Home » Eclipse Projects » GEF » Xerces parser problem with GEF plugin
Xerces parser problem with GEF plugin [message #122604] |
Tue, 16 March 2004 07:16  |
Originally posted by: jig.patel.excite.com
-I get the following message when a class (called from my GEF plugin at
runtime)
trys to create a new instance of the SAX parser.
(I have included the xerces .jar files in my plugins java build path.)
Unhandled exception caught in event loop.
Reason:
org/apache/xerces/parsers/SAXParser
However when I run the parser as a standalone java application (from
eclipse) it runs fine.
Im pretty sure eclipse is causing the problem but im not sure how to fix it.
-I have noticed that a xerces plugin is included with eclipse, but if I
remove that, eclipse doesnt start.
(At the moment the parser just parses an xml file, and prints the content,
so there is no interaction with the plugin. The plugin just creates a new
instance of my parser, which automatically attempts to parse a predefined
file.)
Any help/tips greatly appreciated.
-Jig.
Re: Xerces parser problem with GEF plugin [message #122648 is a reply to message #122643] |
Tue, 16 March 2004 11:00   |
Whitney,
I think we talking about diff. things -to clarify:
"Unhandled exception caught in event loop.
Reason:
org/apache/xerces/parsers/SAXParser"
-is the messege generated @ runtime by the workbench, as my parser cant be
initilised when called by my plugin -when my plugin tries to create an new
example file like the logic diagram example. (File -> new -> example ->
(select type) -> finish)doesnt work as my parser is called when the example
diagram is meant to be made.
(this is the integration problem with the plugin, as the parser works fine
when launched as a java application)
I have noticed that eclipse comes with a xerces plugin, -which i am not
using. When i removed this xerces plugin (hoping that it might rectify the
above problem), eclipse wont start and the following messege is generated in
the .log file:
"java.lang.RuntimeException: Fatal Error: Unable to locate matching
org.apache.xerces plug-in."
-im pretty sure this is because eclipse needs this plugin to run.
hope that clarifies what the problem is.
-Jig
"Whitney Sorenson" <none@us.ibm.com> wrote in message
news:c3761v$o8$1@eclipse.org...
> So what's the exception in the .log file that causes this message:
> Reason:
> (check runtime-workbench-workspace maybe?)
> "J Patel" <jig.patel@excite.com> wrote in message
> news:c3748a$to8$1@eclipse.org...
> > I already know that if i remove the xerces plugin (the ones thats part
of
> > eclipse) eclipse doesnt start because it cant locate it:
> > -"java.lang.RuntimeException: Fatal Error: Unable to locate matching
> > But im hoping to find a solution that can allow my specified version of
> > xerces parser (which ive included in the plugin project build path) to
> > coexist with the version thats part of eclipse.
> > -Or find another suitable solution that will allow me to get my parser
> > working.
> > news:c373it$sqo$1@eclipse.org...
> > > You should look in your .log file in the .metadata directory of your
> > > workspace to find out the exact exception that is being thrown.
> > > news:c36qui$hf8$1@eclipse.org...
> at
> > > > runtime)
path.)
> > > > Reason:
> fix
> > > it.
if
> I
> > content,
a
> > new
> > predefined
> > > > file.)
> > > > -Jig.
Re: Xerces parser problem with GEF plugin [message #122674 is a reply to message #122648] |
Tue, 16 March 2004 14:17   |
I understand the problem - here's what you can do to find out more about it:
Open up the .metadata directory of your runtime-workbench-workspace. In the
..metadata directory, there is a .log file which contains the verbose details
of this error:
Reason:
Seeing this extra information about what caused this exception will help you
determine exactly what is going wrong when you are running your plug-in.
This is because when Eclipse encounters an unhandled exception, such as the
one above, it prints out the exact exception to the .log file. This error
has nothing to do with eclipse not starting when you remove the xerces
plug-in.
news:c37834$3jm$1@eclipse.org...
> Whitney,
> Reason:
example
the
in
> the .log file:
> -Jig
> > Reason:
> of
of
> > > working.
plugin
> > at
> > > > > runtime)
> path.)
