Home » Newcomers » Newcomers » Error creating WAR
Error creating WAR [message #122229] Wed, 07 December 2005 10:16
Originally posted by: v_anandi.hotmail.com
I tried to create a WAR using the wizard, and came up with the following
error. Did i do something wrong or is it a bug ?
java.lang.reflect.InvocationTargetException
org.eclipse.wst.common.frameworks.internal.ui.RunnableOperat ionWrapper.run(RunnableOperationWrapper.java:34)
org.eclipse.jface.operation.ModalContext.runInCurrentThread( ModalContext.java:346)
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:291)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 830)
org.eclipse.wst.common.frameworks.internal.datamodel.ui.Data ModelWizard.performFinish(DataModelWizard.java:245)
org.eclipse.jface.wizard.WizardDialog.finishPressed(WizardDi alog.java:676)
org.eclipse.jface.wizard.WizardDialog.buttonPressed(WizardDi alog.java:349)
at org.eclipse.jface.dialogs.Dialog$2.widgetSelected(Dialog.jav a:556)
org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:90)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3080)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2713)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:809 )
at org.eclipse.jface.window.Window.open(Window.java:787)
org.eclipse.ui.actions.ExportResourcesAction.run(ExportResou rcesAction.java:180)
org.eclipse.ui.actions.BaseSelectionListenerAction.runWithEv ent(BaseSelectionListenerAction.java:167)
org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:538)
org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:488)
org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:400)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1699)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:367)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:143)
at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:103)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:226)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:376)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:163)
at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334 )
at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
at org.eclipse.core.launcher.Main.run(Main.java:973)
at org.eclipse.core.launcher.Main.main(Main.java:948)
Caused by: org.eclipse.core.commands.ExecutionException: Error
exportingWar File
org.eclipse.jst.j2ee.internal.archive.operations.J2EEArtifac tExportOperation.execute(J2EEArtifactExportOperation.java:73 )
org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl.doExecute(ExtendableOperationImpl.java:129)
org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl$1.run(ExtendableOperationImpl.java:109)
at org.eclipse.core.internal.resources.Workspace.run(Workspace. java:1719)
org.eclipse.wst.common.frameworks.internal.datamodel.Extenda bleOperationImpl.execute(ExtendableOperationImpl.java:117)
org.eclipse.wst.common.frameworks.internal.ui.RunnableOperat ionWrapper.run(RunnableOperationWrapper.java:32)
... 39 more
Caused by:
org.eclipse.jst.j2ee.commonarchivecore.internal.exception.Sa veFailureException:
Error opening archive for export..
org.eclipse.jst.j2ee.internal.web.archive.operations.WebComp onentExportOperation.export(WebComponentExportOperation.java :44)
org.eclipse.jst.j2ee.internal.archive.operations.J2EEArtifac tExportOperation.execute(J2EEArtifactExportOperation.java:71 )
... 44 more
Previous Topic:Can't install updates
Next Topic:Eclipse plugins & network problem
Current Time: Thu Jul 17 19:34:12 EDT 2025
Powered by FUDForum. Page generated in 0.06328 seconds
