Home » Eclipse Projects » GEF » BundleException in 3.0M7
BundleException in 3.0M7 [message #122089] Fri, 12 March 2004 11:49 Go to next message
what should I do when I get the exception below?
I ported my plugin which uses GEF to M7 and when I try to open my editor
which extends GraphicalEditorWithPalette then I get this exception
message.
With regards,
Udo
org.osgi.framework.BundleException: The BundleActivator
org.eclipse.gef.GEFPlugin is invalid
org.eclipse.osgi.framework.internal.core.Bundle.loadBundleAc tivator(Bundle.java:176)
org.eclipse.osgi.framework.internal.core.BundleContext.start (BundleContext.java:987)
org.eclipse.osgi.framework.internal.core.BundleHost.startWor ker(BundleHost.java:403)
org.eclipse.osgi.framework.internal.core.Bundle.start(Bundle .java:312)
org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLoca lClass(EclipseClassLoader.java:58)
org.eclipse.osgi.framework.internal.core.BundleLoader.findLo calClass(BundleLoader.java:326)
org.eclipse.osgi.framework.internal.core.BundleLoader.requir eClass(BundleLoader.java:291)
org.eclipse.osgi.framework.internal.core.BundleLoader.findRe quiredClass(BundleLoader.java:915)
org.eclipse.osgi.framework.internal.core.BundleLoader.findCl ass(BundleLoader.java:352)
org.eclipse.osgi.framework.adaptor.BundleClassLoader.loadCla ss(BundleClassLoader.java:115)
at java.lang.ClassLoader.loadClass(ClassLoader.java:255)
at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:315 )
at java.lang.Class.getDeclaredConstructors0(Native Method)
at java.lang.Class.privateGetDeclaredConstructors(Class.java:15 90)
at java.lang.Class.getConstructor0(Class.java:1762)
at java.lang.Class.newInstance0(Class.java:276)
at java.lang.Class.newInstance(Class.java:259)
org.eclipse.osgi.framework.internal.core.Bundle.loadBundleAc tivator(Bundle.java:170)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:133)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:125)
org.eclipse.core.internal.registry.ConfigurationElement.crea teExecutableExtension(ConfigurationElement.java:114)
org.eclipse.ui.internal.WorkbenchPlugin$1.run(WorkbenchPlugi n.java:171)
org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator .java:84)
org.eclipse.ui.internal.WorkbenchPlugin.createExtension(Work benchPlugin.java:168)
at org.eclipse.ui.internal.EditorManager$3.run(EditorManager.ja va:642)
org.eclipse.core.internal.runtime.InternalPlatform.run(Inter nalPlatform.java:819)
at org.eclipse.core.runtime.Platform.run(Platform.java:493)
org.eclipse.ui.internal.EditorManager.createPart(EditorManag er.java:640)
org.eclipse.ui.internal.EditorManager.openInternalEditor(Edi torManager.java:627)
org.eclipse.ui.internal.EditorManager.openEditorFromDescript or(EditorManager.java:437)
org.eclipse.ui.internal.EditorManager.openEditor(EditorManag er.java:425)
org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(Workben chPage.java:2099)
org.eclipse.ui.internal.WorkbenchPage.access$6(WorkbenchPage .java:2042)
at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.ja va:2029)
org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPa ge.java:2024)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:265)
org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileActio n.java:96)
org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystem EditorAction.java:94)
org.eclipse.ui.views.navigator.OpenActionGroup.runDefaultAct ion(OpenActionGroup.java:111)
org.eclipse.ui.views.navigator.MainActionGroup.runDefaultAct ion(MainActionGroup.java:300)
org.eclipse.ui.views.navigator.ResourceNavigator.handleOpen( ResourceNavigator.java:624)
org.eclipse.ui.views.navigator.ResourceNavigator$6.open(Reso urceNavigator.java:388)
org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredV iewer.java:406)
org.eclipse.jface.viewers.StructuredViewer.fireOpen(Structur edViewer.java:404)
org.eclipse.jface.viewers.StructuredViewer.handleOpen(Struct uredViewer.java:614)
org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(Stru cturedViewer.java:703)
org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrate gy.java:209)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.ja va:204)
org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrate gy.java:233)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :82)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:833)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:2348)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :2029)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:1550)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1526)
org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:265)
at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.j ava:139)
org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplicatio n.java:47)
org.eclipse.core.internal.runtime.PlatformActivator$1.run(Pl atformActivator.java:257)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:104)
at org.eclipse.core.launcher.Main.basicRun(Main.java:279)
at org.eclipse.core.launcher.Main.run(Main.java:742)
at org.eclipse.core.launcher.Main.main(Main.java:581)
java.lang.InstantiationException: org.eclipse.gef.GEFPlugin
at java.lang.Class.newInstance0(Class.java:291)
Re: BundleException in 3.0M7 [message #122104 is a reply to message #122089] Fri, 12 March 2004 13:00 Go to previous messageGo to next message
with the nightly build of GEF this exception is not there anymore. But
now that exception occurs in my editor which is a subclass of
GraphicalEditorWithPalette. In Eclipse 2.1.2 it worked without any
problem.