> > > > > Reason:
(from
to
> > fix
> > > > it.
> if
> > I
> > > content,
creates
> a
> > > new
> > > predefined
> > > > > file.)
> > > > > -Jig.
Re: Xerces parser problem with GEF plugin [message #122712 is a reply to message #122674] |
Tue, 16 March 2004 15:47   |
Thanks Whitney, i understand what you mean now.
the source of the prob. is:
"java.lang.NoClassDefFoundError: org/apache/xerces/parsers/SAXParser"
i dont understand how this can be, as the code compiles fine, and all the
appropriate libraries have been included in the build path. (I even included
a ref. to xerces in my windows classpath)
am i missing somthing obvious?
-Jig.
news:c37jh3$jef$1@eclipse.org...
it:
the
details
> of this error:
> Reason:
you
the
> plug-in.
> > Whitney,
> > Reason:
be
new
> example
fine
> the
generated
> in
> > the .log file:
> > -Jig
> > > Reason:
part
> > of
> of
to
parser
> > > > working.
your
> plugin
> > > at
> > > > > > runtime)
> > path.)
> > > > > > Reason:
> (from
how
> to
> > > fix
> > > > > it.
but
> > if
> > > I
the
> > > > content,
> creates
> > a
> > > > new
> > > > predefined
> > > > > > file.)
> > > > > > -Jig.
Re: Xerces parser problem with GEF plugin [message #122717 is a reply to message #122712] |
Tue, 16 March 2004 16:35   |
Does your plugin.xml require the xerces plug-in? In the Plug-in Manifest
Editor, in the Dependencies tab, add it as a required plug-in if you havn't
already.
news:c37ose$q8m$1@eclipse.org...
included
> -Jig.
> it:
> the
> details
> > of this error:
> > Reason:
> you
> the
error
> > plug-in.
> > > Whitney,
> > > Reason:
cant
> be
> new
example ->
> > example
> fine
not
rectify
> > the
> generated
> > in
> > > the .log file:
> > > -Jig
> > > > Reason:
> part
> > > of
matching
version
> > of
path)
> to
> parser
> > > > > working.
> your
> > plugin
> > > > at
> > > > > > > runtime)
build
> > > path.)
> > > > > > > Reason:
> > (from
> how
> > to
> > > > fix
> > > > > > it.
> but
> > > if
> > > > I
> the
> > > > > content,
> > creates
> > > a
> > > > > new
> > > > > predefined
> > > > > > > file.)
> > > > > > > -Jig.
thanks [message #122727 is a reply to message #122717] |
Tue, 16 March 2004 18:15  |
that did the job. -cant believe it was that simple.
thanks for all your help Whitney.
-Jig
news:c37rj9$tot$1@eclipse.org...
havn't
> already.
the
> included
> > -Jig.
about
> > it:
In
> > the
> > details
> > > of this error:
> > > Reason:
help
> > you
plug-in.
as
> > the
> error
> > > plug-in.
> > > > Whitney,
> > > > Reason:
> cant
> > be
an
> > new
> example ->
> > > example
works
> > fine
> not
> rectify
> > > the
> > generated
> > > in
> > > > the .log file:
> > > > -Jig
> > > > > Reason:
thats
> > part
> > > > of
> matching
> version
> > > of
> path)
> > to
> > parser
> > > > > > working.
of
> > your
thrown.
GEF
> > > plugin
> > > > > at
> > > > > > > > runtime)
> build
> > > > path.)
> > > > > > > > Reason:
application
> > > (from
sure
> > how
> > > to
> > > > > fix
> > > > > > > it.
eclipse,
> > but
> > > > if
> > > > > I
prints
> > the
> > > > > > content,
> > > creates
> > > > a
> > > > > > new
a
> > > > > > predefined
> > > > > > > > file.)
> > > > > > > > -Jig.
Current Time: Thu Jul 17 13:31:38 EDT 2025
Powered by FUDForum. Page generated in 0.09917 seconds
