Eclipse-LazyStart vs Bundle-ActivationPolicy [message #122561] |
Sun, 14 December 2008 17:03  |
Originally posted by: jmordax.terra.es
Hi, I was developing with Eclipse R3.4.1 and PDE by default, when
checking "Activate this plug-in when one of its classes is loaded",
added to MANIFEST.MF the field:
Bundle-ActivationPolicy: lazy
This worked fine with 3.4.x and 3.5. But when I tested the plug-ins with
3.2.x it failed with a NPE. After some investigation, the problem was
that 3.2 doesn't understand Bundle-ActivationPolicy field. And PDE in
3.2.x adds this other field instead:
Eclipse-LazyStart: true
I have been searching the docs to find why these two different fields
theoretically to do the same thing with no luck. Do you know of any
article related?
Finally, to have plug-ins compatible with previous versions like 3.2.x I
have both fields added to MANIFEST.MF. Does it make sense to you? Can I
have any problem in new releases because I am using two fileds
theoretically for the same thing?
Thanks in advance,
Chemi.
Re: Eclipse-LazyStart vs Bundle-ActivationPolicy [message #122581 is a reply to message #122573] |
Sun, 14 December 2008 18:23  |
Perfect, thanks for the information. That is exactly what I was looking
for...
ekke wrote:
> Chemi,
> since OSGI R4.1 OSGI supports lazy start using
> so it makes sense to use this now as default, because its official
> OSGI where Eclipse-LazyStart: true was equinox-only.
> if you have to be compatible to older versions there's no probem to
> have both in your manifest.mf
> ekke
FUDForum. Page generated in 0.07491 seconds
