Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [EMF Compare]icons for remote changes not implemented?
[EMF Compare]icons for remote changes not implemented? [message #122334] Tue, 13 May 2008 10:28 Go to next message
It seems the remote provider does not pick up the model icons contributed by
generated Edit plugins, and the image is shown as a generic diamond of EMF
models. It works fine for local changes though. The class I refer to is
RemoteAddModelElementItemProvider, here is the getImage() impl:
* This returns RemoteAddModelElement.gif.
* <!-- begin-user-doc --> <!-- end-user-doc -->
* @generated
public Object getImage(Object object) {
return overlayImage(object,
getResourceLocator().getImage("full/obj16/RemoteAddModelElement "));
//$NON-NLS-1$
Furthermore the icon referenced here is a diamond in the source code.
In comparison, the addmodelelementitemprovider implementation was overriden:
* This returns AddModelElement.gif. <!-- begin-user-doc --> <!--
end-user-doc -->
* @generated NOT
final AddModelElement diff = (AddModelElement)object;
Object labelImage =
AdapterUtils.getItemProviderImage(diff.getRightElement());
if (labelImage != null) {
List<Object> images = new ArrayList<Object>(2);
images.add(labelImage);
images.add(getResourceLocator().getImage("full/obj16/AddModelElement "));
//$NON-NLS-1$
labelImage = new ComposedImage(images);
} else {
labelImage = getResourceLocator().getImage("full/obj16/AddModelElement");
//$NON-NLS-1$
return labelImage;
David
Re: [EMF Compare]icons for remote changes not implemented? [message #122462 is a reply to message #122334] Wed, 14 May 2008 04:00 Go to previous messageGo to next message
--------------050001030807050700010404
David,
Remote changes (3-way comparison) have been implemented after all
others. I guess we forgot the icons when implementing it :) (or worse,
we left "@generated" on the *Impl classes which effectively overrode the
modifications).
Though this doesn't seem to be of utmost importance, could you raise a
bugzilla on this issue?
Laurent Goubet
Obeo
David Michonneau a
Re: [EMF Compare]icons for remote changes not implemented? [message #122472 is a reply to message #122462] Wed, 14 May 2008 04:19 Go to previous message
https://bugs.eclipse.org/bugs/show_bug.cgi?id=232019 has been filed.
David
"laurent Goubet" <laurent.goubet@obeo.fr> wrote in message
news:g0e66b$912$1@build.eclipse.org...
> David,
> modifications).
> Thanks
> Laurent Goubet
> Obeo
> David Michonneau a
Re: [EMF Compare]icons for remote changes not implemented? [message #618042 is a reply to message #122334] Wed, 14 May 2008 04:00 Go to previous message
David,
modifications).
Laurent Goubet
Obeo
David Michonneau a
Re: [EMF Compare]icons for remote changes not implemented? [message #618043 is a reply to message #122462] Wed, 14 May 2008 04:19 Go to previous message
David
> David,
> modifications).
> Thanks
> Laurent Goubet
> Obeo
> David Michonneau a
Previous Topic:[CDO 0.8.0M7] server problem
Next Topic:[CDO 0.8.0 M7] unknow error / problem
Current Time: Mon Jul 14 06:25:17 EDT 2025
Powered by FUDForum. Page generated in 2.92819 seconds
