Problem with Equinox p2 and About info? [message #122551] |
Sun, 14 December 2008 16:48 |
Originally posted by: jmordax.terra.es
Hi. I opened a week ago bug 257493 against R3.5 because About info of my
feature didn't appear. And exactly the same feature worked fine with R3.4.1.
After some more tests, I discovered the problem was related with the new
two files: artifacts.xml and content.xml. As I understood they are not
mandatory yet, and as I was trying to avoid bug 257493 (category names
don't appear) I removed those two files and left just site.xml as
Ganymede Update site does for example.
But... without those tow files the About info of my feature doesn't
work. If I add the two files, then the About info works. Does it make
sense? As with 3.4.1 it worked... does this mean a bug in Equinox p2?
I have created two Update Sites as test cases so you can check what I mean:
http://eclipse-games.sourceforge.net/update without the files (so About
info won't appear).
http://eclipse-games.sourceforge.net/updatetestcase with the files (so
About info will appear).
Thanks in advance,
Chemi.
FUDForum. Page generated in 0.05784 seconds
