Bug in serverdefinitions of generic server [message #121990] |
Mon, 18 July 2005 16:40  |
I consider the following a bug. I will give you an explanation of of why I
think so. Maybe the fix I suggest will be considered for 0.7RC2. I would be
happy to get feedback from a committer, otherwise I would have to file this
as a bug too. Thanks in advance.
First, let me give you the paths that are relevant:
The build file jonas.xml is located at
${eclipse_home}/eclipse/plugins/org.eclipse.jst.server.gener ic.serverdefinitions_0.7.0/buildfiles/jonas.xml
The web project is located at
${workspace}/ProjectName
The deployables are located at
${workspace}/ProjectName/.deployables/ModuleName
In jonas.xml, the following piece of code is currently used to deploy a war:
<jar destfile="${module.name}.war">
<zipfileset dir="${module.dir}">
<include name="**/*.*"/>
<exclude name="**/*.war"/>
</zipfileset>
</jar>
<move file="${module.name}.war" todir="${server.publish.dir}"/>
The properties module.name and module.dir are set in the class
org.eclipse.jst.server.generic.core.internal.AntPublisher.ja va to
module.name = ModuleName
module.dir = ${workspace}/ProjectName/.deployables/ModuleName
Hence, the jar command tries to create the war file at
the home of the file jonas.xml, before it is to be moved to the servers
publish dir.
This is the bug.
In general, users will have write access to ${workspace}, but not to
${eclipse_home}. Hence, the ant script aborts because the war file cannot
be created. But even if a user had write access to ${eclipse_home}, a
temporary file should never be stored there.
As a fix, the war should be created somewhere in the projects file system,
before it is moved to the server. I have used the following change in
jonas.xml, which works:
<jar destfile="${module.dir}/${module.name}.war">
</zipfileset>
</jar>
<move file="${module.dir}/${module.name}.war"
One could as well use another path in the projects file system for the
temporary war file.
Andreas Schenk
Re: Bug in serverdefinitions of generic server [message #122043 is a reply to message #121990] |
Mon, 18 July 2005 17:58  |
Originally posted by: gercan.removeThis.acm.org
Hi Andreas,
That is a good point eclipse_home is not the best place to create
temporary files. Please go ahead and open that bug report, you can
assign it directly to me.
Gorkem Ercan
Andreas Schenk wrote:
> </zipfileset>
> </jar>
> publish dir.
> This is the bug.
> </zipfileset>
> </jar>
> temporary war file.
> Andreas Schenk
FUDForum. Page generated in 0.03353 seconds