What changed?
With regards,
Udo
Udo Walker wrote:
> message.
> With regards,
> Udo
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
Re: BundleException in 3.0M7 [message #122132 is a reply to message #122104] Fri, 12 March 2004 15:05 Go to previous messageGo to next message
Are you saying that you're now getting the BundleActivator is invalid
exception for GraphicalEditorWithPalette instead of GEFPlugin? I'd have
thought switching to an M7-supported GEF build would fix any such problem.
You're migrating from 2.1.2 to 3.0M7, is that right? Did you make all
required plug-in changes for OSGi support? You might want to try the
eclipse.platform forums to see if they can help you with this problem.
"Udo Walker" <Udo.Walker@abas.de> wrote in message
news:4051FAA0.CC93958B@abas.de...
> problem.
> What changed?
> With regards,
> Udo
> Udo Walker wrote:
> > Hi,
> > message.
> > With regards,
> > Udo
> > at
ava:176)
> > at
ava:987)
> > at
ava:403)
> > at
> > at
assLoader.java:58)
> > at
oader.java:326)
> > at
der.java:291)
> > at
leLoader.java:915)
> > at
..java:352)
> > at
ader.java:115)
> > at
> > at
ava:170)
> > at
ava:987)
> > at
ava:403)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
:168)
> > at
> > at
:819)
> > at
> > at
627)
> > at
..java:437)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
a:94)
> > at
oup.java:111)
> > at
oup.java:300)
> > at
r.java:624)
> > at
va:388)
> > at
> > at
:819)
> > at
4)
> > at
614)
> > at
a:703)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
java:257)
> > at
> > at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
> > at
> > at
..java:25)
> > at
ava:170)
> > at
ava:987)
> > at
ava:403)
> > at
> > at
assLoader.java:58)
> > at
oader.java:326)
> > at
der.java:291)
> > at
leLoader.java:915)
> > at
..java:352)
> > at
ader.java:115)
> > at
> > at
ava:170)
> > at
ava:987)
> > at
ava:403)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
:168)
> > at
> > at
:819)
> > at
> > at
627)
> > at
..java:437)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
a:94)
> > at
oup.java:111)
> > at
oup.java:300)
> > at
r.java:624)
> > at
va:388)
> > at
> > at
:819)
> > at
4)
> > at
614)
> > at
a:703)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
java:257)
> > at
> > at
> > at
..java:25)
Re: BundleException in 3.0M7 [message #122200 is a reply to message #122104] Sun, 14 March 2004 07:18 Go to previous messageGo to next message
Originally posted by: shimbun.gmx.de
Hi!
I had to migrate from 3.0M5 to 3.0M7
At first it did not work, I had the same exceptions you had. But today, I
again tried to use 3.0M7 but I used GEF-SDK from 20040309, and it worked
immediately without any problem! So, maybe you would try using the same GEF
version I use.
Nmae ga nai :)
aka
Hiro
Re: BundleException in 3.0M7 [message #122374 is a reply to message #122104] Mon, 15 March 2004 09:57 Go to previous message
Your plug-in should probably import the
org.eclpise.core.runtime.compatibility plugin.
> problem.
> What changed?
> With regards,
> Udo
> Udo Walker wrote:
> > Hi,
> > message.
> > With regards,
> > Udo
> > at
ava:176)
> > at
ava:987)
> > at
ava:403)
> > at
> > at
assLoader.java:58)
> > at
oader.java:326)
> > at
der.java:291)
> > at
leLoader.java:915)
> > at
..java:352)
> > at
ader.java:115)
> > at
> > at
ava:170)
> > at
ava:987)
> > at
ava:403)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
:168)
> > at
> > at
:819)
> > at
> > at
627)
> > at
ager.java:437)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
a:94)
> > at
oup.java:111)
> > at
oup.java:300)
> > at
r.java:624)
> > at
va:388)
> > at
> > at
:819)
> > at
4)
> > at
614)
> > at
a:703)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
java:257)
> > at
> > at
> > at
..java:25)
> > at
ava:170)
> > at
ava:987)
> > at
ava:403)
> > at
> > at
assLoader.java:58)
> > at
oader.java:326)
> > at
der.java:291)
> > at
leLoader.java:915)
> > at
..java:352)
> > at
ader.java:115)
> > at
> > at
ava:170)
> > at
ava:987)
> > at
ava:403)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
:168)
> > at
> > at
:819)
> > at
> > at
627)
> > at
..java:437)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
a:94)
> > at
oup.java:111)
> > at
oup.java:300)
> > at
r.java:624)
> > at
va:388)
> > at
> > at
:819)
> > at
4)
> > at
614)
> > at
a:703)
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
> > at
java:257)
> > at
> > at
> > at
..java:25)
Previous Topic:Incompatibility between XYLayout and ScrollPane ?
Next Topic:Selecting multiple editparts at 1 time with 1 click
Current Time: Sun Aug 31 20:51:44 EDT 2025
Powered by FUDForum. Page generated in 0.04908 seconds
