Home » Eclipse Projects » Equinox » Install Eclipse 3.5M3 using P2 and shared bundle pooling ?
Install Eclipse 3.5M3 using P2 and shared bundle pooling ? [message #122196] Thu, 04 December 2008 07:57 Go to next message
Hi guys,
I'm currently regularly using P2 Installer to create 3.4 based Eclipse SDK
installations in shared bundle pooling mode as described here:
http://wiki.eclipse.org/Equinox_p2_Installer
But I can't manage to achieve the same result with Eclipse 3.5M3. I've used
P2 Installer from here:
http://download.eclipse.org/equinox/drops/S-3.5M3-2008103019 17/index.php
and the following properties:
eclipse.p2.metadata=http://download.eclipse.org/eclipse/updates/3.5milestones/
eclipse.p2.artifacts=http://download.eclipse.org/eclipse/updates/3.5milestones/
eclipse.p2.flavor=tooling
eclipse.p2.profileName=Eclipse SDK
eclipse.p2.launcherName=eclipse
eclipse.p2.rootId=org.eclipse.sdk.ide
eclipse.p2.autoStart=true
When P2 Installer starts downloading bundles, nothing happens.
Am I doing something wrong ?
Kind regards,
C
Re: Install Eclipse 3.5M3 using P2 and shared bundle pooling ? [message #123579 is a reply to message #122196] Thu, 01 January 2009 11:05 Go to previous message
Hi guys,
Actually, the 3.5 milestones update site I was using seems to be incomplete.
I've sucessfully installed 3.5 integration build in shared bundle pooling
mode using P2 Agent 3.4.1 and the following 3.5 integration builds update
site:
http://download.eclipse.org/eclipse/updates/3.5-I-builds
Kind regards,
C
Previous Topic:[ds] Declarative Services and Fragments
Next Topic:P2 No Repository at..
Current Time: Fri Jul 18 01:58:36 EDT 2025
Powered by FUDForum. Page generated in 0.10398 seconds
