Home » Eclipse Projects » Eclipse Platform » Project Paths and Workspaces
Project Paths and Workspaces [message #122555] Thu, 04 September 2003 05:04 Go to next message
I apologize in advance, as this seems to me like it must be a fairly-frequent
question. However, the only ways I could thing to phrase it for either the
Eclipse help-system or various search engines were all too vague to produce
helpful results.
I start up Eclipse with the -data option on the command-line to define my
workspace area. I (plan to) work in Java, Perl, C, C++ and C# using Eclipse.
When I create a new project, Eclipse wants very much to create the project
directory immediately under my workspace area. I want another level of division
there, for the various languages. But when I try to specify an explicit
directory by navigating down through "java" and then to the desired target
area, the wizard tells me that "Project contents cannot be inside workspace
directory". I have a similar problem if I try to import an existing code tree
under the workspace area.
Is the only solution to use a whole different area for Eclipse and import my
existing code from adjacent directory structures? I'm really pleased with
Eclipse overall, and would like to adapt most of my current projects into
relevant projects within the applicable views (I've installed the Improve
group's C# stuff, the CDT package and the EPIC Perl plugins). I may just be
overlooking some obvious detail, but this is eluding me.
Randy
Re: Project Paths and Workspaces [message #123002 is a reply to message #122555] Fri, 05 September 2003 09:52 Go to previous messageGo to next message
Originally posted by: lynne_kues.oti.com
Search for "Linked Resources" in the help documentation.
"Randy J. Ray" <rjray@blackperl.com> wrote in message
news:bj6v8o$ho3$1@eclipse.org...
fairly-frequent
produce
> helpful results.
Eclipse.
division
workspace
tree
my
be
> Randy
Re: Project Paths and Workspaces [message #123678 is a reply to message #123002] Sun, 07 September 2003 04:52 Go to previous messageGo to next message
Unfortunately, this really doesn't address the problem I'm having. I want to be
able to categorize my projects using a directory structure, so that all Perl
projects are under "perl" and Java under "java", and so forth. The "/"
character is not allowable in a project name, and trying to provide Eclipse an
explicit directory path that includes the additional level of division also
leads to an error in the wizard.
Randy
Randy J. Ray Campbell, CA http://www.rjray.org rjray@blackperl.com
Silicon Valley Scale Modelers: http://www.svsm.org
Re: Project Paths and Workspaces [message #124317 is a reply to message #123678] Mon, 08 September 2003 11:24 Go to previous messageGo to next message
I think you can do what you want with linked resources by creating a Java
Project and using source and output folders for the project. These Eclipse
folders can be linked to external folders. Here is what you would do to
link the source folder for a project, "JavaProject1", to an external folder:
Open the Properties file for the Project.
Under the Java Build Path --> Source tab, click Add New Folder. This opens
the Source Folder Dialog.
Click Create New Folder. Enter "src" in the text box and then click
"Advanced"
Check off the "Link to folder in file system" check box. And click
"Browse".
From this dialog you can create the external structure you want (e.g.,
create a "JavaProjects" folder, then create a "JavaProject1" subfolder, then
create a source folder for the project) or you can point to an existing
folder somewhere.
news:bjerm3$t1g$1@eclipse.org...
to be
Perl
Eclipse an
also
> Randy
rjray@blackperl.com
Re: Project Paths and Workspaces [message #126777 is a reply to message #123678] Wed, 10 September 2003 14:39 Go to previous message
Without any guarantee, you may try this plugin
(Project Set support)
http://www.ejbprovider.de/homepage/index.html
It is in my list of plugins to test, so I never tried it ;-)
--Steve
On Sun, 07 Sep 2003 01:52:15 -0700, Randy J. Ray <rjray@blackperl.com>
> to be able to categorize my projects using a directory structure, so that
> all Perl projects are under "perl" and Java under "java", and so forth.
> The "/" character is not allowable in a project name, and trying to
> provide Eclipse an explicit directory path that includes the additional
> level of division also leads to an error in the wizard.
> Randy
Previous Topic:Problems when running some applets in External Preview View
Next Topic:Unresolved compilation problem; using assert
Current Time: Mon Jul 28 18:59:58 EDT 2025
Powered by FUDForum. Page generated in 0.02730 seconds
