Lars Schneider a
Re: [EMF Compare] How to use EMF Compare in Java [message #618099 is a reply to message #122763] Wed, 21 May 2008 11:56 Go to previous message
Laurent,
Lars
> Lars,
> Laurent Goubet
> Obeo
>> Thanks Laurent,
>> Lars
>>> Lars,
>>> models.
>>> Cheers,
>>> Laurent Goubet
>>> Obeo
>>>>> Hi,
>>>>> Stephane
>>>>> Obeo
>>>>>> Hi,
>>>>>> work (anymore):
Previous Topic:[CDO 0.8.0RC1] CDOUtil.openSession missing
Next Topic:ClassCastException to EList
Current Time: Sun Jul 13 23:51:26 EDT 2025
Powered by FUDForum. Page generated in 0.08630 seconds
